Nvidia 350.xx with opencl 1.2
DemonfangArun
Post by DemonfangArun »
just came across this today and installed it, sofar nothing appears to have broken from it and gtx960 is chewing through 10475s at same speed as it was before.
the big reason for me posting this is to see if anyone over at pande wants to check if the opencl bug has been finally fixed, because regardless of ppd, it would be nice to have things running efficiently without workarounds.
link to article: http://www.anandtech.com/show/9139/nvid ... 12-support
download link (scroll down past all the broken css nonsense): https://nvidia.custhelp.com/app/answers ... ver-350.05
This user has stopped using F@H because it supports fake crap!
Re: Nvidia 350.05 with opencl 1.2
The OpenMM/FAHCore developers are in close contact with developers at both NVidia and AMD and my guess is that their back-channel communications carry a lot more information about the FAH specific bug that have limited forward progress of FAHCore_1* than you or I (or anandtech, for that matter) have access to. In spite of the lack of announcements from Stanford, I have no doubt that the Developers continue to develop/test/optimize the critical issues that limit progress on the GPU front.
As far as your report is concerned, are you implying that 10475 was touched by the applicable bug so you detected that something changed? It's my impression Projects which DONOT use the critical feature(s) are the only ones distributed to FAH Donors so we have no way to test a potential fix, while Projects which DO use those features are tested and retested in the Pande Lab. The developers must be staying on top of the issue(s) and when they have something, they'll start distributing it.
As far as 350.05 is concerned, NVidia specifically mentions crashes in the Frostbite engine and says nothing about crashes in OpenMM so my hunch is that it's strictly a game-oriented fix, not a Stream Computing oriented fix.
DemonfangArun
bruce wrote:As far as your report is concerned, are you implying that 10475 was touched by the applicable bug so you detected that something changed?
that was more a quick "i updated to this (from what i can tell alpha) driver version and nothing has broken in the process" (from the little amount of stuff i've done today). my reason for mentioning 10475 was also because it is a core 18 project, and i'm running it on hardware that is impacted by the bug. this is easily recognized by roughly 1/3 the ppd of a core 17 wu run on the same hardware, whereas on something like a gtx660 i have normally seen a modest 15-20% difference across core17 and 18 projects, as is to be expected.
that out of the way, i mainly posted to get attention of this out there, since it's going to a new opencl version the bug might have gotten fixed, hence the entire reason for posting (i don't play any games that were affected by it). however the potential for the opencl update to include a fix for the opencl bug that causes the performance drop for all (iirc) core18 wus on windows is definitely worth making a "hey, this driver might have fixed this issue with core18" post.
just my two cents.
Breach
Post by Breach »
Great news & many thanks for the info!
EXT64
Post by EXT64 »
Demonfang - if you are referring to the Maxwell OpenCL bug (that required a patch to core 18 so it wouldn't crash on Maxwells, but killed performance), that was fixed in a previous but recent driver and the FahCore was modified to include a check for recent drivers. If new enough drivers are found then it removes the workaround and runs at full speed. Is your 960 not getting comparable PPD to Core 17 projects on that 10475?
DemonfangArun
EXT64 wrote:Demonfang - if you are referring to the Maxwell OpenCL bug (that required a patch to core 18 so it wouldn't crash on Maxwells, but killed performance), that was fixed in a previous but recent driver and the FahCore was modified to include a check for recent drivers. If new enough drivers are found then it removes the workaround and runs at full speed. Is your 960 not getting comparable PPD to Core 17 projects on that 10475?
that is the very bug i was referring to, of which i question the fixing of it
i'll put it this way: my gtx660 (which i stuffed back in for folding alone) is getting more ppd, by a good amount, compared to my 960 running the same core 18 project. with core 17 i normally see ~150-170k ppd if i let it run nonstop, right now on 10477 i'm seeing ~43k ppd
if someone could chime in with proper ppd for a 960 running 10477 with 1392 or thereabouts boost clock (this is just what my asus card came at).
