Fialed to get assingment from 171.64-65-35
stratocastor
Log:
8:05:13:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:05:14:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:05:14:ERROR:WU02:FS00:Exception: Could not get an assignment
18:05:14:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:06:14:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:06:15:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:06:15:ERROR:WU02:FS00:Exception: Could not get an assignment
18:07:52:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:07:52:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:07:52:ERROR:WU02:FS00:Exception: Could not get an assignment
18:10:29:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:10:29:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:10:29:ERROR:WU02:FS00:Exception: Could not get an assignment
18:14:43:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:14:44:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:14:44:ERROR:WU02:FS00:Exception: Could not get an assignment
18:21:34:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:21:35:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:21:35:ERROR:WU02:FS00:Exception: Could not get an assignment
18:32:40:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:32:40:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:32:40:ERROR:WU02:FS00:Exception: Could not get an assignment
18:50:37:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:50:37:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:50:37:ERROR:WU02:FS00:Exception: Could not get an assignment
19:19:39:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:19:39:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:19:39:ERROR:WU02:FS00:Exception: Could not get an assignment
20:06:38:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
20:06:38:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
20:06:38:ERROR:WU02:FS00:Exception: Could not get an assignment
******************************* Date: 2016-08-02 *******************************
21:22:38:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:22:39:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:22:39:ERROR:WU02:FS00:Exception: Could not get an assignment
Can connect fine, but no assingment? Thanks for any information!
stratocastor
Re: Fialed to get assingment from 171.64-65-35
Hmmm, reinstalled, seems to be getting work units now... strange
That's not enough information to help you. See the link in the signature of this post -- if the problem reoccurs.
"Empty work server assignment" means that no servers could be found that match the requirements of the configuration being reported by your system. If there's only one work server that has WUs that you could process and it runs out or goes off-line, you'll get that message. For common client configurations, WUs can be obtained from many work servers and it's the assignment server's job to pick one -- and neither one of them could find anything for you.
stratocastor
Happened to me again, from researching a bit, seems to be related to the default cpu setting of -1. Changed to 6 for the time being, and everything is a go!!. This was configer folding slot, under slots in configure client!!! Attached is the error, and the continuing log after slots was changed to 6.
*********************** Log Started 2016-08-03T00:19:07Z ***********************
00:19:07:************************* Folding@home Client *************************
00:19:07: Website: http://folding.stanford.edu/
00:19:07: Copyright: (c) 2009-2014 Stanford University
00:19:07: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:19:07: Args: --open-web-control
00:19:07: Config: C:/Users/Beast/AppData/Roaming/FAHClient/config.xml
00:19:07:******************************** Build ********************************
00:19:07: Version: 7.4.4
00:19:07: Date: Mar 4 2014
00:19:07: Time: 20:26:54
00:19:07: SVN Rev: 4130
00:19:07: Branch: fah/trunk/client
00:19:07: Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:19:07: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:19:07: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:19:07: Platform: win32 XP
00:19:07: Bits: 32
00:19:07: Mode: Release
00:19:07:******************************* System ********************************
00:19:07: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
00:19:07: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
00:19:07: CPUs: 8
00:19:07: Memory: 15.92GiB
00:19:07: Free Memory: 11.81GiB
00:19:07: Threads: WINDOWS_THREADS
00:19:07: OS Version: 6.2
00:19:07: Has Battery: false
00:19:07: On Battery: false
00:19:07: UTC Offset: -6
00:19:07: PID: 9792
00:19:07: CWD: C:/Users/Beast/AppData/Roaming/FAHClient
00:19:07: OS: Windows 10 Home
00:19:07: OS Arch: AMD64
00:19:07: GPUs: 1
00:19:07: GPU 0: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
00:19:07: CUDA: 5.2
00:19:07: CUDA Driver: 8000
00:19:07:Win32 Service: false
00:19:07:***********************************************************************
00:19:07:<config>
00:19:07: <!-- Network -->
00:19:07: <proxy v=':8080'/>
00:19:07:
00:19:07: <!-- Slot Control -->
00:19:07: <power v='full'/>
00:19:07:
00:19:07: <!-- User Information -->
00:19:07: <passkey v='********************************'/>
00:19:07: <team v='37729'/>
00:19:07: <user v='stratocastor'/>
00:19:07:
00:19:07: <!-- Folding Slots -->
00:19:07: <slot id='0' type='CPU'>
00:19:07: <paused v='true'/>
00:19:07: </slot>
00:19:07: <slot id='1' type='GPU'>
00:19:07: </slot>
00:19:07:</config>
00:19:07:Trying to access database...
