1. Replacement AcBel PSU 280W damn they want nearly $200.00 crazy. I measured it 5 7/8" X 3 1/2" X 5 3/4"... Because this will become a dedicated folder, should I look for a two fan replacement with similar dimensions, note some have a 120mm fan, inside, presume blowing air out the rear, this on surface seems good, as it would suck some of the heat, out the PSU. If wrong, on which way those internal 120mm fans blow, vice a versa. Count the pins on the new & old. Flys in the ointment?
2. It looks like the case fan, just one rear, no front is a 92mm. The rear fan just has rubber protrusions, going through the 4 holes to secure. Not sure I could install a front fan, would need to be jury rigged. Planning on a EVGA GTX1070
3. Specs say's slot 1 half length, full height PCIe express 2.0 x 16 ver. 2.0. The actual slot is 'black' I was thinking it was AGP, not correct. Half length? Sorry silly just measure the card in it now, 1070 half cards 10.5"
4. Lenovo seems to be proprietary MB, & says no BIOS upgrade required. How big of a deal is this machine built in 2008, for the 1070? Speccy say's the MB is Lenovo, if the card does not work, BIOS, anyway around?
____________
____________
Cleaned the machine lots of malware, updated 100's WU's (windows updates), junk files 28Gb.
Thanks Guys my only experience with hardware, is from my recent Folding experience, any help greatly appreciated. One case fan 92mm & 1070 is perhaps biggest concern
Merry Christmas
Rico
