Empty work server assignment
BillGallagher
- Hardware configuration: AMD Threader Ripper 24 cores RTX 3090 Graphic Card
The GPU connect fine to the server, but the CPU has a error code
13:32:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
7:32:42:WU00:FS00:Connecting to 171.67.108.45:8080
07:32:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
07:32:42:WU00:FS00:Connecting to 171.64.65.35:80
07:32:42:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
Thanks
Bill Gallagher
Thanks
Bill Gallagher
ComputerGenie
Re: Server not connected
This can't be true, because it's been "fixed" and I'm supposedly the only one with issues with any 171.67.108.xx servers.
This has nothing to do with the issues with the WS's in that range that were fixed a week ago. Both servers shown in Bill's section of log are Assignment Servers, and they are not matching up the CPU configuration with a WS with suitable projects for the configuration requesting a CPU job.ComputerGenie wrote:This can't be true, because it's been "fixed" and I'm supposedly the only one with issues with any 171.67.108.xx servers.
Back to the actual problem, Bill is probably using the 7.4.4 version of the client and has a quad-core i7. With a GPU slot it will default to requesting CPU:7 WU's at the Full setting, which are no longer being supplied. The "Empty work server" message is referring to the lack of any WS having WU's that meet the request.
There are several solutions to this. First just move the slider to Medium after pausing the CPU slot instead of Full, and that will change the request to CPU:6. Or that can be set for the CPU slot using Configure.
The final option is moving the the public beta version, 7.4.16. That has updated code to have the client negotiate with the AS for the highest available CPU count up to the requested amount.
The other possibility is that the GPU is running on a system with a dual-core CPU. At times there are a limited number of projects that will assign to CPU:1 requests.
As we get adequate information from folks, we can often solve their actual problem. Often the process of obtaining information is the slow part.ComputerGenie wrote:This can't be true, because it's been "fixed" and I'm supposedly the only one with issues with any 171.67.108.xx servers.
Joe_H has made very good guesses, but they are only guesses as we have not seen Mr Gallagher's configuration, so we do not know the number of CPUs, the number of GPUs, the OS, the client version, etc. that would allow an accurate diagnosis.
viewtopic.php?f=24&t=26036
ComputerGenie
I'm pretty damn sure that the thread my post got merged with (where I was repeatedly told was "fixed" and I was the only one having an issue) was titled "WU's Not Being Assigned by 171.67.108...". But sure, let's just go with your "it's Genie and not 3+ different threads needing to be started about issues with the 171.67.108.xx servers giving out valid work" theory...Joe_H wrote:This has nothing to do with the issues with the WS's in that range that were fixed a week ago. Both servers shown in Bill's section of log are Assignment Servers, and they are not matching up the CPU configuration with a WS with suitable projects for the configuration requesting a CPU job...
No, it was titled with two specific WS's, and a '?' mark as someone posted that possibly another server was involved. The problem reported there was fixed, you still have not posted any specific and sufficient details to show a continuing or different problem as requested. You can post them there, if they do show a different problem they will become a different topic. In the meantime, your attempt to hijack this persons problem has been noted.
The fact that others are not reporting a continuing problem should be taken by you as a hint that whatever you are seeing is either different, or specific to your system and/or its internet connection.
ComputerGenie
True, it's highly likely that a Windows 10 system, a Windows 7 system, and a Debian system all suffer from the same "specific" issue (but only with 171.67.108.xx servers) or that the internet connection which flawlessly runs 13 cryptocurrency nodes, 3 servers, a mining farm, and a no less than 2 dozen other devices (not counting the Windows 10 system, the Windows 7 system, and the Debian system that all suffer from the same "specific" issue) only has a "specific" issue with 171.67.108.xx servers that is sporadic and leaves no log trace of such an issue.Joe_H wrote:...The fact that others are not reporting a continuing problem should be taken by you as a hint that whatever you are seeing is either different, or specific to your system and/or its internet connection.
You can resist giving the information as long as you want. We can't help until you do. viewtopic.php?f=24&t=26036
ComputerGenie
Not sure how many times I need to post the same words before someone actually reads them:JimboPalmer wrote:You can resist giving the information as long as you want. We can't help until you do. viewtopic.php?f=24&t=26036
Here's 100% of the relevant information in the log (timestamps and slot info removed because it happened 60+ times to more than 1 slot on more than 1 system):
Assigned to work server 171.67.108.102
Downloading [x] MiBThe log shows no more about that slot or that WS after that.
ComputerGenie wrote:Would that be the Debian system, the Win 10 system, or the Win 7 system?Joe_H wrote:...That will need to include current systems....
Yes.
If you want help, you have to give us clues. Without information, we just can't help wisely.
BillGallagher
Re: Empty work server assignment
I did what joe_h suggested. Stop folding, set slider to moderate, start folding......then in a short time CPU connected and grinding away. Joe_h has excellent analytical skills. I run folding 24/7 and noticed the CPU was not connecting..stay that way a couple days. Yep, win 10 quard-core i7 7.4.4 is sufficient iinfo to solve the problem.
All downloads start with your Client contacting an Assignment Server which subsequently assigns to a Work server.ComputerGenie wrote:I'm pretty damn sure that the thread my post got merged with (where I was repeatedly told was "fixed" and I was the only one having an issue) was titled "WU's Not Being Assigned by 171.67.108...". But sure, let's just go with your "it's Genie and not 3+ different threads needing to be started about issues with the 171.67.108.xx servers giving out valid work" theory...
Both assign.stanford.edu and assign-gpu.stanford.edu are on 171.67.108.45 and that misleads many people ... it shows up in every download attempt, but that's not representative of the problem. The actual download then comes from the assigned WS and that's what really counts.
