trouble with fah_core_a7 on 32 bit OS
whocrazy
Post by whocrazy »
Hi.
I'm still using windows XP, and there's a work unit that won't run because it uses fa_core_a7, it just sits there doing nothing.
if I try to run fa_core_a7 manually, it says it's not a valid win32 application.
Can you please compile fah_core_a7 so it will run on older OS' like XP?
Thanks.
Re: trouble with fah_core_a7 on 32 bit OS
There is a reddit where you can made suggestions to developers, this forum is just help.
Core_a7 should not run on older hardware or software. It is optimized for recent CPUs that can run AVX2 instructions, which requires newer OSs.
If you post the first 100 lines of your log, they may be able to prevent other Core_a7 WUs from downloading to your PC.
Blue_Bubble
Post by Blue_Bubble »
Jimbo, I'd be very appreciative if you could tell me how to configure to prevent Core_A7 WUs from being downloaded.
Thanks in advance.
Thanks in advance.
That is a function of the Assignment Server reading the request for work based on your folding configuration. Short of not configuring to fold CPU WU's at all, that is not something you can configure. If you are getting Core_A7 assignments to a system that can not process them due to running an old OS, post the first section of your log file so we can see the system and configuration info. That can be passed on to the people who configure the Assignment and Work Servers so they can adjust those configurations to not assign to the wrong systems.
