No new WU downloaded
Grandpa_01
Post by Grandpa_01 »
I'm having the same problem on both Windows and Linux boxen the wu finishes and then it is getting stuck on download It has happened several times in the last few days. Below is the way I found 2 of my rigs this morning. It has been happening at leas once a day to at least 1 of the rigs this just started within the last few days. :(
07:47:26:WU02:FS00:0x21:Completed 2000000 out of 2000000 steps (100%)
07:47:27:WU01:FS00:Connecting to 171.67.108.45:80
07:47:27:WU01:FS00:Assigned to work server 140.163.4.245
07:47:27:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] from 140.163.4.245
07:47:27:WU01:FS00:Connecting to 140.163.4.245:8080
07:47:31:WU02:FS00:0x21:Saving result file logfile_01.txt
07:47:31:WU02:FS00:0x21:Saving result file checkpointState.xml
07:47:35:WU02:FS00:0x21:Saving result file checkpt.crc
07:47:35:WU02:FS00:0x21:Saving result file log.txt
07:47:35:WU02:FS00:0x21:Saving result file positions.xtc
07:47:36:WARNING:FS00:Size of positions 18925 does not match topology 18840
07:47:37:WU02:FS00:0x21:Folding@home Core Shutdown: FINISHED_UNIT
07:47:37:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:47:37:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10496 run:37 clone:37 gen:12 core:0x21 unit:0x0000000e8ca304f55889607c3aa9ab18
07:47:37:WU02:FS00:Uploading 21.89MiB to 140.163.4.245
07:47:37:WU02:FS00:Connecting to 140.163.4.245:8080
07:47:43:WU02:FS00:Upload 2.57%
07:47:49:WU02:FS00:Upload 5.14%
07:47:55:WU02:FS00:Upload 7.71%
07:48:01:WU02:FS00:Upload 10.28%
07:48:07:WU02:FS00:Upload 13.13%
07:48:13:WU02:FS00:Upload 15.70%
07:48:19:WU02:FS00:Upload 18.27%
07:48:25:WU02:FS00:Upload 20.84%
07:48:31:WU02:FS00:Upload 23.41%
07:48:37:WU02:FS00:Upload 26.27%
07:48:43:WU02:FS00:Upload 28.84%
07:48:49:WU02:FS00:Upload 31.41%
07:48:55:WU02:FS00:Upload 33.98%
07:49:01:WU02:FS00:Upload 36.55%
07:49:07:WU02:FS00:Upload 39.12%
07:49:13:WU02:FS00:Upload 41.69%
07:49:19:WU02:FS00:Upload 44.26%
07:49:25:WU02:FS00:Upload 46.54%
07:49:31:WU02:FS00:Upload 49.11%
07:49:37:WU02:FS00:Upload 51.68%
07:49:43:WU02:FS00:Upload 54.25%
07:49:49:WU02:FS00:Upload 56.53%
07:49:55:WU02:FS00:Upload 59.10%
07:50:01:WU02:FS00:Upload 61.67%
07:50:07:WU02:FS00:Upload 64.24%
07:50:13:WU02:FS00:Upload 66.81%
07:50:19:WU02:FS00:Upload 69.38%
07:50:25:WU02:FS00:Upload 71.95%
07:50:31:WU02:FS00:Upload 74.52%
07:50:37:WU02:FS00:Upload 77.09%
07:50:43:WU02:FS00:Upload 79.66%
07:50:49:WU02:FS00:Upload 82.23%
07:50:55:WU02:FS00:Upload 84.80%
07:51:01:WU02:FS00:Upload 87.37%
07:51:07:WU02:FS00:Upload 89.94%
07:51:13:WU02:FS00:Upload 92.51%
07:51:19:WU02:FS00:Upload 95.08%
07:51:25:WU02:FS00:Upload 97.65%
07:51:50:WU02:FS00:Upload complete
07:51:50:WU02:FS00:Server responded WORK_ACK (400)
07:51:50:WU02:FS00:Final credit estimate, 103221.00 points
07:51:50:WU02:FS00:Cleaning up
******************************* Date: 2017-05-08 *******************************
03:47:29:WU03:FS00:0x21:Completed 4950000 out of 5000000 steps (99%)
03:50:39:WU03:FS00:0x21:Completed 5000000 out of 5000000 steps (100%)
03:50:40:WU01:FS00:Connecting to 171.67.108.45:80
03:50:42:WU03:FS00:0x21:Saving result file logfile_01.txt
03:50:42:WU03:FS00:0x21:Saving result file checkpointState.xml
03:50:43:WU03:FS00:0x21:Saving result file checkpt.crc
03:50:43:WU03:FS00:0x21:Saving result file log.txt
03:50:43:WU03:FS00:0x21:Saving result file positions.xtc
03:50:45:WU03:FS00:0x21:Folding@home Core Shutdown: FINISHED_UNIT
03:50:45:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:50:45:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:11406 run:6 clone:21 gen:279 core:0x21 unit:0x000001968ca304f25686b1f0215b7211
03:50:45:WU03:FS00:Uploading 14.12MiB to 140.163.4.242
03:50:45:WU03:FS00:Connecting to 140.163.4.242:8080
03:50:51:WU03:FS00:Upload 55.79%
03:51:04:WU03:FS00:Upload complete
03:51:04:WU03:FS00:Server responded WORK_ACK (400)
03:51:04:WU03:FS00:Final credit estimate, 134800.00 points
03:51:04:WU03:FS00:Cleaning up
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Re: FahCore21.exe Crashing After Upload
Post by foldy »
I guess Grandpa_01 problem is a different one where the download next work unit is stuck, I think a known issue.
This thread problem is the next work unit is downloaded and started but crashes immediatly because previous work unit cleanup does still something with the driver maybe.
@ryoungblood: If you use visual studio debug the most valueable part would be the callstack of the exception and create a dump file.
EDIT by Mod:
Grandpa's problem report moved here No new WU downloaded
(It's NOT the same problem. He does not report the error code of a crash of FahCore21.exe because his Core_21 did not crash.)
Note the old topic title that's still on this post.
foldy wrote:I guess Grandpa_01 problem is a different one where the download next work unit is stuck, I think a known issue.
Agreed.
A hung internet transfer is NOT the same problem as a Windows exception in the FAHCore.
There's a long-standing problem in many revisions of FAHClient where an upload or a download will "hang" and ever recover (except by restarting FAHClient). There have been some changes in the beta version of the client which MAY fix this problem.
@Grandpa_01: Which version of FAHClient is having that problem?