00:19:07:Successfully acquired database lock
00:19:07:Enabled folding slot 00: PAUSED cpu:7 (by user)
00:19:07:Enabled folding slot 01: PAUSED gpu:0:GM200 [GeForce GTX 980 Ti] (by user)
00:19:09:12:127.0.0.1:New Web connection
00:19:17:FS00:Unpaused
00:19:17:FS01:Unpaused
00:19:17:WU02:FS01:Starting
00:19:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Beast/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 9792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:19:17:WU02:FS01:Started FahCore on PID 10408
00:19:17:WU02:FS01:Core PID:10420
00:19:17:WU02:FS01:FahCore 0x18 started
00:19:17:WU00:FS00:Starting
00:19:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Beast/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 9792 -checkpoint 15 -np 7
00:19:17:WU00:FS00:Started FahCore on PID 10428
00:19:17:WU00:FS00:Core PID:10452
00:19:17:WU00:FS00:FahCore 0xa4 started
00:19:17:WU02:FS01:0x18:*********************** Log Started 2016-08-03T00:19:17Z ***********************
00:19:17:WU02:FS01:0x18:Project: 9660 (Run 1, Clone 11, Gen 193)
00:19:17:WU02:FS01:0x18:Unit: 0x000000dbab436c9b56de69ba6803ccfb
00:19:17:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
00:19:17:WU02:FS01:0x18:Machine: 1
00:19:17:WU02:FS01:0x18:Digital signatures verified
00:19:17:WU02:FS01:0x18:Folding@home GPU core18
00:19:17:WU02:FS01:0x18:Version 0.0.4
00:19:17:WU02:FS01:0x18: Found a checkpoint file
00:19:18:WU00:FS00:0xa4:
00:19:18:WU00:FS00:0xa4:*------------------------------*
00:19:18:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
00:19:18:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:19:18:WU00:FS00:0xa4:Preparing to commence simulation
00:19:18:WU00:FS00:0xa4:- Looking at optimizations...
00:19:18:WU00:FS00:0xa4:- Files status OK
00:19:18:WU00:FS00:0xa4:- Expanded 825179 -> 1398040 (decompressed 169.4 percent)
00:19:18:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825179 data_size=1398040, decompressed_data_size=1398040 diff=0
00:19:18:WU00:FS00:0xa4:- Digital signature verified
00:19:18:WU00:FS00:0xa4:Project: 9039 (Run 476, Clone 1, Gen 370)
00:19:18:WU00:FS00:0xa4:Assembly optimizations on if available.
00:19:18:WU00:FS00:0xa4:Entering M.D.
