can't find the advanced client
scooter800m
Post by scooter800m »
i want to find the advanced client because my CPU is crap, but my GPU is pretty tough for my laptops category (Radeon HD 4250). when i start up the client from my desktop shortcut it brings me to web control and shows that my computer isn't doing any work, and if it is it isn't showing, even in task manager it shows less than 10% CPU usage.
HELP ME FIND THE ADVANCED CLIENT
Re: can't find the advanced client
Right click on the fah tray icon, select Advanced Control.
FYI, the minimum supported AMD GPU is currently a 5000 series and above. 4000 series and below support ended a year or two ago.
However, your CPU client slot should be able to fold on all the CPU cores.
