Advanced Control reporting of work unit hung up at 99.99%
I am running FAH version 7.4.4 and using only a GPU slot on a windows 8.1 Intel I7 3770 computer. FAH works fine, but sometimes when I look at the Advanced Control screen it shows the WU as having completed 99.99% with an ETA of a few seconds. In reality FAH is working on a new WU as indicated by looking at the log file. When this happens the Web Control displays the same 99.99% complete information. I know the log file isn't stuck because I can stop or pause processing then start it again and that appears in the log entries. Exiting the Advance Control feature and restarting it does not fix the problem. If I quit FAH then restart it I loose the icon in the system tray and have to restart the computer if I want to access the Advance Control feature or view the progress on the web. Is this a known problem? If it matters I have a Radeon HD 7750 series video card. I do not have this problem on my other computer with almost identical components, but windows 7 O/S. On that one I have 6 slots running the cpu and one slot gpu versions.
Re: Advanced Control reporting of work unit hung up at 99.99
This is generally the result of some kind of driver interruption such as launching Microsoft's Remote Desktop or maybe something overheating or too much overclocking. Pause FAH ... wait 30 seconds ... unpause (Fold) and FAHControl should agree with the latter part of the log again. (Of course, you can reboot instead.)
Your suggestion of pausing the restarting does not work. However when I pause folding the WU information displayed either online or in Advanced Control changes to the proper data showing a completion of 73%. When I then choose fold again the data changes to the 99% figure on both web and advanced control.
Walter
Walter
Please post your log.
Ok here is the log. For some reason in the last 60- minutes the problem disappeared. I did nothing to affect it that I know of.
Walter
Mod edit: added code tags to log
Walter
****************** Log Started 2015-01-04T03:43:15Z ***********************
03:43:15:************************* Folding@home Client *************************
03:43:15: Website: http://folding.stanford.edu/
03:43:15: Copyright: (c) 2009-2014 Stanford University
03:43:15: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:43:15: Args: --open-web-control
03:43:15: Config: C:/Users/Walter H/AppData/Roaming/FAHClient/config.xml
03:43:15:******************************** Build ********************************
03:43:15: Version: 7.4.4
03:43:15: Date: Mar 4 2014
03:43:15: Time: 20:26:54
03:43:15: SVN Rev: 4130
03:43:15: Branch: fah/trunk/client
03:43:15: Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:43:15: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:43:15: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:43:15: Platform: win32 XP
03:43:15: Bits: 32
03:43:15: Mode: Release
03:43:15:******************************* System ********************************
03:43:15: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
03:43:15: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
03:43:15: CPUs: 8
03:43:15: Memory: 11.96GiB
03:43:15: Free Memory: 8.01GiB
03:43:15: Threads: WINDOWS_THREADS
03:43:15: OS Version: 6.2
03:43:15: Has Battery: false
03:43:15: On Battery: false
03:43:15: UTC Offset: -5
03:43:15: PID: 924
03:43:15: CWD: C:/Users/Walter H/AppData/Roaming/FAHClient
03:43:15: OS: Windows 8.1
03:43:15: OS Arch: AMD64
03:43:15: GPUs: 1
03:43:15: GPU 0: ATI:5 R575A [Radeon R7 250/HD 7700]
03:43:15: CUDA: Not detected
03:43:15:Win32 Service: false
03:43:15:***********************************************************************
03:43:15:<config>
03:43:15: <!-- Network -->
03:43:15: <proxy v=':8080'/>
03:43:15:
03:43:15: <!-- User Information -->
03:43:15: <passkey v='********************************'/>
03:43:15: <user v='Walter_Hamilton'/>
03:43:15:
03:43:15: <!-- Folding Slots -->
03:43:15: <slot id='1' type='GPU'/>
03:43:15:</config>
03:43:15:Trying to access database...
