Somewhat new to F@H, have a few questions...
Spei
Post by Spei »
Hello all,
I have been folding for a little while and recently joined the forum to ask some questions and confirm other things. First off, I am running a slightly overclocked i7-3930K with 32GB of ram and two GTX680's in sli. Until I run out of vram it will give the 980 a good challenge. It's mainly used for gaming but was built with the intention of running Siemens NX on a regular basis bu so far I just do NX beta testing and investigate NX options we might purchase as work. Back to folding...currently I fold only with my cpu because I was finding that gpu projects (I know that's not the correct term...???) were very large and I simply cannot run any other software when folding is crunching on my gpu's. However I did not see an elegant method to terminate a project. I am aware this is super undesirable so currently I allow only my cpu to fold. I suppose I could use pause or finish but I have questions. After playing around with client settings I have found some useful things. I have read the docs and faq's but a simple quick start guide would have been helpful. More of tips and trick sort of doc, not the docs.
Since gpu folding disables sli, I suspect pausing will not allow sli to be active until the FAH client is terminated. I haven't had a chance to verify this but I do not want to initiate more gpu projects if there is no elegant way to terminate it. I know project termination is bad so perhaps I should refrain from any gpu folding at all. By the way, gpu folding does not seem to be as flexible as cpu folding. When I use my computer the folding client seems to nicely back off the load so I may do other things but gpu folding is no such friend. Sli is disabled and I cannot use Siemens NX at all while folding (*cough* nor play World of Tanks *cough, cough*). Here is the gpu folding part I have a question about: If had terminated gpu folding in the middle of a project should I notify anyone? I have no idea how deeply folding is managed nor how flexible it is.
Does F@H run faster on xeon processors than consumer processors such as my 3930K? Floating point intensive I's imagine. I might be able to scrounge up an old Dell Precision with two quad core xeons. If xeons fold well then I'd be willing to set it up as a dedicated folding computer.
Will F@H complete more work with hyperthreading turned on? I usually leave it on until I run NX which runs better without it.
I seem to recall reading on the F@H site monetary donations to Standford were tax deductible. If this is the case then we should be able to write off the electricity used for crunching. (I can measure usage) Hardware is another matter and if it's even a fraction as complicated as office computing write offs then I won't bother but I would like to write off electricity. Are there any folders out there who have done this?
Other thoughts...
So it sounds like Pi's, beagles, arduinos and such are horrible for folding. It would be interesting if Pi device could be made with a processor that does better at FP crunching but I suppose that cost and power consumption would be prohibitive.
Intel i7-3930K@4.7GHz, 3-way GTX680 SLI, 32GB ram
Samsung ssd in rapid mode, Kingston ssd for apps, 1TB WD black for storage, 1K watt psu.
Mid 2010 Mac Mini, still plugging away ; )
Re: Somewhat new to F@H, have a few questions...
As I understand it, FAH does not disable SLI; it simply ignores it. Of course this may cause interesting events to software that sees SLI is enabled but happens to find one GPU very busy doing floating point calculations and the other GPU mostly idle. (about that, I can only speculate)
As you suggest, CPU folding depends mostly on floating point calculations. GFLOPS is not an accurate measure of FAH performance, but it's probably the best indication that's readily available. Unfortunately the software tends to distribute equal amounts of work to each thread and then waits until they synchronize, so if some other heavy calculations are active, you may need to reduce the number of threads into which the work is divided so that you're only using the CPUs that are mostly idle.
Except for the synchronization issues, hyperthreading can increase performance somewhat. A pair threads share the same FPU, so if that pair is idle, it will produce about 120% as much as the same (idle) non-hyperthreaded FPU.
GPUs are, as you suggest, inflexible. They have no operating system. Work from other processes (such as a screen update) wait behind large computational blocks of work since there is no concept of priority and no ability to interrupt and resume work when non-higher priority work arrives, processing everything FIFO, modified somewhat to accomodate parallelization.
A Pi (etc.) may have good floating point throughput, but Stanford only has code that runs on Intel-compatible hardware ozn Windows/Linux/MacOS although Sony/Stanford have just announced a joint version that supports Android hardware. (I would not expect support for other platforms, however, mostly because they only pick platforms that have attained wide distribution to home uses.)
The question of tax deductibility is one for you tax expert, but you can search this forum where the question has been asked many times and where the answer seems to have been a pretty universal no.
Bruce answered some questions, but I can add some small insight to the difference between folding on a Xeon vs. a Core i-series processor. The Mac Pro and iMac mentioned in my signature as folding machines have Xeon and i7 CPU's that are from the same generation, a W3530 and an i7-860. Both are at the same clock speed of 2.8 Ghz. The Mac Pro's Xeon will process WU's from the same projects just a few percent faster than the iMac's i7.
Where does the difference lie? I don't know with any certainty, but suspect the access to triple-channel RAM vs. dual-channel and possibly some I/O channels within the Xeon CPU being a bit faster may account for the speed difference.
The main advantage I see to Xeon processors at this point is the higher number of cores available. That is either through chips with more than the 6 max in the Core i7 series, or through multi-socket motherboards. Would I personally recommend getting a Xeon if it was just for folding, no. But if you were contemplating the purchase because it supported another need, then it would also fold rather well.
Spei
Post by Spei »
Thanks for the info gentlemen,
I discovered sli was disabled at some point but I do not know when. Siemens NX and the only game I play would not have disabled sli but I cannot say for sure the F@H client did it. Like I mentioned before I do not want to start any folding projects I cannot let finish so I'm going to investigate this a bit further before I try gpu folding again.
I remember when the old mainstream cpu architecture allowed multiple sockets but now just xeons are multi-socket. Even Windows was restricted on socket number depending on the windows version. I think I have an old cad station laying around that is a dual 450, lol. Huge case; a full tower i believe. Back then the cad/cam heavy hitters and speed freaks would populate every last bay with a drive and run raid-0. Amazing how the computing landscape has changed since I first started on 386's and HP's running Domain and HP-UX. Damn I feel old right now.
Spei
Post by Spei »
I just tried gpu folding again and I think I'll stick with just cpu folding, at least for the time being. I can't seem to get the client to back off enough for other graphic intensive programs to be usable but the cpu slot seems to being running excellent. SLI is running like you said so I think the incident where it turned off is probably unrelated.
At any rate I like participating in this project and I might even snatch up the Dell 8-core xeon I mentioned. I heard it's possible to have multiple graphics cards running that aren't sli or crossfire so theoretically I could populate more pci slots with graphics cards.
Hmmm...
The best option for GPU computing (for most people) is to fold only when the computer is idle. That suspends it when you're using but gives it a good shot overnight plus when your at work/school during the day. GPU folding is paused completely sort of like when a screensaver is paused.
Rel25917
Post by Rel25917 »
As you have 2 video cards you can always run folding on the card that is not driving the monitor if your other programs don't need/can't use both. Pause if you need the card for another program or game.
Spei
Post by Spei »
Gpu folding doesn't seem to slow down when I use the computer. Can you recommend checking any settings?
Spei wrote:Gpu folding doesn't seem to slow down when I use the computer. Can you recommend checking any settings?
Interesting question....
I'm not sure how the idle status i managed when there are multiple GPUs. I know that in V7 you can set idle as true or false for each slot or set it globally. I suppose the presence or absence of keyboard/mouse activity is determined for the entire system but whether it pauses a particular GPU depends on the true/false setting for that slot.
No matter what SLI setting is used, FAH considers each GPU to be independent of the others. Whatever you use to monitor GPU activity may or may not treat them as unified or separate.
Spei
Post by Spei »
Not a big hurry on this but when someone has a moment could my work be confirmed so I know it's valid?
Thanks a bunch and have a great weekend, All.
Jim
Spei wrote:Not a big hurry on this but when someone has a moment could my work be confirmed so I know it's valid?
Please post a recent log. (See instructions in the Signature portion of my FIRST post in this topic.)
Spei
Post by Spei »
*********************** Log Started 2015-02-20T02:56:20Z ***********************
02:56:20:************************* Folding@home Client *************************
02:56:20:      Website: http://folding.stanford.edu/
02:56:20:    Copyright: (c) 2009-2014 Stanford University
02:56:20:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:56:20:         Args: --open-web-control
02:56:20:       Config: C:/Users/user-99/AppData/Roaming/FAHClient/config.xml
02:56:20:******************************** Build ********************************
02:56:20:      Version: 7.4.4
02:56:20:         Date: Mar 4 2014
02:56:20:         Time: 20:26:54
02:56:20:      SVN Rev: 4130
02:56:20:       Branch: fah/trunk/client
02:56:20:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:56:20:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:56:20:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:56:20:     Platform: win32 XP
02:56:20:         Bits: 32
02:56:20:         Mode: Release
02:56:20:******************************* System ********************************
02:56:20:          CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
02:56:20:       CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
02:56:20:         CPUs: 12
02:56:20:       Memory: 31.94GiB
02:56:20:  Free Memory: 28.03GiB
02:56:20:      Threads: WINDOWS_THREADS
02:56:20:   OS Version: 6.1
02:56:20:  Has Battery: false
02:56:20:   On Battery: false
02:56:20:   UTC Offset: -6
02:56:20:          PID: 1512
02:56:20:          CWD: C:/Users/user-99/AppData/Roaming/FAHClient
02:56:20:           OS: Windows 7 Professional
02:56:20:      OS Arch: AMD64
02:56:20:         GPUs: 2
02:56:20:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 680]
02:56:20:        GPU 1: NVIDIA:3 GK104 [GeForce GTX 680]
02:56:20:         CUDA: 3.0
02:56:20:  CUDA Driver: 7000
02:56:20:Win32 Service: false
02:56:20:***********************************************************************
02:56:20:<config>
02:56:20:  <!-- Folding Core -->
02:56:20:  <core-priority v='low'/>
02:56:20:
02:56:20:  <!-- Network -->
02:56:20:  <proxy v=':8080'/>
02:56:20:
02:56:20:  <!-- Slot Control -->
02:56:20:  <power v='full'/>
02:56:20:
02:56:20:  <!-- User Information -->
02:56:20:  <passkey v='********************************'/>
02:56:20:  <user v='spei_et_exspectationis'/>
02:56:20:
02:56:20:  <!-- Folding Slots -->
02:56:20:  <slot id='0' type='CPU'>
02:56:20:    <paused v='true'/>
02:56:20:  </slot>
02:56:20:</config>
02:56:20:Trying to access database...
02:56:20:Successfully acquired database lock
02:56:20:Enabled folding slot 00: PAUSED cpu:12 (by user)
02:56:22:8:127.0.0.1:New Web connection
02:56:44:FS00:Unpaused
02:56:44:WU00:FS00:Starting
02:56:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
02:56:44:WU00:FS00:Started FahCore on PID 6876
02:56:45:WU00:FS00:Core PID:4976
02:56:45:WU00:FS00:FahCore 0xa4 started
02:56:45:WU00:FS00:0xa4:
02:56:45:WU00:FS00:0xa4:*------------------------------*
02:56:45:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:56:45:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:56:45:WU00:FS00:0xa4:Preparing to commence simulation
02:56:45:WU00:FS00:0xa4:- Looking at optimizations...
02:56:45:WU00:FS00:0xa4:- Files status OK
02:56:45:WU00:FS00:0xa4:- Expanded 827285 -> 1400900 (decompressed 169.3 percent)
02:56:45:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=827285 data_size=1400900, decompressed_data_size=1400900 diff=0
02:56:45:WU00:FS00:0xa4:- Digital signature verified
02:56:45:WU00:FS00:0xa4:Project: 9007 (Run 726, Clone 0, Gen 238)
02:56:45:WU00:FS00:0xa4:Assembly optimizations on if available.