00:19:21:WU02:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
00:19:21:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:19:24:WU00:FS00:0xa4:Using Gromacs checkpoints
00:19:24:WU00:FS00:0xa4:Mapping NT from 7 to 7
00:19:24:WU00:FS00:0xa4:Resuming from checkpoint
00:19:24:WU00:FS00:0xa4:Verified 00/wudata_01.log
00:19:24:WU00:FS00:0xa4:Verified 00/wudata_01.trr
00:19:24:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
00:19:24:WU00:FS00:0xa4:Verified 00/wudata_01.edr
00:19:24:WU00:FS00:0xa4:Completed 85170 out of 250000 steps (34%)
00:19:43:WU02:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
00:20:04:WU02:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
00:20:08:Saving configuration to config.xml
00:20:08:<config>
00:20:08: <!-- Network -->
00:20:08: <proxy v=':8080'/>
00:20:08:
00:20:08: <!-- Slot Control -->
00:20:08: <power v='full'/>
00:20:08:
00:20:08: <!-- User Information -->
00:20:08: <passkey v='********************************'/>
00:20:08: <team v='37729'/>
00:20:08: <user v='stratocastor'/>
00:20:08:
00:20:08: <!-- Folding Slots -->
00:20:08: <slot id='0' type='CPU'/>
00:20:08: <slot id='1' type='GPU'/>
00:20:08:</config>
00:20:25:WU02:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
00:20:26:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
00:20:46:WU02:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
00:21:07:WU02:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
00:21:30:WU02:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
00:21:41:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
00:21:51:WU02:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
00:22:12:WU02:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
00:22:34:WU02:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
00:22:55:WU02:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
00:23:00:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
00:23:18:WU02:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
00:23:39:WU02:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
00:24:00:WU02:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
00:24:21:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
00:24:21:WU02:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
00:24:42:WU02:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
00:25:06:WU02:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
00:25:27:WU02:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
00:25:45:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
00:25:48:WU02:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
00:26:09:WU02:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
00:26:30:WU02:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
00:26:54:WU02:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
00:27:04:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
00:27:15:WU02:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
00:27:36:WU02:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
00:27:57:WU02:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
00:28:18:WU02:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
00:28:21:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
00:28:41:WU02:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
00:29:02:WU02:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
00:29:24:WU02:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
00:29:39:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
00:29:45:WU02:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
00:30:06:WU02:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
00:30:29:WU02:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
00:30:50:WU02:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
00:30:56:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
00:31:11:WU02:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
00:31:32:WU02:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
00:31:54:WU02:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
00:32:14:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
00:32:17:WU02:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
00:32:38:WU02:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
00:32:59:WU02:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
00:33:20:WU02:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
00:33:31:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
00:33:41:WU02:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
00:34:05:WU02:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
00:34:26:WU02:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
00:34:47:WU02:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
00:34:48:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
00:35:08:WU02:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
00:35:29:WU02:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
00:35:53:WU02:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
00:36:06:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
00:36:14:WU02:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
00:36:35:WU02:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
00:36:56:WU02:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
00:37:17:WU02:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
00:37:24:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
00:37:40:WU02:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
00:38:02:WU02:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
00:38:23:WU02:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
00:38:41:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
00:38:44:WU02:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
00:39:05:WU02:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
00:39:06:WU01:FS01:Connecting to 171.67.108.45:80
00:39:06:WU01:FS01:Assigned to work server 140.163.4.243
00:39:06:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.243
00:39:06:WU01:FS01:Connecting to 140.163.4.243:8080
00:39:06:WU01:FS01:Downloading 3.98MiB
00:39:07:WU02:FS01:0x18:Saving result file logfile_01.txt
00:39:07:WU02:FS01:0x18:Saving result file checkpointState.xml
00:39:08:WU02:FS01:0x18:Saving result file checkpt.crc
00:39:08:WU02:FS01:0x18:Saving result file log.txt
00:39:08:WU02:FS01:0x18:Saving result file positions.xtc
00:39:08:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