03:43:15:Successfully acquired database lock
03:43:15:Enabled folding slot 01: READY gpu:0:R575A [Radeon R7 250/HD 7700]
03:43:16:WU01:FS01:Starting
03:43:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:43:16:WU01:FS01:Started FahCore on PID 11544
03:43:16:WU01:FS01:Core PID:12156
03:43:16:WU01:FS01:FahCore 0x17 started
03:43:16:WU01:FS01:0x17:*********************** Log Started 2015-01-04T03:43:16Z ***********************
03:43:16:WU01:FS01:0x17:Project: 13000 (Run 1798, Clone 2, Gen 68)
03:43:16:WU01:FS01:0x17:Unit: 0x00000086538b3db753119834c481a3e9
03:43:16:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
03:43:16:WU01:FS01:0x17:Machine: 1
03:43:16:WU01:FS01:0x17:Digital signatures verified
03:43:16:WU01:FS01:0x17:Folding@home GPU core17
03:43:16:WU01:FS01:0x17:Version 0.0.52
03:43:16:WU01:FS01:0x17: Found a checkpoint file
03:44:16:Saving configuration to config.xml
03:44:16:<config>
03:44:16: <!-- Network -->
03:44:16: <proxy v=':8080'/>
03:44:16:
03:44:16: <!-- Slot Control -->
03:44:16: <power v='FULL'/>
03:44:16:
03:44:16: <!-- User Information -->
03:44:16: <passkey v='********************************'/>
03:44:16: <user v='Walter_Hamilton'/>
03:44:16:
03:44:16: <!-- Folding Slots -->
03:44:16: <slot id='1' type='GPU'/>
03:44:16:</config>
03:46:38:WU01:FS01:0x17:Completed 1750000 out of 5000000 steps (35%)
03:46:38:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:24:46:WU01:FS01:0x17:Completed 1800000 out of 5000000 steps (36%)
05:02:30:WU01:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
05:40:36:WU01:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
06:18:24:WU01:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
06:56:11:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
07:34:42:WU01:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
08:12:31:WU01:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
08:50:56:WU01:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
09:28:49:WU01:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
******************************* Date: 2015-01-04 *******************************
10:06:32:WU01:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
10:45:03:WU01:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
11:22:50:WU01:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
12:01:00:WU01:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
12:38:58:WU01:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
13:16:53:WU01:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
13:55:49:WU01:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
14:34:15:WU01:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
15:12:50:WU01:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
15:50:45:WU01:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
16:28:51:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
17:07:15:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
17:45:02:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
18:23:26:WU01:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
19:01:23:WU01:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
19:39:14:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
20:18:27:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
20:57:37:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
21:36:49:WU01:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
22:15:40:WU01:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
22:54:30:WU01:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
23:33:40:WU01:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
00:12:30:WU01:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
00:51:40:WU01:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
01:30:31:WU01:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
02:09:24:WU01:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
02:48:36:WU01:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
03:26:58:WU01:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
04:05:16:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
04:43:02:WU01:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
******************************* Date: 2015-01-05 *******************************
05:20:46:WU01:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
05:59:13:WU01:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
06:36:59:WU01:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
07:15:21:WU01:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
07:53:16:WU01:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
08:31:03:WU01:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
09:09:09:WU01:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
09:46:58:WU01:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
10:25:03:WU01:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
11:02:49:WU01:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
11:40:33:WU01:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
12:18:46:WU01:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
12:56:39:WU01:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
13:34:47:WU01:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
