Low points today
Ricorocks
Low points today
Post by Ricorocks »
Found 'Aileen' GPU1050ti working, but CPU not working,
*********************** Log Started 2017-12-12T14:34:31Z ***********************
14:34:31:************************* Folding@home Client *************************
14:34:31:      Website: http://folding.stanford.edu/
14:34:31:    Copyright: (c) 2009-2014 Stanford University
14:34:31:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:34:31:         Args: --open-web-control
14:34:31:       Config: C:/Users/Aileen/AppData/Roaming/FAHClient/config.xml
14:34:31:******************************** Build ********************************
14:34:31:      Version: 7.4.4
14:34:31:         Date: Mar 4 2014
14:34:31:         Time: 20:26:54
14:34:31:      SVN Rev: 4130
14:34:31:       Branch: fah/trunk/client
14:34:31:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:34:31:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:34:31:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:34:31:     Platform: win32 XP
14:34:31:         Bits: 32
14:34:31:         Mode: Release
14:34:31:******************************* System ********************************
14:34:31:          CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
14:34:31:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
14:34:31:         CPUs: 8
14:34:31:       Memory: 7.94GiB
14:34:31:  Free Memory: 5.89GiB
14:34:31:      Threads: WINDOWS_THREADS
14:34:31:   OS Version: 6.1
14:34:31:  Has Battery: false
14:34:31:   On Battery: false
14:34:31:   UTC Offset: -6
14:34:31:          PID: 6792
14:34:31:          CWD: C:/Users/Aileen/AppData/Roaming/FAHClient
14:34:31:           OS: Windows 7 Home Premium
14:34:31:      OS Arch: AMD64
14:34:31:         GPUs: 1
14:34:31:        GPU 0: NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
14:34:31:         CUDA: 6.1
14:34:31:  CUDA Driver: 9010
14:34:31:Win32 Service: false
14:34:31:***********************************************************************
14:34:31:<config>
14:34:31:  <!-- Slot Control -->
14:34:31:  <power v='FULL'/>
14:34:31:
14:34:31:  <!-- User Information -->
14:34:31:  <passkey v='********************************'/>
14:34:31:  <user v='Ricoocks'/>
14:34:31:
14:34:31:  <!-- Folding Slots -->
14:34:31:  <slot id='0' type='CPU'/>
14:34:31:  <slot id='1' type='GPU'/>
14:34:31:</config>
14:34:31:Trying to access database...
14:34:31:Successfully acquired database lock
14:34:31:Enabled folding slot 00: READY cpu:7
14:34:31:Enabled folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138
14:34:31:WU02:FS01:Starting
14:34:31:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Aileen/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
14:34:31:WU02:FS01:Started FahCore on PID 3188
14:34:31:WU02:FS01:Core PID:6972
14:34:31:WU02:FS01:FahCore 0x21 started
14:34:31:WU00:FS00:Connecting to 171.67.108.45:8080
14:34:32:WU02:FS01:0x21:*********************** Log Started 2017-12-12T14:34:31Z ***********************
14:34:32:WU02:FS01:0x21:Project: 9431 (Run 1327, Clone 2, Gen 430)
14:34:32:WU02:FS01:0x21:Unit: 0x000001f5ab436c9d586fdd3ee2ca347a
14:34:32:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:34:32:WU02:FS01:0x21:Machine: 1
14:34:32:WU02:FS01:0x21:Digital signatures verified
14:34:32:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:34:32:WU02:FS01:0x21:Version 0.0.18
14:34:32:WU02:FS01:0x21:  Found a checkpoint file
14:34:32:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:34:32:WU00:FS00:Connecting to 171.64.65.35:80
14:34:33:WU00:FS00:Assigned to work server 155.247.166.219
14:34:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
14:34:33:WU00:FS00:Connecting to 155.247.166.219:8080
14:34:34:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:34:34:WU00:FS00:Connecting to 155.247.166.219:80
14:34:34:WU02:FS01:0x21:Completed 4900000 out of 6250000 steps (78%)
14:34:34:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:34:37:12:127.0.0.1:New Web connection
14:34:55:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:34:55:WU00:FS00:Connecting to 171.67.108.45:8080
14:34:56:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:34:56:WU00:FS00:Connecting to 171.64.65.35:80
14:34:56:WU00:FS00:Assigned to work server 155.247.166.219
14:34:56:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
14:34:56:WU00:FS00:Connecting to 155.247.166.219:8080
14:34:57:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:34:57:WU00:FS00:Connecting to 155.247.166.219:80
14:35:18:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:35:56:WU00:FS00:Connecting to 171.67.108.45:8080
14:35:56:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:35:56:WU00:FS00:Connecting to 171.64.65.35:80
14:35:56:WU00:FS00:Assigned to work server 155.247.166.219
14:35:56:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
14:35:56:WU00:FS00:Connecting to 155.247.166.219:8080
14:35:57:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:35:57:WU00:FS00:Connecting to 155.247.166.219:80
14:36:14:WU02:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
14:36:18:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:37:33:WU00:FS00:Connecting to 171.67.108.45:8080
14:37:33:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:37:33:WU00:FS00:Connecting to 171.64.65.35:80
14:37:34:WU00:FS00:Assigned to work server 155.247.166.219
14:37:34:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
14:37:34:WU00:FS00:Connecting to 155.247.166.219:8080
14:37:35:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:37:35:WU00:FS00:Connecting to 155.247.166.219:80
Is this just failed to get assignment & wait? Does FS00 = CPU?
Thanks
bollix47
Re: Low points today
Post by bollix47 »
7 is a prime number and is excluded by a lot of projects.
You could go into your configuration using FAHControl and change the number of CPUs to 6 and you should get work. The PPD should not suffer too much.
You could try using 8 but that might overuse your CPU and cause a negative effect since the GPU slot needs a cpu thread to feed the GPU.
In your case yes, FS00 (folding slot 00) is your cpu slot.
bollix47 wrote:You could go into your configuration using FAHControl and change the number of CPUs to 6 and you should get work. The PPD should not suffer too much.
For a system like this one, 6 is a lot better than 7 because the CPU will get work. Another good option is to use 4 CPUs. It will always get work, too, and there is zero chance it will impact the points earned by the GPU. It will produce less than 6, of course, but not by much. (I'd avoid 5 as it, too, sometimes faces restrictions.)
This problem will be fixed in the next revision of FAHClient. If you ever upgrade to a new client, you can remove the changes we're recommending.
Ricorocks
Post by Ricorocks »
Ok At ADV control SAYS CPU 7 ready >>>configure >>> slots SAYS cpu 0 >>>> highlight cpu 0 >>>> edit SAYS -1 Where to enter 6?
Change the "-1" to a 6.
Ricorocks
Post by Ricorocks »
It's all good now! Thanks Guys