00:39:08:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:39:08:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9660 run:1 clone:11 gen:193 core:0x18 unit:0x000000dbab436c9b56de69ba6803ccfb
00:39:08:WU02:FS01:Uploading 1.75MiB to 171.67.108.155
00:39:08:WU02:FS01:Connecting to 171.67.108.155:8080
00:39:09:WU01:FS01:Download complete
00:39:09:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11704 run:0 clone:449 gen:75 core:0x21 unit:0x000000638ca304f35689628fab3b3558
00:39:09:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
00:39:09:WU01:FS01:Connecting to web.stanford.edu:80
00:39:09:WU01:FS01:FahCore 21: Downloading 3.47MiB
00:39:14:WU02:FS01:Upload complete
00:39:14:WU02:FS01:Server responded WORK_ACK (400)
00:39:14:WU02:FS01:Final credit estimate, 11409.00 points
00:39:14:WU02:FS01:Cleaning up
00:39:15:WU01:FS01:FahCore 21: 79.19%
00:39:15:WU01:FS01:FahCore 21: Download complete
00:39:15:WU01:FS01:Valid core signature
00:39:15:WU01:FS01:Unpacked 11.81MiB to cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
00:39:15:WU01:FS01:Starting
00:39:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Beast/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 9792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:39:15:WU01:FS01:Started FahCore on PID 4788
00:39:15:WU01:FS01:Core PID:2828
00:39:15:WU01:FS01:FahCore 0x21 started
00:39:50:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
00:40:54:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
00:41:58:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
00:43:03:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
00:44:07:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
00:45:12:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
00:46:16:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
00:47:21:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
00:48:25:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
00:49:30:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
00:50:35:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
00:51:40:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
00:52:44:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
00:53:49:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
00:54:53:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
00:55:57:WU00:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
00:57:01:WU00:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
00:58:05:WU00:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
00:59:10:WU00:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
01:00:15:WU00:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
01:01:19:WU00:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
01:02:24:WU00:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
01:03:28:WU00:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
01:04:32:WU00:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
01:05:37:WU00:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
01:06:41:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
01:07:45:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
01:08:49:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
01:09:53:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
01:10:57:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
01:12:01:WU00:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
01:13:06:WU00:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
01:14:10:WU00:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
01:15:14:WU00:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
01:16:18:WU00:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
01:17:23:WU00:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
01:18:27:WU00:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
01:19:32:WU00:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
01:20:36:WU00:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
01:21:40:WU00:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
01:22:45:WU00:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
01:23:49:WU00:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
01:24:54:WU00:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
01:25:58:WU00:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
01:27:03:WU00:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
01:28:08:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
01:29:13:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
01:30:17:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
01:31:21:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
01:32:26:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
01:32:26:WU02:FS00:Connecting to 171.67.108.45:8080
01:32:26:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:32:26:WU02:FS00:Connecting to 171.64.65.35:80
01:32:27:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:32:27:ERROR:WU02:FS00:Exception: Could not get an assignment
01:32:27:WU02:FS00:Connecting to 171.67.108.45:8080
01:32:27:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:32:27:WU02:FS00:Connecting to 171.64.65.35:80
01:32:28:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:32:28:ERROR:WU02:FS00:Exception: Could not get an assignment
01:33:27:WU02:FS00:Connecting to 171.67.108.45:8080
01:33:27:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:33:27:WU02:FS00:Connecting to 171.64.65.35:80
01:33:28:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:33:28:ERROR:WU02:FS00:Exception: Could not get an assignment
01:33:30:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
01:33:30:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
01:33:40:WU00:FS00:0xa4:
01:33:40:WU00:FS00:0xa4:Finished Work Unit:
01:33:40:WU00:FS00:0xa4:- Reading up to 811440 from "00/wudata_01.trr": Read 811440
01:33:40:WU00:FS00:0xa4:trr file hash check passed.
01:33:40:WU00:FS00:0xa4:- Reading up to 745844 from "00/wudata_01.xtc": Read 745844
01:33:40:WU00:FS00:0xa4:xtc file hash check passed.
01:33:40:WU00:FS00:0xa4:edr file hash check passed.
01:33:40:WU00:FS00:0xa4:logfile size: 24489
01:33:40:WU00:FS00:0xa4:Leaving Run
01:33:41:WU00:FS00:0xa4:- Writing 1584261 bytes of core data to disk...
01:33:41:WU00:FS00:0xa4:Done: 1583749 -> 1538006 (compressed to 97.1 percent)
01:33:41:WU00:FS00:0xa4: ... Done.