Grandpa_01
Re: No new WU downloaded
I don't think it is a version of fah problem it has just started recently and it never happened before I would look at any recent changes on the server end it is happening on both 7.4.4 and 7.4.16 version of fah.
https://www.dropbox.com/s/tp8xm7fugr0u5o0/Hung.png?dl=0
It may also depend on your location and the location of the server your system was connecting to. For example, over the weekend I was having troubles connecting due to issues with my internet connection dropping out which were not fixed by the provider until Monday. Adding to that was connecting to one of the PG WS's was going through a router somewhere that was introducing 1,000-5,000 ms of delay as shown by traceroutes. This affected both my uploads and downloads, hung two of my systems with 5 WU's that did not get returned until Monday and had to reset a couple times to get a new WU or restart an upload.
Connecting to a different WS in a different area of the country had fewer network issues. But all it takes for the network bug in the client is sufficient interruption in the connection, that interruption could be local to your system or somewhere else. The 7.4.16 version is somewhat better at detecting the stalled download or upload and retrying, but not 100%.
pahiggz
Post by pahiggz »
I have been folding at home for years without any issues.
I recently can not download new work units for my GPU.
Please let me know what I need to do to fix this....
Thanks in advance,
Pahiggz
02:08:31:WU02:FS00:0xa7:*********************** Log Started 2018-05-05T02:08:30Z ***********************
02:08:31:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:08:31:WU02:FS00:0xa7:       Type: 0xa7
02:08:31:WU02:FS00:0xa7:       Core: Gromacs
02:08:31:WU02:FS00:0xa7:    Website: http://folding.stanford.edu/
02:08:31:WU02:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
02:08:31:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:08:31:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 704 -lifeline 616 -checkpoint 15 -np 2
02:08:31:WU02:FS00:0xa7:     Config: <none>
02:08:31:WU02:FS00:0xa7:************************************ Build *************************************
02:08:31:WU02:FS00:0xa7:    Version: 0.0.16
02:08:31:WU02:FS00:0xa7:       Date: Oct 31 2017
02:08:31:WU02:FS00:0xa7:       Time: 14:04:33
02:08:31:WU02:FS00:0xa7: Repository: Git
02:08:31:WU02:FS00:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
02:08:31:WU02:FS00:0xa7:     Branch: master
02:08:31:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
02:08:31:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:08:31:WU02:FS00:0xa7:   Platform: win32 10
02:08:31:WU02:FS00:0xa7:       Bits: 64
02:08:31:WU02:FS00:0xa7:       Mode: Release
02:08:31:WU02:FS00:0xa7:       SIMD: sse2
02:08:31:WU02:FS00:0xa7:************************************ System ************************************
02:08:31:WU02:FS00:0xa7:        CPU: Unknown
02:08:31:WU02:FS00:0xa7:     CPU ID:
02:08:31:WU02:FS00:0xa7:       CPUs: 3
02:08:31:WU02:FS00:0xa7:     Memory: 15.49GiB
02:08:31:WU02:FS00:0xa7:Free Memory: 13.08GiB
02:08:31:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
02:08:31:WU02:FS00:0xa7: OS Version: 6.1
02:08:31:WU02:FS00:0xa7:Has Battery: false
02:08:31:WU02:FS00:0xa7: On Battery: false
02:08:31:WU02:FS00:0xa7: UTC Offset: -5
02:08:31:WU02:FS00:0xa7:        PID: 2960
02:08:31:WU02:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
02:08:31:WU02:FS00:0xa7:         OS: Windows 7 Home Premium Service Pack 1
02:08:31:WU02:FS00:0xa7:    OS Arch: AMD64
02:08:31:WU02:FS00:0xa7:********************************************************************************
02:08:31:WU02:FS00:0xa7:Project: 13809 (Run 0, Clone 318, Gen 55)
02:08:31:WU02:FS00:0xa7:Unit: 0x0000003f80fccb025a9190b9f036b870
02:08:31:WU02:FS00:0xa7:Digital signatures verified
02:08:31:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -x frame55.xtc -cpi state.cpt -cpt 15 -nt 2
02:08:32:WU02:FS00:0xa7:Steps: first=13750000 total=250000
02:08:36:WU02:FS00:0xa7:Completed 18801 out of 250000 steps (7%)
02:18:01:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
02:35:57:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
02:53:53:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
03:11:48:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
03:29:41:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
03:47:34:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
04:05:23:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
04:23:14:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
04:23:35:WU00:FS01:Connecting to 171.67.108.45:80
04:23:35:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:23:35:WU00:FS01:Connecting to 171.64.65.35:80
04:23:37:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:23:37:ERROR:WU00:FS01:Exception: Could not get an assignment
******************************* Date: 2018-05-05 *******************************
04:43:16:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
05:01:32:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
05:20:41:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
05:38:31:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
05:48:24:105:127.0.0.1:New Web connection
05:56:25:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
05:57:34:FS00:Shutting core down
05:57:34:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 2960
05:57:34:WU02:FS00:0xa7:Exiting, please wait. . .