14:12:44:WU01:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
14:50:39:WU01:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
15:28:59:WU01:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
16:07:02:WU01:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
16:45:24:WU01:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
17:23:12:WU01:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
18:01:00:WU01:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
18:39:27:WU01:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
19:17:15:WU01:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
19:55:36:WU01:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
20:34:09:WU01:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
21:12:12:WU01:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
21:12:12:WU00:FS01:Connecting to 171.67.108.200:80
21:12:13:WU00:FS01:Assigned to work server 140.163.4.233
21:12:13:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:R575A [Radeon R7 250/HD 7700] from 140.163.4.233
21:12:13:WU00:FS01:Connecting to 140.163.4.233:8080
21:12:13:WU00:FS01:Downloading 4.32MiB
21:12:19:WU00:FS01:Download 76.66%
21:12:20:WU00:FS01:Download complete
21:12:20:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10468 run:0 clone:335 gen:76 core:0x17 unit:0x0000007d538b3db9538cb300ec2bd864
21:12:31:WU01:FS01:0x17:Saving result file logfile_01.txt
21:12:31:WU01:FS01:0x17:Saving result file checkpointState.xml
21:12:33:WU01:FS01:0x17:Saving result file checkpt.crc
21:12:33:WU01:FS01:0x17:Saving result file log.txt
21:12:34:WU01:FS01:0x17:Saving result file positions.xtc
21:12:36:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
21:12:37:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:12:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13000 run:1798 clone:2 gen:68 core:0x17 unit:0x00000086538b3db753119834c481a3e9
21:12:37:WU01:FS01:Uploading 12.83MiB to 140.163.4.231
21:12:37:WU01:FS01:Connecting to 140.163.4.231:8080
21:12:37:WU00:FS01:Starting
21:12:37:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:12:37:WU00:FS01:Started FahCore on PID 29524
21:12:37:WU00:FS01:Core PID:29892
21:12:37:WU00:FS01:FahCore 0x17 started
21:12:37:WU00:FS01:0x17:*********************** Log Started 2015-01-05T21:12:37Z ***********************
21:12:37:WU00:FS01:0x17:Project: 10468 (Run 0, Clone 335, Gen 76)
21:12:37:WU00:FS01:0x17:Unit: 0x0000007d538b3db9538cb300ec2bd864
21:12:37:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:12:37:WU00:FS01:0x17:Machine: 1
21:12:37:WU00:FS01:0x17:Reading tar file state.xml
21:12:38:WU00:FS01:0x17:Reading tar file system.xml
21:12:39:WU00:FS01:0x17:Reading tar file integrator.xml
21:12:39:WU00:FS01:0x17:Reading tar file core.xml
21:12:39:WU00:FS01:0x17:Digital signatures verified
21:12:39:WU00:FS01:0x17:Folding@home GPU core17
21:12:39:WU00:FS01:0x17:Version 0.0.52
21:12:43:WU01:FS01:Upload 16.08%
21:12:49:WU01:FS01:Upload 22.90%
21:12:55:WU01:FS01:Upload 33.13%
21:13:01:WU01:FS01:Upload 43.36%
21:13:07:WU01:FS01:Upload 53.59%
21:13:13:WU01:FS01:Upload 63.81%
21:13:19:WU01:FS01:Upload 74.04%
21:13:25:WU01:FS01:Upload 84.76%
21:13:31:WU01:FS01:Upload 94.99%
21:13:48:WU01:FS01:Upload complete
21:13:48:WU01:FS01:Server responded WORK_ACK (400)
21:13:48:WU01:FS01:Final credit estimate, 32680.00 points
21:13:48:WU01:FS01:Cleaning up
21:15:17:WU00:FS01:0x17:Completed 0 out of 5000000 steps (0%)
21:15:17:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:45:51:WU00:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
22:16:10:WU00:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
22:47:01:WU00:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
23:17:35:WU00:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
23:47:55:WU00:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
******************************* Date: 2015-01-06 *******************************
00:18:58:WU00:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
00:49:19:WU00:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
01:19:59:WU00:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
01:50:30:WU00:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
02:20:51:WU00:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
02:51:47:WU00:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
03:22:07:WU00:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
03:53:06:WU00:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
04:23:57:WU00:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
04:54:37:WU00:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
05:25:12:WU00:FS01:0x17:Completed 800000 out of 5000000 steps (16%)
05:55:32:WU00:FS01:0x17:Completed 850000 out of 5000000 steps (17%)
06:26:08:WU00:FS01:0x17:Completed 900000 out of 5000000 steps (18%)
06:56:28:WU00:FS01:0x17:Completed 950000 out of 5000000 steps (19%)
07:26:49:WU00:FS01:0x17:Completed 1000000 out of 5000000 steps (20%)
07:57:25:WU00:FS01:0x17:Completed 1050000 out of 5000000 steps (21%)
08:27:46:WU00:FS01:0x17:Completed 1100000 out of 5000000 steps (22%)
08:58:21:WU00:FS01:0x17:Completed 1150000 out of 5000000 steps (23%)
09:28:41:WU00:FS01:0x17:Completed 1200000 out of 5000000 steps (24%)
