- Windows 8.1 Pro, 64Bit
Intel Core i7-5930K Processor (6-cores, 15MB Cache, Overclocked up to 3.9 GHz w/ Turbo Boost) (F@H says I have 12 CPU's)
Triple NVIDIA GeForce GTX 980 graphics with 12GB total (3x 4GB) GDDR5 -NVIDIA SLI Enabled (came disabled which is what I wanted!)
32GB Quad Channel DDR4 at 2133MHz
512GB SSD 6Gb/s Main + 4TB 6kRPM SATA 6Gb/s Storage
Alienware 1500 Watt Multi-GPU Approved Power Supply
Probably most notably it looks like I'm stuck in the situation documented here with the Maxwell cards and OpenCL: https://forums.geforce.com/default/topi ... ver-bug/1/
I posted in that forum and also here to try and make some progress on that front:
viewtopic.php?f=16&t=26980&p=272269#p272269
The Core 18s are only estimated at 80K PPD.
It looks like a new web control was introduced since I last used F@H. Personally I'd prefer to use the original version 7 FAHControl as I couldn't see anything that the web control allowed me to do beyond what I can already do in the FAHControl. So I think it was safe for me to remove that Client Option.
I think it might make sense for my system to participate in Beta or Advanced but I want to get some feedback. I'm pretty good at reviewing my log files for "Warnings & Errors".
It looks like the install automatically withheld 3 of my "CPUs" from my CPU slot for running the GPUs because it says CPU:9 but I want to confirm. I get a small PPD increase on my GPU slots when pausing the CPU slot so it might be throttling it a bit. (approx 270K to 290K PPD on my Core 17 9201 project) My GPU temp is being held at 80C so I think that might also be limiting their performance some.
Here is my log, please review for any improvement considerations:
*********************** Log Started 2014-12-18T09:01:41Z ***********************
09:01:41:************************* Folding@home Client *************************
09:01:41: Website: http://folding.stanford.edu/
09:01:41: Copyright: (c) 2009-2014 Stanford University
09:01:41: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:01:41: Args:
09:01:41: Config: C:/ProgramData/FAHClient/config.xml
09:01:41:******************************** Build ********************************
09:01:41: Version: 7.4.4
09:01:41: Date: Mar 4 2014
09:01:41: Time: 20:26:54
09:01:41: SVN Rev: 4130
09:01:41: Branch: fah/trunk/client
09:01:41: Compiler: Intel(R) C++ MSVC 1500 mode 1200
09:01:41: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
09:01:41: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
09:01:41: Platform: win32 XP
09:01:41: Bits: 32
09:01:41: Mode: Release
09:01:41:******************************* System ********************************
09:01:41: CPU: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
09:01:41: CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
09:01:41: CPUs: 12
09:01:41: Memory: 31.89GiB
09:01:41: Free Memory: 30.40GiB
09:01:41: Threads: WINDOWS_THREADS
09:01:41: OS Version: 6.2
09:01:41: Has Battery: false
09:01:41: On Battery: false
09:01:41: UTC Offset: -5
09:01:41: PID: 772
09:01:41: CWD: C:/ProgramData/FAHClient
09:01:41: OS: Windows 8.1 Pro
09:01:41: OS Arch: AMD64
09:01:41: GPUs: 3
09:01:41: GPU 0: NVIDIA:4 GM204 [GeForce GTX 980]
09:01:41: GPU 1: NVIDIA:4 GM204 [GeForce GTX 980]
09:01:41: GPU 2: NVIDIA:4 GM204 [GeForce GTX 980]
09:01:41: CUDA: 5.2
09:01:41: CUDA Driver: 6050
09:01:41:Win32 Service: false
09:01:41:***********************************************************************
09:01:41:<config>
09:01:41: <!-- Network -->
09:01:41: <proxy v=':8080'/>
09:01:41:
09:01:41: <!-- Slot Control -->
09:01:41: <power v='FULL'/>
09:01:41:
09:01:41: <!-- User Information -->
09:01:41: <passkey v='********************************'/>
09:01:41: <team v='182919'/>
09:01:41: <user v='Kornflake'/>
09:01:41:
09:01:41: <!-- Folding Slots -->
09:01:41: <slot id='0' type='CPU'/>
09:01:41: <slot id='1' type='GPU'/>
09:01:41: <slot id='2' type='GPU'/>
09:01:41: <slot id='3' type='GPU'/>
09:01:41:</config>
09:01:41:Trying to access database...