logfile:
   Line 1092: 08:13:03:WU00:FS01:Connecting to 140.163.4.234:8080
	Line 1093: 08:13:03:WU02:FS01:Download complete
	Line 1094: 08:13:04:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10477 run:0 clone:20 gen:38 core:0x18 unit:0x0000003f538b3dba548b1c0b151c46a2
	Line 1095: 08:13:04:WU02:FS01:Starting
	Line 1096: 08:13:04:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Demonfang Arun/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_18.fah/FahCore_18.exe" -dir 02 -suffix 01 -version 704 -lifeline 2808 -checkpoint 27 -gpu 0 -gpu-vendor nvidia
	Line 1097: 08:13:04:WU02:FS01:Started FahCore on PID 6356
	Line 1098: 08:13:04:WU02:FS01:Core PID:7792
	Line 1099: 08:13:04:WU02:FS01:FahCore 0x18 started
	Line 1100: 08:13:05:WU02:FS01:0x18:*********************** Log Started 2015-03-30T08:13:05Z ***********************
	Line 1101: 08:13:05:WU02:FS01:0x18:Project: 10477 (Run 0, Clone 20, Gen 38)
	Line 1102: 08:13:05:WU02:FS01:0x18:Unit: 0x0000003f538b3dba548b1c0b151c46a2
	Line 1103: 08:13:05:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
	Line 1104: 08:13:05:WU02:FS01:0x18:Machine: 1
	Line 1105: 08:13:05:WU02:FS01:0x18:Reading tar file state.xml
	Line 1106: 08:13:06:WU02:FS01:0x18:Reading tar file system.xml
	Line 1107: 08:13:06:WU02:FS01:0x18:Reading tar file integrator.xml
	Line 1108: 08:13:06:WU02:FS01:0x18:Reading tar file core.xml
	Line 1109: 08:13:06:WU02:FS01:0x18:Digital signatures verified
	Line 1110: 08:13:06:WU02:FS01:0x18:Folding@home GPU core18
	Line 1111: 08:13:06:WU02:FS01:0x18:Version 0.0.3
	Line 1112: 08:13:09:WU00:FS01:Upload 4.99%
	Line 1114: 08:13:15:WU00:FS01:Upload 9.99%
	Line 1115: 08:13:21:WU00:FS01:Upload 14.98%
	Line 1116: 08:13:27:WU00:FS01:Upload 20.68%
	Line 1117: 08:13:29:WU02:FS01:0x18:Completed 0 out of 5000000 steps (0%)
	Line 1118: 08:13:29:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
	Line 1119: 08:13:33:WU00:FS01:Upload 25.68%
	Line 1120: 08:13:39:WU00:FS01:Upload 30.67%
	Line 1121: 08:13:45:WU00:FS01:Upload 35.66%
	Line 1122: 08:13:51:WU00:FS01:Upload 40.65%
	Line 1123: 08:13:57:WU00:FS01:Upload 46.36%
	Line 1125: 08:14:03:WU00:FS01:Upload 51.35%
	Line 1126: 08:14:09:WU00:FS01:Upload 56.35%
	Line 1127: 08:14:15:WU00:FS01:Upload 61.34%
	Line 1128: 08:14:21:WU00:FS01:Upload 66.33%
	Line 1129: 08:14:27:WU00:FS01:Upload 72.04%
	Line 1130: 08:14:33:WU00:FS01:Upload 76.32%
	Line 1131: 08:14:39:WU00:FS01:Upload 81.31%
	Line 1133: 08:14:45:WU00:FS01:Upload 87.01%
	Line 1134: 08:14:51:WU00:FS01:Upload 92.01%
	Line 1135: 08:14:57:WU00:FS01:Upload 97.00%
	Line 1136: 08:15:08:WU00:FS01:Upload complete
	Line 1137: 08:15:08:WU00:FS01:Server responded WORK_ACK (400)
	Line 1138: 08:15:08:WU00:FS01:Final credit estimate, 31349.00 points