02:56:45:WU00:FS00:0xa4:Entering M.D.
02:56:51:WU00:FS00:0xa4:Using Gromacs checkpoints
02:56:51:WU00:FS00:0xa4:Mapping NT from 12 to 12
02:56:51:WU00:FS00:0xa4:Resuming from checkpoint
02:56:51:WU00:FS00:0xa4:Verified 00/wudata_01.log
02:56:51:WU00:FS00:0xa4:Verified 00/wudata_01.trr
02:56:51:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
02:56:51:WU00:FS00:0xa4:Verified 00/wudata_01.edr
02:56:51:WU00:FS00:0xa4:Completed 102455 out of 250000 steps  (40%)
02:56:52:WU00:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
02:57:21:Removing old file 'configs/config-20150131-235924.xml'
02:57:21:Saving configuration to config.xml
02:57:21:<config>
02:57:21:  <!-- Folding Core -->
02:57:21:  <core-priority v='low'/>
02:57:21:
02:57:21:  <!-- Network -->
02:57:21:  <proxy v=':8080'/>
02:57:21:
02:57:21:  <!-- Slot Control -->
02:57:21:  <power v='full'/>
02:57:21:
02:57:21:  <!-- User Information -->
02:57:21:  <passkey v='********************************'/>
02:57:21:  <user v='spei_et_exspectationis'/>
02:57:21:
02:57:21:  <!-- Folding Slots -->
02:57:21:  <slot id='0' type='CPU'/>
02:57:21:</config>
02:57:43:WU00:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
02:58:52:WU00:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
02:59:52:WU00:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
03:00:41:WU00:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
03:01:47:WU00:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
03:03:05:WU00:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
03:04:09:WU00:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
03:05:16:WU00:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
03:06:18:WU00:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
03:07:27:WU00:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
03:08:36:WU00:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
03:09:35:WU00:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
03:10:39:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
03:11:28:WU00:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
03:12:21:WU00:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
03:13:12:WU00:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
03:14:12:WU00:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
03:15:08:WU00:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
03:16:16:WU00:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
03:17:08:WU00:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
03:17:55:WU00:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
03:18:41:WU00:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
03:19:28:WU00:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
03:20:15:WU00:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
03:21:03:WU00:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
03:21:56:WU00:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
03:22:52:WU00:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
03:23:52:WU00:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
03:24:52:WU00:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
03:25:48:WU00:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
03:26:44:WU00:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
03:27:33:WU00:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
03:28:21:WU00:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
03:29:09:WU00:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
03:30:06:WU00:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
03:30:57:WU00:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
03:31:48:WU00:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
03:32:34:WU00:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
03:33:21:WU00:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
03:34:13:WU00:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
03:34:56:WU00:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
03:35:38:WU00:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
03:36:21:WU00:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
03:37:03:WU00:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
03:37:46:WU00:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
03:38:28:WU00:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
03:39:11:WU00:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
03:39:53:WU00:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
03:40:35:WU00:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
03:41:18:WU00:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
03:42:00:WU00:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
03:42:43:WU00:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
03:43:25:WU00:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
03:44:07:WU00:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
03:44:49:WU00:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
03:45:32:WU00:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
03:46:14:WU00:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
03:46:57:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
03:46:57:WU01:FS00:Connecting to 171.67.108.200:8080
03:46:58:WU01:FS00:Assigned to work server 171.64.65.124
03:46:58:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.124
03:46:58:WU01:FS00:Connecting to 171.64.65.124:8080
03:46:58:WU01:FS00:Downloading 902.95KiB
03:47:00:WU01:FS00:Download complete
03:47:00:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9011 run:198 clone:0 gen:233 core:0xa4 unit:0x0000010e664f2de453c8770f50642cb9
03:47:39:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
03:47:39:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
03:47:49:WU00:FS00:0xa4:
03:47:49:WU00:FS00:0xa4:Finished Work Unit:
03:47:49:WU00:FS00:0xa4:- Reading up to 811800 from "00/wudata_01.trr": Read 811800
03:47:49:WU00:FS00:0xa4:trr file hash check passed.
03:47:49:WU00:FS00:0xa4:- Reading up to 746436 from "00/wudata_01.xtc": Read 746436
03:47:49:WU00:FS00:0xa4:xtc file hash check passed.
03:47:49:WU00:FS00:0xa4:edr file hash check passed.
03:47:49:WU00:FS00:0xa4:logfile size: 24018
03:47:49:WU00:FS00:0xa4:Leaving Run
03:47:53:WU00:FS00:0xa4:- Writing 1584742 bytes of core data to disk...
03:47:53:WU00:FS00:0xa4:Done: 1584230 -> 1538845 (compressed to 97.1 percent)
03:47:53:WU00:FS00:0xa4:  ... Done.
03:47:53:WU00:FS00:0xa4:- Shutting down core
03:47:53:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
03:47:54:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:47:54:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9007 run:726 clone:0 gen:238 core:0xa4 unit:0x00000120664f2de453278cb34b66567b
03:47:54:WU00:FS00:Uploading 1.47MiB to 171.64.65.124
03:47:54:WU00:FS00:Connecting to 171.64.65.124:8080
03:47:54:WU01:FS00:Starting
03:47:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
03:47:54:WU01:FS00:Started FahCore on PID 4500
03:47:54:WU01:FS00:Core PID:6464
03:47:54:WU01:FS00:FahCore 0xa4 started
03:47:55:WU01:FS00:0xa4:
03:47:55:WU01:FS00:0xa4:*------------------------------*
03:47:55:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
03:47:55:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:47:55:WU01:FS00:0xa4:Preparing to commence simulation
03:47:55:WU01:FS00:0xa4:- Looking at optimizations...
03:47:55:WU01:FS00:0xa4:- Created dyn
03:47:55:WU01:FS00:0xa4:- Files status OK
03:47:55:WU01:FS00:0xa4:- Expanded 924109 -> 1527780 (decompressed 165.3 percent)
03:47:55:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=924109 data_size=1527780, decompressed_data_size=1527780 diff=0
03:47:55:WU01:FS00:0xa4:- Digital signature verified
03:47:55:WU01:FS00:0xa4:Project: 9011 (Run 198, Clone 0, Gen 233)
03:47:55:WU01:FS00:0xa4:Assembly optimizations on if available.
03:47:55:WU01:FS00:0xa4:Entering M.D.
03:48:00:WU00:FS00:Upload 51.09%
03:48:00:WU01:FS00:0xa4:Mapping NT from 12 to 12
03:48:00:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
03:48:08:WU00:FS00:Upload complete
03:48:08:WU00:FS00:Server responded WORK_ACK (400)
03:48:08:WU00:FS00:Final credit estimate, 400.00 points
03:48:08:WU00:FS00:Cleaning up
03:48:49:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
03:49:34:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
03:50:19:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
03:51:05:WU01:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
03:51:50:WU01:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
03:52:36:WU01:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
03:53:21:WU01:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
03:54:06:WU01:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
03:54:52:WU01:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
03:55:37:WU01:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
03:56:22:WU01:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
03:57:08:WU01:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
03:57:53:WU01:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
03:58:38:WU01:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
03:59:24:WU01:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
04:00:09:WU01:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
04:00:54:WU01:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
04:01:40:WU01:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
04:02:25:WU01:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
04:03:10:WU01:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
04:03:55:WU01:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
04:08:43:WU01:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
04:09:28:WU01:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
04:10:13:WU01:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
04:10:59:WU01:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
04:11:44:WU01:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
04:12:29:WU01:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
04:13:15:WU01:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
04:14:00:WU01:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
04:14:46:WU01:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
04:15:31:WU01:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
04:16:16:WU01:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
04:17:06:WU01:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
04:18:01:WU01:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
04:18:51:WU01:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
04:19:36:WU01:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
04:20:23:WU01:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
04:21:09:WU01:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
04:21:54:WU01:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
04:22:39:WU01:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
04:23:25:WU01:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
04:24:10:WU01:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
04:24:55:WU01:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
04:25:41:WU01:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
04:26:26:WU01:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
04:27:11:WU01:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
04:27:56:WU01:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
04:28:42:WU01:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
04:29:27:WU01:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
04:30:12:WU01:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
04:30:57:WU01:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
04:31:43:WU01:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
04:32:28:WU01:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
04:33:13:WU01:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
04:33:58:WU01:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
04:34:44:WU01:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
04:35:30:WU01:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
04:36:15:WU01:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
04:37:01:WU01:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
04:37:46:WU01:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
04:38:32:WU01:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
04:39:17:WU01:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
04:40:02:WU01:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
04:40:48:WU01:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
04:41:33:WU01:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
04:42:18:WU01:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
04:43:03:WU01:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
04:43:48:WU01:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
04:44:34:WU01:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
04:45:19:WU01:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
04:46:04:WU01:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
04:46:49:WU01:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
04:47:35:WU01:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
04:48:20:WU01:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
04:49:05:WU01:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
04:49:50:WU01:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
04:50:35:WU01:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
04:51:20:WU01:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
04:52:05:WU01:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
04:52:50:WU01:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
04:53:36:WU01:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
04:54:21:WU01:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
04:55:06:WU01:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
04:55:51:WU01:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
04:56:37:WU01:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
04:57:22:WU01:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
04:58:07:WU01:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
04:58:52:WU01:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
04:59:37:WU01:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
05:00:22:WU01:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
05:01:08:WU01:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
05:01:53:WU01:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
05:02:38:WU01:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
05:03:23:WU01:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
05:04:08:WU01:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
05:04:53:WU01:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
05:05:39:WU01:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
05:06:24:WU01:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
05:07:09:WU01:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
05:07:10:WU00:FS00:Connecting to 171.67.108.200:8080
05:07:10:WU00:FS00:Assigned to work server 155.247.166.219
05:07:10:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 155.247.166.219
05:07:10:WU00:FS00:Connecting to 155.247.166.219:8080
05:07:11:WU00:FS00:Downloading 117.10KiB
05:07:11:WU00:FS00:Download complete
05:07:11:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8600 run:83 clone:8 gen:31 core:0xa4 unit:0x000000230002894b5462cdc9f638eb2b
05:07:54:WU01:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
05:07:55:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
05:08:05:WU01:FS00:0xa4:
05:08:05:WU01:FS00:0xa4:Finished Work Unit:
05:08:05:WU01:FS00:0xa4:- Reading up to 917280 from "01/wudata_01.trr": Read 917280
05:08:05:WU01:FS00:0xa4:trr file hash check passed.
05:08:05:WU01:FS00:0xa4:- Reading up to 840364 from "01/wudata_01.xtc": Read 840364
05:08:05:WU01:FS00:0xa4:xtc file hash check passed.
05:08:05:WU01:FS00:0xa4:edr file hash check passed.
05:08:05:WU01:FS00:0xa4:logfile size: 23193
05:08:05:WU01:FS00:0xa4:Leaving Run
05:08:08:WU01:FS00:0xa4:- Writing 1783325 bytes of core data to disk...
05:08:08:WU01:FS00:0xa4:Done: 1782813 -> 1723935 (compressed to 96.6 percent)
05:08:08:WU01:FS00:0xa4:  ... Done.