09:01:41:Successfully acquired database lock
09:01:41:Enabled folding slot 00: READY cpu:9
09:01:41:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 980]
09:01:41:Enabled folding slot 02: READY gpu:1:GM204 [GeForce GTX 980]
09:01:41:Enabled folding slot 03: READY gpu:2:GM204 [GeForce GTX 980]
09:01:42:WU00:FS00:Connecting to 171.67.108.200:8080
09:01:42:WU01:FS01:Connecting to 171.67.108.200:80
09:01:42:WU02:FS02:Connecting to 171.67.108.200:80
09:01:42:WU03:FS03:Connecting to 171.67.108.200:80
09:01:42:WU00:FS00:Assigned to work server 171.64.65.99
09:01:42:WU00:FS00:Requesting new work unit for slot 00: READY cpu:9 from 171.64.65.99
09:01:42:WU00:FS00:Connecting to 171.64.65.99:8080
09:01:43:WU03:FS03:Assigned to work server 171.67.108.52
09:01:43:WU03:FS03:Requesting new work unit for slot 03: READY gpu:2:GM204 [GeForce GTX 980] from 171.67.108.52
09:01:43:WU01:FS01:Assigned to work server 140.163.4.235
09:01:43:WU03:FS03:Connecting to 171.67.108.52:8080
09:01:43:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM204 [GeForce GTX 980] from 140.163.4.235
09:01:43:WU02:FS02:Assigned to work server 171.67.108.52
09:01:43:WU01:FS01:Connecting to 140.163.4.235:8080
09:01:43:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GM204 [GeForce GTX 980] from 171.67.108.52
09:01:43:WU02:FS02:Connecting to 171.67.108.52:8080
09:01:43:WU01:FS01:Downloading 4.18MiB
09:01:43:WU02:FS02:Downloading 1.53MiB
09:01:43:WU03:FS03:Downloading 1.52MiB
09:01:44:WU00:FS00:Downloading 1.98MiB
09:01:47:WU02:FS02:Download complete
09:01:47:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:911 clone:2 gen:65 core:0x17 unit:0x0000006b6652edc45399f9d90741f5c0
09:01:47:WU02:FS02:Starting
09:01:47:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 772 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
09:01:47:WU02:FS02:Started FahCore on PID 5392
09:01:48:WU02:FS02:Core PID:5416
09:01:48:WU02:FS02:FahCore 0x17 started
09:01:48:WU02:FS02:0x17:*********************** Log Started 2014-12-18T09:01:48Z ***********************
09:01:48:WU02:FS02:0x17:Project: 9201 (Run 911, Clone 2, Gen 65)
09:01:48:WU02:FS02:0x17:Unit: 0x0000006b6652edc45399f9d90741f5c0
09:01:48:WU02:FS02:0x17:CPU: 0x00000000000000000000000000000000
09:01:48:WU02:FS02:0x17:Machine: 2
09:01:48:WU02:FS02:0x17:Reading tar file state.xml
09:01:48:WU02:FS02:0x17:Reading tar file system.xml
09:01:48:WU02:FS02:0x17:Reading tar file integrator.xml
09:01:48:WU02:FS02:0x17:Reading tar file core.xml
09:01:48:WU02:FS02:0x17:Digital signatures verified
09:01:48:WU02:FS02:0x17:Folding@home GPU core17
09:01:48:WU02:FS02:0x17:Version 0.0.52
09:01:49:WU01:FS01:Download 68.81%
09:01:49:WU03:FS03:Download 82.05%
09:01:49:WU03:FS03:Download complete
09:01:50:WU00:FS00:Download 59.86%
09:01:50:WU03:FS03:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9201 run:932 clone:4 gen:107 core:0x17 unit:0x000000936652edc45399fab23e1bdd2c
09:01:50:WU03:FS03:Starting
09:01:50:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 704 -lifeline 772 -checkpoint 15 -gpu 2 -gpu-vendor nvidia
09:01:50:WU03:FS03:Started FahCore on PID 5444
09:01:50:WU03:FS03:Core PID:5456
09:01:50:WU03:FS03:FahCore 0x17 started