	Line 1139: 08:15:08:WU00:FS01:Cleaning up
	Line 1154: 08:25:50:WU02:FS01:0x18:Completed 50000 out of 5000000 steps (1%)
	Line 1171: 08:38:03:WU02:FS01:0x18:Completed 100000 out of 5000000 steps (2%)
	Line 1245: 08:50:27:WU02:FS01:0x18:Completed 150000 out of 5000000 steps (3%)
	Line 1261: 09:02:41:WU02:FS01:0x18:Completed 200000 out of 5000000 steps (4%)
	Line 1276: 09:14:56:WU02:FS01:0x18:Completed 250000 out of 5000000 steps (5%)
	Line 1292: 09:27:20:WU02:FS01:0x18:Completed 300000 out of 5000000 steps (6%)
	Line 1308: 09:39:35:WU02:FS01:0x18:Completed 350000 out of 5000000 steps (7%)
	Line 1325: 09:51:58:WU02:FS01:0x18:Completed 400000 out of 5000000 steps (8%)
	Line 1341: 10:04:12:WU02:FS01:0x18:Completed 450000 out of 5000000 steps (9%)
	Line 1411: 10:16:26:WU02:FS01:0x18:Completed 500000 out of 5000000 steps (10%)
	Line 1422: 10:28:50:WU02:FS01:0x18:Completed 550000 out of 5000000 steps (11%)
	Line 1438: 10:41:04:WU02:FS01:0x18:Completed 600000 out of 5000000 steps (12%)
	Line 1455: 10:53:27:WU02:FS01:0x18:Completed 650000 out of 5000000 steps (13%)
	Line 1472: 11:05:40:WU02:FS01:0x18:Completed 700000 out of 5000000 steps (14%)
	Line 1489: 11:17:54:WU02:FS01:0x18:Completed 750000 out of 5000000 steps (15%)
	Line 1506: 11:30:17:WU02:FS01:0x18:Completed 800000 out of 5000000 steps (16%)
	Line 1581: 11:42:30:WU02:FS01:0x18:Completed 850000 out of 5000000 steps (17%)
	Line 1599: 11:54:54:WU02:FS01:0x18:Completed 900000 out of 5000000 steps (18%)
	Line 1615: 12:07:08:WU02:FS01:0x18:Completed 950000 out of 5000000 steps (19%)
	Line 1632: 12:19:21:WU02:FS01:0x18:Completed 1000000 out of 5000000 steps (20%)
	Line 1649: 12:31:44:WU02:FS01:0x18:Completed 1050000 out of 5000000 steps (21%)
	Line 1667: 12:43:58:WU02:FS01:0x18:Completed 1100000 out of 5000000 steps (22%)
	Line 1742: 12:56:21:WU02:FS01:0x18:Completed 1150000 out of 5000000 steps (23%)
	Line 1760: 13:08:34:WU02:FS01:0x18:Completed 1200000 out of 5000000 steps (24%)
	Line 1774: 13:20:49:WU02:FS01:0x18:Completed 1250000 out of 5000000 steps (25%)
	Line 1792: 13:33:12:WU02:FS01:0x18:Completed 1300000 out of 5000000 steps (26%)
	Line 1810: 13:45:33:WU02:FS01:0x18:Completed 1350000 out of 5000000 steps (27%)
	Line 1828: 13:58:03:WU02:FS01:0x18:Completed 1400000 out of 5000000 steps (28%)
	Line 1903: 14:10:25:WU02:FS01:0x18:Completed 1450000 out of 5000000 steps (29%)
	Line 1919: 14:22:47:WU02:FS01:0x18:Completed 1500000 out of 5000000 steps (30%)
	Line 1936: 14:35:18:WU02:FS01:0x18:Completed 1550000 out of 5000000 steps (31%)
	Line 1953: 14:47:39:WU02:FS01:0x18:Completed 1600000 out of 5000000 steps (32%)
	Line 1970: 15:00:05:WU02:FS01:0x18:Completed 1650000 out of 5000000 steps (33%)
