Can not receive any more assignments
cfg1337
Post by cfg1337 »
Hi,
I recently started Folding and everything seemed to work just fine.
However, ever scince I rebooted, I can no longer get any work assigned. I am not sure what could cause
this issue scince I made an exception in the Firewall on the first startup and the first assignment for CPU and GPU worked just fine.
The log also reports that it keeps failing to connect to the assignment server.
Thanks in advance
*********************** Log Started 2015-10-02T11:17:02Z ***********************
11:17:02:************************* Folding@home Client *************************
11:17:02:      Website: http://folding.stanford.edu/
11:17:02:    Copyright: (c) 2009-2014 Stanford University
11:17:02:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:17:02:         Args: --open-web-control
11:17:02:       Config: C:/Users/Z/AppData/Roaming/FAHClient/config.xml
11:17:02:******************************** Build ********************************
11:17:02:      Version: 7.4.4
11:17:02:         Date: Mar 4 2014
11:17:02:         Time: 20:26:54
11:17:02:      SVN Rev: 4130
11:17:02:       Branch: fah/trunk/client
11:17:02:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:17:02:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:17:02:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:17:02:     Platform: win32 XP
11:17:02:         Bits: 32
11:17:02:         Mode: Release
11:17:02:******************************* System ********************************
11:17:02:          CPU: AMD FX(tm)-8350 Eight-Core Processor
11:17:02:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
11:17:02:         CPUs: 8
11:17:02:       Memory: 15.90GiB
11:17:02:  Free Memory: 13.89GiB
11:17:02:      Threads: WINDOWS_THREADS
11:17:02:   OS Version: 6.1
11:17:02:  Has Battery: false
11:17:02:   On Battery: false
11:17:02:   UTC Offset: 2
11:17:02:          PID: 5412
11:17:02:          CWD: C:/Users/Z/AppData/Roaming/FAHClient
11:17:02:           OS: Windows 7 Professional
11:17:02:      OS Arch: AMD64
11:17:02:         GPUs: 1
11:17:02:        GPU 0: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
11:17:02:         CUDA: Not detected
11:17:02:Win32 Service: false
11:17:02:***********************************************************************
11:17:02:<config>
11:17:02:  <!-- Network -->
11:17:02:  <proxy v=':8080'/>
11:17:02:
11:17:02:  <!-- Slot Control -->
11:17:02:  <power v='MEDIUM'/>
11:17:02:
11:17:02:  <!-- User Information -->
11:17:02:  <team v='225605'/>
11:17:02:  <user v='CorneliusF.G.'/>
11:17:02:
11:17:02:  <!-- Folding Slots -->
11:17:02:  <slot id='0' type='CPU'/>
11:17:02:  <slot id='1' type='GPU'/>
11:17:02:</config>
11:17:02:Trying to access database...
11:17:02:Successfully acquired database lock
11:17:02:Enabled folding slot 00: READY cpu:6
11:17:02:Enabled folding slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970]
11:17:02:WU00:FS00:Connecting to 171.67.108.200:8080
11:17:03:WU01:FS01:Connecting to 171.67.108.200:80
11:17:09:17:127.0.0.1:New Web connection
11:17:23:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:17:23:WU00:FS00:Connecting to 171.67.108.204:80
11:17:24:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:17:24:WU01:FS01:Connecting to 171.67.108.204:80
11:17:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:17:44:ERROR:WU00:FS00:Exception: Could not get an assignment
11:17:45:WU00:FS00:Connecting to 171.67.108.200:8080
11:17:45:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:17:45:ERROR:WU01:FS01:Exception: Could not get an assignment
11:17:45:WU01:FS01:Connecting to 171.67.108.200:80
11:18:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:18:06:WU00:FS00:Connecting to 171.67.108.204:80
11:18:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:18:06:WU01:FS01:Connecting to 171.67.108.204:80
11:18:27:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:18:27:ERROR:WU00:FS00:Exception: Could not get an assignment
11:18:27:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:18:27:ERROR:WU01:FS01:Exception: Could not get an assignment
11:18:45:WU00:FS00:Connecting to 171.67.108.200:8080
11:18:45:WU01:FS01:Connecting to 171.67.108.200:80
11:19:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:19:06:WU00:FS00:Connecting to 171.67.108.204:80
11:19:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:19:06:WU01:FS01:Connecting to 171.67.108.204:80
11:19:27:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:19:27:ERROR:WU00:FS00:Exception: Could not get an assignment
11:19:27:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:19:27:ERROR:WU01:FS01:Exception: Could not get an assignment
11:20:22:WU00:FS00:Connecting to 171.67.108.200:8080
11:20:22:WU01:FS01:Connecting to 171.67.108.200:80
11:20:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:20:43:WU00:FS00:Connecting to 171.67.108.204:80
11:20:43:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:20:43:WU01:FS01:Connecting to 171.67.108.204:80
11:21:04:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:21:04:ERROR:WU00:FS00:Exception: Could not get an assignment
11:21:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:21:05:ERROR:WU01:FS01:Exception: Could not get an assignment
11:22:59:WU00:FS00:Connecting to 171.67.108.200:8080
11:23:00:WU01:FS01:Connecting to 171.67.108.200:80
11:23:20:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:23:20:WU00:FS00:Connecting to 171.67.108.204:80
11:23:21:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:23:21:WU01:FS01:Connecting to 171.67.108.204:80
11:23:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:23:41:ERROR:WU00:FS00:Exception: Could not get an assignment
11:23:42:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:23:42:ERROR:WU01:FS01:Exception: Could not get an assignment
11:27:13:WU00:FS00:Connecting to 171.67.108.200:8080
11:27:14:WU01:FS01:Connecting to 171.67.108.200:80
11:27:35:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:27:35:WU00:FS00:Connecting to 171.67.108.204:80
11:27:35:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Failed to connect to 171.67.108.200:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:27:35:WU01:FS01:Connecting to 171.67.108.204:80
11:27:56:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:27:56:ERROR:WU00:FS00:Exception: Could not get an assignment
11:27:56:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
11:27:56:ERROR:WU01:FS01:Exception: Could not get an assignment
ChristianVirtual
Re: Can not receive any more assignments
Post by ChristianVirtual »
Welcome to the forum,
First and obvious question: did you saved the setting for the firewall ? Sometimes they keep changes only until reboot ? Based on the error you run in timeout which indicate the fw keeps blocking.
Hallo cfg1337, Willkommen in der Folding Support Forum.
That log message from the server indicates there are no work units available that matches the client settings on your computer. However your computer seems very much like a lot of computers folding today. There should be a lot of work available for your computer. That makes me think there is a problem with the servers at Stanford. While waiting for Stanford to sort this out, please try restarting your internet modem/router.
Please also consider adding a Passkey so you are eligible to earn bonus points.
cfg1337
Post by cfg1337 »
So I've restarted modem and router and now everything works fine. The only thing that seems weird to me is that
netstat -n -a
reported the same for the port F@H is using, before and after the reset.
Anyway, thanks for the help
cfg1337 wrote:So I've restarted modem and router and now everything works fine. The only thing that seems weird to me is that
netstat -n -a
Did FAHClient remain operating during that reset or did you also restart FAH?
