Ryzen 5 2400G
MARSTG
Hardware configuration: B450 AORUS M w 3800X & WRAITH PRISM
16 GB DELTA RGB 3600 & WD SN 770 500GB
GTX 1070 GAMING X w LG OLED C1 55"
ECLIPSE P300A TG
Ryzen 5 2400G
Post by MARSTG »
Hi guys, what is the performance of the Ryzen 5 2400G on F@h, specifically the Vega embedded gpu?
JiiPee
Re: Ryzen 5 2400G
Post by JiiPee »
For me Vega 56 is giving around 600k points per day, so 600k/56*11=118k
So 118k per day in theory, but I am not sure how much folding hit GPU memory and thouse APU's don't have deticated memory so they will use much slower system memory. If folding hits memory hard, then performance isn't that great. Also I think APU's runs lower clocks, so that will affect also. Maybe around 100k max would be more accurate, but because I do not own one, I only can do some simple math based on CU's from both chips.
Re: Ryzen 5 2400G
Due to Quick Return Bonuses, Points are not linear with performance.
You may find that it is 11/56th as fast, but does not get 11/56th the PPD.