01:33:41:WU00:FS00:0xa4:- Shutting down core
01:33:41:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
01:33:42:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:33:42:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9039 run:476 clone:1 gen:370 core:0xa4 unit:0x0000019bab436c9e5698280fc37a607a
01:33:42:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
01:33:42:WU00:FS00:Connecting to 171.67.108.158:8080
01:33:50:WU00:FS00:Upload complete
01:33:50:WU00:FS00:Server responded WORK_ACK (400)
01:33:50:WU00:FS00:Final credit estimate, 1691.00 points
01:33:50:WU00:FS00:Cleaning up
01:35:05:WU02:FS00:Connecting to 171.67.108.45:8080
01:35:05:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:35:05:WU02:FS00:Connecting to 171.64.65.35:80
01:35:05:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:35:05:ERROR:WU02:FS00:Exception: Could not get an assignment
01:37:42:WU02:FS00:Connecting to 171.67.108.45:8080
01:37:42:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:37:42:WU02:FS00:Connecting to 171.64.65.35:80
01:37:42:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:37:42:ERROR:WU02:FS00:Exception: Could not get an assignment
01:41:56:WU02:FS00:Connecting to 171.67.108.45:8080
01:41:56:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:41:56:WU02:FS00:Connecting to 171.64.65.35:80
01:41:57:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:41:57:ERROR:WU02:FS00:Exception: Could not get an assignment
01:48:47:WU02:FS00:Connecting to 171.67.108.45:8080
01:48:47:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:48:47:WU02:FS00:Connecting to 171.64.65.35:80
01:48:48:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:48:48:ERROR:WU02:FS00:Exception: Could not get an assignment
01:59:53:WU02:FS00:Connecting to 171.67.108.45:8080
01:59:53:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:59:53:WU02:FS00:Connecting to 171.64.65.35:80
01:59:53:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:59:54:ERROR:WU02:FS00:Exception: Could not get an assignment
02:17:49:WU02:FS00:Connecting to 171.67.108.45:8080
02:17:50:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:17:50:WU02:FS00:Connecting to 171.64.65.35:80
02:17:50:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:17:50:ERROR:WU02:FS00:Exception: Could not get an assignment
02:46:51:WU02:FS00:Connecting to 171.67.108.45:8080
02:46:52:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:46:52:WU02:FS00:Connecting to 171.64.65.35:80
02:46:52:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:46:52:ERROR:WU02:FS00:Exception: Could not get an assignment
03:33:50:WU02:FS00:Connecting to 171.67.108.45:8080
03:33:51:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:33:51:WU02:FS00:Connecting to 171.64.65.35:80
03:33:51:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:33:51:ERROR:WU02:FS00:Exception: Could not get an assignment
04:49:51:WU02:FS00:Connecting to 171.67.108.45:8080
04:49:51:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
04:49:51:WU02:FS00:Connecting to 171.64.65.35:80
04:49:52:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:49:52:ERROR:WU02:FS00:Exception: Could not get an assignment
******************************* Date: 2016-08-03 *******************************
06:52:51:WU02:FS00:Connecting to 171.67.108.45:8080
06:52:51:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:52:51:WU02:FS00:Connecting to 171.64.65.35:80
06:52:51:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:52:51:ERROR:WU02:FS00:Exception: Could not get an assignment
10:11:51:WU02:FS00:Connecting to 171.67.108.45:8080
10:11:51:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
10:11:51:WU02:FS00:Connecting to 171.64.65.35:80
10:11:52:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
10:11:52:ERROR:WU02:FS00:Exception: Could not get an assignment
