NVIDIA GTX 1070 Ti
jonault
NVIDIA GTX 1070 Ti
Post by jonault »
output of "fahclient --lspci:
c:\Program Files (x86)\FAHClient>fahclient --lspci
0x8086:0x8c18:Intel Corporation:Intel(R) 8 Series/C220 Series PCI Express Root Port #5 - 8C18
0x10de:0x0fbb:NVIDIA Corporation:High Definition Audio Controller
0x10de:0x13c2:NVIDIA Corporation:NVIDIA GeForce GTX 970
0x1106:0x3044:VIA Technologies, Inc.:VIA 1394 OHCI Compliant Host Controller
0x8086:0x0c00:Intel Corporation:PCI standard host CPU bridge
0x8086:0x8c22:Intel Corporation:Intel(R) 8 Series/C220 Series SMBus Controller - 8C22
0x1b4b:0x9230:Marvell Technology Group Ltd.:Standard SATA AHCI Controller
0x8086:0x8c31:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x8c44:Intel Corporation:Intel(R) Z87 LPC Controller - 8C44
0x8086:0x8c3a:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x153b:Intel Corporation:Intel(R) Ethernet Connection I217-V
0x8086:0x0c05:Intel Corporation:PCI-to-PCI Bridge
0x10de:0x1b82:NVIDIA Corporation:NVIDIA GeForce GTX 1070 Ti
0x1102:0x0012:Creative Labs:Sound Blaster Audio Controller
0x8086:0x8c02:Intel Corporation:Standard SATA AHCI Controller
0x8086:0x244e:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x1533:Intel Corporation:Intel(R) I210 Gigabit Network Connection
0x8086:0x0c01:Intel Corporation:PCI-to-PCI Bridge
0x10de:0x10f0:NVIDIA Corporation:NV3 [PCI]
0x8086:0x8c16:Intel Corporation:Intel(R) 8 Series/C220 Series PCI Express Root Port #4 - 8C16
0x8086:0x8c2d:Intel Corporation:Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D
0x8086:0x8c26:Intel Corporation:Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26
0x8086:0x8c10:Intel Corporation:Intel(R) 8 Series/C220 Series PCI Express Root Port #1 - 8C10
log file:
*********************** Log Started 2017-11-03T17:36:36Z ***********************
17:36:36:************************* Folding@home Client *************************
17:36:36:      Website: http://folding.stanford.edu/
17:36:36:    Copyright: (c) 2009-2014 Stanford University
17:36:36:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:36:36:         Args:
17:36:36:       Config: C:/Users/Jon/AppData/Roaming/FAHClient/config.xml
17:36:36:******************************** Build ********************************
17:36:36:      Version: 7.4.4
17:36:36:         Date: Mar 4 2014
17:36:36:         Time: 20:26:54
17:36:36:      SVN Rev: 4130
17:36:36:       Branch: fah/trunk/client
17:36:36:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:36:36:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:36:36:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:36:36:     Platform: win32 XP
17:36:36:         Bits: 32
17:36:36:         Mode: Release
17:36:36:******************************* System ********************************
17:36:36:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
17:36:36:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:36:36:         CPUs: 8
17:36:36:       Memory: 15.95GiB
17:36:36:  Free Memory: 14.28GiB
17:36:36:      Threads: WINDOWS_THREADS
17:36:36:   OS Version: 6.2
17:36:36:  Has Battery: false
17:36:36:   On Battery: false
17:36:36:   UTC Offset: -5
17:36:36:          PID: 9584
17:36:36:          CWD: C:/Users/Jon/AppData/Roaming/FAHClient
17:36:36:           OS: Windows 10 Pro
17:36:36:      OS Arch: AMD64
17:36:36:         GPUs: 3
17:36:36:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
17:36:36:        GPU 1: NVIDIA:5 GP104 [xxx]
17:36:36:        GPU 2: UNSUPPORTED: NV3 [PCI]
17:36:36:         CUDA: 6.1
17:36:36:  CUDA Driver: 9010
17:36:36:Win32 Service: false
17:36:36:***********************************************************************
17:36:37:<config>
17:36:37:  <!-- Network -->
17:36:37:  <proxy v=':8080'/>
17:36:37:
17:36:37:  <!-- Slot Control -->
17:36:37:  <power v='FULL'/>
17:36:37:
17:36:37:  <!-- User Information -->
17:36:37:  <passkey v='********************************'/>
17:36:37:  <team v='224497'/>
17:36:37:  <user v='JonAult_ALL_1EoodzUREAtXZTUYzJLSW9hNtoRSuRDJnD'/>
17:36:37:
17:36:37:  <!-- Folding Slots -->
17:36:37:  <slot id='1' type='GPU'>
17:36:37:    <paused v='true'/>
17:36:37:  </slot>
17:36:37:  <slot id='0' type='GPU'>
17:36:37:  </slot>
17:36:37:</config>
17:36:37:Trying to access database...