05:08:08:WU01:FS00:0xa4:- Shutting down core
05:08:08:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:08:09:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:08:09:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9011 run:198 clone:0 gen:233 core:0xa4 unit:0x0000010e664f2de453c8770f50642cb9
05:08:09:WU01:FS00:Uploading 1.64MiB to 171.64.65.124
05:08:09:WU01:FS00:Connecting to 171.64.65.124:8080
05:08:09:WU00:FS00:Starting
05:08:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
05:08:09:WU00:FS00:Started FahCore on PID 4872
05:08:10:WU00:FS00:Core PID:3824
05:08:10:WU00:FS00:FahCore 0xa4 started
05:08:10:WU00:FS00:0xa4:
05:08:10:WU00:FS00:0xa4:*------------------------------*
05:08:10:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:08:10:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:08:10:WU00:FS00:0xa4:Preparing to commence simulation
05:08:10:WU00:FS00:0xa4:- Looking at optimizations...
05:08:10:WU00:FS00:0xa4:- Created dyn
05:08:10:WU00:FS00:0xa4:- Files status OK
05:08:10:WU00:FS00:0xa4:- Expanded 119395 -> 271368 (decompressed 227.2 percent)
05:08:10:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=119395 data_size=271368, decompressed_data_size=271368 diff=0
05:08:10:WU00:FS00:0xa4:- Digital signature verified
05:08:10:WU00:FS00:0xa4:Project: 8600 (Run 83, Clone 8, Gen 31)
05:08:10:WU00:FS00:0xa4:Assembly optimizations on if available.
05:08:10:WU00:FS00:0xa4:Entering M.D.
05:08:15:WU01:FS00:Upload 38.00%
05:08:16:WU00:FS00:0xa4:Mapping NT from 12 to 12
05:08:16:WU00:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
05:08:21:WU01:FS00:Upload 79.81%
05:08:24:WU01:FS00:Upload complete
05:08:24:WU01:FS00:Server responded WORK_ACK (400)
05:08:24:WU01:FS00:Final credit estimate, 2361.00 points
05:08:24:WU01:FS00:Cleaning up
05:09:19:WU00:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
05:10:22:WU00:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
05:11:25:WU00:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
05:12:28:WU00:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
05:13:30:WU00:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
05:14:33:WU00:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
05:15:36:WU00:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
05:16:40:WU00:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
05:17:43:WU00:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
05:18:46:WU00:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
05:19:49:WU00:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
05:20:53:WU00:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
05:21:56:WU00:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
05:22:58:WU00:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
05:24:01:WU00:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
05:25:04:WU00:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
05:26:07:WU00:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
05:27:10:WU00:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
05:28:13:WU00:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
05:29:16:WU00:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
05:30:20:WU00:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
05:31:23:WU00:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
05:32:25:WU00:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
05:33:28:WU00:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
05:34:32:WU00:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
05:35:36:WU00:FS00:0xa4:Completed 1300000 out of 5000000 steps  (26%)
05:38:15:WU00:FS00:0xa4:Completed 1350000 out of 5000000 steps  (27%)
05:39:18:WU00:FS00:0xa4:Completed 1400000 out of 5000000 steps  (28%)
05:40:22:WU00:FS00:0xa4:Completed 1450000 out of 5000000 steps  (29%)
05:41:25:WU00:FS00:0xa4:Completed 1500000 out of 5000000 steps  (30%)
05:42:28:WU00:FS00:0xa4:Completed 1550000 out of 5000000 steps  (31%)
05:43:32:WU00:FS00:0xa4:Completed 1600000 out of 5000000 steps  (32%)
05:44:35:WU00:FS00:0xa4:Completed 1650000 out of 5000000 steps  (33%)
05:45:39:WU00:FS00:0xa4:Completed 1700000 out of 5000000 steps  (34%)
05:46:43:WU00:FS00:0xa4:Completed 1750000 out of 5000000 steps  (35%)
05:47:46:WU00:FS00:0xa4:Completed 1800000 out of 5000000 steps  (36%)
05:48:49:WU00:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
05:49:52:WU00:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
05:50:55:WU00:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
05:51:58:WU00:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
05:53:01:WU00:FS00:0xa4:Completed 2050000 out of 5000000 steps  (41%)
05:54:04:WU00:FS00:0xa4:Completed 2100000 out of 5000000 steps  (42%)
05:55:07:WU00:FS00:0xa4:Completed 2150000 out of 5000000 steps  (43%)
05:56:10:WU00:FS00:0xa4:Completed 2200000 out of 5000000 steps  (44%)
05:57:13:WU00:FS00:0xa4:Completed 2250000 out of 5000000 steps  (45%)
05:58:16:WU00:FS00:0xa4:Completed 2300000 out of 5000000 steps  (46%)
05:59:19:WU00:FS00:0xa4:Completed 2350000 out of 5000000 steps  (47%)
06:00:23:WU00:FS00:0xa4:Completed 2400000 out of 5000000 steps  (48%)
06:01:27:WU00:FS00:0xa4:Completed 2450000 out of 5000000 steps  (49%)
06:02:30:WU00:FS00:0xa4:Completed 2500000 out of 5000000 steps  (50%)
06:03:34:WU00:FS00:0xa4:Completed 2550000 out of 5000000 steps  (51%)
06:04:37:WU00:FS00:0xa4:Completed 2600000 out of 5000000 steps  (52%)
06:05:41:WU00:FS00:0xa4:Completed 2650000 out of 5000000 steps  (53%)
06:06:44:WU00:FS00:0xa4:Completed 2700000 out of 5000000 steps  (54%)
06:07:47:WU00:FS00:0xa4:Completed 2750000 out of 5000000 steps  (55%)
06:08:51:WU00:FS00:0xa4:Completed 2800000 out of 5000000 steps  (56%)
06:09:54:WU00:FS00:0xa4:Completed 2850000 out of 5000000 steps  (57%)
06:10:57:WU00:FS00:0xa4:Completed 2900000 out of 5000000 steps  (58%)
06:12:00:WU00:FS00:0xa4:Completed 2950000 out of 5000000 steps  (59%)
06:13:03:WU00:FS00:0xa4:Completed 3000000 out of 5000000 steps  (60%)
06:14:07:WU00:FS00:0xa4:Completed 3050000 out of 5000000 steps  (61%)
06:15:10:WU00:FS00:0xa4:Completed 3100000 out of 5000000 steps  (62%)
06:16:13:WU00:FS00:0xa4:Completed 3150000 out of 5000000 steps  (63%)
06:17:17:WU00:FS00:0xa4:Completed 3200000 out of 5000000 steps  (64%)
06:18:19:WU00:FS00:0xa4:Completed 3250000 out of 5000000 steps  (65%)
06:19:23:WU00:FS00:0xa4:Completed 3300000 out of 5000000 steps  (66%)
06:20:26:WU00:FS00:0xa4:Completed 3350000 out of 5000000 steps  (67%)
06:21:29:WU00:FS00:0xa4:Completed 3400000 out of 5000000 steps  (68%)
06:22:33:WU00:FS00:0xa4:Completed 3450000 out of 5000000 steps  (69%)
06:23:36:WU00:FS00:0xa4:Completed 3500000 out of 5000000 steps  (70%)
06:24:40:WU00:FS00:0xa4:Completed 3550000 out of 5000000 steps  (71%)
06:25:44:WU00:FS00:0xa4:Completed 3600000 out of 5000000 steps  (72%)
06:26:47:WU00:FS00:0xa4:Completed 3650000 out of 5000000 steps  (73%)
06:27:50:WU00:FS00:0xa4:Completed 3700000 out of 5000000 steps  (74%)
06:28:54:WU00:FS00:0xa4:Completed 3750000 out of 5000000 steps  (75%)
06:29:57:WU00:FS00:0xa4:Completed 3800000 out of 5000000 steps  (76%)
06:31:01:WU00:FS00:0xa4:Completed 3850000 out of 5000000 steps  (77%)
06:32:05:WU00:FS00:0xa4:Completed 3900000 out of 5000000 steps  (78%)
06:33:08:WU00:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
06:34:12:WU00:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
06:35:15:WU00:FS00:0xa4:Completed 4050000 out of 5000000 steps  (81%)
06:36:19:WU00:FS00:0xa4:Completed 4100000 out of 5000000 steps  (82%)
06:37:22:WU00:FS00:0xa4:Completed 4150000 out of 5000000 steps  (83%)
06:38:26:WU00:FS00:0xa4:Completed 4200000 out of 5000000 steps  (84%)
06:39:29:WU00:FS00:0xa4:Completed 4250000 out of 5000000 steps  (85%)
06:40:33:WU00:FS00:0xa4:Completed 4300000 out of 5000000 steps  (86%)
06:41:36:WU00:FS00:0xa4:Completed 4350000 out of 5000000 steps  (87%)
06:42:39:WU00:FS00:0xa4:Completed 4400000 out of 5000000 steps  (88%)
06:43:43:WU00:FS00:0xa4:Completed 4450000 out of 5000000 steps  (89%)
06:44:46:WU00:FS00:0xa4:Completed 4500000 out of 5000000 steps  (90%)
06:45:49:WU00:FS00:0xa4:Completed 4550000 out of 5000000 steps  (91%)
06:46:52:WU00:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
06:47:55:WU00:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
06:48:58:WU00:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
06:50:01:WU00:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
06:51:04:WU00:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
06:52:08:WU00:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
06:53:11:WU00:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
06:54:14:WU00:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
06:54:15:WU01:FS00:Connecting to 171.67.108.200:8080
06:54:15:WU01:FS00:Assigned to work server 155.247.166.219
06:54:15:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 155.247.166.219
06:54:15:WU01:FS00:Connecting to 155.247.166.219:8080
06:54:16:WU01:FS00:Downloading 116.07KiB
06:54:16:WU01:FS00:Download complete
06:54:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6391 run:90 clone:1 gen:45 core:0xa4 unit:0x000000310002894b545b9b71baba29ae
06:55:18:WU00:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
06:55:18:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
06:55:28:WU00:FS00:0xa4:
06:55:28:WU00:FS00:0xa4:Finished Work Unit:
06:55:28:WU00:FS00:0xa4:- Reading up to 1255848 from "00/wudata_01.trr": Read 1255848
06:55:28:WU00:FS00:0xa4:trr file hash check passed.
06:55:28:WU00:FS00:0xa4:- Reading up to 111136 from "00/wudata_01.xtc": Read 111136
06:55:28:WU00:FS00:0xa4:xtc file hash check passed.
06:55:28:WU00:FS00:0xa4:edr file hash check passed.
06:55:28:WU00:FS00:0xa4:logfile size: 86735
06:55:28:WU00:FS00:0xa4:Leaving Run
06:55:29:WU00:FS00:0xa4:- Writing 1525619 bytes of core data to disk...
06:55:30:WU00:FS00:0xa4:Done: 1525107 -> 1292376 (compressed to 84.7 percent)
06:55:30:WU00:FS00:0xa4:  ... Done.
06:55:30:WU00:FS00:0xa4:- Shutting down core
06:55:30:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
06:55:30:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:55:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8600 run:83 clone:8 gen:31 core:0xa4 unit:0x000000230002894b5462cdc9f638eb2b
06:55:30:WU00:FS00:Uploading 1.23MiB to 155.247.166.219
06:55:30:WU00:FS00:Connecting to 155.247.166.219:8080
06:55:30:WU01:FS00:Starting
06:55:30:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
06:55:31:WU01:FS00:Started FahCore on PID 3448
06:55:31:WU01:FS00:Core PID:4792
06:55:31:WU01:FS00:FahCore 0xa4 started
06:55:31:WU01:FS00:0xa4:
06:55:31:WU01:FS00:0xa4:*------------------------------*
06:55:31:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
06:55:31:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:55:31:WU01:FS00:0xa4:Preparing to commence simulation
06:55:31:WU01:FS00:0xa4:- Looking at optimizations...