13:53:13:44:127.0.0.1:New Web connection
13:53:35:Saving configuration to config.xml
13:53:35:<config>
13:53:35: <!-- Network -->
13:53:35: <proxy v=':8080'/>
13:53:35:
13:53:35: <!-- Slot Control -->
13:53:35: <power v='full'/>
13:53:35:
13:53:35: <!-- User Information -->
13:53:35: <passkey v='********************************'/>
13:53:35: <team v='37729'/>
13:53:35: <user v='stratocastor'/>
13:53:35:
13:53:35: <!-- Folding Slots -->
13:53:35: <slot id='0' type='CPU'>
13:53:35: <cpus v='6'/>
13:53:35: </slot>
13:53:35: <slot id='1' type='GPU'/>
13:53:35:</config>
13:54:08:Saving configuration to config.xml
13:54:08:<config>
13:54:08: <!-- Network -->
13:54:08: <proxy v=':8080'/>
13:54:08:
13:54:08: <!-- Slot Control -->
13:54:08: <power v='full'/>
13:54:08:
13:54:08: <!-- User Information -->
13:54:08: <passkey v='********************************'/>
13:54:08: <team v='37726'/>
13:54:08: <user v='stratocastor'/>
13:54:08:
13:54:08: <!-- Folding Slots -->
13:54:08: <slot id='0' type='CPU'>
13:54:08: <cpus v='6'/>
13:54:08: </slot>
13:54:08: <slot id='1' type='GPU'/>
13:54:08:</config>
13:54:24:FS00:Paused
13:54:24:FS01:Paused
13:54:24:FS01:Shutting core down
13:54:25:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:54:29:Saving configuration to config.xml
13:54:29:<config>
13:54:29: <!-- Network -->
13:54:29: <proxy v=':8080'/>
13:54:29:
13:54:29: <!-- Slot Control -->
13:54:29: <power v='full'/>
13:54:29:
13:54:29: <!-- User Information -->
13:54:29: <passkey v='********************************'/>
13:54:29: <team v='37726'/>
13:54:29: <user v='stratocastor'/>
13:54:29:
13:54:29: <!-- Folding Slots -->
13:54:29: <slot id='0' type='CPU'>
13:54:29: <cpus v='6'/>
13:54:29: <paused v='true'/>
13:54:29: </slot>
13:54:29: <slot id='1' type='GPU'>
13:54:29: </slot>
13:54:29:</config>
13:54:31:FS00:Unpaused
13:54:31:FS01:Unpaused
13:54:31:WU01:FS01:Starting
13:54:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Beast/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 9792 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
13:54:31:WU01:FS01:Started FahCore on PID 6736
13:54:31:WU01:FS01:Core PID:6664
13:54:31:WU01:FS01:FahCore 0x21 started
13:54:31:WU02:FS00:Connecting to 171.67.108.45:8080
13:54:31:WU02:FS00:Assigned to work server 171.67.108.158
13:54:31:WU02:FS00:Requesting new work unit for slot 00: READY cpu:6 from 171.67.108.158
13:54:31:WU02:FS00:Connecting to 171.67.108.158:8080
13:54:32:WU02:FS00:Downloading 806.28KiB
13:54:32:WU02:FS00:Download complete
13:54:32:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9039 run:899 clone:0 gen:356 core:0xa4 unit:0x0000018bab436c9e56982742a0d04ecc
13:54:32:WU02:FS00:Starting
13:54:32:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Beast/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 9792 -checkpoint 15 -np 6
13:54:33:WU02:FS00:Started FahCore on PID 6204
13:54:33:WU02:FS00:Core PID:7128
13:54:33:WU02:FS00:FahCore 0xa4 started
13:54:33:WU02:FS00:0xa4:
13:54:33:WU02:FS00:0xa4:*------------------------------*
13:54:33:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
13:54:33:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:54:33:WU02:FS00:0xa4:Preparing to commence simulation
13:54:33:WU02:FS00:0xa4:- Looking at optimizations...
13:54:33:WU02:FS00:0xa4:- Created dyn
13:54:33:WU02:FS00:0xa4:- Files status OK
13:54:33:WU02:FS00:0xa4:- Expanded 825117 -> 1398040 (decompressed 169.4 percent)
13:54:33:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825117 data_size=1398040, decompressed_data_size=1398040 diff=0
13:54:33:WU02:FS00:0xa4:- Digital signature verified
13:54:33:WU02:FS00:0xa4:Project: 9039 (Run 899, Clone 0, Gen 356)
13:54:33:WU02:FS00:0xa4:Assembly optimizations on if available.
13:54:33:WU02:FS00:0xa4:Entering M.D.
