Ablomeke
Posts: 4 Joined: Mon Nov 13, 2017 5:32 pm
Post
by Ablomeke » Mon Apr 08, 2019 6:25 pm
I started by getting the following errors in my GPU log:
17:55:50:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
17:56:50:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
17:58:28:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
18:01:05:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
Did a little bit of digging, tried altering -opencl-index to zero, 1, and 2, then back to -1, and it gives me other errors:
18:06:10:ERROR:WU01:FS01:Failed to start core: Option 'opencl-index' has no default and is not set.
18:07:10:ERROR:WU01:FS01:Failed to start core: Option 'opencl-index' has no default and is not set.
18:08:47:ERROR:WU01:FS01:Failed to start core: Option 'opencl-index' has no default and is not set.
I will note that I have recently replaced my GPU moving from an ATI -> NVidia, but looking at my history and my memory of the timeline on things, I believe that it did fold successfully on the new GPU at least for a few days.
Posts: 8347 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Mon Apr 08, 2019 8:39 pm
When you removed the AMD card and replaced it with the one from nVidia did you reinstall the folding client software? That is the recommended method for making a major hardware change like this. You would finish any current WU's, uninstall the client along with the data files, and then reinstall. Saving a copy of the config.xml file would provide you a source to copy and paste information to setup the client with your username, team and passkey.
You may also need to run driver cleaner software to make certain all components of the AMD drivers have been removed.
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Tue Apr 09, 2019 12:55 am
If you had pasted the top couple of pages from FAH's log, we could see if FAHClient detects ANY GPUs with the proper drivers. When you download the drivers from NVidia, you'll get a complete set. If you obtained the drivers from another source, things like CUDA might not be included. We would also know if you're running LInux or Windows. (See below)
Ablomeke
Post
by Ablomeke » Tue Apr 09, 2019 12:44 pm
Reinstalled to no avail. Here's the complete log:
*********************** Log Started 2019-04-09T12:41:56Z ***********************
12:41:56:************************* Folding@home Client *************************
12:41:56: Website: https://foldingathome.org/
12:41:56: Copyright: (c) 2009-2018 foldingathome.org
12:41:56: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:41:56: Args: --open-web-control
12:41:56: Config: <none>
12:41:56:******************************** Build ********************************
12:41:56: Version: 7.5.1
12:41:56: Date: May 11 2018
12:41:56: Time: 13:06:32
12:41:56: Repository: Git
12:41:56: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:41:56: Branch: master
12:41:56: Compiler: Visual C++ 2008
12:41:56: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:41:56: Platform: win32 10
12:41:56: Bits: 32
12:41:56: Mode: Release
12:41:56:******************************* System ********************************
12:41:56: CPU: AMD Ryzen 5 2600 Six-Core Processor
12:41:56: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
12:41:56: CPUs: 12
12:41:56: Memory: 7.93GiB
12:41:56: Free Memory: 2.76GiB
12:41:56: Threads: WINDOWS_THREADS
12:41:56: OS Version: 6.2
12:41:56: Has Battery: false
12:41:56: On Battery: false
12:41:56: UTC Offset: -4
12:41:56: PID: 3820
12:41:56: CWD: C:\Users\Adam Blomeke\AppData\Roaming\FAHClient
12:41:56: OS: Windows 10 Enterprise
12:41:56: OS Arch: AMD64
12:41:56: GPUs: 0
12:41:56:CUDA Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:6.1 Driver:10.0
12:41:56: OpenCL: Not detected: clGetPlatformIDs() returned -1001
12:41:56:Win32 Service: false
12:41:56:***********************************************************************
12:41:56:<config>
12:41:56: <!-- Folding Slots -->
12:41:56:</config>
12:41:56:Connecting to assign1.foldingathome.org:8080
12:41:57:Updated GPUs.txt
12:41:57:Read GPUs.txt
12:41:57:Trying to access database...
12:41:57:Successfully acquired database lock
12:41:57:Enabled folding slot 00: PAUSED cpu:10 (not configured)
12:41:57:Enabled folding slot 01: PAUSED gpu:0:GP107 [GeForce GTX 1050 Ti] 2138 (not configured)
12:42:07:Set client configured
12:42:07:WU00:FS00:Connecting to 65.254.110.245:8080
12:42:07:WU01:FS01:Connecting to 65.254.110.245:8080
12:42:08:WU00:FS00:Connecting to 65.254.110.245:8080
12:42:08:WU00:FS00:Assigned to work server 128.252.203.9
12:42:08:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 128.252.203.9
12:42:08:WU00:FS00:Connecting to 128.252.203.9:8080
12:42:08:WU01:FS01:Connecting to 65.254.110.245:8080
12:42:08:WU00:FS00:Downloading 7.05MiB
12:42:08:WU01:FS01:Assigned to work server 155.247.166.220
12:42:08:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti] 2138 from 155.247.166.220
12:42:08:WU01:FS01:Connecting to 155.247.166.220:8080
12:42:09:WU00:FS00:Download complete
12:42:09:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13819 run:0 clone:624 gen:36 core:0xa7 unit:0x0000002d80fccb095c70612b392b9dca
12:42:09:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
