171.67.108.45 / 171.67.108.204 (AS)
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Post by billford »
Been getting the following from my clients since about 03:00Z:
09:39:11:WU00:FS01:0x18:Completed 2500000 out of 2500000 steps (100%)
09:39:11:WU01:FS01:Connecting to 171.67.108.45:80
09:39:12:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
09:39:12:WU01:FS01:Connecting to 171.67.108.204:80
then everything proceeds as normal.
Using a browser to connect to the server shows no error.
DutchForce
Re: 171.67.108.45 (AS)
Post by DutchForce »
The same here... and I also got one message from AS 171.67.108.204.
08:32:22:WU02:FS00:Connecting to 171.67.108.45:80
08:32:23:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:80': 10001: Server responded:
08:32:23:WU02:FS00:Connecting to 171.67.108.204:80
08:32:23:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': 10001: Server responded:
08:32:23:ERROR:WU02:FS00:Exception: Could not get an assignment
08:32:23:WU02:FS00:Connecting to 171.67.108.45:80
08:32:24:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:80': 10001: Server responded:
08:32:24:WU02:FS00:Connecting to 171.67.108.204:80
08:32:25:WU02:FS00:Assigned to work server 140.163.4.235
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
Since posting the OP I've also had a single error from 171.67.108.204,but (so far!) just the one.
Nicolas_orleans
Post by Nicolas_orleans »
Hi guys
It has been a long time
Just to mention the error from 2 weeks ago is back today on this server
******************************* Date: 2015-11-28 *******************************
******************************* Date: 2015-11-29 *******************************
10:25:09:WU02:FS00:Connecting to 171.67.108.45:80
10:25:10:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
10:25:10:WU02:FS00:Connecting to 171.67.108.204:80
10:25:11:WU02:FS00:Assigned to work server 140.163.4.233
10:25:11:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GK104 [GeForce GTX 770] from 140.163.4.233
10:25:11:WU02:FS00:Connecting to 140.163.4.233:8080
10:25:12:WU02:FS00:Downloading 4.94MiB
10:25:17:WU02:FS00:Download complete
10:25:17:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10469 run:0 clone:420 gen:194 core:0x17 unit:0x00000137538b3db9538f4395c0535fd1
10:25:41:WU02:FS00:Starting
10:25:41:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 1059 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
10:25:41:WU02:FS00:Started FahCore on PID 4639
10:25:41:WU02:FS00:Core PID:4643
10:25:41:WU02:FS00:FahCore 0x17 started
10:25:42:WU02:FS00:0x17:*********************** Log Started 2015-11-29T10:25:42Z ***********************
10:25:42:WU02:FS00:0x17:Project: 10469 (Run 0, Clone 420, Gen 194)
10:25:42:WU02:FS00:0x17:Unit: 0x00000137538b3db9538f4395c0535fd1
10:25:42:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
10:25:42:WU02:FS00:0x17:Machine: 0
10:25:42:WU02:FS00:0x17:Reading tar file state.xml
10:25:43:WU02:FS00:0x17:Reading tar file system.xml
10:25:44:WU02:FS00:0x17:Reading tar file integrator.xml
10:25:44:WU02:FS00:0x17:Reading tar file core.xml
10:25:44:WU02:FS00:0x17:Digital signatures verified
10:29:03:WU02:FS00:0x17:Completed 0 out of 5000000 steps (0%)
AORUS Elite X AX B650E- Ryzen 9 9950X - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 580.95
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 580.95
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
Checking logs for the last day or so- confirmed:
01:34:41:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
08:46:30:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
Assignments obtained from backup AS with no issues.
As long as it is a single occurrence, you do not need to keep reporting these. The problem is known, and for the time being there is a restart of the AS set up to recover from this error and have it return to assigning WU's.
Do report if this keeps happening repeatedly over a short period of time. A manual intervention may be required then.
AJMSmith
Post by AJMSmith »
It appears that the server is in trouble again ...
18:04:52:WU02:FS00:Connecting to 171.67.108.45:8080
18:04:53:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:04:53:WU02:FS00:Connecting to 171.67.108.204:80
18:04:54:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
18:04:54:ERROR:WU02:FS00:Exception: Could not get an assignment
23:25:18:WU02:FS00:Connecting to 171.67.108.45:8080
23:25:19:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:25:19:WU02:FS00:Connecting to 171.67.108.204:80
23:25:20:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:25:20:ERROR:WU02:FS00:Exception: Could not get an assignment
No, this is not an example of the AS being in trouble, no HTTP_INTERNAL_SERVER_ERROR messages. What is happening is that the AS's are not finding any Work Servers with WU's appropriate for your client setup, they then can not connect you to a WS to be assigned a WU. The wording is not the clearest, but that is the meaning of this series of messages.
If you would post the first 100 or so lines of your log file, that would give the information needed to determine what your configuration is and what type of WU's are unavailable. Or, if you used to only get assignments from 171.64.65.124, that WS is offline due to issues reported elsewhere.
AJMSmith
Post by AJMSmith »
Work units were processed "normally" until about 18:00 yesterday ... since then nothing has been available for the CPU.
