Work Server 155.247.166.219 Taking Too Long to Respond
SombraGuerrero
Post by SombraGuerrero »
This one's pretty straightforward. The server status page does show that it's in REJECT status against pretty much everything right now, but here's my log anyway.:
15:02:44:WU00:FS00:Uploading 4.26MiB to 155.247.166.219
15:02:44:WU00:FS00:Connecting to 155.247.166.219:8080
15:02:46:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:02:46:WU00:FS00:Connecting to 155.247.166.219:80
15:03:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Re: Work Server 155.247.166.219 Taking Too Long to Respond
The upload should have failed over to the CS at 155.247.166.220. Did it do that or was this the only upload attempt?
SombraGuerrero
I thought that too, but my log shows no attempt at fail-over.
I can open 155.247.166.219:8080 but not 155.247.166.219:80 (which reports a timeout).
The server SHOULD redirect port 80 to 8080 but that doesn't seem to be working correctly.
Your log shows a failure to connect on port 8080. Are you connecting through a proxy server?
Once there's a timeout, the fail-over for the CS won't work. Reported as a bug:
https://github.com/FoldingAtHome/fah-issues/issues/1210
SombraGuerrero
Shortly after I replied to Joe, my upload finally succeeded over TCP8080. I think that bug will be the best takeaway from this thread.