06:55:31:WU01:FS00:0xa4:- Created dyn
06:55:31:WU01:FS00:0xa4:- Files status OK
06:55:31:WU01:FS00:0xa4:- Expanded 118343 -> 268292 (decompressed 226.7 percent)
06:55:31:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=118343 data_size=268292, decompressed_data_size=268292 diff=0
06:55:31:WU01:FS00:0xa4:- Digital signature verified
06:55:31:WU01:FS00:0xa4:Project: 6391 (Run 90, Clone 1, Gen 45)
06:55:31:WU01:FS00:0xa4:Assembly optimizations on if available.
06:55:31:WU01:FS00:0xa4:Entering M.D.
06:55:36:WU00:FS00:Upload complete
06:55:36:WU00:FS00:Server responded WORK_ACK (400)
06:55:36:WU00:FS00:Final credit estimate, 2928.00 points
06:55:36:WU00:FS00:Cleaning up
06:55:37:WU01:FS00:0xa4:Mapping NT from 12 to 12
06:55:37:WU01:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
06:56:41:WU01:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
06:57:44:WU01:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
06:58:47:WU01:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
06:59:51:WU01:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
07:00:54:WU01:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
07:01:57:WU01:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
07:03:00:WU01:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
07:04:04:WU01:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
07:05:07:WU01:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
07:06:10:WU01:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
07:07:13:WU01:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
07:08:15:WU01:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
07:09:18:WU01:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
07:10:21:WU01:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
07:11:24:WU01:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
07:12:27:WU01:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
07:13:29:WU01:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
07:14:32:WU01:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
07:15:35:WU01:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
07:16:38:WU01:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
07:17:42:WU01:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
07:18:45:WU01:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
07:19:49:WU01:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
07:20:53:WU01:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
07:21:57:WU01:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
07:23:00:WU01:FS00:0xa4:Completed 1300000 out of 5000000 steps  (26%)
07:24:03:WU01:FS00:0xa4:Completed 1350000 out of 5000000 steps  (27%)
07:25:06:WU01:FS00:0xa4:Completed 1400000 out of 5000000 steps  (28%)
07:26:09:WU01:FS00:0xa4:Completed 1450000 out of 5000000 steps  (29%)
07:27:13:WU01:FS00:0xa4:Completed 1500000 out of 5000000 steps  (30%)
07:28:17:WU01:FS00:0xa4:Completed 1550000 out of 5000000 steps  (31%)
07:29:21:WU01:FS00:0xa4:Completed 1600000 out of 5000000 steps  (32%)
07:30:25:WU01:FS00:0xa4:Completed 1650000 out of 5000000 steps  (33%)
07:31:29:WU01:FS00:0xa4:Completed 1700000 out of 5000000 steps  (34%)
07:32:32:WU01:FS00:0xa4:Completed 1750000 out of 5000000 steps  (35%)
07:33:35:WU01:FS00:0xa4:Completed 1800000 out of 5000000 steps  (36%)
07:34:39:WU01:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
07:35:43:WU01:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
07:36:47:WU01:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
07:37:53:WU01:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
07:38:58:WU01:FS00:0xa4:Completed 2050000 out of 5000000 steps  (41%)
07:40:06:WU01:FS00:0xa4:Completed 2100000 out of 5000000 steps  (42%)
07:43:30:WU01:FS00:0xa4:Completed 2150000 out of 5000000 steps  (43%)
08:09:54:WU01:FS00:0xa4:Completed 2200000 out of 5000000 steps  (44%)
08:13:38:WU01:FS00:0xa4:Completed 2250000 out of 5000000 steps  (45%)
08:15:08:WU01:FS00:0xa4:Completed 2300000 out of 5000000 steps  (46%)
08:16:45:WU01:FS00:0xa4:Completed 2350000 out of 5000000 steps  (47%)
08:18:18:WU01:FS00:0xa4:Completed 2400000 out of 5000000 steps  (48%)
08:19:47:WU01:FS00:0xa4:Completed 2450000 out of 5000000 steps  (49%)
08:21:20:WU01:FS00:0xa4:Completed 2500000 out of 5000000 steps  (50%)
08:22:52:WU01:FS00:0xa4:Completed 2550000 out of 5000000 steps  (51%)
08:24:27:WU01:FS00:0xa4:Completed 2600000 out of 5000000 steps  (52%)
08:25:59:WU01:FS00:0xa4:Completed 2650000 out of 5000000 steps  (53%)
08:27:10:WU01:FS00:0xa4:Completed 2700000 out of 5000000 steps  (54%)
08:28:22:WU01:FS00:0xa4:Completed 2750000 out of 5000000 steps  (55%)
08:29:53:WU01:FS00:0xa4:Completed 2800000 out of 5000000 steps  (56%)
08:31:18:WU01:FS00:0xa4:Completed 2850000 out of 5000000 steps  (57%)
08:32:37:WU01:FS00:0xa4:Completed 2900000 out of 5000000 steps  (58%)
08:34:06:WU01:FS00:0xa4:Completed 2950000 out of 5000000 steps  (59%)
08:35:43:WU01:FS00:0xa4:Completed 3000000 out of 5000000 steps  (60%)
08:37:08:WU01:FS00:0xa4:Completed 3050000 out of 5000000 steps  (61%)
08:38:34:WU01:FS00:0xa4:Completed 3100000 out of 5000000 steps  (62%)
08:40:00:WU01:FS00:0xa4:Completed 3150000 out of 5000000 steps  (63%)
08:41:24:WU01:FS00:0xa4:Completed 3200000 out of 5000000 steps  (64%)
08:42:52:WU01:FS00:0xa4:Completed 3250000 out of 5000000 steps  (65%)
08:44:16:WU01:FS00:0xa4:Completed 3300000 out of 5000000 steps  (66%)
08:45:59:WU01:FS00:0xa4:Completed 3350000 out of 5000000 steps  (67%)
08:47:26:WU01:FS00:0xa4:Completed 3400000 out of 5000000 steps  (68%)
08:48:59:WU01:FS00:0xa4:Completed 3450000 out of 5000000 steps  (69%)
08:50:29:WU01:FS00:0xa4:Completed 3500000 out of 5000000 steps  (70%)
08:51:51:WU01:FS00:0xa4:Completed 3550000 out of 5000000 steps  (71%)
08:53:17:WU01:FS00:0xa4:Completed 3600000 out of 5000000 steps  (72%)
08:54:43:WU01:FS00:0xa4:Completed 3650000 out of 5000000 steps  (73%)
08:56:00:WU01:FS00:0xa4:Completed 3700000 out of 5000000 steps  (74%)
******************************* Date: 2015-02-20 *******************************
08:57:06:WU01:FS00:0xa4:Completed 3750000 out of 5000000 steps  (75%)
08:58:14:WU01:FS00:0xa4:Completed 3800000 out of 5000000 steps  (76%)
09:01:02:WU01:FS00:0xa4:Completed 3850000 out of 5000000 steps  (77%)
09:03:08:WU01:FS00:0xa4:Completed 3900000 out of 5000000 steps  (78%)
09:04:36:WU01:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
09:05:57:WU01:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
09:07:08:WU01:FS00:0xa4:Completed 4050000 out of 5000000 steps  (81%)
09:08:20:WU01:FS00:0xa4:Completed 4100000 out of 5000000 steps  (82%)
09:09:40:WU01:FS00:0xa4:Completed 4150000 out of 5000000 steps  (83%)
09:10:49:WU01:FS00:0xa4:Completed 4200000 out of 5000000 steps  (84%)
09:12:01:WU01:FS00:0xa4:Completed 4250000 out of 5000000 steps  (85%)
09:13:10:WU01:FS00:0xa4:Completed 4300000 out of 5000000 steps  (86%)
09:14:13:WU01:FS00:0xa4:Completed 4350000 out of 5000000 steps  (87%)
09:15:16:WU01:FS00:0xa4:Completed 4400000 out of 5000000 steps  (88%)
09:16:19:WU01:FS00:0xa4:Completed 4450000 out of 5000000 steps  (89%)
09:17:22:WU01:FS00:0xa4:Completed 4500000 out of 5000000 steps  (90%)
09:18:25:WU01:FS00:0xa4:Completed 4550000 out of 5000000 steps  (91%)
09:19:28:WU01:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
09:20:32:WU01:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
09:21:35:WU01:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
09:22:38:WU01:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
09:23:41:WU01:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
09:24:45:WU01:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
09:25:48:WU01:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
09:26:52:WU01:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
09:26:52:WU00:FS00:Connecting to 171.67.108.200:8080
09:26:53:WU00:FS00:Assigned to work server 155.247.166.219
09:26:53:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 155.247.166.219
09:26:53:WU00:FS00:Connecting to 155.247.166.219:8080
09:26:53:WU00:FS00:Downloading 116.87KiB
09:26:53:WU00:FS00:Download complete
09:26:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6398 run:89 clone:3 gen:40 core:0xa4 unit:0x0000002d0002894b5462cb4e08de5d6d
09:27:57:WU01:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
09:27:57:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
09:28:07:WU01:FS00:0xa4:
09:28:07:WU01:FS00:0xa4:Finished Work Unit:
09:28:07:WU01:FS00:0xa4:- Reading up to 1254528 from "01/wudata_01.trr": Read 1254528
09:28:07:WU01:FS00:0xa4:trr file hash check passed.
09:28:07:WU01:FS00:0xa4:- Reading up to 108680 from "01/wudata_01.xtc": Read 108680
09:28:07:WU01:FS00:0xa4:xtc file hash check passed.
09:28:07:WU01:FS00:0xa4:edr file hash check passed.
09:28:07:WU01:FS00:0xa4:logfile size: 87978
09:28:07:WU01:FS00:0xa4:Leaving Run
09:28:08:WU01:FS00:0xa4:- Writing 1523086 bytes of core data to disk...
09:28:08:WU01:FS00:0xa4:Done: 1522574 -> 1289368 (compressed to 84.6 percent)
09:28:08:WU01:FS00:0xa4:  ... Done.
09:28:08:WU01:FS00:0xa4:- Shutting down core
09:28:08:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
09:28:09:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:28:09:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6391 run:90 clone:1 gen:45 core:0xa4 unit:0x000000310002894b545b9b71baba29ae
09:28:09:WU01:FS00:Uploading 1.23MiB to 155.247.166.219
09:28:09:WU01:FS00:Connecting to 155.247.166.219:8080
09:28:09:WU00:FS00:Starting
09:28:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
09:28:09:WU00:FS00:Started FahCore on PID 1196
09:28:09:WU00:FS00:Core PID:5848
09:28:09:WU00:FS00:FahCore 0xa4 started
09:28:10:WU00:FS00:0xa4:
09:28:10:WU00:FS00:0xa4:*------------------------------*
09:28:10:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
09:28:10:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
09:28:10:WU00:FS00:0xa4:Preparing to commence simulation
09:28:10:WU00:FS00:0xa4:- Looking at optimizations...
09:28:10:WU00:FS00:0xa4:- Created dyn
09:28:10:WU00:FS00:0xa4:- Files status OK
09:28:10:WU00:FS00:0xa4:- Expanded 119160 -> 270464 (decompressed 226.9 percent)
09:28:10:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=119160 data_size=270464, decompressed_data_size=270464 diff=0
09:28:10:WU00:FS00:0xa4:- Digital signature verified
09:28:10:WU00:FS00:0xa4:Project: 6398 (Run 89, Clone 3, Gen 40)
09:28:10:WU00:FS00:0xa4:Assembly optimizations on if available.