*********************** Log Started 2016-01-02T22:17:24Z ***********************
22:17:24:************************* Folding@home Client *************************
22:17:24:      Website: http://folding.stanford.edu/
22:17:24:    Copyright: (c) 2009-2014 Stanford University
22:17:24:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:17:24:         Args:
22:17:24:       Config: C:/ProgramData/FAHClient/config.xml
22:17:24:******************************** Build ********************************
22:17:24:      Version: 7.4.4
22:17:24:         Date: Mar 4 2014
22:17:24:         Time: 20:26:54
22:17:24:      SVN Rev: 4130
22:17:24:       Branch: fah/trunk/client
22:17:24:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:17:24:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:17:24:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:17:24:     Platform: win32 XP
22:17:24:         Bits: 32
22:17:24:         Mode: Release
22:17:24:******************************* System ********************************
22:17:24:          CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
22:17:24:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:17:24:         CPUs: 8
22:17:24:       Memory: 7.95GiB
22:17:24:  Free Memory: 6.41GiB
22:17:24:      Threads: WINDOWS_THREADS
22:17:24:   OS Version: 6.2
22:17:24:  Has Battery: false
22:17:24:   On Battery: false
22:17:24:   UTC Offset: 0
22:17:24:          PID: 764
22:17:24:          CWD: C:/ProgramData/FAHClient
22:17:24:           OS: Windows 10 Home
22:17:24:      OS Arch: AMD64
22:17:24:         GPUs: 1
22:17:24:        GPU 0: NVIDIA:4 GM107 [GeForce GTX 745]
22:17:24:         CUDA: 5.0
22:17:24:  CUDA Driver: 7050
22:17:24:Win32 Service: false
22:17:24:***********************************************************************
22:17:24:<config>
22:17:24:  <service-description v='Folding@home Client'/>
22:17:24:  <service-restart v='true'/>
22:17:24:  <service-restart-delay v='5000'/>
22:17:24:
22:17:24:  <!-- Client Control -->
22:17:24:  <client-threads v='6'/>
22:17:24:  <cycle-rate v='4'/>
22:17:24:  <cycles v='-1'/>
22:17:24:  <data-directory v='.'/>
22:17:24:  <disable-sleep-when-active v='true'/>
22:17:24:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
22:17:24:  <exit-when-done v='false'/>
22:17:24:  <fold-anon v='false'/>
22:17:24:  <open-web-control v='false'/>
22:17:24:
22:17:24:  <!-- Configuration -->
22:17:24:  <config-rotate v='true'/>
22:17:24:  <config-rotate-dir v='configs'/>
22:17:24:  <config-rotate-max v='16'/>
22:17:24:
22:17:24:  <!-- Debugging -->
22:17:24:  <assignment-servers>
22:17:24:    assign3.stanford.edu:8080 assign4.stanford.edu:80
22:17:24:  </assignment-servers>
22:17:24:  <auth-as v='true'/>
22:17:24:  <capture-directory v='capture'/>
22:17:24:  <capture-on-error v='false'/>
22:17:24:  <capture-packets v='false'/>
22:17:24:  <capture-requests v='false'/>
22:17:24:  <capture-responses v='false'/>
22:17:24:  <capture-sockets v='false'/>
22:17:24:  <core-exec v='FahCore_$type'/>
22:17:24:  <core-wrapper-exec v='FAHCoreWrapper'/>
22:17:24:  <debug-sockets v='false'/>
22:17:24:  <exception-locations v='true'/>
22:17:24:  <gpu-assignment-servers>
22:17:24:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
22:17:24:  </gpu-assignment-servers>
22:17:24:  <stack-traces v='false'/>
22:17:24:
22:17:24:  <!-- Error Handling -->
22:17:24:  <max-slot-errors v='10'/>
22:17:24:  <max-unit-errors v='5'/>
22:17:24:
22:17:24:  <!-- Folding Core -->
22:17:24:  <checkpoint v='15'/>
22:17:24:  <core-dir v='cores'/>
22:17:24:  <core-priority v='idle'/>
22:17:24:  <cpu-affinity v='false'/>
22:17:24:  <cpu-usage v='100'/>
22:17:24:  <gpu-usage v='100'/>
22:17:24:  <no-assembly v='false'/>
22:17:24:
22:17:24:  <!-- Folding Slot Configuration -->
22:17:24:  <cause v='ANY'/>
22:17:24:  <client-subtype v='STDCLI'/>
22:17:24:  <client-type v='normal'/>
22:17:24:  <cpu-species v='X86_PENTIUM_II'/>
22:17:24:  <cpu-type v='AMD64'/>
22:17:24:  <cpus v='-1'/>
22:17:24:  <gpu v='true'/>
22:17:24:  <max-packet-size v='normal'/>
22:17:24:  <os-species v='UNKNOWN'/>
22:17:24:  <os-type v='WIN32'/>
22:17:24:  <project-key v='0'/>
22:17:24:  <smp v='true'/>
22:17:24:
22:17:24:  <!-- GUI -->
22:17:24:  <gui-enabled v='true'/>
22:17:24:
22:17:24:  <!-- HTTP Server -->
22:17:24:  <allow v='127.0.0.1 192.168.1.0/24'/>