	Line 1986: 15:12:20:WU02:FS01:0x18:Completed 1700000 out of 5000000 steps (34%)
	Line 2010: 15:24:41:WU02:FS01:0x18:Completed 1750000 out of 5000000 steps (35%)
	Line 2078: 15:37:07:WU02:FS01:0x18:Completed 1800000 out of 5000000 steps (36%)
	Line 2095: 15:49:21:WU02:FS01:0x18:Completed 1850000 out of 5000000 steps (37%)
	Line 2112: 16:01:44:WU02:FS01:0x18:Completed 1900000 out of 5000000 steps (38%)
	Line 2129: 16:13:57:WU02:FS01:0x18:Completed 1950000 out of 5000000 steps (39%)
	Line 2146: 16:26:11:WU02:FS01:0x18:Completed 2000000 out of 5000000 steps (40%)
	Line 2163: 16:38:35:WU02:FS01:0x18:Completed 2050000 out of 5000000 steps (41%)
	Line 2237: 16:50:49:WU02:FS01:0x18:Completed 2100000 out of 5000000 steps (42%)
	Line 2254: 17:03:15:WU02:FS01:0x18:Completed 2150000 out of 5000000 steps (43%)
	Line 2271: 17:15:36:WU02:FS01:0x18:Completed 2200000 out of 5000000 steps (44%)
	Line 2288: 17:27:52:WU02:FS01:0x18:Completed 2250000 out of 5000000 steps (45%)
	Line 2305: 17:40:15:WU02:FS01:0x18:Completed 2300000 out of 5000000 steps (46%)
	Line 2322: 17:52:29:WU02:FS01:0x18:Completed 2350000 out of 5000000 steps (47%)
	Line 2397: 18:04:53:WU02:FS01:0x18:Completed 2400000 out of 5000000 steps (48%)
	Line 2414: 18:17:07:WU02:FS01:0x18:Completed 2450000 out of 5000000 steps (49%)
	Line 2431: 18:29:21:WU02:FS01:0x18:Completed 2500000 out of 5000000 steps (50%)
	Line 2448: 18:41:45:WU02:FS01:0x18:Completed 2550000 out of 5000000 steps (51%)
	Line 2466: 18:54:00:WU02:FS01:0x18:Completed 2600000 out of 5000000 steps (52%)
	Line 2484: 19:06:24:WU02:FS01:0x18:Completed 2650000 out of 5000000 steps (53%)
	Line 2559: 19:18:38:WU02:FS01:0x18:Completed 2700000 out of 5000000 steps (54%)
	Line 2577: 19:30:52:WU02:FS01:0x18:Completed 2750000 out of 5000000 steps (55%)
	Line 2595: 19:43:17:WU02:FS01:0x18:Completed 2800000 out of 5000000 steps (56%)
	Line 2613: 19:55:32:WU02:FS01:0x18:Completed 2850000 out of 5000000 steps (57%)
	Line 2631: 20:07:55:WU02:FS01:0x18:Completed 2900000 out of 5000000 steps (58%)
	Line 2649: 20:20:10:WU02:FS01:0x18:Completed 2950000 out of 5000000 steps (59%)
	Line 2724: 20:32:24:WU02:FS01:0x18:Completed 3000000 out of 5000000 steps (60%)
	Line 2742: 20:44:48:WU02:FS01:0x18:Completed 3050000 out of 5000000 steps (61%)
	Line 2759: 20:57:02:WU02:FS01:0x18:Completed 3100000 out of 5000000 steps (62%)
	Line 2776: 21:09:26:WU02:FS01:0x18:Completed 3150000 out of 5000000 steps (63%)
	Line 2793: 21:21:47:WU02:FS01:0x18:Completed 3200000 out of 5000000 steps (64%)
	Line 2806: 21:30:14:FS01:Shutting core down
	Line 2807: 21:30:14:WU02:FS01:0x18:WARNING:Console control signal 1 on PID 7792
	Line 2808: 21:30:14:WU02:FS01:0x18:Exiting, please wait. . .
