Project 14124 what wrong with you?
Calcii
Post by Calcii »
14:36:26:WU01:FS00:0x21:*********************** Log Started 2018-10-12T14:36:26Z ***********************
14:36:26:WU01:FS00:0x21:Project: 14124 (Run 23, Clone 0, Gen 0)
14:36:26:WU01:FS00:0x21:Unit: 0x000000000002894c5bc0ad213d5d8b4b
14:36:26:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
14:36:26:WU01:FS00:0x21:Machine: 0
14:36:26:WU01:FS00:0x21:Reading tar file core.xml
14:36:26:WU01:FS00:0x21:Reading tar file integrator.xml
14:36:26:WU01:FS00:0x21:Reading tar file state.xml
14:36:26:WU01:FS00:0x21:Reading tar file system.xml
14:36:26:WU01:FS00:0x21:Digital signatures verified
14:36:26:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
14:36:26:WU01:FS00:0x21:Version 0.0.20
14:36:31:WU00:FS00:Upload 53.43%
14:36:33:WU01:FS00:0x21:Completed 0 out of 25000000 steps (0%)
14:36:33:WU01:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:36:37:WU00:FS00:Upload 73.02%
14:36:42:WU00:FS00:Upload complete
14:36:42:WU00:FS00:Server responded WORK_ACK (400)
14:36:42:WU00:FS00:Final credit estimate, 56777.00 points
14:36:42:WU00:FS00:Cleaning up
14:39:07:WU01:FS00:0x21:Completed 250000 out of 25000000 steps (1%)
******************************* Date: 2018-10-12 *******************************
14:41:42:WU01:FS00:0x21:Completed 500000 out of 25000000 steps (2%)
14:44:16:WU01:FS00:0x21:Completed 750000 out of 25000000 steps (3%)
14:46:51:WU01:FS00:0x21:Completed 1000000 out of 25000000 steps (4%)
14:49:26:WU01:FS00:0x21:Completed 1250000 out of 25000000 steps (5%)
14:52:00:WU01:FS00:0x21:Completed 1500000 out of 25000000 steps (6%)
14:54:35:WU01:FS00:0x21:Completed 1750000 out of 25000000 steps (7%)
14:57:10:WU01:FS00:0x21:Completed 2000000 out of 25000000 steps (8%)
14:59:45:WU01:FS00:0x21:Completed 2250000 out of 25000000 steps (9%)
15:02:20:WU01:FS00:0x21:Completed 2500000 out of 25000000 steps (10%)
TPF 2:34 97788 PPD why so cheap? Wrong bonus? My videocard is 1080 ti
I recommend all to switch on to advanced, who catch that beast
Re: Project 14124 what wrong with you?
The information shown in that log doesn't support your claim. You'll need to find more information.
which indicates that an unknown WU was uploaded at 14:36Z for 56777 points.
I also see information for WU01 which is Project: 14124 (23,0,0) but was not yet finished.
NOTE: The logs for each WU are interleaved, and you have to read them carefully unless you use the filters provided in the FAHClient viewer.
When was WU00 downloaded and what is it's PRCG?
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
@Calcii, this project is still with a beta key. Now the base points will be corrected.
Support for Beta projects is done in the Beta test sub-forum. If you are not a member, we do not recommend you use the beta key in your setup.
Calcii
Post by Calcii »
bruce wrote: I also see information for WU01 which is Project: 14124 (23,0,0) but was not yet finished.
Of course, i drop that WU already, it waste of time to chew that WU
"NOTE: The logs for each WU are interleaved, and you have to read them carefully unless you use the filters provided in the FAHClient viewer."
There are all data for the analysis.
PPD i can take from "Folding@home Bonus Point Calculator" from here http://www.linuxforge.net/bonuscalc2.php?all=1
Joe_H wrote:Support for Beta projects is done in the Beta test sub-forum. If you are not a member, we do not recommend you use the beta key in your setup.
These jobs go also on advanced key :(
You did not post enough of the log to show that it was assigned with the Advanced setting. That would be shown in the section of the log where the request for a new WU, and the WU starting up is listed.
Calcii
Post by Calcii »
Oh, sorry, key was beta now switch to advanced, but not reload FAHClient then the configuration was not applied.
Now I watch, while these tasks are not present
artoar_11
Post by artoar_11 »
@Calcii, Last, on advanced key, you get p14124 or not?
UPD: На advanced тоже приходят
Yes, you usually have to at least pause a slot and restart it for a WU request settings change to take effect. Changes that affect the client as a whole will often require a restart to go into effect.
Calcii wrote:Of course, i drop that WU already, it waste of time to chew that WU
It's not a waste, science done is still useful ... it is actually a waste now you deleted it, someone else will have to compute it.
But I'm not surprised with your reaction since you're one of those people using a setting you shouldn't use ... There are rules : viewtopic.php?f=16&t=8 so you don't have the right to complain.
mmonnin
Post by mmonnin »
I thought my GPU crashed since HFM was showing like 64k PPD on a 980Ti. 21,1,0 on a completed task. 11,0,1 on one running atm.
Calcii
Post by Calcii »
Joe_H wrote:Yes, you usually have to at least pause a slot
yes I always pause, then delete the slot and create a new one
toTOW wrote:science done is still useful ...
I agree, but the competitive component is important too, it in blood
artoar_11 wrote:@Calcii, Last, on advanced key, you get p14124 or not?
On advanced not caught in the last 3 hours
kiore
Re: New (GRO A7) projects p14123,14132-14134
Post by kiore »
Have 2x 14124's on my GTX 1080ti and 1080, running fine but the ppd is showing significantly lower than other projects on these cards. Suspect something wrong with the bonus calculation, expect these readings will generate some project dumping from those using beta setting but not interested in beta testing.
bollix47
Post by bollix47 »
@kiore The problem with 14124 has been reported here and has recently been corrected ... both the assignment & the points.
Admin/Mod - Please move these two posts to the aforementioned thread, thanks.
Mod edit - Done. j
Calcii
Post by Calcii »
Wow, Basepoints increased from 3800 to 38000, thanks, now better :D