09:59:00:WU00:FS01:0x17:Completed 1250000 out of 5000000 steps (25%)
10:29:36:WU00:FS01:0x17:Completed 1300000 out of 5000000 steps (26%)
10:59:57:WU00:FS01:0x17:Completed 1350000 out of 5000000 steps (27%)
11:30:32:WU00:FS01:0x17:Completed 1400000 out of 5000000 steps (28%)
12:00:52:WU00:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
12:31:12:WU00:FS01:0x17:Completed 1500000 out of 5000000 steps (30%)
13:01:47:WU00:FS01:0x17:Completed 1550000 out of 5000000 steps (31%)
13:32:07:WU00:FS01:0x17:Completed 1600000 out of 5000000 steps (32%)
14:02:44:WU00:FS01:0x17:Completed 1650000 out of 5000000 steps (33%)
14:33:08:WU00:FS01:0x17:Completed 1700000 out of 5000000 steps (34%)
15:04:03:WU00:FS01:0x17:Completed 1750000 out of 5000000 steps (35%)
15:35:39:WU00:FS01:0x17:Completed 1800000 out of 5000000 steps (36%)
16:06:21:WU00:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
16:37:02:WU00:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
17:07:29:WU00:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
17:38:00:WU00:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
18:08:47:WU00:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
18:39:37:WU00:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
19:10:29:WU00:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
19:41:00:WU00:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
20:11:23:WU00:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
20:42:27:WU00:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
21:12:51:WU00:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
21:43:39:WU00:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
22:14:03:WU00:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
22:44:38:WU00:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
23:15:18:WU00:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
23:45:39:WU00:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
00:16:30:WU00:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
******************************* Date: 2015-01-07 *******************************
00:47:00:WU00:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
01:17:21:WU00:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
01:48:23:WU00:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
02:18:46:WU00:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
02:49:38:WU00:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
03:20:11:WU00:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
03:50:44:WU00:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
04:21:29:WU00:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
04:51:50:WU00:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
05:22:40:WU00:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
05:53:23:WU00:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
06:24:05:WU00:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
06:55:06:WU00:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
07:25:28:WU00:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
07:56:19:WU00:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
08:26:51:WU00:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
08:57:12:WU00:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
09:28:09:WU00:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
09:58:38:WU00:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
10:29:31:WU00:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
11:00:05:WU00:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
11:30:29:WU00:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
12:01:33:WU00:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
12:31:57:WU00:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
13:02:37:WU00:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
13:33:15:WU00:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
14:03:42:WU00:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
14:34:22:WU00:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
15:05:04:WU00:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
15:36:49:WU00:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
16:08:07:WU00:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
16:39:49:WU00:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
17:10:49:WU00:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
17:41:10:WU00:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
18:12:06:WU00:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
18:42:43:WU00:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
19:13:06:WU00:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
19:44:21:WU00:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
20:15:28:WU00:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
20:46:32:WU00:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
21:17:21:WU00:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
21:48:12:WU00:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
22:18:55:WU00:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
22:49:17:WU00:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
23:19:56:WU00:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
23:50:18:WU00:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