22:17:24:  <connection-timeout v='60'/>
22:17:24:  <deny v='0/0'/>
22:17:24:  <http-addresses v='0:7396'/>
22:17:24:  <https-addresses v=''/>
22:17:24:  <max-connect-time v='900'/>
22:17:24:  <max-connections v='800'/>
22:17:24:  <max-request-length v='52428800'/>
22:17:24:  <min-connect-time v='300'/>
22:17:24:  <threads v='8'/>
22:17:24:
22:17:24:  <!-- Logging -->
22:17:24:  <log v='log.txt'/>
22:17:24:  <log-color v='false'/>
22:17:24:  <log-crlf v='true'/>
22:17:24:  <log-date v='false'/>
22:17:24:  <log-date-periodically v='21600'/>
22:17:24:  <log-debug v='true'/>
22:17:24:  <log-domain v='false'/>
22:17:24:  <log-header v='true'/>
22:17:24:  <log-level v='true'/>
22:17:24:  <log-no-info-header v='true'/>
22:17:24:  <log-redirect v='false'/>
22:17:24:  <log-rotate v='true'/>
22:17:24:  <log-rotate-dir v='logs'/>
22:17:24:  <log-rotate-max v='16'/>
22:17:24:  <log-short-level v='false'/>
22:17:24:  <log-simple-domains v='true'/>
22:17:24:  <log-thread-id v='false'/>
22:17:24:  <log-thread-prefix v='true'/>
22:17:24:  <log-time v='true'/>
22:17:24:  <log-to-screen v='true'/>
22:17:24:  <log-truncate v='false'/>
22:17:24:  <verbosity v='5'/>
22:17:24:
22:17:24:  <!-- Network -->
22:17:24:  <proxy v=':8080'/>
22:17:24:  <proxy-enable v='false'/>
22:17:24:  <proxy-pass v=''/>
22:17:24:  <proxy-user v=''/>
22:17:24:
22:17:24:  <!-- Process Control -->
22:17:24:  <child v='false'/>
22:17:24:  <daemon v='false'/>
22:17:24:  <pid v='false'/>
22:17:24:  <pid-file v='Folding@home Client.pid'/>
22:17:24:  <respawn v='false'/>
22:17:24:  <service v='false'/>
22:17:24:
22:17:24:  <!-- Remote Command Server -->
22:17:24:  <command-address v='0.0.0.0'/>
22:17:24:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/28'/>
22:17:24:  <command-deny-no-pass v='0/0'/>
22:17:24:  <command-enable v='true'/>
22:17:24:  <command-port v='36330'/>
22:17:24:
22:17:24:  <!-- Slot Control -->
22:17:24:  <idle v='false'/>
22:17:24:  <max-shutdown-wait v='60'/>
22:17:24:  <pause-on-battery v='true'/>
22:17:24:  <pause-on-start v='false'/>
22:17:24:  <paused v='false'/>
22:17:24:  <power v='FULL'/>
22:17:24:
22:17:24:  <!-- User Information -->
22:17:24:  <machine-id v='0'/>
22:17:24:  <passkey v='********************************'/>
22:17:24:  <team v='35947'/>
22:17:24:  <user v='Allan_Smith'/>
22:17:24:
22:17:24:  <!-- Web Server -->
22:17:24:  <web-allow v='127.0.0.1'/>
22:17:24:  <web-deny v='0/0'/>
22:17:24:  <web-enable v='true'/>
22:17:24:
22:17:24:  <!-- Web Server Sessions -->
22:17:24:  <session-cookie v='sid'/>
22:17:24:  <session-lifetime v='86400'/>
22:17:24:  <session-timeout v='3600'/>
22:17:24:
22:17:24:  <!-- Work Unit Control -->
22:17:24:  <dump-after-deadline v='true'/>
22:17:24:  <max-queue v='16'/>
22:17:24:  <max-units v='0'/>
22:17:24:  <next-unit-percentage v='99'/>
22:17:24:  <stall-detection-enabled v='false'/>
22:17:24:  <stall-percent v='5'/>
22:17:24:  <stall-timeout v='1800'/>
22:17:24:
22:17:24:  <!-- Folding Slots -->
22:17:24:  <slot id='0' type='CPU'/>
22:17:24:  <slot id='1' type='GPU'/>
22:17:24:</config>
22:17:24:Trying to access database...
22:17:24:Successfully acquired database lock
22:17:24:Enabled folding slot 00: READY cpu:7
22:17:24:Enabled folding slot 01: READY gpu:0:GM107 [GeForce GTX 745]
22:17:25:Started thread 6 on PID 764
22:17:25:Started thread 5 on PID 764
22:17:25:Started thread 7 on PID 764
22:17:25:Started thread 9 on PID 764
22:17:25:Started thread 8 on PID 764
22:17:25:Started thread 4 on PID 764
22:17:25:WU01:FS01:Starting
22:17:25:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 764 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:17:25:WU01:FS01:Started FahCore on PID 2916
22:17:25:Started thread 10 on PID 764
22:17:26:WU01:FS01:Core PID:2728
22:17:26:WU01:FS01:FahCore 0x17 started
22:17:26:WU00:FS00:Starting
22:17:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 764 -checkpoint 15 -np 7
22:17:26:WU00:FS00:Started FahCore on PID 2656
22:17:26:Started thread 11 on PID 764
22:17:26:WU00:FS00:Core PID:2620
22:17:26:WU00:FS00:FahCore 0xa4 started
22:17:27:WU00:FS00:0xa4:
Try setting the CPU slot to use 6 threads instead of the default of 7. There are CPU jobs that will assign to 7 threads, but with the one WS down they may be less available due to the competition for the remaining projects.