09:28:10:WU00:FS00:0xa4:Entering M.D.
09:28:14:WU01:FS00:Upload complete
09:28:14:WU01:FS00:Server responded WORK_ACK (400)
09:28:14:WU01:FS00:Final credit estimate, 2458.00 points
09:28:14:WU01:FS00:Cleaning up
09:28:16:WU00:FS00:0xa4:Mapping NT from 12 to 12
09:28:16:WU00:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
09:29:19:WU00:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
09:30:22:WU00:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
09:31:26:WU00:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
09:32:29:WU00:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
09:33:32:WU00:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
09:34:35:WU00:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
09:35:38:WU00:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
09:36:41:WU00:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
09:37:44:WU00:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
09:38:47:WU00:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
09:39:50:WU00:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
09:40:53:WU00:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
09:41:56:WU00:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
09:42:59:WU00:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
09:44:02:WU00:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
09:45:06:WU00:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
09:46:09:WU00:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
09:47:12:WU00:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
09:48:16:WU00:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
09:49:19:WU00:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
09:50:22:WU00:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
09:51:25:WU00:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
09:52:28:WU00:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
09:53:31:WU00:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
09:54:34:WU00:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
09:55:37:WU00:FS00:0xa4:Completed 1300000 out of 5000000 steps  (26%)
09:56:40:WU00:FS00:0xa4:Completed 1350000 out of 5000000 steps  (27%)
09:57:44:WU00:FS00:0xa4:Completed 1400000 out of 5000000 steps  (28%)
09:58:47:WU00:FS00:0xa4:Completed 1450000 out of 5000000 steps  (29%)
09:59:50:WU00:FS00:0xa4:Completed 1500000 out of 5000000 steps  (30%)
10:00:53:WU00:FS00:0xa4:Completed 1550000 out of 5000000 steps  (31%)
10:01:56:WU00:FS00:0xa4:Completed 1600000 out of 5000000 steps  (32%)
10:02:59:WU00:FS00:0xa4:Completed 1650000 out of 5000000 steps  (33%)
10:04:02:WU00:FS00:0xa4:Completed 1700000 out of 5000000 steps  (34%)
10:05:05:WU00:FS00:0xa4:Completed 1750000 out of 5000000 steps  (35%)
10:06:08:WU00:FS00:0xa4:Completed 1800000 out of 5000000 steps  (36%)
10:07:11:WU00:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
10:08:13:WU00:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
10:09:16:WU00:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
10:10:18:WU00:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
10:11:21:WU00:FS00:0xa4:Completed 2050000 out of 5000000 steps  (41%)
10:12:23:WU00:FS00:0xa4:Completed 2100000 out of 5000000 steps  (42%)
10:13:25:WU00:FS00:0xa4:Completed 2150000 out of 5000000 steps  (43%)
10:14:28:WU00:FS00:0xa4:Completed 2200000 out of 5000000 steps  (44%)
10:15:31:WU00:FS00:0xa4:Completed 2250000 out of 5000000 steps  (45%)
10:16:34:WU00:FS00:0xa4:Completed 2300000 out of 5000000 steps  (46%)
10:17:37:WU00:FS00:0xa4:Completed 2350000 out of 5000000 steps  (47%)
10:18:40:WU00:FS00:0xa4:Completed 2400000 out of 5000000 steps  (48%)
10:19:43:WU00:FS00:0xa4:Completed 2450000 out of 5000000 steps  (49%)
10:20:46:WU00:FS00:0xa4:Completed 2500000 out of 5000000 steps  (50%)
10:21:48:WU00:FS00:0xa4:Completed 2550000 out of 5000000 steps  (51%)
10:22:52:WU00:FS00:0xa4:Completed 2600000 out of 5000000 steps  (52%)
10:23:54:WU00:FS00:0xa4:Completed 2650000 out of 5000000 steps  (53%)
10:24:57:WU00:FS00:0xa4:Completed 2700000 out of 5000000 steps  (54%)
10:26:00:WU00:FS00:0xa4:Completed 2750000 out of 5000000 steps  (55%)
10:27:02:WU00:FS00:0xa4:Completed 2800000 out of 5000000 steps  (56%)
10:28:05:WU00:FS00:0xa4:Completed 2850000 out of 5000000 steps  (57%)
10:29:08:WU00:FS00:0xa4:Completed 2900000 out of 5000000 steps  (58%)
10:30:11:WU00:FS00:0xa4:Completed 2950000 out of 5000000 steps  (59%)
10:31:14:WU00:FS00:0xa4:Completed 3000000 out of 5000000 steps  (60%)
10:32:17:WU00:FS00:0xa4:Completed 3050000 out of 5000000 steps  (61%)
10:33:20:WU00:FS00:0xa4:Completed 3100000 out of 5000000 steps  (62%)
10:34:23:WU00:FS00:0xa4:Completed 3150000 out of 5000000 steps  (63%)
10:35:26:WU00:FS00:0xa4:Completed 3200000 out of 5000000 steps  (64%)
10:36:29:WU00:FS00:0xa4:Completed 3250000 out of 5000000 steps  (65%)
10:37:32:WU00:FS00:0xa4:Completed 3300000 out of 5000000 steps  (66%)
10:38:34:WU00:FS00:0xa4:Completed 3350000 out of 5000000 steps  (67%)
10:39:37:WU00:FS00:0xa4:Completed 3400000 out of 5000000 steps  (68%)
10:40:40:WU00:FS00:0xa4:Completed 3450000 out of 5000000 steps  (69%)
10:41:44:WU00:FS00:0xa4:Completed 3500000 out of 5000000 steps  (70%)
10:42:47:WU00:FS00:0xa4:Completed 3550000 out of 5000000 steps  (71%)
10:43:50:WU00:FS00:0xa4:Completed 3600000 out of 5000000 steps  (72%)
10:44:53:WU00:FS00:0xa4:Completed 3650000 out of 5000000 steps  (73%)
10:45:56:WU00:FS00:0xa4:Completed 3700000 out of 5000000 steps  (74%)
10:46:59:WU00:FS00:0xa4:Completed 3750000 out of 5000000 steps  (75%)
10:48:02:WU00:FS00:0xa4:Completed 3800000 out of 5000000 steps  (76%)
10:49:05:WU00:FS00:0xa4:Completed 3850000 out of 5000000 steps  (77%)
10:50:08:WU00:FS00:0xa4:Completed 3900000 out of 5000000 steps  (78%)
10:51:11:WU00:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
10:52:14:WU00:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
10:53:17:WU00:FS00:0xa4:Completed 4050000 out of 5000000 steps  (81%)
10:54:20:WU00:FS00:0xa4:Completed 4100000 out of 5000000 steps  (82%)
10:55:22:WU00:FS00:0xa4:Completed 4150000 out of 5000000 steps  (83%)
10:56:26:WU00:FS00:0xa4:Completed 4200000 out of 5000000 steps  (84%)
10:57:29:WU00:FS00:0xa4:Completed 4250000 out of 5000000 steps  (85%)
10:58:33:WU00:FS00:0xa4:Completed 4300000 out of 5000000 steps  (86%)
10:59:36:WU00:FS00:0xa4:Completed 4350000 out of 5000000 steps  (87%)
11:00:40:WU00:FS00:0xa4:Completed 4400000 out of 5000000 steps  (88%)
11:01:44:WU00:FS00:0xa4:Completed 4450000 out of 5000000 steps  (89%)
11:02:48:WU00:FS00:0xa4:Completed 4500000 out of 5000000 steps  (90%)
11:03:53:WU00:FS00:0xa4:Completed 4550000 out of 5000000 steps  (91%)
11:04:57:WU00:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
11:06:00:WU00:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
11:07:03:WU00:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
11:08:07:WU00:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
11:09:10:WU00:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
11:10:13:WU00:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
11:11:16:WU00:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
11:12:18:WU00:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
11:12:19:WU01:FS00:Connecting to 171.67.108.200:8080
11:12:20:WU01:FS00:Assigned to work server 171.64.65.124
11:12:20:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.124
11:12:20:WU01:FS00:Connecting to 171.64.65.124:8080
11:12:21:WU01:FS00:Downloading 902.47KiB
11:12:22:WU01:FS00:Download complete
11:12:22:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9014 run:22 clone:9 gen:77 core:0xa4 unit:0x00000058664f2de45491d2273845e811
11:13:22:WU00:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
Spei
Post by Spei »
FYI- I deleted some of the log because of the size limitation.
Spei
Post by Spei »
02:56:20:         Bits: 32
02:56:20:         CPUs: 12
02:56:20:          PID: 1512
02:56:20:         GPUs: 2
02:56:20:         CUDA: 3.0
02:56:20:<config>
02:56:20:
02:56:20:
02:56:20:
02:56:20:
02:56:20:  </slot>
02:56:20:</config>
02:57:21:<config>
02:57:21:
02:57:21:
02:57:21:
02:57:21:
02:57:21:</config>
*I deleted some data here*
11:47:22:WU01:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
11:48:27:WU01:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
11:49:31:WU01:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
11:49:31:WU00:FS00:Connecting to 171.67.108.200:8080
11:49:32:WU00:FS00:Assigned to work server 155.247.166.219
11:49:32:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 155.247.166.219
11:49:32:WU00:FS00:Connecting to 155.247.166.219:8080
11:49:32:WU00:FS00:Downloading 117.08KiB
11:49:32:WU00:FS00:Download complete
11:49:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6396 run:71 clone:2 gen:30 core:0xa4 unit:0x000000220002894b5462c8b21bbe5638
11:50:34:WU01:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
11:50:34:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
11:50:44:WU01:FS00:0xa4:
11:50:44:WU01:FS00:0xa4:Finished Work Unit:
11:50:44:WU01:FS00:0xa4:- Reading up to 1254528 from "01/wudata_01.trr": Read 1254528
11:50:44:WU01:FS00:0xa4:trr file hash check passed.
11:50:44:WU01:FS00:0xa4:- Reading up to 109852 from "01/wudata_01.xtc": Read 109852
11:50:44:WU01:FS00:0xa4:xtc file hash check passed.
11:50:44:WU01:FS00:0xa4:edr file hash check passed.
11:50:44:WU01:FS00:0xa4:logfile size: 87064
11:50:44:WU01:FS00:0xa4:Leaving Run
11:50:44:WU01:FS00:0xa4:- Writing 1523344 bytes of core data to disk...
11:50:44:WU01:FS00:0xa4:Done: 1522832 -> 1289933 (compressed to 84.7 percent)
11:50:44:WU01:FS00:0xa4:  ... Done.
11:50:45:WU01:FS00:0xa4:- Shutting down core
11:50:45:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
11:50:45:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:50:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6391 run:61 clone:10 gen:33 core:0xa4 unit:0x000000240002894b545b9b3831623486
11:50:45:WU01:FS00:Uploading 1.23MiB to 155.247.166.219
11:50:45:WU01:FS00:Connecting to 155.247.166.219:8080
11:50:45:WU00:FS00:Starting
11:50:45:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
11:50:46:WU00:FS00:Started FahCore on PID 6444
11:50:46:WU00:FS00:Core PID:4436
11:50:46:WU00:FS00:FahCore 0xa4 started
11:50:46:WU00:FS00:0xa4:
11:50:46:WU00:FS00:0xa4:*------------------------------*
11:50:46:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
11:50:46:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:50:46:WU00:FS00:0xa4:Preparing to commence simulation
11:50:46:WU00:FS00:0xa4:- Looking at optimizations...