	Line 2809: 21:30:15:WU02:FS01:0x18:Lost lifeline PID 6356, exiting
	Line 2810: 21:30:15:WU02:FS01:0x18:ERROR:103: Lost client lifeline
	Line 2811: 21:30:15:WU02:FS01:0x18:Folding@home Core Shutdown: CLIENT_DIED
	Line 2812: 21:30:15:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
	Line 2843: 21:36:40:WU02:FS01:Starting
	Line 2844: 21:36:40:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Demonfang Arun/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_18.fah/FahCore_18.exe" -dir 02 -suffix 01 -version 704 -lifeline 2808 -checkpoint 27 -gpu 0 -gpu-vendor nvidia
	Line 2845: 21:36:40:WU02:FS01:Started FahCore on PID 12844
	Line 2846: 21:36:40:WU02:FS01:Core PID:12624
	Line 2847: 21:36:40:WU02:FS01:FahCore 0x18 started
	Line 2869: 21:36:41:WU02:FS01:0x18:*********************** Log Started 2015-03-30T21:36:40Z ***********************
	Line 2870: 21:36:41:WU02:FS01:0x18:Project: 10477 (Run 0, Clone 20, Gen 38)
	Line 2871: 21:36:41:WU02:FS01:0x18:Unit: 0x0000003f538b3dba548b1c0b151c46a2
	Line 2872: 21:36:41:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
	Line 2873: 21:36:41:WU02:FS01:0x18:Machine: 1
	Line 2874: 21:36:41:WU02:FS01:0x18:Digital signatures verified
	Line 2875: 21:36:41:WU02:FS01:0x18:Folding@home GPU core18
	Line 2876: 21:36:41:WU02:FS01:0x18:Version 0.0.3
	Line 2877: 21:36:41:WU02:FS01:0x18:  Found a checkpoint file
	Line 2886: 21:37:03:WU02:FS01:0x18:Completed 3125000 out of 5000000 steps (62%)
	Line 2887: 21:37:03:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
	Line 2923: 21:43:22:WU02:FS01:0x18:Completed 3150000 out of 5000000 steps (63%)
	Line 2940: 21:55:44:WU02:FS01:0x18:Completed 3200000 out of 5000000 steps (64%)
	Line 3015: 22:08:07:WU02:FS01:0x18:Completed 3250000 out of 5000000 steps (65%)
	Line 3032: 22:20:42:WU02:FS01:0x18:Completed 3300000 out of 5000000 steps (66%)
	Line 3049: 22:33:02:WU02:FS01:0x18:Completed 3350000 out of 5000000 steps (67%)
	Line 3067: 22:45:33:WU02:FS01:0x18:Completed 3400000 out of 5000000 steps (68%)
	Line 3085: 22:57:53:WU02:FS01:0x18:Completed 3450000 out of 5000000 steps (69%)
	Line 3102: 23:10:11:WU02:FS01:0x18:Completed 3500000 out of 5000000 steps (70%)
	Line 3179: 23:22:32:WU02:FS01:0x18:Completed 3550000 out of 5000000 steps (71%)
	Line 3196: 23:34:44:WU02:FS01:0x18:Completed 3600000 out of 5000000 steps (72%)
	Line 3214: 23:47:06:WU02:FS01:0x18:Completed 3650000 out of 5000000 steps (73%)
	Line 3232: 23:59:20:WU02:FS01:0x18:Completed 3700000 out of 5000000 steps (74%)
	Line 3249: 00:11:46:WU02:FS01:0x18:Completed 3750000 out of 5000000 steps (75%)
	Line 3266: 00:24:21:WU02:FS01:0x18:Completed 3800000 out of 5000000 steps (76%)
	Line 3343: 00:36:47:WU02:FS01:0x18:Completed 3850000 out of 5000000 steps (77%)
	Line 3361: 00:49:22:WU02:FS01:0x18:Completed 3900000 out of 5000000 steps (78%)
	Line 3379: 01:01:41:WU02:FS01:0x18:Completed 3950000 out of 5000000 steps (79%)
	Line 3398: 01:14:04:WU02:FS01:0x18:Completed 4000000 out of 5000000 steps (80%)
	Line 3416: 01:26:38:WU02:FS01:0x18:Completed 4050000 out of 5000000 steps (81%)
	Line 3433: 01:39:03:WU02:FS01:0x18:Completed 4100000 out of 5000000 steps (82%)