00:20:40:WU00:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
00:20:40:WU01:FS01:Connecting to 171.67.108.200:80
00:20:41:WU01:FS01:Assigned to work server 171.67.108.52
00:20:41:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:R575A [Radeon R7 250/HD 7700] from 171.67.108.52
00:20:41:WU01:FS01:Connecting to 171.67.108.52:8080
00:20:41:WU01:FS01:Downloading 1.52MiB
00:20:44:WU01:FS01:Download complete
00:20:44:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:481 clone:4 gen:138 core:0x17 unit:0x000000ba6652edc45399e8f89535fcf2
00:20:58:WU00:FS01:0x17:Saving result file logfile_01.txt
00:20:59:WU00:FS01:0x17:Saving result file checkpointState.xml
00:21:01:WU00:FS01:0x17:Saving result file checkpt.crc
00:21:01:WU00:FS01:0x17:Saving result file log.txt
00:21:01:WU00:FS01:0x17:Saving result file positions.xtc
00:21:04:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
00:21:05:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:21:05:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:10468 run:0 clone:335 gen:76 core:0x17 unit:0x0000007d538b3db9538cb300ec2bd864
00:21:05:WU00:FS01:Uploading 12.97MiB to 140.163.4.233
00:21:05:WU00:FS01:Connecting to 140.163.4.233:8080
00:21:05:WU01:FS01:Starting
00:21:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:21:05:WU01:FS01:Started FahCore on PID 43784
00:21:05:WU01:FS01:Core PID:40764
00:21:05:WU01:FS01:FahCore 0x17 started
00:21:05:WU01:FS01:0x17:*********************** Log Started 2015-01-08T00:21:05Z ***********************
00:21:05:WU01:FS01:0x17:Project: 9201 (Run 481, Clone 4, Gen 138)
00:21:05:WU01:FS01:0x17:Unit: 0x000000ba6652edc45399e8f89535fcf2
00:21:05:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:21:05:WU01:FS01:0x17:Machine: 1
00:21:05:WU01:FS01:0x17:Reading tar file state.xml
00:21:06:WU01:FS01:0x17:Reading tar file system.xml
00:21:06:WU01:FS01:0x17:Reading tar file integrator.xml
00:21:06:WU01:FS01:0x17:Reading tar file core.xml
00:21:06:WU01:FS01:0x17:Digital signatures verified
00:21:06:WU01:FS01:0x17:Folding@home GPU core17
00:21:06:WU01:FS01:0x17:Version 0.0.52
00:21:12:WU00:FS01:Upload 16.38%
00:21:18:WU00:FS01:Upload 24.09%
00:21:24:WU00:FS01:Upload 33.73%
00:21:30:WU00:FS01:Upload 43.85%
00:21:36:WU00:FS01:Upload 53.96%
00:21:40:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
00:21:40:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:21:42:WU00:FS01:Upload 64.08%
00:21:48:WU00:FS01:Upload 74.20%
00:21:54:WU00:FS01:Upload 83.84%
00:22:00:WU00:FS01:Upload 93.95%
00:22:17:WU00:FS01:Upload complete
00:22:17:WU00:FS01:Server responded WORK_ACK (400)
00:22:17:WU00:FS01:Final credit estimate, 30048.00 points
00:22:17:WU00:FS01:Cleaning up
00:33:35:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
00:45:14:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
00:57:10:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
01:08:51:WU01:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
******************************* Date: 2015-01-08 *******************************
01:20:25:WU01:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
01:31:57:WU01:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
01:43:30:WU01:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
01:55:04:WU01:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
02:06:37:WU01:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
02:18:09:WU01:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
02:29:42:WU01:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
02:41:15:WU01:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
02:52:51:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
03:04:24:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
03:16:03:WU01:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
03:27:52:WU01:FS01:0x17:Completed 800000 out of 5000000 steps (16%)
03:39:24:WU01:FS01:0x17:Completed 850000 out of 5000000 steps (17%)
03:50:55:WU01:FS01:0x17:Completed 900000 out of 5000000 steps (18%)
04:02:26:WU01:FS01:0x17:Completed 950000 out of 5000000 steps (19%)
04:14:16:WU01:FS01:0x17:Completed 1000000 out of 5000000 steps (20%)
04:25:53:WU01:FS01:0x17:Completed 1050000 out of 5000000 steps (21%)
04:37:47:WU01:FS01:0x17:Completed 1100000 out of 5000000 steps (22%)
04:49:25:WU01:FS01:0x17:Completed 1150000 out of 5000000 steps (23%)
05:01:19:WU01:FS01:0x17:Completed 1200000 out of 5000000 steps (24%)
05:12:57:WU01:FS01:0x17:Completed 1250000 out of 5000000 steps (25%)
05:24:28:WU01:FS01:0x17:Completed 1300000 out of 5000000 steps (26%)
05:35:59:WU01:FS01:0x17:Completed 1350000 out of 5000000 steps (27%)
05:47:30:WU01:FS01:0x17:Completed 1400000 out of 5000000 steps (28%)
05:59:01:WU01:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
06:10:31:WU01:FS01:0x17:Completed 1500000 out of 5000000 steps (30%)
06:22:02:WU01:FS01:0x17:Completed 1550000 out of 5000000 steps (31%)
06:33:33:WU01:FS01:0x17:Completed 1600000 out of 5000000 steps (32%)
06:45:03:WU01:FS01:0x17:Completed 1650000 out of 5000000 steps (33%)
06:56:35:WU01:FS01:0x17:Completed 1700000 out of 5000000 steps (34%)
07:08:05:WU01:FS01:0x17:Completed 1750000 out of 5000000 steps (35%)
