I can't finish my WU before the deadline
Perrygast
Post by Perrygast »
Hi everybody. Yesterday, I got a new WU for my GPU with a deadline of 9 days. However, it would take around 7 days for my GPU to complete it. Because I can't let my pc run in the night, it's impossible to finish this WU before the deadline. I think it's useless to let it run the next 8 days, because I know I can't finish it. What should I do now?
(As you can see, I added a screenshot)
Re: I can't finish my WU before the deadline
I do not think you will succeed at any GPU WUs if you do not run 24/7.
while most of the info we would need is clipped off the screenshot, a GK104 might well be a GTX670 card
bollix47
Post by bollix47 »
Welcome to the folding@home support forum Perrygast!
artoar_11 brings up a very good point in his post below mine ... always give the estimates time to settle by waiting a few percentages. If that doesn't change your opinion then carry on with my post. :ewink:
I'm fairly confident that your GTX 760 should be able to finish any of the current work units even though it is not running at night. I have a 660ti and although it's running 24/7 it would still finish on time if it were not running at night. My 660ti is averaging around 70,000 PPD. If it wasn't running at night I would expect it to still get more than the 11,666 that your screenshot is showing which leads me to believe the drivers might be the problem.
Two questions:
1. What drivers are you using? The later drivers are known to result in reduced performance on your model of GPU. I'm using 304.131 ... try a driver around that vintage if possible.
2. How many hours a day would you say your GPU is folding?
Also, there is a setting on the Config > Advanced page for Folding Core Priority ... you could try changing that from the default to Slightly higher.
To answer your question a safe way to remove a work unit is to right-click on the slot in FAHControl (aka Advanced Control) and select Pause, then go to Config and Slots ... highlight the slot (gpu in this case) and select Remove, OK and Save ... the Client should send a message back to the server that the work unit has been dumped and perform the necessary adjustments to it's status so that it will be assigned again. Dumping is not something we usually recommend but there are times when it can't be avoided. Personally, I don't think this is one of those times.
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
I'm sure the problem is another. It often happens when the client receive WU from some project for the first time. For the first 4-6% the client shows increased execution time.
My GTX 650Ti performs this project for ~27h (24/7).
Perrygast
Post by Perrygast »
Thanks for your answers!
I came back after a couple of hours, and the problem is solved: like artoar-11 said, the execution time was increased in the beginning. At the moment, my GPU already did 25% of the WU, and the expected execution time is now 12 hours.
The next time I see a very big execution time, I know it will probably decrease after the first few percent. And when it would be really necessary, I know at least how to remove a workunit.
Oh, and sorry for the possible English errors, I'm not a native speaker ;)
artoar_11
Post by artoar_11 »
Perrygast wrote:.......
We are in the same boat :)
