i think the links are wrong?
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
Crazy-Logic
Post by Crazy-Logic »
hi guys - i think the links in the 'Terminal installation for Debian / Mint / Ubuntu' section of linux-install-guide are wrong, as they didn't work for me.
I have working links that i used but i can't post just yet as a new user.
Crazy-Logic
Re: i think the links are wrong?
i used:
wget --no-check-certificate http://folding.stanford.edu/releases/pu ... _amd64.deb
wget --no-check-certificate http://folding.stanford.edu/releases/pu ... -1_all.deb
This topic will be moved in a bit to the regular support topic as Debian, Mint and Ubuntu are supported distros of Linux. But before then, in what way did the links in the installation instructions fail for you? I just tried all three, and they all resulted in successfully downloading files.
Looking at your commands used, please look closer at the installation instructions. They use https for a reason. If you are getting a certificate error, please report that.
Crazy-Logic
Thanks Joe,
I think i was mis typing the address as I don't know why but I was using the folding.stanford.edu server which has a slightly different directory structure.