05:57:37:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:57:37:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:58:09:Removing old file 'configs/config-20180428-161526.xml'
05:58:09:Saving configuration to config.xml
05:58:09:<config>
05:58:09:  <!-- Slot Control -->
05:58:09:  <power v='FULL'/>
05:58:09:
05:58:09:  <!-- User Information -->
05:58:09:  <user v='pahiggz'/>
05:58:09:
05:58:09:  <!-- Folding Slots -->
05:58:09:  <slot id='0' type='CPU'>
05:58:09:    <idle v='true'/>
05:58:09:  </slot>
05:58:09:  <slot id='1' type='GPU'>
05:58:09:  </slot>
05:58:09:</config>
07:21:55:138:127.0.0.1:New Web connection
07:22:07:WU00:FS01:Connecting to 171.67.108.45:80
07:22:07:WU02:FS00:Starting
07:22:07:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 2
07:22:07:WU02:FS00:Started FahCore on PID 4444
07:22:08:WU02:FS00:Core PID:4980
07:22:08:WU02:FS00:FahCore 0xa7 started
07:22:09:WU02:FS00:0xa7:*********************** Log Started 2018-05-05T07:22:08Z ***********************
07:22:09:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:22:09:WU02:FS00:0xa7:       Type: 0xa7
07:22:09:WU02:FS00:0xa7:       Core: Gromacs
07:22:09:WU02:FS00:0xa7:    Website: http://folding.stanford.edu/
07:22:09:WU02:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
07:22:09:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:22:09:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 704 -lifeline 4444 -checkpoint 15 -np 2
07:22:09:WU02:FS00:0xa7:     Config: <none>
07:22:09:WU02:FS00:0xa7:************************************ Build *************************************
07:22:09:WU02:FS00:0xa7:    Version: 0.0.16
07:22:09:WU02:FS00:0xa7:       Date: Oct 31 2017
07:22:09:WU02:FS00:0xa7:       Time: 14:04:33
07:22:09:WU02:FS00:0xa7: Repository: Git
07:22:09:WU02:FS00:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
07:22:09:WU02:FS00:0xa7:     Branch: master
07:22:09:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
07:22:09:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:22:09:WU02:FS00:0xa7:   Platform: win32 10
07:22:09:WU02:FS00:0xa7:       Bits: 64
07:22:09:WU02:FS00:0xa7:       Mode: Release
07:22:09:WU02:FS00:0xa7:       SIMD: sse2
07:22:09:WU02:FS00:0xa7:************************************ System ************************************
07:22:09:WU02:FS00:0xa7:        CPU: Unknown
07:22:09:WU02:FS00:0xa7:     CPU ID:
07:22:09:WU02:FS00:0xa7:       CPUs: 3
07:22:09:WU02:FS00:0xa7:     Memory: 15.49GiB
07:22:09:WU02:FS00:0xa7:Free Memory: 13.13GiB
07:22:09:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
07:22:09:WU02:FS00:0xa7: OS Version: 6.1
07:22:09:WU02:FS00:0xa7:Has Battery: false
07:22:09:WU02:FS00:0xa7: On Battery: false
07:22:09:WU02:FS00:0xa7: UTC Offset: -5
07:22:09:WU02:FS00:0xa7:        PID: 4980
07:22:09:WU02:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
07:22:09:WU02:FS00:0xa7:         OS: Windows 7 Home Premium Service Pack 1
07:22:09:WU02:FS00:0xa7:    OS Arch: AMD64
07:22:09:WU02:FS00:0xa7:********************************************************************************
07:22:09:WU02:FS00:0xa7:Project: 13809 (Run 0, Clone 318, Gen 55)
07:22:09:WU02:FS00:0xa7:Unit: 0x0000003f80fccb025a9190b9f036b870
07:22:09:WU02:FS00:0xa7:Digital signatures verified
07:22:09:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -x frame55.xtc -cpi state.cpt -cpt 15 -nt 2
07:22:09:WU02:FS00:0xa7:Steps: first=13750000 total=250000
07:22:12:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:22:12:WU00:FS01:Connecting to 171.64.65.35:80
07:22:12:WU02:FS00:0xa7:Completed 50162 out of 250000 steps (20%)
07:22:13:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:22:13:ERROR:WU00:FS01:Exception: Could not get an assignment
07:22:32:Removing old file 'configs/config-20180429-053028.xml'
07:22:32:Saving configuration to config.xml
07:22:32:<config>
07:22:32:  <!-- Slot Control -->
07:22:32:  <power v='FULL'/>
07:22:32:
07:22:32:  <!-- User Information -->
07:22:32:  <user v='pahiggz'/>
07:22:32:
07:22:32:  <!-- Folding Slots -->
07:22:32:  <slot id='0' type='CPU'/>
07:22:32:  <slot id='1' type='GPU'/>
07:22:32:</config>
07:23:44:WU00:FS01:Connecting to 171.67.108.45:80
07:23:44:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:23:44:WU00:FS01:Connecting to 171.64.65.35:80
07:23:44:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:23:44:ERROR:WU00:FS01:Exception: Could not get an assignment
07:26:21:WU00:FS01:Connecting to 171.67.108.45:80
07:26:21:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:26:21:WU00:FS01:Connecting to 171.64.65.35:80
07:26:22:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:26:22:ERROR:WU00:FS01:Exception: Could not get an assignment
07:30:35:WU00:FS01:Connecting to 171.67.108.45:80
07:30:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:30:36:WU00:FS01:Connecting to 171.64.65.35:80
07:30:37:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:30:37:ERROR:WU00:FS01:Exception: Could not get an assignment
07:37:27:WU00:FS01:Connecting to 171.67.108.45:80
07:37:27:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:37:27:WU00:FS01:Connecting to 171.64.65.35:80
07:37:28:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:37:28:ERROR:WU00:FS01:Exception: Could not get an assignment
07:39:12:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
07:48:32:WU00:FS01:Connecting to 171.67.108.45:80
07:48:33:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:48:33:WU00:FS01:Connecting to 171.64.65.35:80
07:48:33:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:48:33:ERROR:WU00:FS01:Exception: Could not get an assignment
07:57:57:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
The log from the working CPU slot won't help with your issue, we need the log from the startup of the client : How to provide enough info to get helpful support.
pahiggz
Post by pahiggz »
*********************** Log Started 2018-05-04T04:25:58Z ***********************
04:25:58:************************* Folding@home Client *************************
04:25:58:      Website: http://folding.stanford.edu/
04:25:58:    Copyright: (c) 2009-2014 Stanford University
04:25:58:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:25:58:         Args:
04:25:58:       Config: C:/ProgramData/FAHClient/config.xml
04:25:58:******************************** Build ********************************
04:25:58:      Version: 7.4.4
04:25:58:         Date: Mar 4 2014
04:25:58:         Time: 20:26:54
04:25:58:      SVN Rev: 4130
04:25:58:       Branch: fah/trunk/client
04:25:58:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:25:58:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:25:58:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:25:58:     Platform: win32 XP
04:25:58:         Bits: 32
04:25:58:         Mode: Release
04:25:58:******************************* System ********************************
04:25:58:          CPU: AMD A6-3500 APU with Radeon(tm) HD Graphics
04:25:58:       CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
04:25:58:         CPUs: 3
04:25:58:       Memory: 15.49GiB
04:25:58:  Free Memory: 13.96GiB
04:25:58:      Threads: WINDOWS_THREADS
04:25:58:   OS Version: 6.1
04:25:58:  Has Battery: false
04:25:58:   On Battery: false
04:25:58:   UTC Offset: -5
04:25:58:          PID: 3048
04:25:58:          CWD: C:/ProgramData/FAHClient
04:25:58:           OS: Windows 7 Home Premium
04:25:58:      OS Arch: AMD64
04:25:58:         GPUs: 1
04:25:58:        GPU 0: ATI:4 BeaverCreek [Radeon HD 6530D] S
04:25:58:         CUDA: Not detected
04:25:58:Win32 Service: false
04:25:58:***********************************************************************
04:25:58:<config>
04:25:58:  <!-- Slot Control -->
04:25:58:  <power v='MEDIUM'/>
04:25:58:
04:25:58:  <!-- User Information -->
04:25:58:  <user v='pahiggz'/>
04:25:58:
04:25:58:  <!-- Folding Slots -->
04:25:58:  <slot id='0' type='CPU'/>
04:25:58:  <slot id='1' type='GPU'/>
04:25:58:</config>
04:25:58:Trying to access database...