	Line 3508: 01:51:39:WU02:FS01:0x18:Completed 4150000 out of 5000000 steps (83%)
	Line 3524: 02:04:03:WU02:FS01:0x18:Completed 4200000 out of 5000000 steps (84%)
	Line 3541: 02:16:26:WU02:FS01:0x18:Completed 4250000 out of 5000000 steps (85%)
	Line 3557: 02:29:02:WU02:FS01:0x18:Completed 4300000 out of 5000000 steps (86%)
	Line 3574: 02:41:28:WU02:FS01:0x18:Completed 4350000 out of 5000000 steps (87%)
	Line 3591: 02:53:56:WU02:FS01:0x18:Completed 4400000 out of 5000000 steps (88%)
	Line 3666: 03:06:10:WU02:FS01:0x18:Completed 4450000 out of 5000000 steps (89%)
	Line 3684: 03:18:22:WU02:FS01:0x18:Completed 4500000 out of 5000000 steps (90%)
	Line 3702: 03:30:44:WU02:FS01:0x18:Completed 4550000 out of 5000000 steps (91%)
	Line 3720: 03:42:56:WU02:FS01:0x18:Completed 4600000 out of 5000000 steps (92%)
	Line 3739: 03:55:18:WU02:FS01:0x18:Completed 4650000 out of 5000000 steps (93%)
	Line 3757: 04:07:30:WU02:FS01:0x18:Completed 4700000 out of 5000000 steps (94%)
	Line 3832: 04:19:42:WU02:FS01:0x18:Completed 4750000 out of 5000000 steps (95%)
	Line 3849: 04:32:04:WU02:FS01:0x18:Completed 4800000 out of 5000000 steps (96%)
	Line 3865: 04:44:16:WU02:FS01:0x18:Completed 4850000 out of 5000000 steps (97%)
	Line 3882: 04:56:38:WU02:FS01:0x18:Completed 4900000 out of 5000000 steps (98%)
	Line 3899: 05:08:50:WU02:FS01:0x18:Completed 4950000 out of 5000000 steps (99%)
	Line 3916: 05:21:03:WU02:FS01:0x18:Completed 5000000 out of 5000000 steps (100%)
	Line 3917: 05:21:03:WU00:FS01:Connecting to 171.67.108.200:80
	Line 3918: 05:21:03:WU00:FS01:Assigned to work server 140.163.4.234
	Line 3919: 05:21:03:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM206 [GeForce GTX 960] from 140.163.4.234
	Line 3920: 05:21:03:WU00:FS01:Connecting to 140.163.4.234:8080
	Line 3921: 05:21:04:WU00:FS01:Downloading 2.31MiB
	Line 3922: 05:21:10:WU00:FS01:Download 86.73%
	Line 3923: 05:21:11:WU00:FS01:Download complete
	Line 3924: 05:21:11:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10476 run:0 clone:68 gen:104 core:0x18 unit:0x00000095538b3dba53f381372e2ce579
	Line 3925: 05:21:12:WU02:FS01:0x18:Saving result file logfile_01.txt
	Line 3926: 05:21:12:WU02:FS01:0x18:Saving result file checkpointState.xml
	Line 3927: 05:21:14:WU02:FS01:0x18:Saving result file checkpt.crc
	Line 3928: 05:21:14:WU02:FS01:0x18:Saving result file log.txt
	Line 3929: 05:21:14:WU02:FS01:0x18:Saving result file positions.xtc
	Line 3930: 05:21:15:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
	Line 3931: 05:21:16:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
	Line 3932: 05:21:16:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:10477 run:0 clone:20 gen:38 core:0x18 unit:0x0000003f538b3dba548b1c0b151c46a2
	Line 3933: 05:21:16:WU02:FS01:Uploading 9.76MiB to 140.163.4.234
	Line 3934: 05:21:16:WU02:FS01:Connecting to 140.163.4.234:8080
	Line 3935: 05:21:16:WU00:FS01:Starting
	Line 3936: 05:21:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Demonfang Arun/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_18.fah/FahCore_18.exe" -dir 00 -suffix 01 -version 704 -lifeline 2808 -checkpoint 27 -gpu 0 -gpu-vendor nvidia
