I want to run both my desktops F@H 24/7 but I fear a fire may break out. The tower w/ Gtx 980 stays under 66C both CPU/GPU but the other tower w/ Intel i7 & Gtx 780Ti probably has broken sensors because it's always saying CPU is at 85C and the GPU's 74C. I put my hand on the case and vents and feels warm but not scorching hot. The vent from the 780 video card is where most of the heat is.
PSU:
CORSAIR TX Series CMPSU-650TX 650W (6 years old)
Sentey® Power Supply 750 Watts (5 Months old)
Both 80 Plus Bronze PSU's so I'm hoping they're well built with thermal fail-safes.
I run "medium" on the client. If a fire were to start, I would think the PSU or that 780Ti would be the culprit. Anyone here been risking it successfully at 74C-85C for years?