07:19:36:WU01:FS01:0x17:Completed 1800000 out of 5000000 steps (36%)
07:31:07:WU01:FS01:0x17:Completed 1850000 out of 5000000 steps (37%)
07:42:38:WU01:FS01:0x17:Completed 1900000 out of 5000000 steps (38%)
07:54:09:WU01:FS01:0x17:Completed 1950000 out of 5000000 steps (39%)
08:05:39:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
08:17:11:WU01:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
08:28:42:WU01:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
08:40:13:WU01:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
08:51:51:WU01:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
09:03:29:WU01:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
09:15:01:WU01:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
09:26:32:WU01:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
09:38:03:WU01:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
09:49:34:WU01:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
10:01:06:WU01:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
10:12:37:WU01:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
10:24:09:WU01:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
10:35:40:WU01:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
10:47:12:WU01:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
10:58:43:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
11:10:14:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
11:21:46:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
11:33:18:WU01:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
11:44:50:WU01:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
11:56:22:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
12:07:54:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
12:19:28:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
12:31:02:WU01:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
12:42:34:WU01:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
12:54:07:WU01:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
13:05:39:WU01:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
13:17:30:WU01:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
13:29:28:WU01:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
13:41:20:WU01:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
13:53:09:WU01:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
14:04:58:WU01:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
14:16:58:WU01:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
14:28:43:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
14:38:15:Connecting to assign-GPU.stanford.edu:80
14:38:15:Updated GPUs.txt
******************************* Date: 2015-01-09 *******************************
02:00:04:14:127.0.0.1:New Web connection
02:04:02:FS01:Paused
02:04:02:FS01:Shutting core down
02:04:02:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 40764
02:04:02:WU01:FS01:0x17:Exiting, please wait. . .
02:04:08:FS01:Unpaused
11:02:07:FS01:Paused
11:02:07:FS01:Shutting core down
11:02:30:Removing old file 'configs/config-20140506-112036.xml'
11:02:30:Saving configuration to config.xml
11:02:30:<config>
11:02:30: <!-- Network -->
11:02:30: <proxy v=':8080'/>
11:02:30:
11:02:30: <!-- Slot Control -->
11:02:30: <power v='FULL'/>
11:02:30:
11:02:30: <!-- User Information -->
11:02:30: <passkey v='********************************'/>
11:02:30: <user v='Walter_Hamilton'/>
11:02:30:
11:02:30: <!-- Folding Slots -->
11:02:30: <slot id='1' type='GPU'>
11:02:30: <paused v='true'/>
11:02:30: </slot>
11:02:30:</config>
11:03:08:WARNING:FS01:Killing WU01
11:03:08:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:04:43:FS01:Unpaused
11:04:43:WU01:FS01:Starting
11:04:43:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
11:04:43:WU01:FS01:Started FahCore on PID 50520
11:04:43:WU01:FS01:Core PID:47268
11:04:43:WU01:FS01:FahCore 0x17 started
11:04:43:WU01:FS01:0x17:*********************** Log Started 2015-01-09T11:04:43Z ***********************
11:04:43:WU01:FS01:0x17:Project: 9201 (Run 481, Clone 4, Gen 138)
11:04:43:WU01:FS01:0x17:Unit: 0x000000ba6652edc45399e8f89535fcf2
11:04:43:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:04:43:WU01:FS01:0x17:Machine: 1
11:04:43:WU01:FS01:0x17:Digital signatures verified
11:04:43:WU01:FS01:0x17:Folding@home GPU core17
11:04:43:WU01:FS01:0x17:Version 0.0.52
11:04:43:WU01:FS01:0x17: Found a checkpoint file
11:05:14:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
11:05:14:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:05:33:Removing old file 'configs/config-20140506-112137.xml'
11:05:33:Saving configuration to config.xml
11:05:33:<config>
11:05:33: <!-- Network -->
11:05:33: <proxy v=':8080'/>
11:05:33:
11:05:33: <!-- Slot Control -->
11:05:33: <power v='FULL'/>
11:05:33:
11:05:33: <!-- User Information -->
11:05:33: <passkey v='********************************'/>
11:05:33: <user v='Walter_Hamilton'/>
11:05:33:
11:05:33: <!-- Folding Slots -->
11:05:33: <slot id='1' type='GPU'/>
11:05:33:</config>
11:08:54:FS01:Paused
11:08:54:FS01:Shutting core down
11:08:54:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 47268
11:08:54:WU01:FS01:0x17:Exiting, please wait. . .
