From NaCl:
Warning: Unexpected response to AS assignment request: error,No appropriate assignment
The browser shows: 171.67.108.158 refused to connect.
Wed Mar 16 11:20:16 PDT 2016 171.67.108.158 vspd4 - - standby Not Accept 0.36
WS 171.67.108.158 (Was: NaCl Server)
mattifolder
Re: NaCl. Assignment Server
I had a project for normal CPU-SMP-Client under Linux from this server, no upload since 18:45 UTC.
What is the meaning of "standby" at the server stats page (http://fah-web.stanford.edu/pybeta/serverstat.html) ?
Is it sleeping ?
18:46:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9035 run:163 clone:0 gen:111 core:0xa4 unit:0x00000078ab436c9e56982ecb94a7020c
18:46:26:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
18:46:26:WU00:FS00:Connecting to 171.67.108.158:8080
18:46:26:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:46:26:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.158:80: Connection refused
18:47:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9035 run:163 clone:0 gen:111 core:0xa4 unit:0x00000078ab436c9e56982ecb94a7020c
18:47:26:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
18:47:26:WU00:FS00:Connecting to 171.67.108.158:8080
18:47:26:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:47:27:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.158:80: Connection refused
18:49:04:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9035 run:163 clone:0 gen:111 core:0xa4 unit:0x00000078ab436c9e56982ecb94a7020c
18:49:04:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
18:49:04:WU00:FS00:Connecting to 171.67.108.158:8080
18:49:04:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:49:04:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.158:80: Connection refused
18:51:41:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9035 run:163 clone:0 gen:111 core:0xa4 unit:0x00000078ab436c9e56982ecb94a7020c
18:51:41:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
18:51:41:WU00:FS00:Connecting to 171.67.108.158:8080
18:51:41:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:51:41:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.158:80: Connection refused
18:55:55:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9035 run:163 clone:0 gen:111 core:0xa4 unit:0x00000078ab436c9e56982ecb94a7020c
18:55:55:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
18:55:55:WU00:FS00:Connecting to 171.67.108.158:8080
18:55:55:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:55:56:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.158:80: Connection refusedCode: Select all
33 171.67.108.158 vspd4 - standby Not Accept 0.06 0 0 -1 0 0 0 0 0 1 0 0 Re: WS 171.67.108.158 (Was: NaCl Server)
Standby means the server is intentionally off-line for an indefinite period. (Somebody thought it wasn't currently needed.)
It often happens when the server is being retasked with a new version of server code and a new group of projects.
Since it was down for about 4 hours, the server code was probably being rebuilt.
It now reports that it's running Server V9.0.6
(Serverstat is not making all its normal periodic reports.)
The server should be back up now. A WU that was waiting to upload on one of my systems has been accepted. The server status page has also updated the status to accepting.
Another reason for the WS to be down was that a new beta project has been released to run from there. That usually takes a while to configure.
mattifolder
Ok, other business server do things online. Or when active work is finished.
In this case, I'm sure that the server code (and probably the OS, too) were overdue for an upgrade, and things like that don't happen while projects are on-line. The former code was stable for many years but didn't support a number of newer features.
Since all servers eventually need to be within a reasonable range older versions, there comes a time when the upgrade must be done without actually forcing the active project(s) to be terminated.
I have had 2 WU's that were successfully uploaded to the subject server today, but no credit was issued. The problem WU's are:
Project: 9040 (Run 610, Clone 1, Gen 771)
Project: 9033 (Run 462, Clone 0, Gen 869)
