I've just started folding on my old but trusty gaming PC. CPU (i5 750) is happily folding but I'm having GPU issues. I get the following error messages in the log:
17:54:11:WU00:FS01:Connecting to 65.254.110.245:8080
17:54:11:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:54:11:WU00:FS01:Connecting to 18.218.241.186:80
17:54:12:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:54:12:ERROR:WU00:FS01:Exception: Could not get an assignment
If it helps, it's an ATI Radeon 5850 with updated drivers. Could it be that this GPU is no longer supported or too underpowered to contribute?
The 5850 is still on the supported list, but work that can be assigned to it may have run out or be in short supply. It is at about the minimum level for folding GPU assignments that have been out in the last year or two.
The newest GPU core does not process well on the TeraScale architecture used on the 5850, it works better on GCN based cards that AMD started selling in the HD 7000 series. So the managers of the Work Servers may have limited assignments to Terascale based cards due to that. The older GPU folding core worked okay on these cards, but looking at the available assignments projects using it appear to have finished.
The critical issue is support for Double Precision. The HD7000 is a mixed bag.
Radeon HD 7350 through HD 7670 are TeraScale
Radeon HD 7730 through HD 7990 are GCN
It's a mixed bag in the later Radeon series as well, some low end cards still are based on TeraScale chips. If you stick to the mid-range or higher model AMD cards they will be based on GCN and have double precision enabled.
Hardware configuration: PC 1: Linux Mint 17.3 three gtx 1080 GPUs One on a powered header Motherboard = [MB-AM3-AS-SB-990FXR2] qty 1 Asus Sabertooth 990FX(+59.99) CPU = [CPU-AM3-FX-8320BR] qty 1 AMD FX 8320 Eight Core 3.5GHz(+41.99)
PC2: Linux Mint 18 Open air case Motherboard: ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD AMD FD6300WMHKBOX FX-6300 6-Core Processor Black Edition with Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan three gtx 1080, one gtx 1080 TI on a powered header