11:08:54:WU01:FS01:0x17:Folding@home Core Shutdown: INTERRUPTED
11:08:54:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:09:37:Removing old file 'configs/config-20140506-112141.xml'
11:09:37:Saving configuration to config.xml
11:09:37:<config>
11:09:37: <!-- Network -->
11:09:37: <proxy v=':8080'/>
11:09:37:
11:09:37: <!-- Slot Control -->
11:09:37: <power v='FULL'/>
11:09:37:
11:09:37: <!-- User Information -->
11:09:37: <passkey v='********************************'/>
11:09:37: <user v='Walter_Hamilton'/>
11:09:37:
11:09:37: <!-- Folding Slots -->
11:09:37: <slot id='1' type='GPU'>
11:09:37: <paused v='true'/>
11:09:37: </slot>
11:09:37:</config>
19:06:55:FS01:Unpaused
19:06:55:WU01:FS01:Starting
19:06:55:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:06:55:WU01:FS01:Started FahCore on PID 47488
19:06:55:WU01:FS01:Core PID:52500
19:06:55:WU01:FS01:FahCore 0x17 started
19:06:55:WU01:FS01:0x17:*********************** Log Started 2015-01-09T19:06:55Z ***********************
19:06:55:WU01:FS01:0x17:Project: 9201 (Run 481, Clone 4, Gen 138)
19:06:55:WU01:FS01:0x17:Unit: 0x000000ba6652edc45399e8f89535fcf2
19:06:55:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
19:06:55:WU01:FS01:0x17:Machine: 1
19:06:55:WU01:FS01:0x17:Digital signatures verified
19:06:55:WU01:FS01:0x17:Folding@home GPU core17
19:06:55:WU01:FS01:0x17:Version 0.0.52
19:06:55:WU01:FS01:0x17: Found a checkpoint file
19:07:26:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
19:07:26:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:07:28:Removing old file 'configs/config-20140506-112238.xml'
19:07:28:Saving configuration to config.xml
19:07:28:<config>
19:07:28: <!-- Network -->
19:07:28: <proxy v=':8080'/>
19:07:28:
19:07:28: <!-- Slot Control -->
19:07:28: <power v='full'/>
19:07:28:
19:07:28: <!-- User Information -->
19:07:28: <passkey v='********************************'/>
19:07:28: <user v='Walter_Hamilton'/>
19:07:28:
19:07:28: <!-- Folding Slots -->
19:07:28: <slot id='1' type='GPU'/>
19:07:28:</config>
19:08:54:FS01:Paused
19:08:54:FS01:Shutting core down
19:08:54:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 52500
19:08:54:WU01:FS01:0x17:Exiting, please wait. . .