Also, setting the logging verbosity to 5 serves no purpose and actually makes troubleshooting much more difficult. Please return the setting to the default of 3.
markfw
Post by markfw »
Getting the below, had problems on all of my servers, but this 24 core server is the last to still have a problem. I set the CPU to 22 cores to work:
*********************** Log Started 2016-01-11T04:03:22Z ***********************
04:03:22:************************* Folding@home Client *************************
04:03:22:    Website: http://folding.stanford.edu/
04:03:22:  Copyright: (c) 2009-2014 Stanford University
04:03:22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:03:22:       Args: --child --lifeline 1356 /etc/fahclient/config.xml --run-as
04:03:22:             fahclient --pid-file=/var/run/fahclient.pid --daemon
04:03:22:     Config: /etc/fahclient/config.xml
04:03:22:******************************** Build ********************************
04:03:22:    Version: 7.4.4
04:03:22:       Date: Mar 4 2014
04:03:22:       Time: 12:02:38
04:03:22:    SVN Rev: 4130
04:03:22:     Branch: fah/trunk/client
04:03:22:   Compiler: GNU 4.4.7
04:03:22:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
04:03:22:             -fno-unsafe-math-optimizations -msse2
04:03:22:   Platform: linux2 3.2.0-1-amd64
04:03:22:       Bits: 64
04:03:22:       Mode: Release
04:03:22:******************************* System ********************************
04:03:22:        CPU: Intel(R) Xeon(R) CPU L5639 @ 2.13GHz
04:03:22:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
04:03:22:       CPUs: 24
04:03:22:     Memory: 11.73GiB
04:03:22:Free Memory: 11.28GiB
04:03:22:    Threads: POSIX_THREADS
04:03:22: OS Version: 3.13
04:03:22:Has Battery: false
04:03:22: On Battery: false
04:03:22: UTC Offset: -8
04:03:22:        PID: 1358
04:03:22:        CWD: /var/lib/fahclient
04:03:22:         OS: Linux 3.13.0-46-generic x86_64
04:03:22:    OS Arch: AMD64
04:03:22:       GPUs: 1
04:03:22:      GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
04:03:22:       CUDA: 5.2
04:03:22:CUDA Driver: 7000
04:03:22:***********************************************************************
04:03:22:<config>
04:03:22:  <!-- Client Control -->
04:03:22:  <fold-anon v='true'/>
04:03:22:
04:03:22:  <!-- HTTP Server -->
04:03:22:  <allow v='127.0.0.1,192.168.1.2-192.168.1.255'/>
04:03:22:  <deny v='0.0.0.0/0'/>
04:03:22:
04:03:22:  <!-- Network -->
04:03:22:  <proxy v=':8080'/>
04:03:22:
04:03:22:  <!-- Remote Command Server -->
04:03:22:  <command-allow-no-pass v='127.0.0.1,192.168.1.2-192.168.1.255'/>
04:03:22:  <command-deny-no-pass v='0.0.0.0/0'/>
04:03:22:
04:03:22:  <!-- User Information -->
04:03:22:  <passkey v='********************************'/>
04:03:22:  <team v='198'/>
04:03:22:  <user v='Mark_F_Williams'/>
04:03:22:
04:03:22:  <!-- Folding Slots -->
04:03:22:  <slot id='1' type='CPU'>
04:03:22:    <client-type v='bigadv'/>
04:03:22:    <cpus v='22'/>
04:03:22:    <max-packet-size v='big'/>
04:03:22:    <next-unit-percentage v='100'/>
04:03:22:  </slot>
04:03:22:  <slot id='0' type='GPU'/>
04:03:22:</config>
04:03:22:Switching to user fahclient
04:03:22:Trying to access database...
