WU crashed: ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-36)
Log:
*********************** Log Started 2015-04-06T23:00:26Z ***********************
23:00:26:************************* Folding@home Client *************************
23:00:26:      Website: http://folding.stanford.edu/
23:00:26:    Copyright: (c) 2009-2014 Stanford University
23:00:26:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:00:26:         Args:
23:00:26:       Config: C:/Users/Markus/AppData/Roaming/FAHClient/config.xml
23:00:26:******************************** Build ********************************
23:00:26:      Version: 7.4.4
23:00:26:         Date: Mar 4 2014
23:00:26:         Time: 20:26:54
23:00:26:      SVN Rev: 4130
23:00:26:       Branch: fah/trunk/client
23:00:26:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:00:26:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:00:26:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:00:26:     Platform: win32 XP
23:00:26:         Bits: 32
23:00:26:         Mode: Release
23:00:26:******************************* System ********************************
23:00:26:          CPU: Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
23:00:26:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
23:00:26:         CPUs: 2
23:00:26:       Memory: 2.00GiB
23:00:26:  Free Memory: 695.21MiB
23:00:26:      Threads: WINDOWS_THREADS
23:00:26:   OS Version: 6.1
23:00:26:  Has Battery: false
23:00:26:   On Battery: false
23:00:26:   UTC Offset: 2
23:00:26:          PID: 2876
23:00:26:          CWD: C:/Users/Markus/AppData/Roaming/FAHClient
23:00:26:           OS: Windows 7 Professional
23:00:26:      OS Arch: AMD64
23:00:26:         GPUs: 1
23:00:26:        GPU 0: NVIDIA:2 GF110 [GeForce GTX 560 Ti]
23:00:26:         CUDA: 2.0
23:00:26:  CUDA Driver: 5050
23:00:26:Win32 Service: false
23:00:26:***********************************************************************
23:00:26:<config>
23:00:26:  <!-- Folding Core -->
23:00:26:  <core-priority v='low'/>
23:00:26:
23:00:26:  <!-- HTTP Server -->
23:00:26:  <allow v='192.168.2.100-192.168.2.110  127.0.0.1'/>
23:00:26:
23:00:26:  <!-- Logging -->
23:00:26:  <log-rotate-max v='50'/>
23:00:26:
23:00:26:  <!-- Network -->
23:00:26:  <proxy v=':8080'/>
23:00:26:
23:00:26:  <!-- Remote Command Server -->
23:00:26:  <command-allow-no-pass v='192.168.2.100-192.168.2.110  127.0.0.1'/>
23:00:26:
23:00:26:  <!-- Slot Control -->
23:00:26:  <power v='full'/>
23:00:26:
23:00:26:  <!-- User Information -->
23:00:26:  <passkey v='********************************'/>
23:00:26:  <team v='70335'/>
23:00:26:  <user v='folding_hoomer'/>
23:00:26:
23:00:26:  <!-- Folding Slots -->
23:00:26:  <slot id='0' type='GPU'>
23:00:26:    <client-type v='advanced'/>
23:00:26:    <next-unit-percentage v='100'/>
23:00:26:    <pause-on-start v='true'/>
23:00:26:  </slot>
23:00:26:</config>
*********************** Log Started 2015-04-07T10:09:33Z ***********************
10:09:33:WU01:FS00:0x18:Project: 9110 (Run 21, Clone 6, Gen 36)
10:09:33:WU01:FS00:0x18:Unit: 0x0000002f0a3b1e80546a98c86efdca7e
10:09:33:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
10:09:33:WU01:FS00:0x18:Machine: 0
10:09:33:WU01:FS00:0x18:Reading tar file state.xml
10:09:33:WU01:FS00:0x18:Reading tar file system.xml
10:09:34:WU01:FS00:0x18:Reading tar file integrator.xml
10:09:34:WU01:FS00:0x18:Reading tar file core.xml
10:09:34:WU01:FS00:0x18:Digital signatures verified
10:09:34:WU01:FS00:0x18:Folding@home GPU core18
10:09:34:WU01:FS00:0x18:Version 0.0.3
10:10:17:WU01:FS00:0x18:Completed 0 out of 2500000 steps (0%)
10:10:17:WU01:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:53:22:WU01:FS00:0x18:Completed 900000 out of 2500000 steps (36%)
15:01:26:WU01:FS00:0x18:Completed 925000 out of 2500000 steps (37%)
15:03:23:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:03:23:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
15:03:23:WU01:FS00:Starting
15:03:23:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 2876 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
15:03:23:WU01:FS00:Started FahCore on PID 2196
15:03:23:WU01:FS00:Core PID:4552
15:03:23:WU01:FS00:FahCore 0x18 started
15:03:23:WU01:FS00:0x18:*********************** Log Started 2015-04-07T15:03:23Z ***********************
15:03:23:WU01:FS00:0x18:Project: 9110 (Run 21, Clone 6, Gen 36)
15:03:23:WU01:FS00:0x18:Unit: 0x0000002f0a3b1e80546a98c86efdca7e
15:03:23:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
15:03:23:WU01:FS00:0x18:Machine: 0
15:03:23:WU01:FS00:0x18:Digital signatures verified
15:03:23:WU01:FS00:0x18:Folding@home GPU core18
15:03:23:WU01:FS00:0x18:Version 0.0.3
15:03:23:WU01:FS00:0x18:  Found a checkpoint file
15:03:59:WU01:FS00:0x18:Completed 900000 out of 2500000 steps (36%)
15:03:59:WU01:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:12:01:WU01:FS00:0x18:Completed 925000 out of 2500000 steps (37%)
16:54:16:WU01:FS00:0x18:Completed 1250000 out of 2500000 steps (50%)
17:02:04:WU01:FS00:0x18:Completed 1275000 out of 2500000 steps (51%)
17:04:29:WU01:FS00:0x18:ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-36)
17:04:29:WU01:FS00:0x18:Saving result file logfile_01.txt
17:04:29:WU01:FS00:0x18:Saving result file log.txt
17:04:29:WU01:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
17:04:29:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:04:29:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9110 run:21 clone:6 gen:36 core:0x18 unit:0x0000002f0a3b1e80546a98c86efdca7e
17:04:29:WU01:FS00:Uploading 3.26KiB to 171.64.65.92
17:04:29:WU01:FS00:Connecting to 171.64.65.92:8080
17:04:30:WU01:FS00:Upload complete
17:04:30:WU00:FS00:Connecting to 171.67.108.200:80
17:04:30:WU01:FS00:Server responded WORK_ACK (400)
17:04:30:WU01:FS00:Cleaning up
Normal Core_18-Projects do use Version 0.0.3 whereas Beta-Projects do use Version 0.0.4 on this System.
Edit:
It seems that Projects 91xx does use only Version 0.0.3 - indifferent using beta-flag or not . . .