13:54:39:WU02:FS00:0xa4:Mapping NT from 6 to 6
13:54:39:WU02:FS00:0xa4:Completed 0 out of 250000 steps (0%)
13:55:30:Saving configuration to config.xml
13:55:30:<config>
13:55:30: <!-- Network -->
13:55:30: <proxy v=':8080'/>
13:55:30:
13:55:30: <!-- Slot Control -->
13:55:30: <power v='full'/>
13:55:30:
13:55:30: <!-- User Information -->
13:55:30: <passkey v='********************************'/>
13:55:30: <team v='37726'/>
13:55:30: <user v='stratocastor'/>
13:55:30:
13:55:30: <!-- Folding Slots -->
13:55:30: <slot id='0' type='CPU'>
13:55:30: <cpus v='6'/>
13:55:30: </slot>
13:55:30: <slot id='1' type='GPU'/>
13:55:30:</config>
13:55:39:WU02:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
13:56:40:WU02:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
13:57:41:WU02:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
Reason: Added code tags.
davidcoton
Using CPU:-1 on an eight CPU system with one GPU is effectively CPU:7, which is locked out on most projects (because it doesn't work well). CPU:6 is the correct solution for now.
Kougar
- Hardware configuration: Core i7 920 @ 4.3GHz 1.42v (HT on)
Gigabyte GA-X58-UD5 (F10)
3 x 2GB OCZ Platinum 16400MHz 8-8-8-24 1T
EVGA GTX 260 w/ D-Tek Fuzion 2 GFX
ASUS Xonar DX | Cooler Master UCP 1kW
Intel X25-M 80GB SSD | Windows 7 x64
Swiftech Apogee GTZ + MCP655 Pump & Thermochill PA120.3 Radiator - Location: Texas
That would explain why two of my systems have been CPU idling for over a week. Since the F@H software itself defaults to 7 this should probably be fixed pronto...davidcoton wrote:Using CPU:-1 on an eight CPU system with one GPU is effectively CPU:7, which is locked out on most projects (because it doesn't work well). CPU:6 is the correct solution for now.
Fixing it is on the "pronto" list.
davidcoton
Unfortunately the developers' interpretation of "pronto" is not the same as the users'. Mainly I think because of the extreme amount of development in the queue, and limited resources, and not in any way a reflection on what the developers are doing. Also the problem is more complex than it appears, and any solution is going to need a shedload of testing (even then some clever user will, no doubt, find a perfectly reasonable scenario that breaks something).
Don't expect anything until it arrives.
Amen to that. (and I should have said that).davidcoton wrote:Don't expect anything until it arrives.
The problem, as I see it, is that even proteins which fail with, say CPU:7, will work correctly much of the time, so it's impossible to come up with a test scenario that can provide a Yes/No answer to "Is it fixed in V7.x.y?" Even Kasson (probably the world's expert on this GROMACS topic, hedged his bet by using the words "large primes" to imply that there were smaller primes that presumably work dependably but that the dividing line between large and small was nebulous.
I'll be sure to test 7 (and 5) when I get my hands on a proposed new version (whenever it arrives) that is supposed to fix it, knowing full-well that my testing will be inadequate.
You might solicit a list of projects which have been demonstrated to fail on 7 (and on 5?) but no doubt you'll get feedback from somebody that they successfully completed R,C,G on project P with CPU:K
Henry Minute
I too am having this problem but only on one computer of the two on my network. Until recently both were working as expected, both with default settings. I then had to reinstall the OS and software on one machine and since then the reinstated machine has exhibited this problem
07:23:23:WU00:FS00:Connecting to 171.64.65.35:80
07:23:24:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:23:24:ERROR:WU00:FS00:Exception: Could not get an assignment
07:34:28:WU00:FS00:Connecting to 171.67.108.45:8080
07:34:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
Having read through this thread I have changed the configuration from -1 to 6 (even though the other machine is working OK on -1) So far things are not looking good. No download percentage showing although no errors in the log, yet.
**** Update ****
Success! It seems that the change worked, although I am mystified as to why one machine works with the defaults and the other doesn't.
**** Update ****
davidcoton
Welcome to the Forum!
Could you post the log from the machine that worked at default? Either the hardware is different, or one just happened to get an assignment that worked.
When you post a log, use the Full Editor and then use Code tags so it looks nice!