04:26:02:Successfully acquired database lock
04:26:02:Enabled folding slot 00: READY cpu:1
04:26:02:Enabled folding slot 01: READY gpu:0:BeaverCreek [Radeon HD 6530D] S
04:26:03:WU02:FS00:Starting
04:26:03:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 1
04:26:07:WU02:FS00:Started FahCore on PID 2780
04:26:08:WU02:FS00:Core PID:2960
04:26:08:WU02:FS00:FahCore 0xa4 started
04:26:08:WU02:FS00:0xa4:
04:26:08:WU02:FS00:0xa4:*------------------------------*
04:26:08:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
04:26:08:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:26:08:WU02:FS00:0xa4:Preparing to commence simulation
04:26:08:WU02:FS00:0xa4:- Ensuring status. Please wait.
04:26:09:WU00:FS01:Connecting to 171.67.108.45:80
04:26:11:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:26:11:WU00:FS01:Connecting to 171.64.65.35:80
04:26:12:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:26:12:ERROR:WU00:FS01:Exception: Could not get an assignment
04:26:13:WU00:FS01:Connecting to 171.67.108.45:80
04:26:13:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:26:13:WU00:FS01:Connecting to 171.64.65.35:80
04:26:17:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:26:17:ERROR:WU00:FS01:Exception: Could not get an assignment
04:26:18:WU02:FS00:0xa4:- Looking at optimizations...
04:26:18:WU02:FS00:0xa4:- Working with standard loops on this execution.
04:26:18:WU02:FS00:0xa4:- Previous termination of core was improper.
04:26:18:WU02:FS00:0xa4:- Files status OK
04:26:18:WU02:FS00:0xa4:- Expanded 825309 -> 1398040 (decompressed 169.3 percent)
04:26:18:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825309 data_size=1398040, decompressed_data_size=1398040 diff=0
04:26:18:WU02:FS00:0xa4:- Digital signature verified
04:26:18:WU02:FS00:0xa4:Project: 9039 (Run 787, Clone 1, Gen 1384)
04:26:18:WU02:FS00:0xa4:Entering M.D.
04:26:25:WU02:FS00:0xa4:Using Gromacs checkpoints
04:26:25:WU02:FS00:0xa4:Mapping NT from 1 to 1
04:26:30:WU02:FS00:0xa4:Resuming from checkpoint
04:26:30:WU02:FS00:0xa4:Verified 02/wudata_01.log
04:26:30:WU02:FS00:0xa4:Verified 02/wudata_01.trr
04:26:30:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
04:26:30:WU02:FS00:0xa4:Verified 02/wudata_01.edr
04:26:31:WU02:FS00:0xa4:Completed 126025 out of 250000 steps  (50%)
04:27:13:WU00:FS01:Connecting to 171.67.108.45:80
04:27:13:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:27:13:WU00:FS01:Connecting to 171.64.65.35:80
04:27:14:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:27:14:ERROR:WU00:FS01:Exception: Could not get an assignment
04:28:50:WU00:FS01:Connecting to 171.67.108.45:80
04:28:50:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:28:50:WU00:FS01:Connecting to 171.64.65.35:80
04:28:54:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:28:54:ERROR:WU00:FS01:Exception: Could not get an assignment
04:30:30:17:127.0.0.1:New Web connection
04:31:27:WU00:FS01:Connecting to 171.67.108.45:80
04:31:28:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:31:28:WU00:FS01:Connecting to 171.64.65.35:80
04:31:29:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:31:29:ERROR:WU00:FS01:Exception: Could not get an assignment
04:35:41:WU00:FS01:Connecting to 171.67.108.45:80
04:35:42:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:35:42:WU00:FS01:Connecting to 171.64.65.35:80
04:35:42:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:35:42:ERROR:WU00:FS01:Exception: Could not get an assignment
04:35:48:WU02:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
04:42:33:WU00:FS01:Connecting to 171.67.108.45:80
04:42:33:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:42:33:WU00:FS01:Connecting to 171.64.65.35:80
04:42:34:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:42:34:ERROR:WU00:FS01:Exception: Could not get an assignment
04:49:38:WU02:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
04:53:38:WU00:FS01:Connecting to 171.67.108.45:80
04:53:39:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:53:39:WU00:FS01:Connecting to 171.64.65.35:80
04:53:39:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:53:39:ERROR:WU00:FS01:Exception: Could not get an assignment
05:03:19:WU02:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
05:11:35:WU00:FS01:Connecting to 171.67.108.45:80
05:11:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:11:36:WU00:FS01:Connecting to 171.64.65.35:80
05:11:37:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:11:37:ERROR:WU00:FS01:Exception: Could not get an assignment
05:17:02:WU02:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
05:30:43:WU02:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
05:40:37:WU00:FS01:Connecting to 171.67.108.45:80
05:40:38:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:40:38:WU00:FS01:Connecting to 171.64.65.35:80
05:40:38:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:40:38:ERROR:WU00:FS01:Exception: Could not get an assignment
05:44:41:WU02:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
05:58:24:WU02:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
06:12:03:WU02:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
06:25:49:WU02:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
06:27:37:WU00:FS01:Connecting to 171.67.108.45:80
06:27:38:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:27:38:WU00:FS01:Connecting to 171.64.65.35:80
06:27:39:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:27:39:ERROR:WU00:FS01:Exception: Could not get an assignment
06:40:10:WU02:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
06:54:54:WU02:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
06:57:41:42:127.0.0.1:New Web connection
06:58:07:FS00:Shutting core down
06:58:07:WU00:FS01:Connecting to 171.67.108.45:80
06:58:07:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:58:07:WU00:FS01:Connecting to 171.64.65.35:80
06:58:08:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:58:08:ERROR:WU00:FS01:Exception: Could not get an assignment
06:58:11:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:58:11:WU02:FS00:Starting
06:58:11:WARNING:WU02:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
06:58:11:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 2
06:58:11:WU02:FS00:Started FahCore on PID 2672
06:58:11:WU02:FS00:Core PID:2760
06:58:11:WU02:FS00:FahCore 0xa4 started
06:58:11:WU02:FS00:0xa4:
06:58:11:WU02:FS00:0xa4:*------------------------------*
06:58:11:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
06:58:11:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:58:11:WU02:FS00:0xa4:Preparing to commence simulation
06:58:11:WU02:FS00:0xa4:- Looking at optimizations...
06:58:11:WU02:FS00:0xa4:- Files status OK
06:58:11:WU02:FS00:0xa4:- Expanded 825309 -> 1398040 (decompressed 169.3 percent)
06:58:11:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825309 data_size=1398040, decompressed_data_size=1398040 diff=0
06:58:11:WU02:FS00:0xa4:- Digital signature verified
06:58:11:WU02:FS00:0xa4:Project: 9039 (Run 787, Clone 1, Gen 1384)
06:58:11:WU02:FS00:0xa4:Assembly optimizations on if available.
