Folding @ Home on Android.[Tablet]
Would it be possible to F@H on Nvidias Shield Tablet. If so what could you expect from this, being a tablet for gamers with a dedicated GPU and a Android OS. What about PPD, TPF per WU and Power Consumption, and finally keeping it charged.
Re: Folding @ Home on Android.[Tablet]
See Where to get support for Folding@Home on Android
We can hope that tablets such as yours will be supported by a future version of the client but I have not seen any information confirming that it will happen, and if so, when. I certainly would try it if you have Android 4.4 (KitKat) or above.
It's also reasonable to assume that Points will be supported in future versions. For the time being, it is provides a way to contribute to curing disease.
My Asus/Google Nexus 7 (2013) is able to run the Sony Android client, so it is not JUST Sony phones at this point. I am running Android 5.1 but I think it worked under 4.4 as well.
It runs between midnight and 6 AM when my tablet is on a high current charger and is fully charged. No points, no user id, no GPU, I sure hope they support multiple CPUs.
(I do not expect User IDs or Points unless FAH goes to fractional points instead of the current integer points. An ARM CPU is not very strong. Six hours a day of CPU time may not BE one point)
ChristianVirtual
No luck on that Nexus under 4.4 for me; can install but no folding. viewtopic.php?nomobile=1&f=100&t=27593
I had no luck for some time as i normally charge from a USB cable hooked to a PC, and that is not enough. It has to be a high capacity charger, I have not made any USB work.
That's good to know.JimboPalmer wrote:My Asus/Google Nexus 7 (2013) is able to run the Sony Android client, so it is not JUST Sony phones at this point. I am running Android 5.1 but I think it worked under 4.4 as well.
I'm reasonably confident that the FAHCore supports multiple CPUs, but don't have any official information.
I think it's fair to assume FAH will not go to fractional points. Not long ago they switched from 31-bit integers to 64-bit integers when the stats threatened to overflow.