11:50:46:WU00:FS00:0xa4:- Created dyn
11:50:46:WU00:FS00:0xa4:- Files status OK
11:50:46:WU00:FS00:0xa4:- Expanded 119383 -> 271752 (decompressed 227.6 percent)
11:50:46:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=119383 data_size=271752, decompressed_data_size=271752 diff=0
11:50:46:WU00:FS00:0xa4:- Digital signature verified
11:50:46:WU00:FS00:0xa4:Project: 6396 (Run 71, Clone 2, Gen 30)
11:50:46:WU00:FS00:0xa4:Assembly optimizations on if available.
11:50:46:WU00:FS00:0xa4:Entering M.D.
11:50:51:WU01:FS00:Upload complete
11:50:51:WU01:FS00:Server responded WORK_ACK (400)
11:50:51:WU01:FS00:Final credit estimate, 2913.00 points
11:50:51:WU01:FS00:Cleaning up
11:50:52:WU00:FS00:0xa4:Mapping NT from 12 to 12
11:50:52:WU00:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
11:52:04:WU00:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
11:53:18:WU00:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
11:54:30:WU00:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
11:55:42:WU00:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
11:56:45:WU00:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
11:57:49:WU00:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
11:58:52:WU00:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
11:59:56:WU00:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
12:00:59:WU00:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
12:02:02:WU00:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
12:03:05:WU00:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
12:04:09:WU00:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
12:05:12:WU00:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
12:06:15:WU00:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
12:07:18:WU00:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
12:08:21:WU00:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
12:09:24:WU00:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
12:10:28:WU00:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
12:11:30:WU00:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
12:12:34:WU00:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
12:13:37:WU00:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
12:14:40:WU00:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
12:15:43:WU00:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
12:16:46:WU00:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
12:17:48:WU00:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
12:18:51:WU00:FS00:0xa4:Completed 1300000 out of 5000000 steps  (26%)
12:19:53:WU00:FS00:0xa4:Completed 1350000 out of 5000000 steps  (27%)
12:20:55:WU00:FS00:0xa4:Completed 1400000 out of 5000000 steps  (28%)
12:21:58:WU00:FS00:0xa4:Completed 1450000 out of 5000000 steps  (29%)
12:23:01:WU00:FS00:0xa4:Completed 1500000 out of 5000000 steps  (30%)
12:24:04:WU00:FS00:0xa4:Completed 1550000 out of 5000000 steps  (31%)
12:25:07:WU00:FS00:0xa4:Completed 1600000 out of 5000000 steps  (32%)
12:26:10:WU00:FS00:0xa4:Completed 1650000 out of 5000000 steps  (33%)
12:27:13:WU00:FS00:0xa4:Completed 1700000 out of 5000000 steps  (34%)
12:28:16:WU00:FS00:0xa4:Completed 1750000 out of 5000000 steps  (35%)
12:29:19:WU00:FS00:0xa4:Completed 1800000 out of 5000000 steps  (36%)
12:30:22:WU00:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
12:31:25:WU00:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
12:32:28:WU00:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
12:33:31:WU00:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
12:34:34:WU00:FS00:0xa4:Completed 2050000 out of 5000000 steps  (41%)
12:35:37:WU00:FS00:0xa4:Completed 2100000 out of 5000000 steps  (42%)
12:36:39:WU00:FS00:0xa4:Completed 2150000 out of 5000000 steps  (43%)
12:37:42:WU00:FS00:0xa4:Completed 2200000 out of 5000000 steps  (44%)
12:38:45:WU00:FS00:0xa4:Completed 2250000 out of 5000000 steps  (45%)
12:39:48:WU00:FS00:0xa4:Completed 2300000 out of 5000000 steps  (46%)
12:40:50:WU00:FS00:0xa4:Completed 2350000 out of 5000000 steps  (47%)
12:41:52:WU00:FS00:0xa4:Completed 2400000 out of 5000000 steps  (48%)
12:42:55:WU00:FS00:0xa4:Completed 2450000 out of 5000000 steps  (49%)
12:43:58:WU00:FS00:0xa4:Completed 2500000 out of 5000000 steps  (50%)
12:45:00:WU00:FS00:0xa4:Completed 2550000 out of 5000000 steps  (51%)
12:46:03:WU00:FS00:0xa4:Completed 2600000 out of 5000000 steps  (52%)
12:47:06:WU00:FS00:0xa4:Completed 2650000 out of 5000000 steps  (53%)
12:48:08:WU00:FS00:0xa4:Completed 2700000 out of 5000000 steps  (54%)
12:49:11:WU00:FS00:0xa4:Completed 2750000 out of 5000000 steps  (55%)
12:50:14:WU00:FS00:0xa4:Completed 2800000 out of 5000000 steps  (56%)
12:51:16:WU00:FS00:0xa4:Completed 2850000 out of 5000000 steps  (57%)
12:52:19:WU00:FS00:0xa4:Completed 2900000 out of 5000000 steps  (58%)
12:53:22:WU00:FS00:0xa4:Completed 2950000 out of 5000000 steps  (59%)
12:54:25:WU00:FS00:0xa4:Completed 3000000 out of 5000000 steps  (60%)
12:55:28:WU00:FS00:0xa4:Completed 3050000 out of 5000000 steps  (61%)
12:56:32:WU00:FS00:0xa4:Completed 3100000 out of 5000000 steps  (62%)
12:57:37:WU00:FS00:0xa4:Completed 3150000 out of 5000000 steps  (63%)
12:58:40:WU00:FS00:0xa4:Completed 3200000 out of 5000000 steps  (64%)
12:59:44:WU00:FS00:0xa4:Completed 3250000 out of 5000000 steps  (65%)
13:00:47:WU00:FS00:0xa4:Completed 3300000 out of 5000000 steps  (66%)
13:01:50:WU00:FS00:0xa4:Completed 3350000 out of 5000000 steps  (67%)
13:02:54:WU00:FS00:0xa4:Completed 3400000 out of 5000000 steps  (68%)
13:03:58:WU00:FS00:0xa4:Completed 3450000 out of 5000000 steps  (69%)
13:05:01:WU00:FS00:0xa4:Completed 3500000 out of 5000000 steps  (70%)
13:06:04:WU00:FS00:0xa4:Completed 3550000 out of 5000000 steps  (71%)
13:07:08:WU00:FS00:0xa4:Completed 3600000 out of 5000000 steps  (72%)
13:08:11:WU00:FS00:0xa4:Completed 3650000 out of 5000000 steps  (73%)
13:09:14:WU00:FS00:0xa4:Completed 3700000 out of 5000000 steps  (74%)
13:10:18:WU00:FS00:0xa4:Completed 3750000 out of 5000000 steps  (75%)
13:11:21:WU00:FS00:0xa4:Completed 3800000 out of 5000000 steps  (76%)
13:12:24:WU00:FS00:0xa4:Completed 3850000 out of 5000000 steps  (77%)
13:13:27:WU00:FS00:0xa4:Completed 3900000 out of 5000000 steps  (78%)
13:14:30:WU00:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
13:15:34:WU00:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
13:16:38:WU00:FS00:0xa4:Completed 4050000 out of 5000000 steps  (81%)
13:17:41:WU00:FS00:0xa4:Completed 4100000 out of 5000000 steps  (82%)
13:18:45:WU00:FS00:0xa4:Completed 4150000 out of 5000000 steps  (83%)
13:19:48:WU00:FS00:0xa4:Completed 4200000 out of 5000000 steps  (84%)
13:20:51:WU00:FS00:0xa4:Completed 4250000 out of 5000000 steps  (85%)
13:21:54:WU00:FS00:0xa4:Completed 4300000 out of 5000000 steps  (86%)
13:22:58:WU00:FS00:0xa4:Completed 4350000 out of 5000000 steps  (87%)
13:24:01:WU00:FS00:0xa4:Completed 4400000 out of 5000000 steps  (88%)
13:25:04:WU00:FS00:0xa4:Completed 4450000 out of 5000000 steps  (89%)
13:26:07:WU00:FS00:0xa4:Completed 4500000 out of 5000000 steps  (90%)
13:27:10:WU00:FS00:0xa4:Completed 4550000 out of 5000000 steps  (91%)
13:28:13:WU00:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
13:29:17:WU00:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
13:30:20:WU00:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
13:31:24:WU00:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
13:32:28:WU00:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
13:33:33:WU00:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
13:34:39:WU00:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
13:35:44:WU00:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
13:35:45:WU01:FS00:Connecting to 171.67.108.200:8080
13:35:45:WU01:FS00:Assigned to work server 171.64.65.124
13:35:45:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.124
13:35:45:WU01:FS00:Connecting to 171.64.65.124:8080
13:35:46:WU01:FS00:Downloading 903.40KiB
13:35:48:WU01:FS00:Download complete
13:35:48:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9011 run:209 clone:3 gen:181 core:0xa4 unit:0x000000ca664f2de453c87723a9ab65ac
13:36:50:WU00:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
13:36:50:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
13:37:00:WU00:FS00:0xa4:
13:37:00:WU00:FS00:0xa4:Finished Work Unit:
13:37:00:WU00:FS00:0xa4:- Reading up to 1256376 from "00/wudata_01.trr": Read 1256376
13:37:00:WU00:FS00:0xa4:trr file hash check passed.
13:37:00:WU00:FS00:0xa4:- Reading up to 111824 from "00/wudata_01.xtc": Read 111824
13:37:00:WU00:FS00:0xa4:xtc file hash check passed.
13:37:00:WU00:FS00:0xa4:edr file hash check passed.
13:37:00:WU00:FS00:0xa4:logfile size: 90664
13:37:00:WU00:FS00:0xa4:Leaving Run
13:37:01:WU00:FS00:0xa4:- Writing 1530764 bytes of core data to disk...
13:37:01:WU00:FS00:0xa4:Done: 1530252 -> 1293437 (compressed to 84.5 percent)
13:37:01:WU00:FS00:0xa4:  ... Done.
13:37:01:WU00:FS00:0xa4:- Shutting down core
13:37:01:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
13:37:01:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:37:01:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:6396 run:71 clone:2 gen:30 core:0xa4 unit:0x000000220002894b5462c8b21bbe5638
13:37:01:WU00:FS00:Uploading 1.23MiB to 155.247.166.219
13:37:01:WU00:FS00:Connecting to 155.247.166.219:8080
13:37:01:WU01:FS00:Starting
13:37:01:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
13:37:02:WU01:FS00:Started FahCore on PID 7088
13:37:02:WU01:FS00:Core PID:5612
13:37:02:WU01:FS00:FahCore 0xa4 started
13:37:02:WU01:FS00:0xa4:
13:37:02:WU01:FS00:0xa4:*------------------------------*
13:37:02:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:37:02:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:37:02:WU01:FS00:0xa4:Preparing to commence simulation
13:37:02:WU01:FS00:0xa4:- Looking at optimizations...
13:37:02:WU01:FS00:0xa4:- Created dyn
13:37:02:WU01:FS00:0xa4:- Files status OK
13:37:02:WU01:FS00:0xa4:- Expanded 924567 -> 1527780 (decompressed 165.2 percent)
13:37:02:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=924567 data_size=1527780, decompressed_data_size=1527780 diff=0
13:37:02:WU01:FS00:0xa4:- Digital signature verified
13:37:02:WU01:FS00:0xa4:Project: 9011 (Run 209, Clone 3, Gen 181)
13:37:02:WU01:FS00:0xa4:Assembly optimizations on if available.