06:58:11:WU02:FS00:0xa4:Entering M.D.
06:58:18:WU02:FS00:0xa4:Using Gromacs checkpoints
06:58:18:WU02:FS00:0xa4:Mapping NT from 2 to 2
06:58:18:WU02:FS00:0xa4:Resuming from checkpoint
06:58:18:WU02:FS00:0xa4:Verified 02/wudata_01.log
06:58:18:WU02:FS00:0xa4:Verified 02/wudata_01.trr
06:58:18:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
06:58:18:WU02:FS00:0xa4:Verified 02/wudata_01.edr
06:58:18:WU02:FS00:0xa4:Completed 152790 out of 250000 steps  (61%)
06:58:32:Removing old file 'configs/config-20180428-053153.xml'
06:58:32:Saving configuration to config.xml
06:58:32:<config>
06:58:32:  <!-- Slot Control -->
06:58:32:  <power v='FULL'/>
06:58:32:
06:58:32:  <!-- User Information -->
06:58:32:  <user v='pahiggz'/>
06:58:32:
06:58:32:  <!-- Folding Slots -->
06:58:32:  <slot id='0' type='CPU'/>
06:58:32:  <slot id='1' type='GPU'/>
06:58:32:</config>
06:59:44:WU00:FS01:Connecting to 171.67.108.45:80
06:59:45:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:59:45:WU00:FS01:Connecting to 171.64.65.35:80
06:59:45:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:59:45:ERROR:WU00:FS01:Exception: Could not get an assignment
07:02:21:WU00:FS01:Connecting to 171.67.108.45:80
07:02:22:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:02:22:WU00:FS01:Connecting to 171.64.65.35:80
07:02:22:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:02:22:ERROR:WU00:FS01:Exception: Could not get an assignment
07:04:12:WU02:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
07:06:36:WU00:FS01:Connecting to 171.67.108.45:80
07:06:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:06:36:WU00:FS01:Connecting to 171.64.65.35:80
07:06:37:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:06:37:ERROR:WU00:FS01:Exception: Could not get an assignment
07:10:53:WU02:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
07:13:27:WU00:FS01:Connecting to 171.67.108.45:80
07:13:27:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:13:27:WU00:FS01:Connecting to 171.64.65.35:80
07:13:28:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:13:28:ERROR:WU00:FS01:Exception: Could not get an assignment
07:17:36:WU02:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
07:24:16:WU02:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
07:24:32:WU00:FS01:Connecting to 171.67.108.45:80
07:24:33:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:24:33:WU00:FS01:Connecting to 171.64.65.35:80
07:24:33:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:24:33:ERROR:WU00:FS01:Exception: Could not get an assignment
07:30:59:WU02:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
07:37:41:WU02:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
07:42:30:WU00:FS01:Connecting to 171.67.108.45:80
07:42:30:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:42:30:WU00:FS01:Connecting to 171.64.65.35:80
07:42:31:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:42:31:ERROR:WU00:FS01:Exception: Could not get an assignment
07:44:24:WU02:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
07:51:06:WU02:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
07:57:47:WU02:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
08:04:28:WU02:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
08:11:08:WU02:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
08:11:31:WU00:FS01:Connecting to 171.67.108.45:80
08:11:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
08:11:32:WU00:FS01:Connecting to 171.64.65.35:80
08:11:32:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:11:32:ERROR:WU00:FS01:Exception: Could not get an assignment
08:19:20:WU02:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
08:26:07:WU02:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
08:32:47:WU02:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
08:39:27:WU02:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
08:46:09:WU02:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
08:52:51:WU02:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
08:58:30:WU00:FS01:Connecting to 171.67.108.45:80
08:58:31:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
08:58:31:WU00:FS01:Connecting to 171.64.65.35:80
08:58:31:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:58:31:ERROR:WU00:FS01:Exception: Could not get an assignment
08:59:34:WU02:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
09:06:17:WU02:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
09:13:01:WU02:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
09:19:46:WU02:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
09:26:28:WU02:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
09:33:10:WU02:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
09:39:52:WU02:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
09:46:34:WU02:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
09:53:15:WU02:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
09:59:57:WU02:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
10:06:38:WU02:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
10:13:21:WU02:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
10:14:31:WU00:FS01:Connecting to 171.67.108.45:80
10:14:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
10:14:32:WU00:FS01:Connecting to 171.64.65.35:80
10:14:32:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
10:14:32:ERROR:WU00:FS01:Exception: Could not get an assignment
10:20:01:WU02:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
******************************* Date: 2018-05-04 *******************************
10:26:43:WU02:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
10:33:27:WU02:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
10:40:09:WU02:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
10:46:50:WU02:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
10:53:29:WU02:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
11:00:10:WU02:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
11:06:51:WU02:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
11:13:33:WU02:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
11:13:34:WU01:FS00:Connecting to 171.67.108.45:8080
11:13:35:WU01:FS00:Assigned to work server 171.67.108.158
11:13:35:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.67.108.158
11:13:35:WU01:FS00:Connecting to 171.67.108.158:8080
11:13:36:WU01:FS00:Downloading 806.35KiB
11:13:37:WU01:FS00:Download complete
11:13:37:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9031 run:562 clone:2 gen:1708 core:0xa4 unit:0x0000073bab436c9e5698344ed92132cd
11:20:15:WU02:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
11:20:16:WU02:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
11:20:26:WU02:FS00:0xa4:
11:20:26:WU02:FS00:0xa4:Finished Work Unit:
11:20:26:WU02:FS00:0xa4:- Reading up to 811440 from "02/wudata_01.trr": Read 811440
11:20:26:WU02:FS00:0xa4:trr file hash check passed.
11:20:26:WU02:FS00:0xa4:- Reading up to 746776 from "02/wudata_01.xtc": Read 746776
11:20:26:WU02:FS00:0xa4:xtc file hash check passed.
11:20:26:WU02:FS00:0xa4:edr file hash check passed.
11:20:26:WU02:FS00:0xa4:logfile size: 28753
11:20:26:WU02:FS00:0xa4:Leaving Run
11:20:31:WU02:FS00:0xa4:- Writing 1589457 bytes of core data to disk...
11:20:31:WU02:FS00:0xa4:Done: 1588945 -> 1539399 (compressed to 96.8 percent)
11:20:31:WU02:FS00:0xa4:  ... Done.
