error log, could not connect
MeeLee
Post by MeeLee »
What's happening here?
I know my internet connection is a bit iffy, but it works (now and then).
The WUs are lining up, and aren't being sent!
23:49:48:WARNING:WU03:FS00:Exception: Failed to send results to work server: Transfer failed
00:07:08:WARNING:WU00:FS02:Exception: Failed to send results to work server: Transfer failed
00:50:44:ERROR:WU03:FS00:Exception: Transfer failed
00:57:02:ERROR:WU07:FS01:Exception: Could not get IP address for assign1.foldingathome.org: Temporary failure in name resolution
00:57:12:ERROR:WU07:FS01:Exception: Could not get IP address for assign2.foldingathome.org: Temporary failure in name resolution
00:57:12:WARNING:WU07:FS01:Exception: Failed to find any IP addresses for assignment servers
00:57:12:ERROR:WU07:FS01:Exception: Could not get an assignment
00:57:22:ERROR:WU07:FS01:Exception: Could not get IP address for assign1.foldingathome.org: Temporary failure in name resolution
00:57:32:ERROR:WU07:FS01:Exception: Could not get IP address for assign2.foldingathome.org: Temporary failure in name resolution
00:57:32:WARNING:WU07:FS01:Exception: Failed to find any IP addresses for assignment servers
00:57:32:ERROR:WU07:FS01:Exception: Could not get an assignment
******************************* Date: 2019-04-26 *******************************
01:07:41:ERROR:WU00:FS02:Exception: Transfer failed
01:07:41:WARNING:WU06:FS00:Detected clock skew (9 mins 29 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
01:07:41:WARNING:WU02:FS02:Detected clock skew (9 mins 29 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
01:08:52:WARNING:WU06:FS00:Detected clock skew (1 mins 11 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
01:08:52:WARNING:WU02:FS02:Detected clock skew (1 mins 11 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
01:10:31:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
Re: error log, could not connect
MeeLee wrote:What's happening here?
Your "IFFY" internet connection is failing you. This is not a FAH problem. DNS is not working for you ... which might be the fault of your router or you OS or your ISP.
I would first try opening http://assign1.foldingathome.org in your browser. (It works for me.) Then I'd reboot both your machine and your router. (It might be instructive to do them one-at-a-time and see which one fixes the problem.)
MeeLee
Post by MeeLee »
Funny thing is that my browser worked just fine.
I wrote the thread on the same computer as the error.
I know my internet is a bit on off, due to the wifi signal being a bit low, but it should get the connection through.
Anyway, it seems a bug in Ubuntu, that after a few days, I have to reset the PC, to have it connect correctly again.
You might consider adding other servers to whatever DNS sites you are currently using. That might work around the problem by speeding up name resolution. (I'm not sure how long the timeout is before the "temporary failure" error is reported. You might also add some FAH sites to your local "hosts" file -- although you will have to remember to edit them in the event that FAH decides to relocate any of those hosts.