04:03:22:Successfully acquired database lock
04:03:22:Enabled folding slot 01: READY cpu:22
04:03:22:Enabled folding slot 00: READY gpu:0:GM204 [GeForce GTX 980]
\x1b[93m04:03:22:WARNING:WU00:FS01:Exception: Could not get IP address for assign3.stanford.edu: No address associated with hostname\x1b[0m
\x1b[91m04:03:22:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
\x1b[93m04:03:22:WARNING:WU01:FS00:Exception: Could not get IP address for assign-GPU.stanford.edu: No address associated with hostname\x1b[0m
\x1b[91m04:03:22:ERROR:WU01:FS00:Exception: Could not get an assignment\x1b[0m
\x1b[93m04:03:23:WARNING:WU00:FS01:Exception: Could not get IP address for assign3.stanford.edu: No address associated with hostname\x1b[0m
\x1b[91m04:03:23:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
\x1b[93m04:03:23:WARNING:WU01:FS00:Exception: Could not get IP address for assign-GPU.stanford.edu: No address associated with hostname\x1b[0m
\x1b[91m04:03:23:ERROR:WU01:FS00:Exception: Could not get an assignment\x1b[0m
04:04:24:WU00:FS01:Connecting to 171.67.108.45:8080
04:04:25:WU01:FS00:Connecting to 171.67.108.45:80
\x1b[93m04:04:25:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
04:04:25:WU00:FS01:Connecting to 171.67.108.204:80
04:04:25:WU01:FS00:Assigned to work server 140.163.4.241
04:04:25:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 140.163.4.241
04:04:25:WU01:FS00:Connecting to 140.163.4.241:8080
\x1b[93m04:04:26:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m04:04:26:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
\x1b[91m04:04:27:ERROR:WU01:FS00:Exception: Server did not assign work unit\x1b[0m
04:06:01:WU00:FS01:Connecting to 171.67.108.45:8080
04:06:02:WU01:FS00:Connecting to 171.67.108.45:80
\x1b[93m04:06:03:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
04:06:03:WU00:FS01:Connecting to 171.67.108.204:80
\x1b[93m04:06:03:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m04:06:03:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
04:06:04:WU01:FS00:Assigned to work server 140.163.4.244
04:06:04:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM204 [GeForce GTX 980] from 140.163.4.244
04:06:04:WU01:FS00:Connecting to 140.163.4.244:8080
04:06:05:WU01:FS00:Downloading 2.54MiB
04:06:11:WU01:FS00:Download 41.79%
04:06:17:WU01:FS00:Download 59.00%
04:06:23:WU01:FS00:Download 93.41%
04:06:23:WU01:FS00:Download complete
04:06:23:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10490 run:364 clone:0 gen:38 core:0x18 unit:0x0000002c8ca304f45537e915c0e574d9
04:06:23:WU01:FS00:Starting
04:06:23:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 1358 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:06:23:WU01:FS00:Started FahCore on PID 3081
04:06:23:WU01:FS00:Core PID:3085
04:06:23:WU01:FS00:FahCore 0x18 started
04:06:24:WU01:FS00:0x18:*********************** Log Started 2016-01-11T04:06:24Z ***********************
04:06:24:WU01:FS00:0x18:Project: 10490 (Run 364, Clone 0, Gen 38)
04:06:24:WU01:FS00:0x18:Unit: 0x0000002c8ca304f45537e915c0e574d9
04:06:24:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
04:06:24:WU01:FS00:0x18:Machine: 0
04:06:24:WU01:FS00:0x18:Reading tar file core.xml
04:06:24:WU01:FS00:0x18:Reading tar file system.xml
04:06:24:WU01:FS00:0x18:Reading tar file integrator.xml
04:06:24:WU01:FS00:0x18:Reading tar file state.xml
04:06:24:WU01:FS00:0x18:Digital signatures verified
04:06:24:WU01:FS00:0x18:Folding@home GPU core18
04:06:24:WU01:FS00:0x18:Version 0.0.4
04:06:37:WU01:FS00:0x18:Completed 0 out of 5000000 steps (0%)
04:06:37:WU01:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:08:37:WU00:FS01:Connecting to 171.67.108.45:8080
\x1b[93m04:08:37:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
04:08:37:WU00:FS01:Connecting to 171.67.108.204:80
\x1b[93m04:08:38:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m04:08:38:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
04:08:44:WU01:FS00:0x18:Completed 50000 out of 5000000 steps (1%)
04:10:48:WU01:FS00:0x18:Completed 100000 out of 5000000 steps (2%)
04:12:51:WU00:FS01:Connecting to 171.67.108.45:8080
\x1b[93m04:12:52:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
04:12:52:WU00:FS01:Connecting to 171.67.108.204:80
\x1b[93m04:12:52:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m04:12:52:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
04:12:55:WU01:FS00:0x18:Completed 150000 out of 5000000 steps (3%)
04:14:59:WU01:FS00:0x18:Completed 200000 out of 5000000 steps (4%)
04:17:03:WU01:FS00:0x18:Completed 250000 out of 5000000 steps (5%)
04:19:10:WU01:FS00:0x18:Completed 300000 out of 5000000 steps (6%)
04:19:43:WU00:FS01:Connecting to 171.67.108.45:8080
\x1b[93m04:19:43:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
04:19:43:WU00:FS01:Connecting to 171.67.108.204:80
\x1b[93m04:19:44:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m04:19:44:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
04:21:14:WU01:FS00:0x18:Completed 350000 out of 5000000 steps (7%)
04:23:22:WU01:FS00:0x18:Completed 400000 out of 5000000 steps (8%)
04:25:26:WU01:FS00:0x18:Completed 450000 out of 5000000 steps (9%)
04:27:30:WU01:FS00:0x18:Completed 500000 out of 5000000 steps (10%)
04:29:37:WU01:FS00:0x18:Completed 550000 out of 5000000 steps (11%)
04:30:49:WU00:FS01:Connecting to 171.67.108.45:8080
\x1b[93m04:30:49:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment\x1b[0m
04:30:49:WU00:FS01:Connecting to 171.67.108.204:80
\x1b[93m04:30:50:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment\x1b[0m
\x1b[91m04:30:50:ERROR:WU00:FS01:Exception: Could not get an assignment\x1b[0m
04:31:41:WU01:FS00:0x18:Completed 600000 out of 5000000 steps (12%)
04:33:48:WU01:FS00:0x18:Completed 650000 out of 5000000 steps (13%)
04:35:52:WU01:FS00:0x18:Completed 700000 out of 5000000 steps (14%)
04:37:56:WU01:FS00:0x18:Completed 750000 out of 5000000 steps (15%)
04:40:04:WU01:FS00:0x18:Completed 800000 out of 5000000 steps (16%)
04:42:07:WU01:FS00:0x18:Completed 850000 out of 5000000 steps (17%)
bollix47
Post by bollix47 »
@markfw
1. Remove bigadv from your cpu configuration ... the minimum # of cores required for bigadv is 24
2. Change cpu:22 to cpu:20 ... 22 is bad because, other than itself, it can only be divided by 2 and 11 ... 11 is a high prime number which could result in errors
If, after the above changes, you continue to have trouble getting work another option is to make two cpu slots and configure one with cpu:12 and the other with cpu:8 (cpu:10 should work but some projects blacklist 10 so using it may reduce your chances of getting work) ... the cpu:12 and cpu:8 configuration will have a good chance of getting work.
markfw
Post by markfw »
I just waited, all is fine now,55k for 22 cores.
There is no more bigadv, I know that.
TomJohnson
Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD.
Post by TomJohnson »
I have not been able to get a WU from this Server for three days
*********************** Log Started 2016-01-11T14:24:57Z ***********************
14:24:57:************************* Folding@home Client *************************
14:24:57:    Website: http://folding.stanford.edu/
14:24:57:  Copyright: (c) 2009-2014 Stanford University
14:24:57:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:24:57:       Args:
14:24:57:     Config: <none>
14:24:57:******************************** Build ********************************
14:24:57:    Version: 7.4.4
14:24:57:       Date: Mar 4 2014
14:24:57:       Time: 20:27:54
14:24:57:    SVN Rev: 4130
14:24:57:     Branch: fah/trunk/client
14:24:57:   Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
14:24:57:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
14:24:57:             -fno-unsafe-math-optimizations -msse3 -arch x86_64
14:24:57:             -mmacosx-version-min=10.6
14:24:57:   Platform: darwin 10.8.0
14:24:57:       Bits: 64
14:24:57:       Mode: Release
14:24:57:******************************* System ********************************
14:24:57:        CPU: Intel(R) Xeon(R) CPU X5675 @ 3.07GHz
14:24:57:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
14:24:57:       CPUs: 24
14:24:57:     Memory: 52.00GiB
14:24:57:Free Memory: 47.73GiB
14:24:57:    Threads: POSIX_THREADS
14:24:57: OS Version: 10.6
14:24:57:Has Battery: false
14:24:57: On Battery: false
14:24:57: UTC Offset: -8
14:24:57:        PID: 9620
14:24:57:        CWD: /Library/Application Support/FAHClient
14:24:57:         OS: Darwin 10.8.0 x86_64
14:24:57:    OS Arch: AMD64
14:24:57:       GPUs: 1
14:24:57:      GPU 0: ATI:4 Juniper [Radeon HD 5700 Series]
14:24:57:       CUDA: Not detected
14:24:57:***********************************************************************
14:24:57:<config>
14:24:57:  <!-- Folding Slots -->
14:24:57:</config>
14:24:57:Trying to access database...
14:24:57:Successfully acquired database lock
14:24:57:Enabled folding slot 00: PAUSED cpu:23 (not configured)
14:25:58:Saving configuration to config.xml
14:25:58:<config>
14:25:58:  <!-- Folding Slots -->
14:25:58:  <slot id='0' type='CPU'/>
14:25:58:</config>
14:25:59:Set client configured
14:25:59:WU00:FS00:Connecting to 171.67.108.45:8080
14:26:00:WU00:FS00:Connecting to 171.67.108.45:8080
14:26:02:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:26:02:WU00:FS00:Connecting to 171.67.108.204:80
14:26:03:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:26:03:ERROR:WU00:FS00:Exception: Could not get an assignment
14:26:03:WU00:FS00:Connecting to 171.67.108.45:8080
14:26:04:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:26:04:WU00:FS00:Connecting to 171.67.108.204:80
14:26:04:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:26:04:ERROR:WU00:FS00:Exception: Could not get an assignment
14:26:23:Saving configuration to config.xml
14:26:23:<config>
14:26:23:  <!-- Network -->
14:26:23:  <proxy v=':8080'/>
14:26:23:
14:26:23:  <!-- User Information -->
14:26:23:  <passkey v='********************************'/>
14:26:23:  <team v='1971'/>
14:26:23:  <user v='Tom_Johnson'/>
14:26:23:
14:26:23:  <!-- Folding Slots -->
14:26:23:  <slot id='0' type='CPU'/>
14:26:23:</config>
14:26:59:Saving configuration to config.xml
14:26:59:<config>
14:26:59:  <!-- Network -->
14:26:59:  <proxy v=':8080'/>
14:26:59:
14:26:59:  <!-- User Information -->
14:26:59:  <passkey v='********************************'/>
14:26:59:  <team v='1971'/>
14:26:59:  <user v='Tom_Johnson'/>
14:26:59:
14:26:59:  <!-- Folding Slots -->
14:26:59:  <slot id='0' type='CPU'/>
14:26:59:</config>
14:27:03:WU00:FS00:Connecting to 171.67.108.45:8080
14:27:03:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:27:03:WU00:FS00:Connecting to 171.67.108.204:80
14:27:04:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:27:04:ERROR:WU00:FS00:Exception: Could not get an assignment
14:28:40:WU00:FS00:Connecting to 171.67.108.45:8080
14:28:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:28:41:WU00:FS00:Connecting to 171.67.108.204:80
14:28:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:28:41:ERROR:WU00:FS00:Exception: Could not get an assignment
14:28:53:Saving configuration to config.xml
14:28:53:<config>
14:28:53:  <!-- Folding Core -->
14:28:53:  <checkpoint v='30'/>
14:28:53:
14:28:53:  <!-- Folding Slot Configuration -->
14:28:53:  <client-type v='advanced'/>
14:28:53:
14:28:53:  <!-- Network -->
14:28:53:  <proxy v=':8080'/>
14:28:53:
14:28:53:  <!-- Process Control -->
14:28:53:  <child v='true'/>
14:28:53:  <respawn v='true'/>
14:28:53:
14:28:53:  <!-- Slot Control -->
14:28:53:  <pause-on-battery v='false'/>
14:28:53:
14:28:53:  <!-- User Information -->
14:28:53:  <passkey v='********************************'/>
14:28:53:  <team v='1971'/>
14:28:53:  <user v='Tom_Johnson'/>
14:28:53:
14:28:53:  <!-- Folding Slots -->
14:28:53:  <slot id='0' type='CPU'/>
14:28:53:</config>
14:29:01:Saving configuration to config.xml
14:29:01:<config>
14:29:01:  <!-- Folding Core -->
14:29:01:  <checkpoint v='30'/>
14:29:01:
14:29:01:  <!-- Folding Slot Configuration -->
14:29:01:  <client-type v='advanced'/>
14:29:01:
14:29:01:  <!-- Network -->
14:29:01:  <proxy v=':8080'/>
14:29:01:
14:29:01:  <!-- Process Control -->
14:29:01:  <child v='true'/>
14:29:01:  <respawn v='true'/>
14:29:01:
14:29:01:  <!-- Slot Control -->
14:29:01:  <pause-on-battery v='false'/>
14:29:01:
14:29:01:  <!-- User Information -->
14:29:01:  <passkey v='********************************'/>
14:29:01:  <team v='1971'/>
14:29:01:  <user v='Tom_Johnson'/>
14:29:01:
14:29:01:  <!-- Folding Slots -->
14:29:01:  <slot id='0' type='CPU'/>
14:29:01:</config>
14:30:02:Saving configuration to config.xml
14:30:02:<config>
14:30:02:  <!-- Folding Core -->
14:30:02:  <checkpoint v='30'/>
14:30:02:
14:30:02:  <!-- Folding Slot Configuration -->
14:30:02:  <client-type v='advanced'/>
14:30:02:
14:30:02:  <!-- Network -->
14:30:02:  <proxy v=':8080'/>
14:30:02:
14:30:02:  <!-- Process Control -->
14:30:02:  <child v='true'/>
14:30:02:  <respawn v='true'/>
14:30:02:
14:30:02:  <!-- Slot Control -->
14:30:02:  <pause-on-battery v='false'/>
14:30:02:  <power v='full'/>
14:30:02:
14:30:02:  <!-- User Information -->
14:30:02:  <passkey v='********************************'/>
14:30:02:  <team v='1971'/>
14:30:02:  <user v='Tom_Johnson'/>
14:30:02:
14:30:02:  <!-- Folding Slots -->
14:30:02:  <slot id='0' type='CPU'/>
14:30:02:</config>
14:31:17:WU00:FS00:Connecting to 171.67.108.45:8080
14:31:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:31:18:WU00:FS00:Connecting to 171.67.108.204:80
14:31:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:31:18:ERROR:WU00:FS00:Exception: Could not get an assignment
14:31:22:FS00:Finishing
14:31:41:FS00:Paused
14:31:53:FS00:Unpaused
14:32:17:WU00:FS00:Connecting to 171.67.108.45:8080
14:32:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:32:18:WU00:FS00:Connecting to 171.67.108.204:80
14:32:18:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:32:18:ERROR:WU00:FS00:Exception: Could not get an assignment
14:33:55:WU00:FS00:Connecting to 171.67.108.45:8080
14:33:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:33:55:WU00:FS00:Connecting to 171.67.108.204:80
14:33:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:33:55:ERROR:WU00:FS00:Exception: Could not get an assignment
14:36:32:WU00:FS00:Connecting to 171.67.108.45:8080
14:36:32:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:36:32:WU00:FS00:Connecting to 171.67.108.204:80
14:36:33:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:36:33:ERROR:WU00:FS00:Exception: Could not get an assignment
14:40:46:WU00:FS00:Connecting to 171.67.108.45:8080
14:40:46:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:40:46:WU00:FS00:Connecting to 171.67.108.204:80
14:40:47:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:40:47:ERROR:WU00:FS00:Exception: Could not get an assignment
14:47:38:WU00:FS00:Connecting to 171.67.108.45:8080
14:47:38:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:47:38:WU00:FS00:Connecting to 171.67.108.204:80
14:47:38:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:47:38:ERROR:WU00:FS00:Exception: Could not get an assignment
14:58:43:WU00:FS00:Connecting to 171.67.108.45:8080
14:58:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:58:44:WU00:FS00:Connecting to 171.67.108.204:80
14:58:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:58:44:ERROR:WU00:FS00:Exception: Could not get an assignment
15:16:40:WU00:FS00:Connecting to 171.67.108.45:8080
15:16:40:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
15:16:40:WU00:FS00:Connecting to 171.67.108.204:80
15:16:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:16:41:ERROR:WU00:FS00:Exception: Could not get an assignment
15:45:42:WU00:FS00:Connecting to 171.67.108.45:8080
15:45:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
15:45:42:WU00:FS00:Connecting to 171.67.108.204:80
15:45:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:45:43:ERROR:WU00:FS00:Exception: Could not get an assignment
16:32:41:WU00:FS00:Connecting to 171.67.108.45:8080
16:32:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
16:32:41:WU00:FS00:Connecting to 171.67.108.204:80
16:32:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
16:32:41:ERROR:WU00:FS00:Exception: Could not get an assignment
17:48:42:WU00:FS00:Connecting to 171.67.108.45:8080
17:48:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
17:48:42:WU00:FS00:Connecting to 171.67.108.204:80
17:48:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
17:48:43:ERROR:WU00:FS00:Exception: Could not get an assignment
19:51:41:WU00:FS00:Connecting to 171.67.108.45:8080
19:51:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:51:42:WU00:FS00:Connecting to 171.67.108.204:80
19:51:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
19:51:42:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2016-01-11 *******************************
23:10:42:WU00:FS00:Connecting to 171.67.108.45:8080
23:10:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:10:42:WU00:FS00:Connecting to 171.67.108.204:80
23:10:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:10:42:ERROR:WU00:FS00:Exception: Could not get an assignment
23:47:01:FS00:Finishing
23:47:06:FS00:Paused
23:47:10:Saving configuration to config.xml
23:47:10:<config>
23:47:10:  <!-- Folding Core -->
23:47:10:  <checkpoint v='30'/>
23:47:10:
23:47:10:  <!-- Folding Slot Configuration -->
23:47:10:  <client-type v='advanced'/>
23:47:10:
23:47:10:  <!-- Network -->
23:47:10:  <proxy v=':8080'/>
23:47:10:
23:47:10:  <!-- Process Control -->
23:47:10:  <child v='true'/>
23:47:10:  <respawn v='true'/>
23:47:10:
23:47:10:  <!-- Slot Control -->
23:47:10:  <pause-on-battery v='false'/>
23:47:10:  <power v='full'/>
23:47:10:
23:47:10:  <!-- User Information -->
23:47:10:  <passkey v='********************************'/>
23:47:10:  <team v='1971'/>
23:47:10:  <user v='Tom_Johnson'/>
23:47:10:
23:47:10:  <!-- Folding Slots -->
23:47:10:  <slot id='0' type='CPU'>
23:47:10:    <paused v='true'/>
23:47:10:  </slot>
23:47:10:</config>
23:47:16:FS00:Unpaused
23:47:16:WU00:FS00:Connecting to 171.67.108.45:8080
23:47:17:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:47:17:WU00:FS00:Connecting to 171.67.108.204:80
23:47:17:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:47:17:ERROR:WU00:FS00:Exception: Could not get an assignment
23:48:11:Saving configuration to config.xml
23:48:11:<config>
23:48:11:  <!-- Folding Core -->
23:48:11:  <checkpoint v='30'/>
23:48:11:
23:48:11:  <!-- Folding Slot Configuration -->
23:48:11:  <client-type v='advanced'/>
23:48:11:
23:48:11:  <!-- Network -->
23:48:11:  <proxy v=':8080'/>
23:48:11:
23:48:11:  <!-- Process Control -->
23:48:11:  <child v='true'/>
23:48:11:  <respawn v='true'/>
23:48:11:
23:48:11:  <!-- Slot Control -->
23:48:11:  <pause-on-battery v='false'/>
23:48:11:  <power v='full'/>
23:48:11:
23:48:11:  <!-- User Information -->
23:48:11:  <passkey v='********************************'/>
23:48:11:  <team v='1971'/>
23:48:11:  <user v='Tom_Johnson'/>
23:48:11:
23:48:11:  <!-- Folding Slots -->
23:48:11:  <slot id='0' type='CPU'/>
23:48:11:</config>
23:48:53:WU00:FS00:Connecting to 171.67.108.45:8080
23:48:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:48:54:WU00:FS00:Connecting to 171.67.108.204:80
23:48:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
23:48:54:ERROR:WU00:FS00:Exception: Could not get an assignment
23:51:31:WU00:FS00:Connecting to 171.67.108.45:8080
23:51:31:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
You do not get WUs from an Assignment Server, you get an assignment to some Work Server that has Work for your system. The question is which work servers have work for your slot.
Looking back in your history, which project was last processed by that slot? Which Work Server downloaded that WU? What is the state of that WS or any other WS that might provide you with work?
The Assignment server can only assign you to a work server if it is operational and if it has WUs to be distributed and there's no easy way to figure out what WS that was except if it's in your history.
Cpu:22 is an awkward setting. The number of projects which can be processed by a CPU:22 slot is extremely small.