11:20:32:WU02:FS00:0xa4:- Shutting down core
11:20:32:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
11:20:33:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:20:33:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9039 run:787 clone:1 gen:1384 core:0xa4 unit:0x000005e3ab436c9e5698278c4c7aae8b
11:20:33:WU02:FS00:Uploading 1.47MiB to 171.67.108.158
11:20:33:WU02:FS00:Connecting to 171.67.108.158:8080
11:20:33:WU01:FS00:Starting
11:20:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 2
11:20:33:WU01:FS00:Started FahCore on PID 4092
11:20:33:WU01:FS00:Core PID:3584
11:20:33:WU01:FS00:FahCore 0xa4 started
11:20:33:WU01:FS00:0xa4:
11:20:33:WU01:FS00:0xa4:*------------------------------*
11:20:33:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
11:20:33:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:20:33:WU01:FS00:0xa4:Preparing to commence simulation
11:20:33:WU01:FS00:0xa4:- Looking at optimizations...
11:20:33:WU01:FS00:0xa4:- Created dyn
11:20:33:WU01:FS00:0xa4:- Files status OK
11:20:33:WU01:FS00:0xa4:- Expanded 825186 -> 1397768 (decompressed 169.3 percent)
11:20:33:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825186 data_size=1397768, decompressed_data_size=1397768 diff=0
11:20:33:WU01:FS00:0xa4:- Digital signature verified
11:20:33:WU01:FS00:0xa4:Project: 9031 (Run 562, Clone 2, Gen 1708)
11:20:33:WU01:FS00:0xa4:Assembly optimizations on if available.
11:20:33:WU01:FS00:0xa4:Entering M.D.
11:20:39:WU01:FS00:0xa4:Mapping NT from 2 to 2
11:20:40:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
11:20:40:WU02:FS00:Upload 12.77%
11:20:47:WU02:FS00:Upload 29.79%
11:20:54:WU02:FS00:Upload 46.81%
11:21:00:WU02:FS00:Upload 68.09%
11:21:07:WU02:FS00:Upload 80.86%
11:21:13:WU02:FS00:Upload 97.88%
11:21:14:WU02:FS00:Upload complete
11:21:14:WU02:FS00:Server responded WORK_ACK (400)
11:21:14:WU02:FS00:Final credit estimate, 424.00 points
11:21:14:WU02:FS00:Cleaning up
11:27:30:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
11:34:20:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
11:41:10:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
11:48:01:WU01:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
11:54:50:WU01:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
12:01:40:WU01:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
12:08:32:WU01:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
12:15:22:WU01:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
12:17:31:WU00:FS01:Connecting to 171.67.108.45:80
12:17:31:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
12:17:31:WU00:FS01:Connecting to 171.64.65.35:80
12:17:32:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:17:32:ERROR:WU00:FS01:Exception: Could not get an assignment
12:22:15:WU01:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
12:29:07:WU01:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
12:35:59:WU01:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
12:42:49:WU01:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
12:49:38:WU01:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
12:56:30:WU01:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
13:03:20:WU01:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
13:10:11:WU01:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
13:11:52:70:127.0.0.1:New Web connection
13:17:03:WU01:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
13:23:54:WU01:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
13:28:05:FS00:Shutting core down
13:28:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:28:56:Removing old file 'configs/config-20180428-073757.xml'
13:28:56:Saving configuration to config.xml
13:28:56:<config>
13:28:56:  <!-- Slot Control -->
13:28:56:  <power v='FULL'/>
13:28:56:
13:28:56:  <!-- User Information -->
13:28:56:  <user v='pahiggz'/>
13:28:56:
13:28:56:  <!-- Folding Slots -->
13:28:56:  <slot id='0' type='CPU'>
13:28:56:    <idle v='true'/>
13:28:56:  </slot>
13:28:56:  <slot id='1' type='GPU'>
13:28:56:  </slot>
13:28:56:</config>
14:23:11:WU00:FS01:Connecting to 171.67.108.45:80
14:23:11:WU01:FS00:Starting
14:23:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 2
14:23:11:WU01:FS00:Started FahCore on PID 2272
14:23:11:WU01:FS00:Core PID:168
14:23:11:WU01:FS00:FahCore 0xa4 started
14:23:11:WU01:FS00:0xa4:
14:23:11:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
14:23:11:WU01:FS00:0xa4:*------------------------------*
14:23:11:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
14:23:11:WU00:FS01:Connecting to 171.64.65.35:80
14:23:11:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:23:11:WU01:FS00:0xa4:Preparing to commence simulation
14:23:11:WU01:FS00:0xa4:- Looking at optimizations...
14:23:11:WU01:FS00:0xa4:- Files status OK
14:23:11:WU01:FS00:0xa4:- Expanded 825186 -> 1397768 (decompressed 169.3 percent)
14:23:11:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825186 data_size=1397768, decompressed_data_size=1397768 diff=0
14:23:11:WU01:FS00:0xa4:- Digital signature verified
14:23:11:WU01:FS00:0xa4:Project: 9031 (Run 562, Clone 2, Gen 1708)
14:23:11:WU01:FS00:0xa4:Assembly optimizations on if available.
14:23:11:WU01:FS00:0xa4:Entering M.D.
