Project 13107 stuck at 0.00%, no log message
slapdashbr
Post by slapdashbr »
Hi,
I left my computer running F@H while I was gone for the weekend and upon returning I see my GPU is running at 100% load, but the temperature is very low, and the progress bar for the current GPU unit is at 0.00% and apparently not working. There are no error messages in the log, in fact there is nothing in the log at all besides updates on the CPU folding (which has continued without a hitch). I'm running an R9 Nano with the latest (non-beta) drivers from AMD. Can anyone help me troubleshoot what's going on with this? The GPU work unit that started before I left finished with no errors and at about the speed it should run on my GPU (roughly 330k ppd).
16:04:14:WU00:FS01:0xa4:Completed 4000000 out of 5000000 steps  (80%)
16:05:39:WU02:FS00:0x21:Completed 2475000 out of 2500000 steps (99%)
16:05:40:WU01:FS00:Connecting to 171.67.108.45:80
16:05:41:WU01:FS00:Assigned to work server 171.67.108.144
16:05:41:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Fiji XT [Radeon R9 Fury X] from 171.67.108.144
16:05:41:WU01:FS00:Connecting to 171.67.108.144:8080
16:05:54:WU01:FS00:Downloading 8.26MiB
16:05:57:WU01:FS00:Download complete
16:05:57:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13107 run:1 clone:3 gen:44 core:0x21 unit:0x00000017ab436c90571fa38435403c15
16:06:31:WU00:FS01:0xa4:Completed 4050000 out of 5000000 steps  (81%)
16:08:49:WU00:FS01:0xa4:Completed 4100000 out of 5000000 steps  (82%)
16:10:10:WU02:FS00:0x21:Completed 2500000 out of 2500000 steps (100%)
16:10:14:WU02:FS00:0x21:Saving result file logfile_01.txt
16:10:14:WU02:FS00:0x21:Saving result file checkpointState.xml
16:10:14:WU02:FS00:0x21:Saving result file checkpt.crc
16:10:14:WU02:FS00:0x21:Saving result file log.txt
16:10:14:WU02:FS00:0x21:Saving result file positions.xtc
16:10:14:WU02:FS00:0x21:Folding@home Core Shutdown: FINISHED_UNIT
16:10:15:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:10:15:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9205 run:31 clone:6 gen:0 core:0x21 unit:0x00000005664f2dd056fb26ae3ab10b00
16:10:15:WU02:FS00:Uploading 37.95MiB to 171.64.65.104
16:10:15:WU02:FS00:Connecting to 171.64.65.104:8080
16:10:15:WU01:FS00:Starting
16:10:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ben/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 5568 -checkpoint 15 -gpu 0 -gpu-vendor ati
16:10:15:WU01:FS00:Started FahCore on PID 5392
16:10:15:WU01:FS00:Core PID:6856
16:10:15:WU01:FS00:FahCore 0x21 started
16:10:15:WU01:FS00:0x21:*********************** Log Started 2016-06-03T16:10:15Z ***********************
16:10:15:WU01:FS00:0x21:Project: 13107 (Run 1, Clone 3, Gen 44)
16:10:15:WU01:FS00:0x21:Unit: 0x00000017ab436c90571fa38435403c15
16:10:15:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
16:10:15:WU01:FS00:0x21:Machine: 0
16:10:15:WU01:FS00:0x21:Reading tar file core.xml
16:10:15:WU01:FS00:0x21:Reading tar file integrator.xml
16:10:15:WU01:FS00:0x21:Reading tar file state.xml
16:10:16:WU01:FS00:0x21:Reading tar file system.xml
16:10:17:WU01:FS00:0x21:Digital signatures verified
16:10:17:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
16:10:17:WU01:FS00:0x21:Version 0.0.17
16:10:21:WU02:FS00:Upload 8.56%
16:10:27:WU02:FS00:Upload 20.26%
16:10:33:WU02:FS00:Upload 31.95%
16:10:39:WU02:FS00:Upload 43.65%
16:10:45:WU02:FS00:Upload 55.34%
16:10:51:WU02:FS00:Upload 67.20%
16:10:57:WU02:FS00:Upload 78.89%
16:11:03:WU02:FS00:Upload 90.59%
16:11:07:WU00:FS01:0xa4:Completed 4150000 out of 5000000 steps  (83%)
16:11:09:WU02:FS00:Upload complete
16:11:09:WU02:FS00:Server responded WORK_ACK (400)
16:11:09:WU02:FS00:Final credit estimate, 169360.00 points
16:11:09:WU02:FS00:Cleaning up
16:13:24:WU00:FS01:0xa4:Completed 4200000 out of 5000000 steps  (84%)
There is not a single line after than for 3 more days about the GPU work unit. It just does nothing. Any suggestions?
Mod edit: changed Quote tags to Code for log file
Re: Project 13107 stuck at 0.00%, no log message
The issues you mention usually are connected with a video driver reset. You can probably find a crash report for the video driver in the Windows event logs that correlates with the time of the last log entry for the GPU folding slot. You may be able to restart the GPU folding slot by restarting the client, or it may take a reboot.
As to the cause of the driver reset, that could be from overheating or from overclocking. There are some other causes, they may have left traces in the event log.
slapdashbr
Nope. Not a thing in event viewer. Rebooted, the work unit started right away. Inexplicable as far as I can tell.
