Can't get Work anymore
spersall
Post by spersall »
       00:54:21] - Autosend completed
[00:54:21] + Attempting to get work packet
[00:54:21] Passkey found
[00:54:21] - Will indicate memory of 32169 MB
[00:54:21] - Connecting to assignment server
[00:54:21] Connecting to http://assign.stanford.edu:8080/
[00:54:21] Posted data.
[00:54:21] Initial: 0000; + Could not authenticate Assignment Server response
[00:54:21] Connecting to http://assign2.stanford.edu:80/
[00:54:22] Posted data.
[00:54:22] Initial: 0000; + Could not authenticate Assignment Server 2 response
[00:54:22] + Couldn't get work instructions.
[00:54:22] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[00:54:33] + Attempting to get work packet
[00:54:33] Passkey found
[00:54:33] - Will indicate memory of 32169 MB
[00:54:33] - Connecting to assignment server
[00:54:33] Connecting to http://assign.stanford.edu:8080/
[00:54:34] Posted data.
[00:54:34] Initial: 0000; + Could not authenticate Assignment Server response
[00:54:34] Connecting to http://assign2.stanford.edu:80/
[00:54:34] Initial: 0000; + Could not authenticate Assignment Server 2 response
[00:54:34] + Couldn't get work instructions.
[00:54:34] - Attempt #2  to get work failed, and no other work to do.
[00:54:56] + Attempting to get work packet
[00:54:56] Passkey found
[00:54:56] - Will indicate memory of 32169 MB
[00:54:56] - Connecting to assignment server
[00:54:56] Connecting to http://assign.stanford.edu:8080/
[00:54:57] Posted data.
[00:54:57] Initial: 0000; + Could not authenticate Assignment Server response
[00:54:57] Connecting to http://assign2.stanford.edu:80/
[00:54:57] Initial: 0000; + Could not authenticate Assignment Server 2 response
[00:54:57] + Couldn't get work instructions.
[00:54:57] - Attempt #3  to get work failed, and no other work to do.
[00:55:32] + Attempting to get work packet
[00:55:32] Passkey found
[00:55:32] - Will indicate memory of 32169 MB
[00:55:32] - Connecting to assignment server
[00:55:32] Connecting to http://assign.stanford.edu:8080/
[00:55:32] Posted data.
[00:55:32] Initial: 0000; + Could not authenticate Assignment Server response
[00:55:32] Connecting to http://assign2.stanford.edu:80/
[00:55:33] Posted data.
[00:55:33] Initial: 0000; + Could not authenticate Assignment Server 2 response
[00:55:33] + Couldn't get work instructions.
[00:55:33] - Attempt #4  to get work failed, and no other work to do.
[00:56:19] + Attempting to get work packet
[00:56:19] Passkey found
[00:56:19] - Will indicate memory of 32169 MB
[00:56:19] - Connecting to assignment server
[00:56:19] Connecting to http://assign.stanford.edu:8080/
[00:56:19] Posted data.
[00:56:19] Initial: 0000; + Could not authenticate Assignment Server response
[00:56:19] Connecting to http://assign2.stanford.edu:80/
[00:56:19] Initial: 0000; + Could not authenticate Assignment Server 2 response
[00:56:19] + Couldn't get work instructions.
[00:56:19] - Attempt #5  to get work failed, and no other work to do.
[00:57:47] + Attempting to get work packet
[00:57:47] Passkey found
[00:57:47] - Will indicate memory of 32169 MB
[00:57:47] - Connecting to assignment server
[00:57:47] Connecting to http://assign.stanford.edu:8080/
[00:57:47] Posted data.
[00:57:47] Initial: 0000; + Could not authenticate Assignment Server response
[00:57:47] Connecting to http://assign2.stanford.edu:80/
[00:57:48] Posted data.
[00:57:48] Initial: 0000; + Could not authenticate Assignment Server 2 response
[00:57:48] + Couldn't get work instructions.
[00:57:48] - Attempt #6  to get work failed, and no other work to do.
[01:00:39] + Attempting to get work packet
[01:00:39] Passkey found
[01:00:39] - Will indicate memory of 32169 MB
[01:00:39] - Connecting to assignment server
[01:00:39] Connecting to http://assign.stanford.edu:8080/
[01:00:39] Posted data.
[01:00:39] Initial: 0000; + Could not authenticate Assignment Server response
[01:00:39] Connecting to http://assign2.stanford.edu:80/
[01:00:40] Posted data.
[01:00:40] Initial: 0000; + Could not authenticate Assignment Server 2 response
[01:00:40] + Couldn't get work instructions.
[01:00:40] - Attempt #7  to get work failed, and no other work to do.
[01:06:07] + Attempting to get work packet
[01:06:07] Passkey found
[01:06:07] - Will indicate memory of 32169 MB
[01:06:07] - Connecting to assignment server
[01:06:07] Connecting to http://assign.stanford.edu:8080/
[01:06:07] Posted data.
[01:06:07] Initial: 0000; + Could not authenticate Assignment Server response
[01:06:07] Connecting to http://assign2.stanford.edu:80/
[01:06:08] Posted data.
[01:06:08] Initial: 0000; + Could not authenticate Assignment Server 2 response
[01:06:08] + Couldn't get work instructions.
[01:06:08] - Attempt #8  to get work failed, and no other work to do.
Re: Can't get Work anymore
PG is aware of the problem and working on it, please see the blog - https://folding.stanford.edu/home/multi-core-cpu-jobs/.
In addition, how many cores you have configured and which OS is being used would be useful in trying to provide help.
spersall
Post by spersall »
32 cores
Ubuntu 12.04 OS
This log output looks like you're running a v6 client ... are you ? If the answer is yes, I strongly advice you to upgrade to the latest v7 one.
There is also a temporary workaround for machines with quite a high number of CPUs when they can't get work : instead of running one 32 core slot, try to split it into two 16 cores slots or four 8 cores slots ...
