my WAN information:
Service Provider AT&T Uverse
IP Address 108.208.203.68
Subnet Mask 255.255.252.0
Default Gateway 108.208.200.1
tracert results:
tracert 171.67.108.200
Tracing route to vsp10v-vz00.stanford.edu [171.67.108.200]
over a maximum of 30 hops:
1 * * * Request timed out.
2 21 ms 22 ms 21 ms 108-208-200-2.lightspeed.irvnca.sbcglobal.net [108.208.200.2]
3 21 ms 23 ms 21 ms 75.20.1.0
4 23 ms 23 ms 23 ms 12.83.38.145
5 26 ms 26 ms 24 ms ggr2.la2ca.ip.att.net [12.122.128.97]
6 22 ms 25 ms 23 ms las-bb1-link.telia.net [80.239.193.213]
7 35 ms 36 ms 35 ms palo-b1-link.telia.net [80.91.252.232]
8 41 ms 48 ms 48 ms hurricane-ic-308019-palo-b1.c.telia.net [80.239.167.174]
9 * 35 ms 57 ms stanford-university.10gigabitethernet1-4.core1.pao1.he.net [216.218.209.118]
10 36 ms 36 ms 36 ms rtf-rtr-po8-8.SUNet [171.64.255.194]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
*********************** Log Started 2015-06-26T02:12:37Z ***********************
02:12:37:************************* Folding@home Client *************************
02:12:37: Website: http://folding.stanford.edu/
02:12:37: Copyright: (c) 2009-2014 Stanford University
02:12:37: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:12:37: Args: --open-web-control
02:12:37: Config: C:/Users/jbodenhoefer/AppData/Roaming/FAHClient/config.xml
02:12:37:******************************** Build ********************************
02:12:37: Version: 7.4.4
02:12:37: Date: Mar 4 2014
02:12:37: Time: 20:26:54
02:12:37: SVN Rev: 4130
02:12:37: Branch: fah/trunk/client
02:12:37: Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:12:37: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:12:37: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:12:37: Platform: win32 XP
02:12:37: Bits: 32
02:12:37: Mode: Release
02:12:37:******************************* System ********************************
02:12:37: CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
02:12:37: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
02:12:37: CPUs: 4
02:12:37: Memory: 7.97GiB
02:12:37: Free Memory: 4.35GiB
02:12:37: Threads: WINDOWS_THREADS
02:12:37: OS Version: 6.1
02:12:37: Has Battery: false
02:12:37: On Battery: false
02:12:37: UTC Offset: -7
02:12:37: PID: 9104
02:12:37: CWD: C:/Users/jbodenhoefer/AppData/Roaming/FAHClient
02:12:37: OS: Windows 7 Professional
02:12:37: OS Arch: AMD64
02:12:37: GPUs: 1
02:12:37: GPU 0: NVIDIA:2 GF114 [GeForce GTX 560 Ti]
02:12:37: CUDA: 2.1
02:12:37: CUDA Driver: 7050
02:12:37:Win32 Service: false
02:12:37:***********************************************************************
02:12:37:<config>
02:12:37: <!-- Slot Control -->
02:12:37: <power v='FULL'/>
02:12:37:
02:12:37: <!-- User Information -->
02:12:37: <passkey v='********************************'/>
02:12:37: <team v='143016'/>
02:12:37: <user v='Fresh_Cookies'/>
02:12:37:
02:12:37: <!-- Folding Slots -->
02:12:37: <slot id='0' type='CPU'/>
02:12:37: <slot id='1' type='GPU'/>
02:12:37:</config>
02:12:37:Connecting to assign-GPU.stanford.edu:80
02:12:58:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:12:58:Connecting to assign-GPU2.stanford.edu:80
02:13:19:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:13:19:Trying to access database...
02:13:19:Successfully acquired database lock
02:13:19:Enabled folding slot 00: READY cpu:3
02:13:19:Enabled folding slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti]
02:13:19:WU00:FS00:Connecting to 171.67.108.200:8080
02:13:19:WU01:FS01:Connecting to 171.67.108.200:8080
02:13:23:15:127.0.0.1:New Web connection
02:13:41:WARNING:WU00:FS00:Failed to get ID from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:13:41:WARNING:WU01:FS01:Failed to get ID from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:13:41:WU00:FS00:Connecting to 171.67.108.204:80
02:13:41:WU01:FS01:Connecting to 171.67.108.204:80
02:14:01:WARNING:WU01:FS01:Failed to get ID from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:14:01:ERROR:WU01:FS01:Exception: Could not get an assignment ID
02:14:02:WARNING:WU00:FS00:Failed to get ID from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:14:02:ERROR:WU00:FS00:Exception: Could not get an assignment ID
Mod edit: Please enclose long listings such as your log file in Code tags, they are available from the Full Editor option for posting