13:37:02:WU01:FS00:0xa4:Entering M.D.
13:37:07:WU00:FS00:Upload 100.00%
13:37:07:WU00:FS00:Upload complete
13:37:07:WU00:FS00:Server responded WORK_ACK (400)
13:37:07:WU00:FS00:Final credit estimate, 2940.00 points
13:37:07:WU00:FS00:Cleaning up
13:37:08:WU01:FS00:0xa4:Mapping NT from 12 to 12
13:37:08:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
13:37:54:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
13:38:39:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
13:39:25:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
13:40:10:WU01:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
13:40:56:WU01:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
13:41:41:WU01:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
13:42:27:WU01:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
13:43:12:WU01:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
13:43:57:WU01:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
13:44:43:WU01:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
13:45:28:WU01:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
13:46:13:WU01:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
13:46:59:WU01:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
13:47:44:WU01:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
13:48:30:WU01:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
13:49:15:WU01:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
13:50:00:WU01:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
13:50:45:WU01:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
13:51:31:WU01:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
13:52:16:WU01:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
13:53:01:WU01:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
13:53:46:WU01:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
13:54:32:WU01:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
13:55:17:WU01:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
13:56:02:WU01:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
13:56:48:WU01:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
13:57:33:WU01:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
13:58:18:WU01:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
13:59:04:WU01:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
13:59:49:WU01:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
14:00:34:WU01:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
14:01:20:WU01:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
14:02:05:WU01:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
14:02:51:WU01:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
14:03:36:WU01:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
14:04:21:WU01:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
14:05:07:WU01:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
14:05:52:WU01:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
14:06:37:WU01:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
14:07:23:WU01:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
14:08:08:WU01:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
14:08:54:WU01:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
14:09:39:WU01:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
14:10:24:WU01:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
14:11:10:WU01:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
14:11:55:WU01:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
14:12:41:WU01:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
14:13:26:WU01:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
14:14:11:WU01:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
14:14:57:WU01:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
14:15:42:WU01:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
14:16:28:WU01:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
14:17:13:WU01:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
14:17:58:WU01:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
14:18:44:WU01:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
14:19:29:WU01:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
14:20:14:WU01:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
14:21:00:WU01:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
14:21:45:WU01:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
14:22:30:WU01:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
14:23:16:WU01:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
14:24:01:WU01:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
14:24:47:WU01:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
14:25:32:WU01:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
14:26:17:WU01:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
14:27:03:WU01:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
14:27:48:WU01:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
14:28:34:WU01:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
14:29:19:WU01:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
14:30:04:WU01:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
14:30:50:WU01:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
14:31:35:WU01:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
14:32:20:WU01:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
14:33:06:WU01:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
14:33:51:WU01:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
14:34:36:WU01:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
14:35:22:WU01:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
14:36:07:WU01:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
14:36:53:WU01:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
14:37:38:WU01:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
14:38:23:WU01:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
14:39:09:WU01:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
14:39:54:WU01:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
14:40:39:WU01:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
14:41:25:WU01:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
14:42:10:WU01:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
14:42:56:WU01:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
14:43:41:WU01:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
14:44:26:WU01:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
14:45:12:WU01:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
14:45:57:WU01:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
14:46:42:WU01:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
14:47:28:WU01:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
14:48:13:WU01:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
14:48:59:WU01:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
14:49:44:WU01:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
14:50:29:WU01:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
14:51:14:WU01:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
14:52:00:WU01:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
14:52:00:WU00:FS00:Connecting to 171.67.108.200:8080
14:52:01:WU00:FS00:Assigned to work server 171.64.65.124
14:52:01:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.124
14:52:01:WU00:FS00:Connecting to 171.64.65.124:8080
14:52:02:WU00:FS00:Downloading 807.67KiB
14:52:03:WU00:FS00:Download complete
14:52:03:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9016 run:118 clone:6 gen:45 core:0xa4 unit:0x00000035664f2de4549de681b779ba35
14:52:45:WU01:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
14:52:46:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:52:56:WU01:FS00:0xa4:
14:52:56:WU01:FS00:0xa4:Finished Work Unit:
14:52:56:WU01:FS00:0xa4:- Reading up to 917280 from "01/wudata_01.trr": Read 917280
14:52:56:WU01:FS00:0xa4:trr file hash check passed.
14:52:56:WU01:FS00:0xa4:- Reading up to 840476 from "01/wudata_01.xtc": Read 840476
14:52:56:WU01:FS00:0xa4:xtc file hash check passed.
14:52:56:WU01:FS00:0xa4:edr file hash check passed.
14:52:56:WU01:FS00:0xa4:logfile size: 23201
14:52:56:WU01:FS00:0xa4:Leaving Run
14:53:00:WU01:FS00:0xa4:- Writing 1783445 bytes of core data to disk...
14:53:00:WU01:FS00:0xa4:Done: 1782933 -> 1723855 (compressed to 96.6 percent)
14:53:00:WU01:FS00:0xa4:  ... Done.
14:53:01:WU01:FS00:0xa4:- Shutting down core
14:53:01:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:53:01:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:53:01:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9011 run:209 clone:3 gen:181 core:0xa4 unit:0x000000ca664f2de453c87723a9ab65ac
14:53:01:WU01:FS00:Uploading 1.64MiB to 171.64.65.124
14:53:01:WU00:FS00:Starting
14:53:01:WU01:FS00:Connecting to 171.64.65.124:8080
14:53:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
14:53:01:WU00:FS00:Started FahCore on PID 6356
14:53:02:WU00:FS00:Core PID:6248
14:53:02:WU00:FS00:FahCore 0xa4 started
14:53:02:WU00:FS00:0xa4:
14:53:02:WU00:FS00:0xa4:*------------------------------*
14:53:02:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:53:02:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:53:02:WU00:FS00:0xa4:Preparing to commence simulation
14:53:02:WU00:FS00:0xa4:- Looking at optimizations...
14:53:02:WU00:FS00:0xa4:- Created dyn
14:53:02:WU00:FS00:0xa4:- Files status OK
14:53:02:WU00:FS00:0xa4:- Expanded 826542 -> 1397548 (decompressed 169.0 percent)
14:53:02:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826542 data_size=1397548, decompressed_data_size=1397548 diff=0
14:53:02:WU00:FS00:0xa4:- Digital signature verified
14:53:02:WU00:FS00:0xa4:Project: 9016 (Run 118, Clone 6, Gen 45)
14:53:02:WU00:FS00:0xa4:Assembly optimizations on if available.
14:53:02:WU00:FS00:0xa4:Entering M.D.
14:53:07:WU01:FS00:Upload 45.61%
14:53:08:WU00:FS00:0xa4:Mapping NT from 12 to 12
14:53:08:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
14:53:13:WU01:FS00:Upload 95.01%
14:53:14:WU01:FS00:Upload complete
14:53:14:WU01:FS00:Server responded WORK_ACK (400)
14:53:14:WU01:FS00:Final credit estimate, 2421.00 points
14:53:14:WU01:FS00:Cleaning up
14:53:52:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
14:54:37:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
14:55:21:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
14:56:06:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
14:56:50:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
14:57:41:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
******************************* Date: 2015-02-21 *******************************
14:58:25:WU00:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
14:59:10:WU00:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
14:59:54:WU00:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
15:00:38:WU00:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
15:01:22:WU00:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
15:02:07:WU00:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
15:02:51:WU00:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
15:03:36:WU00:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
15:04:20:WU00:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
15:05:04:WU00:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
15:05:49:WU00:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
15:06:33:WU00:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
15:07:17:WU00:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
15:08:02:WU00:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
15:08:46:WU00:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
15:09:31:WU00:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
15:10:15:WU00:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
15:11:00:WU00:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
15:11:44:WU00:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
15:12:28:WU00:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
15:13:12:WU00:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
15:13:57:WU00:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
15:14:41:WU00:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
15:15:26:WU00:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
15:16:10:WU00:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
15:16:55:WU00:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
15:17:39:WU00:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
15:18:23:WU00:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
15:19:08:WU00:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
15:19:52:WU00:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
15:20:37:WU00:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
15:21:21:WU00:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
15:22:06:WU00:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
15:22:50:WU00:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
15:23:35:WU00:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
15:24:20:WU00:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
15:25:05:WU00:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
15:25:49:WU00:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
15:26:33:WU00:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
15:27:17:WU00:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
15:28:02:WU00:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
15:28:45:WU00:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
15:29:30:WU00:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
15:30:14:WU00:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
15:30:58:WU00:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
15:31:43:WU00:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
15:32:27:WU00:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
15:33:12:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
15:33:57:WU00:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
15:34:42:WU00:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
15:35:26:WU00:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
15:36:10:WU00:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
15:36:55:WU00:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
15:37:40:WU00:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
15:38:24:WU00:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
15:39:08:WU00:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
15:39:52:WU00:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
15:40:36:WU00:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
15:41:20:WU00:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
15:42:04:WU00:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
15:42:47:WU00:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
15:43:31:WU00:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
15:44:15:WU00:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
15:44:59:WU00:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
15:45:43:WU00:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
15:46:27:WU00:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
15:47:11:WU00:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
15:47:55:WU00:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
15:48:39:WU00:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
15:49:23:WU00:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
15:50:07:WU00:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
15:50:51:WU00:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
15:51:36:WU00:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
15:52:20:WU00:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
15:53:04:WU00:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
15:53:49:WU00:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
15:54:33:WU00:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
15:55:17:WU00:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
15:56:01:WU00:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
15:56:45:WU00:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
15:57:30:WU00:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
15:58:14:WU00:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
15:58:58:WU00:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
15:59:42:WU00:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
16:00:26:WU00:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
16:01:10:WU00:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
16:01:54:WU00:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
16:02:39:WU00:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
16:03:23:WU00:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
16:04:07:WU00:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
16:04:51:WU00:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
16:05:35:WU00:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
16:06:19:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
16:06:20:WU01:FS00:Connecting to 171.67.108.200:8080
16:06:21:WU01:FS00:Assigned to work server 171.64.65.124
16:06:21:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.124
16:06:21:WU01:FS00:Connecting to 171.64.65.124:8080
16:06:22:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:06:22:WU01:FS00:Connecting to 171.64.65.124:80
16:06:23:ERROR:WU01:FS00:Exception: Failed to connect to 171.64.65.124:80: No connection could be made because the target machine actively refused it.
16:06:23:WU01:FS00:Connecting to 171.67.108.200:8080
16:06:24:WU01:FS00:Assigned to work server 171.64.65.124
16:06:24:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 171.64.65.124
16:06:24:WU01:FS00:Connecting to 171.64.65.124:8080
16:06:25:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:06:25:WU01:FS00:Connecting to 171.64.65.124:80
16:06:27:ERROR:WU01:FS00:Exception: Failed to connect to 171.64.65.124:80: No connection could be made because the target machine actively refused it.
16:07:03:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
16:07:04:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
16:07:14:WU00:FS00:0xa4:
16:07:14:WU00:FS00:0xa4:Finished Work Unit:
16:07:14:WU00:FS00:0xa4:- Reading up to 811488 from "00/wudata_01.trr": Read 811488
16:07:14:WU00:FS00:0xa4:trr file hash check passed.
16:07:14:WU00:FS00:0xa4:- Reading up to 746052 from "00/wudata_01.xtc": Read 746052
16:07:14:WU00:FS00:0xa4:xtc file hash check passed.