	Line 3937: 05:21:16:WU00:FS01:Started FahCore on PID 11224
	Line 3938: 05:21:16:WU00:FS01:Core PID:13924
	Line 3939: 05:21:16:WU00:FS01:FahCore 0x18 started
	Line 3940: 05:21:17:WU00:FS01:0x18:*********************** Log Started 2015-03-31T05:21:17Z ***********************
	Line 3941: 05:21:17:WU00:FS01:0x18:Project: 10476 (Run 0, Clone 68, Gen 104)
	Line 3942: 05:21:17:WU00:FS01:0x18:Unit: 0x00000095538b3dba53f381372e2ce579
	Line 3943: 05:21:17:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
	Line 3944: 05:21:17:WU00:FS01:0x18:Machine: 1
	Line 3945: 05:21:17:WU00:FS01:0x18:Reading tar file state.xml
	Line 3946: 05:21:17:WU00:FS01:0x18:Reading tar file system.xml
	Line 3947: 05:21:17:WU00:FS01:0x18:Reading tar file integrator.xml
	Line 3948: 05:21:17:WU00:FS01:0x18:Reading tar file core.xml
	Line 3949: 05:21:17:WU00:FS01:0x18:Digital signatures verified
	Line 3950: 05:21:17:WU00:FS01:0x18:Folding@home GPU core18
	Line 3951: 05:21:17:WU00:FS01:0x18:Version 0.0.3
	Line 3952: 05:21:22:WU02:FS01:Upload 4.48%
	Line 3953: 05:21:28:WU02:FS01:Upload 8.96%
	Line 3954: 05:21:32:WU00:FS01:0x18:Completed 0 out of 5000000 steps (0%)
	Line 3955: 05:21:32:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
	Line 3956: 05:21:34:WU02:FS01:Upload 13.45%
	Line 3957: 05:21:40:WU02:FS01:Upload 17.93%
	Line 3959: 05:21:46:WU02:FS01:Upload 22.41%
	Line 3960: 05:21:52:WU02:FS01:Upload 26.89%
	Line 3961: 05:21:58:WU02:FS01:Upload 31.38%
	Line 3962: 05:22:04:WU02:FS01:Upload 35.86%
	Line 3963: 05:22:10:WU02:FS01:Upload 40.34%
	Line 3964: 05:22:16:WU02:FS01:Upload 44.82%
	Line 3965: 05:22:22:WU02:FS01:Upload 49.31%
	Line 3967: 05:22:28:WU02:FS01:Upload 53.79%
	Line 3968: 05:22:34:WU02:FS01:Upload 57.63%
	Line 3969: 05:22:40:WU02:FS01:Upload 62.11%
	Line 3970: 05:22:46:WU02:FS01:Upload 66.60%
	Line 3971: 05:22:52:WU02:FS01:Upload 71.08%
	Line 3972: 05:22:58:WU02:FS01:Upload 75.56%
	Line 3973: 05:23:04:WU02:FS01:Upload 80.04%
	Line 3974: 05:23:10:WU02:FS01:Upload 83.89%
	Line 3976: 05:23:16:WU02:FS01:Upload 88.37%
	Line 3977: 05:23:22:WU02:FS01:Upload 92.85%
	Line 3978: 05:23:28:WU02:FS01:Upload 97.33%
	Line 3979: 05:23:39:WU02:FS01:Upload complete
	Line 3980: 05:23:39:WU02:FS01:Server responded WORK_ACK (400)
	Line 3981: 05:23:39:WU02:FS01:Final credit estimate, 37951.00 points
	Line 3982: 05:23:39:WU02:FS01:Cleaning up
DemonfangArun
ok, found the issue. new core version works great...after i force the client to download it >.>
i think someone somewhere didn't update the WS to trigger downloading a new core version that has the code that looks for newer drivers :!:
on that note, getting ~131k on 10477, about 20% below average points but certainly more than the crappy 45k or so i was getting, so i'll take it.
also of note, i HATE windows when it cannot be bothered to put gpu indices in the right order, gpu 0 with an opencl index of 1 and gpu 1 with an opencl index of 0 :roll:
It's like the United Nations of slot ordering, no one can agree on a fixed definition! Windows? Driver? Motherboard position? OpenCL index? CUDA index?
