http://foldingforum.org/viewtopic.php?p=949#949
However, now I have too much of a good thing. In the process of trying to figure out what I was doing (with the vague or perhaps misguided idea of coming up with instructions for adding a console client so easy even anko1 could do it
-- Opening Log file [December 5 02:29:33]
# Windows Console Edition #####################################################
Folding@Home Client Version 5.04beta
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
Executable: C:\FAH2a\FAH504-Console.exe
Arguments: -configonly
[02:29:33] - Ask before connecting: No
[02:29:33] - User name: anko1 (Team 47815)
[02:29:33] - User ID: 14991F842ED3B1A8
[02:29:33] - Machine ID: 2
[02:29:33]
[02:29:33] Configuring Folding@Home...
--- Opening Log file [December 5 07:25:13]
[07:25:13] - Ask before connecting: No
[07:25:13] - User name: anko1 (Team 47815)
[07:25:13] - User ID: 14991F842ED3B1A8
[07:25:13] - Machine ID: 2
[07:25:13]
[07:25:13] Configuring Folding@Home...
[07:25:42] - Ask before connecting: No
[07:25:42] - User name: anko1 (Team 47815)
[07:25:42] - User ID: 14991F842ED3B1A8
[07:25:42] - Machine ID: 2
[07:25:42]
[07:25:42] -configonly flag given, so exiting.
--- Opening Log file [December 5 08:14:44]
Executable: C:\Test\FAH504-Console.exe
[08:14:44] - Ask before connecting: No
[08:14:44] - User name: anko1 (Team 47815)
[08:14:44] - User ID: 14991F842ED3B1A8
[08:14:44] - Machine ID: 2
[08:14:44]
[08:14:44] Configuring Folding@Home...
The program will continue in non-service mode now, working in C:\Program Files\Folding@Home.
The next time the computer is starts up, you should see work automatically
continue there. Note that when this service is running, you should not try
to manually run F@H from that directory at the same time.
[08:19:42] - Ask before connecting: No
[08:19:42] - User name: anko1 (Team 47815)
[08:19:42] - User ID: 14991F842ED3B1A8
[08:19:42] - Machine ID: 3
[08:19:42]
[08:19:42] -configonly flag given, so exiting.
--- Opening Log file [December 5 08:27:53]
[08:27:53] - Ask before connecting: No
[08:27:53] - User name: anko1 (Team 47815)
[08:27:53] - User ID: 14991F842ED3B1A8
[08:27:53] - Machine ID: 3
[08:27:53]
[08:27:53] Configuring Folding@Home...
--- Opening Log file [December 6 15:46:10]
# Windows Graphical Edition ###################################################
Folding@Home Client Version 5.03
[15:46:10] - Ask before connecting: No
[15:46:10] - User name: anko1 (Team 47815)
[15:46:10] - User ID: 14991F842ED3B1A8
[15:46:10] - Machine ID: 3
[15:46:10]
[15:46:10] Loaded queue successfully.
[15:46:10] Initialization complete
[15:46:10] + Benchmarking ...
[15:46:12]
[15:46:12] + Processing work unit
[15:46:12] Core required: FahCore_79.exe
[15:46:12] Core found.
[15:46:12] Working on Unit 06 [December 6 15:46:12]
[15:46:12] + Working ...
[15:46:13]
[15:46:13] *------------------------------*
[15:46:13] Folding@Home Double Gromacs Core
[15:46:13] Version 1.91 (April 11, 2006)
[15:46:13]
[15:46:13] Preparing to commence simulation
[15:46:13] - Looking at optimizations...
[15:46:13] - Files status OK
[15:46:33] - Expanded 9453186 -> 34412398 (decompressed 364.0 percent)
[15:46:34]
[15:46:34] Project: 3905 (Run 1229, Clone 4, Gen 1)
[15:46:34]
[15:46:34] Assembly optimizations on if available.
[15:46:34] Entering M.D.
[15:46:58] (Starting from checkpoint)
[15:46:58] Protein: IBX in water
[15:46:58]
[15:46:58] Writing local files
[15:46:58] Completed 216 out of 25000 steps (1)
[15:47:18] Extra SSE2 boost OK.
[15:55:43] Opening http://vspx27.stanford.edu/cgi-bin/main ... name=anko1...
[16:06:13] Writing local files
[16:06:14] Completed 500 out of 25000 steps (2)
[16:38:56] Writing local files
[16:38:57] Completed 1000 out of 25000 steps (4)
[17:11:23] Writing local files
[17:11:24] Completed 1500 out of 25000 steps (6)
[17:43:43] Writing local files
[17:43:45] Completed 2000 out of 25000 steps (8)
[18:15:56] Writing local files
[18:15:57] Completed 2500 out of 25000 steps (10)
[18:48:24] Writing local files
[18:48:25] Completed 3000 out of 25000 steps (12)
[19:21:00] Writing local files
[19:21:01] Completed 3500 out of 25000 steps (14)
So you can see that my graphical is now running on machine 3. I assumed that machine 1 was out of the picture, and when I checked the processes in the Windows Task Manager, all seemed good, with one program using 48% and the other using 48% or so.
Everything runs hunky-dory for awhile and then I notice that my graphical client has gone from 4min/frame to 6min/frame. So I click on the task manager to see what else is running to discover, low and behold, that I have three cores running at about 30%. I figure out which core is not being used by M2 or M3 and exit it. Check back a little later expecting that the time will have dropped, but no, it's still at 6min/f. Go back to task manager, and still have three cores running, but the third core is a different one. Hence, I've come to the conclusion that Machine 1 is alive and well somewhere, though I'm not sure what prompted its resurrection, since it was just M2 and M3 for several days.
I should also mention that I started to download a console client in C:\Program Files\FAH2, but like \Test, I didn't think I started it. Also I conducted an experiment (yes, I know, that's how I got in this mess in the first place), and shut down the console client I can "see" [the one I have a short cut to, that ends up in my task bar, and is on M2], and the process rates on the other two cores have jumped up to 48%. I also have two copies of FAH504-Console.exe in the Task Manager.
So, now I have some questions. (I see you rolling your eyes.
I presume that there's no advantage to running three programs when I can only use 30% on each, but is there a harm, other than slooooow processing?
I confess I have an inherent level of discomfort in not being able to track what's going on with M1. So I'd like to get rid of one of the console clients, preferably one that I can't "see." My first thought was to just trash \Test and \Program Files\FAH2, but I'm afraid that I'll loose machine 3 (or rather all the work the graphical client has done so far), and I don't see how to indicate which machine should be assigned to the graphical client. [Well the obvious solution is to wait till the unit is done.] So, I guess I'm asking, if I wait until the graphical WU is done, and then I trash \Test and \PF\FAH2, and then restart \FAH2a, will order be restored to my universe?
I've also noticed that when I close the window for the console client \FAH2a and then reopen it, sometimes it resumes the prior WU and sometimes it gets a new one.
Thanks again for all your help. I'll accept that maybe I have to start over with trashing all the consoles and just starting that from scratch (on M1?).
PS - just noticed that the console version above was launching from \Program Files, even if the executable was in a different directory. I presume this means I did something else wrong?
ed. for grammer