14:23:12:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:23:12:ERROR:WU00:FS01:Exception: Could not get an assignment
14:23:17:WU01:FS00:0xa4:Using Gromacs checkpoints
14:23:17:WU01:FS00:0xa4:Mapping NT from 2 to 2
14:23:18:WU01:FS00:0xa4:Resuming from checkpoint
14:23:18:WU01:FS00:0xa4:Verified 01/wudata_01.log
14:23:18:WU01:FS00:0xa4:Verified 01/wudata_01.trr
14:23:18:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
14:23:18:WU01:FS00:0xa4:Verified 01/wudata_01.edr
14:23:18:WU01:FS00:0xa4:Completed 43820 out of 250000 steps  (17%)
14:23:50:Removing old file 'configs/config-20180428-151628.xml'
14:23:50:Saving configuration to config.xml
14:23:50:<config>
14:23:50:  <!-- Slot Control -->
14:23:50:  <power v='FULL'/>
14:23:50:
14:23:50:  <!-- User Information -->
14:23:50:  <user v='pahiggz'/>
14:23:50:
14:23:50:  <!-- Folding Slots -->
14:23:50:  <slot id='0' type='CPU'/>
14:23:50:  <slot id='1' type='GPU'/>
14:23:50:</config>
14:24:48:WU00:FS01:Connecting to 171.67.108.45:80
14:24:48:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
14:24:48:WU00:FS01:Connecting to 171.64.65.35:80
14:24:49:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:24:49:ERROR:WU00:FS01:Exception: Could not get an assignment
14:26:32:WU01:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
14:27:25:WU00:FS01:Connecting to 171.67.108.45:80
14:27:25:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
14:27:25:WU00:FS01:Connecting to 171.64.65.35:80
14:27:26:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:27:26:ERROR:WU00:FS01:Exception: Could not get an assignment
14:31:39:WU00:FS01:Connecting to 171.67.108.45:80
14:31:40:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
14:31:40:WU00:FS01:Connecting to 171.64.65.35:80
14:31:40:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:31:40:ERROR:WU00:FS01:Exception: Could not get an assignment
14:33:21:WU01:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
14:38:31:WU00:FS01:Connecting to 171.67.108.45:80
14:38:31:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
14:38:31:WU00:FS01:Connecting to 171.64.65.35:80
14:38:32:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:38:32:ERROR:WU00:FS01:Exception: Could not get an assignment
14:40:10:WU01:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
14:46:56:WU01:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
14:49:36:WU00:FS01:Connecting to 171.67.108.45:80
14:49:37:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
14:49:37:WU00:FS01:Connecting to 171.64.65.35:80
14:49:37:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:49:37:ERROR:WU00:FS01:Exception: Could not get an assignment
14:53:46:WU01:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
15:00:36:WU01:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
15:07:24:WU01:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
15:07:33:WU00:FS01:Connecting to 171.67.108.45:80
15:07:34:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
15:07:34:WU00:FS01:Connecting to 171.64.65.35:80
15:07:34:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
15:07:34:ERROR:WU00:FS01:Exception: Could not get an assignment
15:14:13:WU01:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
15:21:02:WU01:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
15:27:52:WU01:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
15:34:41:WU01:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
15:36:35:WU00:FS01:Connecting to 171.67.108.45:80
15:36:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
15:36:36:WU00:FS01:Connecting to 171.64.65.35:80
15:36:36:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
15:36:36:ERROR:WU00:FS01:Exception: Could not get an assignment
15:41:30:WU01:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
15:48:17:WU01:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
15:55:08:WU01:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
16:01:56:WU01:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
16:08:47:WU01:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
16:15:37:WU01:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
16:22:27:WU01:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
16:23:35:WU00:FS01:Connecting to 171.67.108.45:80
16:23:37:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
16:23:37:WU00:FS01:Connecting to 171.64.65.35:80
16:23:38:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
16:23:38:ERROR:WU00:FS01:Exception: Could not get an assignment
16:29:17:WU01:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
16:36:06:WU01:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
16:42:54:WU01:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
16:49:43:WU01:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
16:56:33:WU01:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
17:03:22:WU01:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
17:10:11:WU01:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
17:16:57:WU01:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
17:23:44:WU01:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
17:30:31:WU01:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
17:37:19:WU01:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
17:39:35:WU00:FS01:Connecting to 171.67.108.45:80
17:39:35:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
17:39:35:WU00:FS01:Connecting to 171.64.65.35:80
17:39:36:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
17:39:36:ERROR:WU00:FS01:Exception: Could not get an assignment
17:44:05:WU01:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
17:50:51:WU01:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
17:57:37:WU01:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
18:04:26:WU01:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
18:11:15:WU01:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
18:18:03:WU01:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
18:24:51:WU01:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
18:31:42:WU01:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
18:38:32:WU01:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
18:45:21:WU01:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
18:52:09:WU01:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
18:58:57:WU01:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
19:05:45:WU01:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
19:12:32:WU01:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
19:19:21:WU01:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
19:26:10:WU01:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
19:32:57:WU01:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
19:39:44:WU01:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
19:42:35:WU00:FS01:Connecting to 171.67.108.45:80
19:42:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
19:42:36:WU00:FS01:Connecting to 171.64.65.35:80
19:42:37:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:42:37:ERROR:WU00:FS01:Exception: Could not get an assignment
19:46:31:WU01:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
19:53:17:WU01:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
20:00:04:WU01:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
20:06:53:WU01:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
20:13:42:WU01:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
20:20:30:WU01:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
20:27:16:WU01:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
20:34:03:WU01:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
20:40:49:WU01:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
20:47:36:WU01:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
20:54:22:WU01:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
21:01:09:WU01:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
21:07:55:WU01:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
21:14:41:WU01:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
21:21:26:WU01:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
21:28:11:WU01:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
21:34:56:WU01:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
21:41:42:WU01:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
21:48:27:WU01:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
21:55:13:WU01:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
22:02:00:WU01:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
22:08:47:WU01:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
22:15:35:WU01:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
22:22:23:WU01:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
22:29:12:WU01:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
22:36:01:WU01:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
22:42:50:WU01:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
22:49:39:WU01:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
22:56:29:WU01:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
23:01:35:WU00:FS01:Connecting to 171.67.108.45:80
23:01:35:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
23:01:35:WU00:FS01:Connecting to 171.64.65.35:80
23:01:36:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
23:01:36:ERROR:WU00:FS01:Exception: Could not get an assignment
23:03:17:WU01:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
23:10:04:WU01:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
23:16:50:WU01:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
23:23:38:WU01:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
23:30:24:WU01:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
23:37:11:WU01:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
23:37:13:WU02:FS00:Connecting to 171.67.108.45:8080
23:37:14:WU02:FS00:Assigned to work server 128.252.203.2
23:37:14:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 128.252.203.2
23:37:14:WU02:FS00:Connecting to 128.252.203.2:8080
23:37:14:WU02:FS00:Downloading 4.53MiB
23:37:20:WU02:FS00:Download 62.12%
23:37:24:WU02:FS00:Download complete
23:37:24:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13809 run:0 clone:318 gen:55 core:0xa7 unit:0x0000003f80fccb025a9190b9f036b870
23:43:59:WU01:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
23:43:59:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:44:09:WU01:FS00:0xa4:
23:44:09:WU01:FS00:0xa4:Finished Work Unit:
23:44:09:WU01:FS00:0xa4:- Reading up to 811512 from "01/wudata_01.trr": Read 811512
23:44:09:WU01:FS00:0xa4:trr file hash check passed.
23:44:09:WU01:FS00:0xa4:- Reading up to 746120 from "01/wudata_01.xtc": Read 746120
23:44:09:WU01:FS00:0xa4:xtc file hash check passed.
23:44:09:WU01:FS00:0xa4:edr file hash check passed.
23:44:09:WU01:FS00:0xa4:logfile size: 26037
23:44:09:WU01:FS00:0xa4:Leaving Run
23:44:14:WU01:FS00:0xa4:- Writing 1586157 bytes of core data to disk...
23:44:15:WU01:FS00:0xa4:Done: 1585645 -> 1538430 (compressed to 97.0 percent)
23:44:15:WU01:FS00:0xa4:  ... Done.