12:42:09:WU00:FS00:Connecting to cores.foldingathome.org:80
12:42:09:WU00:FS00:FahCore a7: Downloading 6.82MiB
12:42:10:WU00:FS00:FahCore a7: Download complete
12:42:10:WU00:FS00:Valid core signature
12:42:10:WU00:FS00:Unpacked 20.16MiB to cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe
12:42:10:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/libfftw3f-3.dll
12:42:10:WU00:FS00:Starting
12:42:10:WARNING:WU00:FS00:AS lowered CPUs from 11 to 10
12:42:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Adam Blomeke\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 3820 -checkpoint 15 -np 10
12:42:10:WU00:FS00:Started FahCore on PID 15336
12:42:10:WU00:FS00:Core PID:12316
12:42:10:WU00:FS00:FahCore 0xa7 started
12:42:11:WU00:FS00:0xa7:*********************** Log Started 2019-04-09T12:42:11Z ***********************
12:42:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:42:11:WU00:FS00:0xa7: Type: 0xa7
12:42:11:WU00:FS00:0xa7: Core: Gromacs
12:42:11:WU00:FS00:0xa7: Website: https://foldingathome.org/
12:42:11:WU00:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
12:42:11:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:42:11:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 15336 -checkpoint 15 -np
12:42:11:WU00:FS00:0xa7: 10
12:42:11:WU00:FS00:0xa7: Config: <none>
12:42:11:WU00:FS00:0xa7:************************************ Build *************************************
12:42:11:WU00:FS00:0xa7: Version: 0.0.17
12:42:11:WU00:FS00:0xa7: Date: Apr 27 2018
12:42:11:WU00:FS00:0xa7: Time: 16:19:36
12:42:11:WU00:FS00:0xa7: Repository: Git
12:42:11:WU00:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
12:42:11:WU00:FS00:0xa7: Branch: master
12:42:11:WU00:FS00:0xa7: Compiler: Visual C++ 2008
12:42:11:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:42:11:WU00:FS00:0xa7: Platform: win32 10
12:42:11:WU00:FS00:0xa7: Bits: 64
12:42:11:WU00:FS00:0xa7: Mode: Release
12:42:11:WU00:FS00:0xa7: SIMD: avx_256
12:42:11:WU00:FS00:0xa7:************************************ System ************************************
12:42:11:WU00:FS00:0xa7: CPU: Unknown
12:42:11:WU00:FS00:0xa7: CPU ID:
12:42:11:WU00:FS00:0xa7: CPUs: 12
12:42:11:WU00:FS00:0xa7: Memory: 7.93GiB
12:42:11:WU00:FS00:0xa7:Free Memory: 2.64GiB
12:42:11:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
12:42:11:WU00:FS00:0xa7: OS Version: 6.2
12:42:11:WU00:FS00:0xa7:Has Battery: false
12:42:11:WU00:FS00:0xa7: On Battery: false
12:42:11:WU00:FS00:0xa7: UTC Offset: -4
12:42:11:WU00:FS00:0xa7: PID: 12316
12:42:11:WU00:FS00:0xa7: CWD: C:\Users\Adam Blomeke\AppData\Roaming\FAHClient\work
12:42:11:WU00:FS00:0xa7: OS: Windows 10 Pro
12:42:11:WU00:FS00:0xa7: OS Arch: AMD64
12:42:11:WU00:FS00:0xa7:********************************************************************************
12:42:11:WU00:FS00:0xa7:Project: 13819 (Run 0, Clone 624, Gen 36)
12:42:11:WU00:FS00:0xa7:Unit: 0x0000002d80fccb095c70612b392b9dca
12:42:11:WU00:FS00:0xa7:Reading tar file core.xml
12:42:11:WU00:FS00:0xa7:Reading tar file frame36.tpr
12:42:11:WU00:FS00:0xa7:Digital signatures verified
12:42:11:WU00:FS00:0xa7:Calling: mdrun -s frame36.tpr -o frame36.trr -x frame36.xtc -cpt 15 -nt 10
12:42:11:WU00:FS00:0xa7:Steps: first=4500000 total=125000
12:42:12:WU01:FS01:Downloading 2.38MiB
12:42:14:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
12:42:18:WU01:FS01:Download 49.90%
12:42:24:WU01:FS01:Download 76.17%
12:42:27:WU01:FS01:Download complete
12:42:27:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14130 run:38 clone:5 gen:148 core:0x21 unit:0x000000ce0002894c5c28213182ff6cf6
12:42:27:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
12:42:27:WU01:FS01:Connecting to cores.foldingathome.org:80
12:42:27:WU01:FS01:FahCore 21: Downloading 3.47MiB
12:42:28:WU01:FS01:FahCore 21: Download complete
12:42:28:WU01:FS01:Valid core signature
12:42:28:WU01:FS01:Unpacked 11.80MiB to cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
12:42:28:WU01:FS01:Starting
12:42:28:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
12:42:58:Saving configuration to config.xml
12:42:58:<config>
12:42:58: <!-- Slot Control -->
12:42:58: <power v='FULL'/>
12:42:58:
12:42:58: <!-- Folding Slots -->
12:42:58: <slot id='0' type='CPU'/>
12:42:58: <slot id='1' type='GPU'/>
12:42:58:</config>
Drivers are direct from NVidia, not a third party.
Posts: 2521 Joined: Mon Feb 16, 2009 4:12 am
Post
by JimboPalmer » Tue Apr 09, 2019 2:47 pm
When you re-installed there was an option to delete the data. If you take it, the old config is deleted, so it can build a new config. Something in the old config is hiding your GPU.
12:41:56: GPUs: 0
Post
by bruce » Tue Apr 09, 2019 5:31 pm
The segment quoted by JimboPalmer looks like an Intel QPU is being detected, not one supported by FAH -- which would have to be nVidia or AMD/ATI. I suggest you remove the drivers for the embedded GPU and install the ones for a supported discrete GPU.
Posts: 2040 Joined: Sat Dec 01, 2012 3:43 pm
Hardware configuration: Folding@Home Client 7.6.13 (1 GPU slots) Windows 7 64bit Intel Core i5 2500k@4Ghz Nvidia gtx 1080ti driver 441
Post
by foldy » Tue Apr 09, 2019 5:34 pm
Yes it is a driver issue where OpenCL is missing. You need to download the driver from nvidia.com and install it again.