16:07:14:WU00:FS00:0xa4:edr file hash check passed.
16:07:14:WU00:FS00:0xa4:logfile size: 22755
16:07:14:WU00:FS00:0xa4:Leaving Run
16:07:14:WU00:FS00:0xa4:- Writing 1582783 bytes of core data to disk...
16:07:15:WU00:FS00:0xa4:Done: 1582271 -> 1537409 (compressed to 97.1 percent)
16:07:15:WU00:FS00:0xa4:  ... Done.
16:07:15:WU00:FS00:0xa4:- Shutting down core
16:07:15:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
16:07:15:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:07:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9016 run:118 clone:6 gen:45 core:0xa4 unit:0x00000035664f2de4549de681b779ba35
16:07:15:WU00:FS00:Uploading 1.47MiB to 171.64.65.124
16:07:15:WU00:FS00:Connecting to 171.64.65.124:8080
16:07:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
16:07:17:WU00:FS00:Connecting to 171.64.65.124:80
16:07:18:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.124:80: No connection could be made because the target machine actively refused it.
16:07:18:WU00:FS00:Trying to send results to collection server
16:07:18:WU00:FS00:Uploading 1.47MiB to 171.65.103.160
16:07:18:WU00:FS00:Connecting to 171.65.103.160:8080
16:07:24:WU00:FS00:Upload 51.14%
16:07:24:WU01:FS00:Connecting to 171.67.108.200:8080
16:07:24:WU01:FS00:Assigned to work server 171.64.65.124
16:07:24:WU01:FS00:Requesting new work unit for slot 00: READY cpu:12 from 171.64.65.124
16:07:24:WU01:FS00:Connecting to 171.64.65.124:8080
16:07:25:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:07:25:WU01:FS00:Connecting to 171.64.65.124:80
16:07:27:ERROR:WU01:FS00:Exception: Failed to connect to 171.64.65.124:80: No connection could be made because the target machine actively refused it.
16:07:29:WU00:FS00:Upload complete
16:07:29:WU00:FS00:Server responded WORK_ACK (400)
16:07:29:WU00:FS00:Final credit estimate, 2440.00 points
16:07:29:WU00:FS00:Cleaning up
16:09:01:WU01:FS00:Connecting to 171.67.108.200:8080
16:09:01:WU01:FS00:Assigned to work server 171.64.65.124
16:09:01:WU01:FS00:Requesting new work unit for slot 00: READY cpu:12 from 171.64.65.124
16:09:01:WU01:FS00:Connecting to 171.64.65.124:8080
16:09:02:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:09:02:WU01:FS00:Connecting to 171.64.65.124:80
16:09:04:ERROR:WU01:FS00:Exception: Failed to connect to 171.64.65.124:80: No connection could be made because the target machine actively refused it.
16:11:38:WU01:FS00:Connecting to 171.67.108.200:8080
16:11:39:WU01:FS00:Assigned to work server 155.247.166.219
16:11:39:WU01:FS00:Requesting new work unit for slot 00: READY cpu:12 from 155.247.166.219
16:11:39:WU01:FS00:Connecting to 155.247.166.219:8080
16:11:39:WU01:FS00:Downloading 116.28KiB
16:11:39:WU01:FS00:Download complete
16:11:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6397 run:95 clone:11 gen:16 core:0xa4 unit:0x000000120002894b5462ca1e94c391b8
16:11:39:WU01:FS00:Starting
16:11:39:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/user-99/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1512 -checkpoint 15 -np 12
16:11:40:WU01:FS00:Started FahCore on PID 5612
16:11:40:WU01:FS00:Core PID:5536
16:11:40:WU01:FS00:FahCore 0xa4 started
16:11:41:WU01:FS00:0xa4:
16:11:41:WU01:FS00:0xa4:*------------------------------*
16:11:41:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
16:11:41:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
16:11:41:WU01:FS00:0xa4:Preparing to commence simulation
16:11:41:WU01:FS00:0xa4:- Looking at optimizations...
16:11:41:WU01:FS00:0xa4:- Created dyn
16:11:41:WU01:FS00:0xa4:- Files status OK
16:11:41:WU01:FS00:0xa4:- Expanded 118555 -> 268860 (decompressed 226.7 percent)
16:11:41:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=118555 data_size=268860, decompressed_data_size=268860 diff=0
16:11:41:WU01:FS00:0xa4:- Digital signature verified
16:11:41:WU01:FS00:0xa4:Project: 6397 (Run 95, Clone 11, Gen 16)
16:11:41:WU01:FS00:0xa4:Assembly optimizations on if available.
16:11:41:WU01:FS00:0xa4:Entering M.D.
16:11:46:WU01:FS00:0xa4:Mapping NT from 12 to 12
16:11:46:WU01:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
16:12:49:WU01:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
16:13:52:WU01:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
16:14:55:WU01:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
16:15:59:WU01:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
16:17:10:WU01:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
16:18:15:WU01:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
16:20:15:WU01:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
16:22:09:WU01:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
16:23:48:WU01:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
16:25:23:WU01:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
16:26:44:WU01:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
16:28:46:WU01:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
16:30:33:WU01:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
16:31:44:WU01:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
16:33:01:WU01:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
16:34:03:WU01:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
16:35:06:WU01:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
16:36:08:WU01:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
16:37:11:WU01:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
16:38:13:WU01:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
16:39:16:WU01:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
16:40:18:WU01:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
16:41:22:WU01:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
16:42:25:WU01:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
16:43:28:WU01:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
16:44:31:WU01:FS00:0xa4:Completed 1300000 out of 5000000 steps  (26%)
16:45:34:WU01:FS00:0xa4:Completed 1350000 out of 5000000 steps  (27%)
16:46:37:WU01:FS00:0xa4:Completed 1400000 out of 5000000 steps  (28%)
16:47:40:WU01:FS00:0xa4:Completed 1450000 out of 5000000 steps  (29%)
16:48:43:WU01:FS00:0xa4:Completed 1500000 out of 5000000 steps  (30%)
16:49:46:WU01:FS00:0xa4:Completed 1550000 out of 5000000 steps  (31%)
16:50:49:WU01:FS00:0xa4:Completed 1600000 out of 5000000 steps  (32%)
16:51:54:WU01:FS00:0xa4:Completed 1650000 out of 5000000 steps  (33%)
16:52:57:WU01:FS00:0xa4:Completed 1700000 out of 5000000 steps  (34%)
16:54:00:WU01:FS00:0xa4:Completed 1750000 out of 5000000 steps  (35%)
16:55:03:WU01:FS00:0xa4:Completed 1800000 out of 5000000 steps  (36%)
16:56:06:WU01:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
16:57:09:WU01:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
16:58:11:WU01:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
16:59:14:WU01:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
17:00:16:WU01:FS00:0xa4:Completed 2050000 out of 5000000 steps  (41%)
17:01:19:WU01:FS00:0xa4:Completed 2100000 out of 5000000 steps  (42%)
17:02:22:WU01:FS00:0xa4:Completed 2150000 out of 5000000 steps  (43%)
17:03:25:WU01:FS00:0xa4:Completed 2200000 out of 5000000 steps  (44%)
17:04:28:WU01:FS00:0xa4:Completed 2250000 out of 5000000 steps  (45%)
17:05:30:WU01:FS00:0xa4:Completed 2300000 out of 5000000 steps  (46%)
17:06:33:WU01:FS00:0xa4:Completed 2350000 out of 5000000 steps  (47%)
17:07:36:WU01:FS00:0xa4:Completed 2400000 out of 5000000 steps  (48%)
17:08:38:WU01:FS00:0xa4:Completed 2450000 out of 5000000 steps  (49%)
17:09:41:WU01:FS00:0xa4:Completed 2500000 out of 5000000 steps  (50%)
17:10:44:WU01:FS00:0xa4:Completed 2550000 out of 5000000 steps  (51%)
17:11:47:WU01:FS00:0xa4:Completed 2600000 out of 5000000 steps  (52%)
17:12:49:WU01:FS00:0xa4:Completed 2650000 out of 5000000 steps  (53%)
17:13:52:WU01:FS00:0xa4:Completed 2700000 out of 5000000 steps  (54%)
17:14:54:WU01:FS00:0xa4:Completed 2750000 out of 5000000 steps  (55%)
17:15:57:WU01:FS00:0xa4:Completed 2800000 out of 5000000 steps  (56%)
17:16:59:WU01:FS00:0xa4:Completed 2850000 out of 5000000 steps  (57%)
17:18:02:WU01:FS00:0xa4:Completed 2900000 out of 5000000 steps  (58%)
17:19:05:WU01:FS00:0xa4:Completed 2950000 out of 5000000 steps  (59%)
17:20:07:WU01:FS00:0xa4:Completed 3000000 out of 5000000 steps  (60%)
17:21:10:WU01:FS00:0xa4:Completed 3050000 out of 5000000 steps  (61%)
17:22:13:WU01:FS00:0xa4:Completed 3100000 out of 5000000 steps  (62%)
17:23:16:WU01:FS00:0xa4:Completed 3150000 out of 5000000 steps  (63%)
17:24:19:WU01:FS00:0xa4:Completed 3200000 out of 5000000 steps  (64%)
17:25:22:WU01:FS00:0xa4:Completed 3250000 out of 5000000 steps  (65%)
17:26:25:WU01:FS00:0xa4:Completed 3300000 out of 5000000 steps  (66%)
17:27:28:WU01:FS00:0xa4:Completed 3350000 out of 5000000 steps  (67%)
17:28:31:WU01:FS00:0xa4:Completed 3400000 out of 5000000 steps  (68%)
17:29:34:WU01:FS00:0xa4:Completed 3450000 out of 5000000 steps  (69%)
17:30:50:WU01:FS00:0xa4:Completed 3500000 out of 5000000 steps  (70%)
17:31:53:WU01:FS00:0xa4:Completed 3550000 out of 5000000 steps  (71%)
17:32:55:WU01:FS00:0xa4:Completed 3600000 out of 5000000 steps  (72%)
17:33:58:WU01:FS00:0xa4:Completed 3650000 out of 5000000 steps  (73%)
17:35:01:WU01:FS00:0xa4:Completed 3700000 out of 5000000 steps  (74%)
17:36:03:WU01:FS00:0xa4:Completed 3750000 out of 5000000 steps  (75%)
17:37:06:WU01:FS00:0xa4:Completed 3800000 out of 5000000 steps  (76%)
17:38:09:WU01:FS00:0xa4:Completed 3850000 out of 5000000 steps  (77%)
17:39:13:WU01:FS00:0xa4:Completed 3900000 out of 5000000 steps  (78%)
17:40:16:WU01:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
17:41:20:WU01:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
17:42:23:WU01:FS00:0xa4:Completed 4050000 out of 5000000 steps  (81%)
17:43:26:WU01:FS00:0xa4:Completed 4100000 out of 5000000 steps  (82%)
17:44:29:WU01:FS00:0xa4:Completed 4150000 out of 5000000 steps
Intel i7-3930K@4.7GHz, 3-way GTX680 SLI, 32GB ram
Samsung ssd in rapid mode, Kingston ssd for apps, 1TB WD black for storage, 1K watt psu.
Mid 2010 Mac Mini, still plugging away ; )
Spei
Re: Somewhat new to F@H, have a few questions...
Post by Spei »
FYI-
The first posting of my log has some data deleted at the end so I could post within the size limitation.
The second posting of my log has some data deleted near the beginning...
