My F@H Doesn't seem to be doing anything.
I just installed F@H, and it doesn't seem to be doing anything. I am on a mac. I click fold on the control panel but it doesn't do anything. Can somebody please help me?
Re: My F@H Doesn't seem to be doing anything.
Some of the default settings may keep your system from getting assignments, it depends on what your system is and the version of the client. If you could post the first 100 or so lines of your log file that would help. Directions on how to locate and post the log are available here - viewtopic.php?p=261084&f=24#p261084.
*********************** Log Started 2018-04-17T00:53:28Z ***********************
00:53:28:************************* Folding@home Client *************************
00:53:28: Website: http://folding.stanford.edu/
00:53:28: Copyright: (c) 2009-2014 Stanford University
00:53:28: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:53:28: Args: --child --lifeline 85 --respawn
00:53:28: Config: /Library/Application Support/FAHClient/config.xml
00:53:28:******************************** Build ********************************
00:53:28: Version: 7.4.4
00:53:28: Date: Mar 4 2014
00:53:28: Time: 20:27:54
00:53:28: SVN Rev: 4130
00:53:28: Branch: fah/trunk/client
00:53:28: Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
00:53:28: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
00:53:28: -fno-unsafe-math-optimizations -msse3 -arch x86_64
00:53:28: -mmacosx-version-min=10.6
00:53:28: Platform: darwin 10.8.0
00:53:28: Bits: 64
00:53:28: Mode: Release
00:53:28:******************************* System ********************************
00:53:28: CPU: Intel(R) Core(TM) i5-7267U CPU @ 3.10GHz
00:53:28: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
00:53:28: CPUs: 4
00:53:28: Memory: 8.00GiB
00:53:28:Free Memory: 6.82GiB
00:53:28: Threads: POSIX_THREADS
00:53:28: OS Version: 10.13
00:53:28:Has Battery: true
00:53:28: On Battery: false
00:53:28: UTC Offset: -4
00:53:28: PID: 178
00:53:28: CWD: /Library/Application Support/FAHClient
00:53:28: OS: Darwin 17.5.0 x86_64
00:53:28: OS Arch: AMD64
00:53:28: GPUs: 0
00:53:28: CUDA: Not detected
00:53:28:***********************************************************************
00:53:28:<config>
00:53:28: <!-- Network -->
00:53:28: <proxy v=':8080'/>
00:53:28:
00:53:28: <!-- Slot Control -->
00:53:28: <power v='medium'/>
00:53:28:
00:53:28: <!-- User Information -->
00:53:28: <team v='225605'/>
00:53:28: <user v='TheTitan'/>
00:53:28:
00:53:28: <!-- Folding Slots -->
00:53:28: <slot id='0' type='CPU'/>
00:53:28:</config>
00:53:28:Trying to access database...
00:53:28:Successfully acquired database lock
00:53:28:Enabled folding slot 00: READY cpu:3
00:53:28:ERROR:Failed to register for display power changes
00:53:28:WARNING:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: nodename nor servname provided, or not known
00:53:28:ERROR:WU00:FS00:Exception: Could not get an assignment
00:54:29:WU00:FS00:Connecting to 171.67.108.45:8080
00:54:30:WU00:FS00:Assigned to work server 155.247.166.219
00:54:30:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.166.219
00:54:30:WU00:FS00:Connecting to 155.247.166.219:8080
00:54:31:WU00:FS00:Downloading 178.62KiB
00:58:42:Caught signal SIGPIPE(13) on PID 178
00:59:02:Caught signal SIGPIPE(13) on PID 178
00:59:14:Caught signal SIGPIPE(13) on PID 178
01:00:29:352:127.0.0.1:New Web connection
01:08:43:Saving configuration to config.xml
01:08:43:<config>
01:08:43: <!-- Network -->
01:08:43: <proxy v=':8080'/>
01:08:43:
01:08:43: <!-- Slot Control -->
01:08:43: <power v='medium'/>
01:08:43:
01:08:43: <!-- User Information -->
01:08:43: <team v='225605'/>
01:08:43: <user v='TheTitan'/>
01:08:43:
01:08:43: <!-- Folding Slots -->
01:08:43: <slot id='0' type='CPU'>
01:08:43: <idle v='true'/>
01:08:43: </slot>
01:08:43:</config>
01:11:46:Saving configuration to config.xml
01:11:46:<config>
01:11:46: <!-- Network -->
01:11:46: <proxy v=':8080'/>
01:11:46:
01:11:46: <!-- Slot Control -->
01:11:46: <power v='medium'/>
01:11:46:
01:11:46: <!-- User Information -->
01:11:46: <team v='225605'/>
01:11:46: <user v='TheTitan'/>
01:11:46:
01:11:46: <!-- Folding Slots -->
01:11:46: <slot id='0' type='CPU'/>
01:11:46:</config>-
00:53:28:WARNING:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: nodename nor servnameCan you open this address in a web browse - http://assign3.stanford.edu?
When I click on the link, opens up a page saying Folding@Home, then there is the logo and then it says Assignment Server v 3.6.4
Looks like starts download a work unit.