17:36:37:Successfully acquired database lock
17:36:37:Enabled folding slot 01: PAUSED gpu:0:GM204 [GeForce GTX 970] (by user)
17:36:37:Enabled folding slot 00: PAUSED gpu:1:GP104 [xxx] (by user)
17:36:37:WARNING:WU00:No longer matches Slot 1's configuration, migrating to FS00
17:36:37:WARNING:WU01:No longer matches Slot 0's configuration, migrating to FS01
17:36:58:FS01:Unpaused
17:36:58:WU01:FS01:Starting
17:36:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jon/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 9584 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
17:36:58:WU01:FS01:Started FahCore on PID 10224
17:36:58:WU01:FS01:Core PID:4020
17:36:58:WU01:FS01:FahCore 0x21 started
17:36:58:WU01:FS01:0x21:*********************** Log Started 2017-11-03T17:36:58Z ***********************
17:36:58:WU01:FS01:0x21:Project: 11409 (Run 181, Clone 15, Gen 77)
17:36:58:WU01:FS01:0x21:Unit: 0x0000005d8ca304e9598ca260c6729430
17:36:58:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
17:36:58:WU01:FS01:0x21:Machine: 1
17:36:58:WU01:FS01:0x21:Digital signatures verified
17:36:58:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
17:36:58:WU01:FS01:0x21:Version 0.0.18
17:36:59:WU01:FS01:0x21:  Found a checkpoint file
17:37:05:WU01:FS01:0x21:Completed 4375000 out of 5000000 steps (87%)
17:37:05:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:37:38:Removing old file 'configs/config-20171102-164420.xml'
17:37:38:Saving configuration to config.xml
17:37:38:<config>
17:37:38:  <!-- Network -->
17:37:38:  <proxy v=':8080'/>
17:37:38:
17:37:38:  <!-- Slot Control -->
17:37:38:  <power v='FULL'/>
17:37:38:
17:37:38:  <!-- User Information -->
17:37:38:  <passkey v='********************************'/>
17:37:38:  <team v='224497'/>
17:37:38:  <user v='JonAult_ALL_1EoodzUREAtXZTUYzJLSW9hNtoRSuRDJnD'/>
17:37:38:
17:37:38:  <!-- Folding Slots -->
17:37:38:  <slot id='1' type='GPU'/>
17:37:38:  <slot id='0' type='GPU'>
17:37:38:    <paused v='true'/>
17:37:38:  </slot>
17:37:38:</config>
17:38:13:WU01:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
17:40:31:WU01:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
17:42:50:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
17:45:10:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
17:47:30:WU01:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
17:48:53:FS01:Finishing
17:48:53:FS00:Unpaused
17:48:53:FS00:Finishing
17:48:53:WU00:FS00:Starting
17:48:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jon/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 9584 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
17:48:53:WU00:FS00:Started FahCore on PID 2276
17:48:53:WU00:FS00:Core PID:3648
17:48:53:WU00:FS00:FahCore 0x21 started
17:48:54:WU00:FS00:0x21:*********************** Log Started 2017-11-03T17:48:53Z ***********************
17:48:54:WU00:FS00:0x21:Project: 9431 (Run 1022, Clone 1, Gen 233)
17:48:54:WU00:FS00:0x21:Unit: 0x00000109ab436c9d586fdd3c941f0438
17:48:54:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
17:48:54:WU00:FS00:0x21:Machine: 1
17:48:54:WU00:FS00:0x21:Digital signatures verified
17:48:54:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
17:48:54:WU00:FS00:0x21:Version 0.0.18
17:48:56:WU00:FS00:0x21:Completed 0 out of 6250000 steps (0%)
17:48:56:WU00:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:49:00:FS00:Paused
17:49:00:FS00:Shutting core down
17:49:00:WU00:FS00:0x21:WARNING:Console control signal 1 on PID 3648
17:49:00:WU00:FS00:0x21:Exiting, please wait. . .
17:49:00:WU00:FS00:0x21:Folding@home Core Shutdown: INTERRUPTED
17:49:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:49:52:WU01:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
17:52:13:WU01:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
17:54:33:WU01:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
17:56:55:WU01:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
Nathan_P
Not currently folding
Re: NVIDIA GTX 1070 Ti
Post by Nathan_P »
In other words, can someone add the 1070Ti to gpus.txt
The GPU was already in GPUs.txt except it was called GP104 [xxx] in the text description since the model number was not known at the time the GPU was added -- it's strictly a comment, being non-functional).
I have corrected the descriptive text but it's still enables the 0x10de:0x1b82:NVIDIA [GP104] ... to be used.
The log you posted above shows two functional GPUs, so nothing really changed.
ChristianVirtual
Post by ChristianVirtual »
Could we keep the established description scheme like: GP104 [GeForce GTX 1070 Ti] or similar ?
husq
Hardware configuration: [img]http://folding.extremeoverclocking.com/sigs/sigimage.php?un=husq&t=3213[/img]
http://www.equn.com/forum/forum-21-1.html
Post by husq »
0x10de:0x1b82:2:5:GP104 [xxx]
Revise to
0x10de:0x1b82:2:5:GP104 [GeForce GTX 1070 Ti]
This is already like this, since this is what your client displays.
The posts that were off-topic for this forum, New GPUs (whitelist), have been moved to here - viewtopic.php?f=38&t=30430