19:08:54:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:09:21:FS01:Unpaused
19:09:21:WU01:FS01:Starting
19:09:21:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:09:21:WU01:FS01:Started FahCore on PID 52268
19:09:21:WU01:FS01:Core PID:8936
19:09:21:WU01:FS01:FahCore 0x17 started
19:09:21:WU01:FS01:0x17:*********************** Log Started 2015-01-09T19:09:21Z ***********************
19:09:21:WU01:FS01:0x17:Project: 9201 (Run 481, Clone 4, Gen 138)
19:09:21:WU01:FS01:0x17:Unit: 0x000000ba6652edc45399e8f89535fcf2
19:09:21:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
19:09:21:WU01:FS01:0x17:Machine: 1
19:09:21:WU01:FS01:0x17:Digital signatures verified
19:09:21:WU01:FS01:0x17:Folding@home GPU core17
19:09:21:WU01:FS01:0x17:Version 0.0.52
19:09:21:WU01:FS01:0x17: Found a checkpoint file
19:09:51:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
19:09:51:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:13:05:57:127.0.0.1:New Web connection
19:13:24:FS01:Paused
19:13:24:FS01:Shutting core down
19:13:24:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 8936
19:13:24:WU01:FS01:0x17:Exiting, please wait. . .
19:13:24:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
19:13:34:Removing old file 'configs/config-20140506-152638.xml'
19:13:34:Saving configuration to config.xml
19:13:34:<config>
19:13:34: <!-- Network -->
19:13:34: <proxy v=':8080'/>
19:13:34:
19:13:34: <!-- Slot Control -->
19:13:34: <power v='full'/>
19:13:34:
19:13:34: <!-- User Information -->
19:13:34: <passkey v='********************************'/>
19:13:34: <user v='Walter_Hamilton'/>
19:13:34:
19:13:34: <!-- Folding Slots -->
19:13:34: <slot id='1' type='GPU'>
19:13:34: <paused v='true'/>
19:13:34: </slot>
19:13:34:</config>
19:13:59:FS01:Unpaused
19:13:59:WU01:FS01:Starting
19:13:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Walter H/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 924 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:14:00:WU01:FS01:Started FahCore on PID 50612
19:14:00:WU01:FS01:Core PID:53028
19:14:00:WU01:FS01:FahCore 0x17 started
19:14:00:WU01:FS01:0x17:*********************** Log Started 2015-01-09T19:14:00Z ***********************
19:14:00:WU01:FS01:0x17:Project: 9201 (Run 481, Clone 4, Gen 138)
19:14:00:WU01:FS01:0x17:Unit: 0x000000ba6652edc45399e8f89535fcf2
19:14:00:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
19:14:00:WU01:FS01:0x17:Machine: 1
19:14:00:WU01:FS01:0x17:Digital signatures verified
19:14:00:WU01:FS01:0x17:Folding@home GPU core17
19:14:00:WU01:FS01:0x17:Version 0.0.52
19:14:00:WU01:FS01:0x17: Found a checkpoint file
19:14:30:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
19:14:30:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:14:35:Removing old file 'configs/config-20140507-204733.xml'
19:14:35:Saving configuration to config.xml
19:14:35:<config>
19:14:35: <!-- Network -->
19:14:35: <proxy v=':8080'/>
19:14:35:
19:14:35: <!-- Slot Control -->
19:14:35: <power v='full'/>
19:14:35:
19:14:35: <!-- User Information -->
19:14:35: <passkey v='********************************'/>
19:14:35: <user v='Walter_Hamilton'/>
19:14:35:
19:14:35: <!-- Folding Slots -->
19:14:35: <slot id='1' type='GPU'/>
19:14:35:</config>
19:26:13:WU01:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
19:37:53:WU01:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
19:49:27:WU01:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
20:01:02:WU01:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
20:12:38:WU01:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
20:24:14:WU01:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
20:35:49:WU01:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
20:47:25:WU01:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
20:59:19:WU01:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
21:11:16:WU01:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
At 00:21:40, the WU was started, running at 11M xxS per frame. At 14:28:43, the WU hung and no actual progress was made after that. After 5 or 6 hours, the clients progress estimator had progressed beyond 99%.
You noticed it soon after 02:00:0 and shut it down. You tweaked the configuration several times, but you never let it run for long enough to see some progress and for a new estimate to be calculated. Restarting doesn't count unless it runs for long enough for you to see progress. That didn't happen until 19:26:13 when progress did continued at the same ed at 11M xxS per frame that it had been true before it hung.
As I said earlier, a GPU will hang if it gets too hot, if it's overclocked so that it's stability is questionable, or if the drivers are interrupted by something like MS RDT. (There may be other reasons that I don't know about.)
