FAHClient messes up aptitude
xoluvitum
Post by xoluvitum »
Downloaded and installed fahclient_7.5.1_amd64.deb
But now apt exists every command with a non zero exit value, because of some problem with non existing runlevel symlinks:
$ sudo dpkg -i fahclient_7.5.1_amd64.deb
Selecting previously unselected package fahclient.
(Reading database ... 368232 files and directories currently installed.)
Preparing to unpack fahclient_7.5.1_amd64.deb ...
usermod: no changes
Unpacking fahclient (7.5.1) ...
Setting up fahclient (7.5.1) ...
update-rc.d: error: no runlevel symlinks to modify, aborting!
dpkg: error processing package fahclient (--install):
 installed fahclient package post-installation script subprocess returned error exit status 1
Processing triggers for systemd (237-3ubuntu10.6) ...
Processing triggers for ureadahead (0.100.0-20) ...
ureadahead will be reprofiled on next reboot
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for desktop-file-utils (0.23+linuxmint3) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Errors were encountered while processing:
 fahclient
Re: FAHClient messes up aptitude
Which distribution do you use ? I guess Mint according to the package names, but we need to know the exact version.