23:44:15:WU01:FS00:0xa4:- Shutting down core
23:44:15:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
23:44:15:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:44:16:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9031 run:562 clone:2 gen:1708 core:0xa4 unit:0x0000073bab436c9e5698344ed92132cd
23:44:16:WU01:FS00:Uploading 1.47MiB to 171.67.108.158
23:44:16:WU01:FS00:Connecting to 171.67.108.158:8080
23:44:16:WU02:FS00:Starting
23:44:16:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 2
23:44:16:WU02:FS00:Started FahCore on PID 4040
23:44:17:WU02:FS00:Core PID:600
23:44:17:WU02:FS00:FahCore 0xa7 started
23:44:18:WU02:FS00:0xa7:*********************** Log Started 2018-05-04T23:44:18Z ***********************
23:44:18:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:44:18:WU02:FS00:0xa7:       Type: 0xa7
23:44:18:WU02:FS00:0xa7:       Core: Gromacs
23:44:18:WU02:FS00:0xa7:    Website: http://folding.stanford.edu/
23:44:18:WU02:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
23:44:18:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:44:18:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 704 -lifeline 4040 -checkpoint 15 -np 2
23:44:18:WU02:FS00:0xa7:     Config: <none>
23:44:18:WU02:FS00:0xa7:************************************ Build *************************************
23:44:18:WU02:FS00:0xa7:    Version: 0.0.16
23:44:18:WU02:FS00:0xa7:       Date: Oct 31 2017
23:44:18:WU02:FS00:0xa7:       Time: 14:04:33
23:44:18:WU02:FS00:0xa7: Repository: Git
23:44:18:WU02:FS00:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
23:44:18:WU02:FS00:0xa7:     Branch: master
23:44:18:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
23:44:18:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:44:18:WU02:FS00:0xa7:   Platform: win32 10
23:44:18:WU02:FS00:0xa7:       Bits: 64
23:44:18:WU02:FS00:0xa7:       Mode: Release
23:44:18:WU02:FS00:0xa7:       SIMD: sse2
23:44:18:WU02:FS00:0xa7:************************************ System ************************************
23:44:18:WU02:FS00:0xa7:        CPU: Unknown
23:44:18:WU02:FS00:0xa7:     CPU ID:
23:44:18:WU02:FS00:0xa7:       CPUs: 3
23:44:18:WU02:FS00:0xa7:     Memory: 15.49GiB
23:44:18:WU02:FS00:0xa7:Free Memory: 13.42GiB
23:44:18:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
23:44:18:WU02:FS00:0xa7: OS Version: 6.1
23:44:18:WU02:FS00:0xa7:Has Battery: false
23:44:18:WU02:FS00:0xa7: On Battery: false
23:44:18:WU02:FS00:0xa7: UTC Offset: -5
23:44:18:WU02:FS00:0xa7:        PID: 600
23:44:18:WU02:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
23:44:18:WU02:FS00:0xa7:         OS: Windows 7 Home Premium Service Pack 1
23:44:18:WU02:FS00:0xa7:    OS Arch: AMD64
23:44:18:WU02:FS00:0xa7:********************************************************************************
23:44:18:WU02:FS00:0xa7:Project: 13809 (Run 0, Clone 318, Gen 55)
23:44:18:WU02:FS00:0xa7:Unit: 0x0000003f80fccb025a9190b9f036b870
23:44:18:WU02:FS00:0xa7:Reading tar file core.xml
23:44:18:WU02:FS00:0xa7:Reading tar file frame55.tpr
23:44:18:WU02:FS00:0xa7:Digital signatures verified
23:44:18:WU02:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -x frame55.xtc -cpt 15 -nt 2
23:44:18:WU02:FS00:0xa7:Steps: first=13750000 total=250000
23:44:22:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
23:44:23:WU01:FS00:Upload 12.78%
23:44:29:WU01:FS00:Upload 29.81%
23:44:36:WU01:FS00:Upload 51.10%
23:44:44:WU01:FS00:Upload 68.14%
23:44:51:WU01:FS00:Upload 80.91%
23:44:58:WU01:FS00:Upload 93.69%
23:45:03:WU01:FS00:Upload complete
23:45:03:WU01:FS00:Server responded WORK_ACK (400)
23:45:03:WU01:FS00:Final credit estimate, 715.00 points
23:45:03:WU01:FS00:Cleaning up
00:02:16:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
00:20:12:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
00:38:10:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
00:56:08:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
01:14:06:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
01:32:06:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
01:50:04:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
02:08:29:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
02:08:29:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
02:08:30:WU02:FS00:Starting
02:08:30:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 704 -lifeline 3048 -checkpoint 15 -np 2
02:08:30:WU02:FS00:Started FahCore on PID 616
02:08:30:WU02:FS00:Core PID:2960
02:08:30:WU02:FS00:FahCore 0xa7 started
05:58:09:<config>
05:58:09:
05:58:09:
05:58:09:  </slot>
05:58:09:  </slot>
05:58:09:</config>
07:22:32:<config>
07:22:32:
07:22:32:
07:22:32:</config>
08:06:29:WU00:FS01:Connecting to 171.67.108.45:80
08:06:30:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
08:06:30:WU00:FS01:Connecting to 171.64.65.35:80
08:06:30:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:06:30:ERROR:WU00:FS01:Exception: Could not get an assignment
08:16:28:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
08:34:26:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
08:35:31:WU00:FS01:Connecting to 171.67.108.45:80
08:35:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
08:35:32:WU00:FS01:Connecting to 171.64.65.35:80
08:35:32:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:35:32:ERROR:WU00:FS01:Exception: Could not get an assignment
08:52:24:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
09:10:17:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
09:22:30:WU00:FS01:Connecting to 171.67.108.45:80
09:22:31:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
09:22:31:WU00:FS01:Connecting to 171.64.65.35:80
09:22:31:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
09:22:31:ERROR:WU00:FS01:Exception: Could not get an assignment
09:29:51:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
09:47:43:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
10:05:36:WU02:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
10:23:32:WU02:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
10:38:31:WU00:FS01:Connecting to 171.67.108.45:80
10:38:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
10:38:32:WU00:FS01:Connecting to 171.64.65.35:80
10:38:32:WARNING:WU00:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
10:38:32:ERROR:WU00:FS01:Exception: Could not get an assignment
10:41:25:WU02:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
Your Radeon HD 6530 is at about the bare minimum to fold GPU WU's from current and recent projects. It does not support double precision calculations, many of the recent projects for Core_21 require that for a portion of the WU processing. So if those are the only WU's available when your system requests one, you will get the empty work server message.
If you can find examples of your client getting GPU WU assignments in the older logs the client keeps, and supply the projects they were from, we can check with the researchers to see if more WU's will become available. It is possible the projects are either completed, or just currently low on available work.
Joe_H wrote:Your Radeon HD 6530 is at about the bare minimum to fold GPU WU's from current and recent projects.
Considering that the Turks GPU platform was an entry-level GPU released in early 2011, a GPU upgrade is perhaps the only reasonable option other than deciding to fold only on your CPU. Seven real years is a lot more than that in GPU-years. :wink:
