Project: 10477 (Run 1, Clone 81, Gen 203) - Bad WU?
weirddan455
Post by weirddan455 »
I had another WU crash on me, this time a Core 18. It crashed less than an hour after starting and never completed a single % of work. Is this a bad WU or another problem on my end?
*********************** Log Started 2015-10-26T06:34:42Z ***********************
06:34:42:************************* Folding@home Client *************************
06:34:42:    Website: http://folding.stanford.edu/
06:34:42:  Copyright: (c) 2009-2014 Stanford University
06:34:42:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:34:42:       Args: --config /var/opt/fah/config.xml --exec-directory=/opt/fah
06:34:42:             --data-directory=/var/opt/fah
06:34:42:     Config: /var/opt/fah/config.xml
06:34:42:******************************** Build ********************************
06:34:42:    Version: 7.4.4
06:34:42:       Date: Mar 4 2014
06:34:42:       Time: 12:02:38
06:34:42:    SVN Rev: 4130
06:34:42:     Branch: fah/trunk/client
06:34:42:   Compiler: GNU 4.4.7
06:34:42:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
06:34:42:             -fno-unsafe-math-optimizations -msse2
06:34:42:   Platform: linux2 3.2.0-1-amd64
06:34:42:       Bits: 64
06:34:42:       Mode: Release
06:34:42:******************************* System ********************************
06:34:42:        CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
06:34:42:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
06:34:42:       CPUs: 4
06:34:42:     Memory: 15.63GiB
06:34:42:Free Memory: 13.98GiB
06:34:42:    Threads: POSIX_THREADS
06:34:42: OS Version: 4.2
06:34:42:Has Battery: false
06:34:42: On Battery: false
06:34:42: UTC Offset: -5
06:34:42:        PID: 7698
06:34:42:        CWD: /var/opt/fah
06:34:42:         OS: Linux 4.2.3-1-ARCH x86_64
06:34:42:    OS Arch: AMD64
06:34:42:       GPUs: 1
06:34:42:      GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
06:34:42:       CUDA: 3.0
06:34:42:CUDA Driver: 7050
06:34:42:***********************************************************************
06:34:42:<config>
06:34:42:  <!-- Slot Control -->
06:34:42:  <power v='full'/>
06:34:42:
06:34:42:  <!-- User Information -->
06:34:42:  <passkey v='********************************'/>
06:34:42:  <team v='45032'/>
06:34:42:  <user v='weirddan455'/>
06:34:42:
06:34:42:  <!-- Folding Slots -->
06:34:42:  <slot id='0' type='CPU'/>
06:34:42:  <slot id='1' type='GPU'/>
06:34:42:</config>
06:34:42:Trying to access database...
06:34:42:Successfully acquired database lock
06:34:42:Enabled folding slot 00: READY cpu:3
06:34:42:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770]
06:34:42:WU01:FS01:Connecting to 171.67.108.45:80
06:34:43:WU01:FS01:Assigned to work server 140.163.4.234
06:34:43:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 770] from 140.163.4.234
06:34:43:WU01:FS01:Connecting to 140.163.4.234:8080
06:34:44:WU01:FS01:Downloading 3.63MiB
06:34:50:WU01:FS01:Download 49.88%
06:34:56:WU01:FS01:Download 91.16%
06:34:57:WU01:FS01:Download complete
06:34:57:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10477 run:1 clone:81 gen:203 core:0x18 unit:0x000000f5538b3dba548b2746ed77d800
06:34:57:WU01:FS01:Starting
06:34:57:WU01:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /var/opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 7698 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:34:57:WU01:FS01:Started FahCore on PID 7730
06:34:57:WU01:FS01:Core PID:7734
06:34:57:WU01:FS01:FahCore 0x18 started
06:34:57:WU01:FS01:0x18:*********************** Log Started 2015-10-26T06:34:57Z ***********************
06:34:57:WU01:FS01:0x18:Project: 10477 (Run 1, Clone 81, Gen 203)
06:34:57:WU01:FS01:0x18:Unit: 0x000000f5538b3dba548b2746ed77d800
06:34:57:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
06:34:57:WU01:FS01:0x18:Machine: 1
06:34:57:WU01:FS01:0x18:Reading tar file state.xml
06:34:57:WU01:FS01:0x18:Reading tar file system.xml
06:34:58:WU01:FS01:0x18:Reading tar file integrator.xml
06:34:58:WU01:FS01:0x18:Reading tar file core.xml
06:34:58:WU01:FS01:0x18:Digital signatures verified
06:34:58:WU01:FS01:0x18:Folding@home GPU core18
06:34:58:WU01:FS01:0x18:Version 0.0.4
06:35:09:WU01:FS01:0x18:Completed 0 out of 5000000 steps (0%)
06:35:09:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:18:49:WU01:FS01:0x18:ERROR:exception: The periodic box size has decreased to less than twice the nonbonded cutoff.
07:18:49:WU01:FS01:0x18:Saving result file logfile_01.txt
07:18:49:WU01:FS01:0x18:Saving result file log.txt
07:18:49:WU01:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
07:18:50:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:18:50:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:10477 run:1 clone:81 gen:203 core:0x18 unit:0x000000f5538b3dba548b2746ed77d800
07:18:50:WU01:FS01:Uploading 2.50KiB to 140.163.4.234
07:18:50:WU01:FS01:Connecting to 140.163.4.234:8080
07:18:50:WU01:FS01:Upload complete
07:18:50:WU01:FS01:Server responded WORK_ACK (400)
07:18:50:WU01:FS01:Cleaning up
Re: Project: 10477 (Run 1, Clone 81, Gen 203) - Bad WU?
Someone else completed it.