DemonfangArun
7im wrote:It's like the United Nations of slot ordering, no one can agree on a fixed definition! Windows? Driver? Motherboard position? OpenCL index? CUDA index?
that gave me a good laugh :lol:
EXT64
Post by EXT64 »
Yeah, that is what I was worried about Demonfang - by chance did you notice if it was a new Core Version #? Periodically I delete all my cores, just to make sure there isn't a sneaky core update hiding :D
DemonfangArun
EXT64 wrote:Yeah, that is what I was worried about Demonfang - by chance did you notice if it was a new Core Version #? Periodically I delete all my cores, just to make sure there isn't a sneaky core update hiding :D
yep, it was on 0.0.3 and after wiping cores folder (since it has a haphazard folder structure) it retrieved 0.0.4 and immediately started chewing along full speed (comparatively). still doesn't change that the client, especially with beta flag set, should be more proactive about checking for new cores (perhaps this could be added in the future? check once a day if any new core versions exist).
that aside, as stated before, ppd seems low on core18 vs core 17 units:
core17: ~160k average
core18: ~135k average
but as with beta, i still chalk this up to either approximation of value and fix later and focus on getting science done, or further core optimizations that have yet to be realized (or most likely both). that said, i tend to use points as a relative measure of work getting done (as i think others do) and seeing lower than optimal (in this case ~170k ppd) points tells me my card is not being as efficiently utilized as it could be (i always factor in 5% just for normal variances, and it's below 95% of 170k). all that said, at least it's not core15 >.> :lol:
oh, and yes, i have been running folding nonstop for a few days bar some fumbling around with slots from the aforementioned indices clusterf*** and some wu's getting dumped as a result >.>
DemonfangArun wrote:
EXT64 wrote:yep, it was on 0.0.3 and after wiping cores folder (since it has a haphazard folder structure) it retrieved 0.0.4 and immediately started chewing along full speed (comparatively). still doesn't change that the client, especially with beta flag set, should be more proactive about checking for new cores (perhaps this could be added in the future? check once a day if any new core versions exist).
The WU is responsible for specifying the minimum version of the core. If you have version 0.0.3 on your system (or nothing) and a WU specifies that it requires 0.0.4, a new core will be downloaded. If the WU specifies that it only requires 0.0.3, a new core will not be downloaded, even if it is on the server. It's the responsibility of the project owner to adjust his project so that the WUs specify the required core. The client doesn't keep track of any of that information, other than to read the information from inside the WU and dispatch the specified core, downloading it if necessary.
Bruce is right about when the client pulls a new core. I would add that if the 0.0.4 version of the core is still in beta status, the researcher is NOT going to update the minimum core version requirement in the existing projects to force the new core to download on unsuspecting donors.
It is then up to beta testers to trigger the download manually. However, a well planned researcher could release a new beta project with the new core requirement. Depends on timing I guess, confidence in the new core version, etc.
Grendel
Hardware configuration: Q6600, Q9560 + GTX 660, i7-3770K + GTX 760
nVidia Driver 350.12 -- OpenCL 1.2
Post by Grendel »
nVidia released 350.12 today, from the release notes:
OpenCL 1.2
Added support for OpenCL 1.2. The OpenCL 1.2 drivers are based on the published Khronos Specification and are expected to pass the Khronos Conformance Testing Process. Current conformance status can be found at http://www.khronos.org/conformance.
Kepler and Maxwell GPUs are supported, including the following: [GT 640 to GeForce GTX TITAN X]
Will OpenCL 1.2 be supported out-of-the-box by the current cores 17 & 18 ? Trying to figure out if I should even consider replacing 327.23 on my folders (reluctant to touch running systems that are spread all over the place...)
Edit: Thanks for merging my post. Thread slipped right by me... :)
Re: nVidia Driver 350.12 -- OpenCL 1.2
A FAHCore that uses OpenCL requires a certain minimum version. If the Pande Group needs a feature that's only in 1.2, they'll need to rewrite the core to use that feature and then find a way to restrict it to machines that have that driver, so NO, the existing cores won't start using it out-of-the-box.
On the other hand, if 1.2 happens to fix some bugs that were in the previous version, you'll benefit from that.
