No full CPU utilization. Run as a service. Win10
sergeyv
Post by sergeyv »
Hi, I installed F@H client for windows 10 as a service.
I set "Folding power" to "Full", and "Folding Core Priority" to "Lowest possible", but maximum CPU utilization by F@H is about 50% even my PC is idle.
Is this perfomance limit for windows services?
Is this problem resolve, if I reinstall client with "automatically start at logon time" option?
Re: No full CPU utilization. Run as a service. Win10
Welcome to foldingforum.org, sergeyv.
No.
Do you have a supported GPU? If so, Microsoft won't let it fold in a service. Either way, FAH may allocate one CPU to support it (wrong, but I think that's what happens. Have you used the Advanced Control (aka FAHControl) program or WebControl?)
Also the service may start at boot time no matter which option you choose. If it doesn't we can fix that, too.
Post the first few pages of your log per the instructions below.
sergeyv
Post by sergeyv »
bruce wrote: Do you have a supported GPU?
I have no GPU.
*********************** Log Started 2016-10-04T16:12:01Z ***********************
16:12:01:************************* Folding@home Client *************************
16:12:01:      Website: http://folding.stanford.edu/
16:12:01:    Copyright: (c) 2009-2014 Stanford University
16:12:01:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:12:01:         Args:
16:12:01:       Config: C:/ProgramData/FAHClient/config.xml
16:12:01:******************************** Build ********************************
16:12:01:      Version: 7.4.4
16:12:01:         Date: Mar 4 2014
16:12:01:         Time: 20:26:54
16:12:01:      SVN Rev: 4130
16:12:01:       Branch: fah/trunk/client
16:12:01:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:12:01:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:12:01:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:12:01:     Platform: win32 XP
16:12:01:         Bits: 32
16:12:01:         Mode: Release
16:12:01:******************************* System ********************************
16:12:01:          CPU: Intel(R) Celeron(R) CPU G530 @ 2.40GHz
16:12:01:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:12:01:         CPUs: 2
16:12:01:       Memory: 7.73GiB
16:12:01:  Free Memory: 7.11GiB
16:12:01:      Threads: WINDOWS_THREADS
16:12:01:   OS Version: 6.2
16:12:01:  Has Battery: false
16:12:01:   On Battery: false
16:12:01:   UTC Offset: 3
16:12:01:          PID: 2072
16:12:01:          CWD: C:/WINDOWS/system32
16:12:01:           OS: Windows 10 Pro
16:12:01:      OS Arch: AMD64
16:12:01:         GPUs: 0
16:12:01:         CUDA: Not detected
16:12:01:Win32 Service: true
16:12:01:***********************************************************************
16:12:01:<config>
16:12:01:  <!-- Network -->
16:12:01:  <proxy v=':8080'/>
16:12:01:
16:12:01:  <!-- Slot Control -->
16:12:01:  <power v='full'/>
16:12:01:
16:12:01:  <!-- User Information -->
16:12:01:  <passkey v='********************************'/>
16:12:01:  <team v='47191'/>
16:12:01:  <user v='sergey_vasiltsov'/>
16:12:01:
16:12:01:  <!-- Folding Slots -->
16:12:01:  <slot id='0' type='CPU'/>
16:12:01:</config>
16:12:01:Trying to access database...
16:12:01:Successfully acquired database lock
16:12:01:Enabled folding slot 00: READY cpu:2
16:12:01:WU00:FS00:Starting
16:12:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2072 -checkpoint 15 -service
16:12:01:WU00:FS00:Started FahCore on PID 3004
16:12:01:WU00:FS00:Core PID:3244
16:12:01:WU00:FS00:FahCore 0xa4 started
16:12:02:WU00:FS00:0xa4:
16:12:02:WU00:FS00:0xa4:*------------------------------*
16:12:02:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
16:12:02:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
16:12:02:WU00:FS00:0xa4:Preparing to commence simulation
16:12:02:WU00:FS00:0xa4:- Looking at optimizations...
16:12:02:WU00:FS00:0xa4:- Files status OK
16:12:02:WU00:FS00:0xa4:- Expanded 826052 -> 1402156 (decompressed 169.7 percent)
16:12:02:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826052 data_size=1402156, decompressed_data_size=1402156 diff=0
16:12:02:WU00:FS00:0xa4:- Digital signature verified
16:12:02:WU00:FS00:0xa4:Project: 9035 (Run 226, Clone 2, Gen 442)
16:12:02:WU00:FS00:0xa4:Assembly optimizations on if available.
16:12:02:WU00:FS00:0xa4:Entering M.D.
16:12:08:WU00:FS00:0xa4:Using Gromacs checkpoints
16:12:09:WU00:FS00:0xa4:Mapping NT from 1 to 1
16:12:10:WU00:FS00:0xa4:Resuming from checkpoint
16:12:10:WU00:FS00:0xa4:Verified 00/wudata_01.log
16:12:10:WU00:FS00:0xa4:Verified 00/wudata_01.trr
16:12:10:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
16:12:10:WU00:FS00:0xa4:Verified 00/wudata_01.edr
16:12:12:WU00:FS00:0xa4:Completed 42450 out of 250000 steps  (16%)
16:13:26:WU00:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
If this is the very first work unit after install, the client may be a victim of a still yet (3 plus years, Joe Coffland) to be fixed legacy installer bug where the first work unit only runs on a single CPU core.
Please let this first work unit finish, and then report the CPU usage on the second work unit. The usage should go up to 100% after that.
sergeyv
Post by sergeyv »
7im wrote:Please let this first work unit finish, and then report the CPU usage on the second work unit. The usage should go up to 100% after that.
Thanks, now f@h use CPU up to 100% (second or third work unit)
