change the service name
siadi
Post by siadi »
is there anyway to change how the client appears in services list? the default would show "FAH@C:+Program Files+FAH+FAH504-Console.exe" or something like that depends on where it's stored. thx heaps.
anandhanju
Re: change the service name
Post by anandhanju »
Get to the place where the FAH service is defined as described in this Wiki article (http://fahwiki.net/index.php/How_do_I_a ... ce_mode%3F). Then, instead of ImagePath, change the DisplayName value.
I don't think the client will be able to uninstall the service if you alter its name ... :?
apd183
Hardware configuration: - Core 2 Duo E6400, 3GB RAM, Win Vista, 1 v5 CPU Client, 1 v6 CPU Client
- Pentium 4 3.xGHz, 1GB RAM, Win XP w/ v6 CPU Client
- 3x Pentium 4 2.26GHz, 1GB RAM
-- Win 2000 w/ v5 CPU Client
-- Win Vista w/ v6 CPU Client
-- Ubuntu 8 w/ v6 CPU Client
Post by apd183 »
If you just change the DisplayName it won't be a problem. FYI, I had to restart before it showed up in the services list with the new name.
siadi
Post by siadi »
thx heaps folks, it works. :)