09:01:50:WU03:FS03:0x17:*********************** Log Started 2014-12-18T09:01:50Z ***********************
09:01:50:WU03:FS03:0x17:Project: 9201 (Run 932, Clone 4, Gen 107)
09:01:50:WU03:FS03:0x17:Unit: 0x000000936652edc45399fab23e1bdd2c
09:01:50:WU03:FS03:0x17:CPU: 0x00000000000000000000000000000000
09:01:50:WU03:FS03:0x17:Machine: 3
09:01:50:WU03:FS03:0x17:Reading tar file state.xml
09:01:50:WU03:FS03:0x17:Reading tar file system.xml
09:01:51:WU03:FS03:0x17:Reading tar file integrator.xml
09:01:51:WU03:FS03:0x17:Reading tar file core.xml
09:01:51:WU03:FS03:0x17:Digital signatures verified
09:01:51:WU03:FS03:0x17:Folding@home GPU core17
09:01:51:WU03:FS03:0x17:Version 0.0.52
09:01:51:WU01:FS01:Download complete
09:01:52:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10471 run:0 clone:171 gen:60 core:0x18 unit:0x0000004f538b3dbb53beab7486b30c0e
09:01:52:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah
09:01:52:WU01:FS01:Connecting to web.stanford.edu:80
09:01:52:WU01:FS01:FahCore 18: Downloading 2.54MiB
09:01:56:WU00:FS00:Download 88.21%
09:01:57:WU00:FS00:Download complete
09:01:57:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7809 run:2 clone:99 gen:36 core:0xa4 unit:0x000000380a3b1e874e31094434291df3
09:01:57:WU00:FS00:Starting
09:01:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 772 -checkpoint 15 -np 9
09:01:57:WU00:FS00:Started FahCore on PID 5608
09:01:57:WU00:FS00:Core PID:5620
09:01:57:WU00:FS00:FahCore 0xa4 started
09:01:58:WU01:FS01:FahCore 18: 91.20%
09:01:58:WU01:FS01:FahCore 18: Download complete
09:01:58:WU00:FS00:0xa4:
09:01:58:WU00:FS00:0xa4:*------------------------------*
09:01:58:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
09:01:58:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
09:01:58:WU00:FS00:0xa4:Preparing to commence simulation
09:01:58:WU00:FS00:0xa4:- Looking at optimizations...
09:01:58:WU00:FS00:0xa4:- Created dyn
09:01:58:WU00:FS00:0xa4:- Files status OK
09:01:58:WU00:FS00:0xa4:- Expanded 2079648 -> 5386224 (decompressed 258.9 percent)
09:01:58:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2079648 data_size=5386224, decompressed_data_size=5386224 diff=0
09:01:58:WU00:FS00:0xa4:- Digital signature verified
09:01:58:WU00:FS00:0xa4:Project: 7809 (Run 2, Clone 99, Gen 36)
09:01:58:WU00:FS00:0xa4:Assembly optimizations on if available.
09:01:58:WU00:FS00:0xa4:Entering M.D.
09:01:58:WU01:FS01:Valid core signature
09:01:58:WU01:FS01:Unpacked 8.47MiB to cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe
09:01:59:WU01:FS01:Starting
09:01:59:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 772 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
09:01:59:WU01:FS01:Started FahCore on PID 5688
09:01:59:WU01:FS01:Core PID:5700
09:01:59:WU01:FS01:FahCore 0x18 started
09:02:00:WU01:FS01:0x18:*********************** Log Started 2014-12-18T09:02:00Z ***********************
09:02:00:WU01:FS01:0x18:Project: 10471 (Run 0, Clone 171, Gen 60)
09:02:00:WU01:FS01:0x18:Unit: 0x0000004f538b3dbb53beab7486b30c0e
09:02:00:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
09:02:00:WU01:FS01:0x18:Machine: 1
09:02:00:WU01:FS01:0x18:Reading tar file state.xml
09:02:01:WU01:FS01:0x18:Reading tar file system.xml
09:02:01:WU01:FS01:0x18:Reading tar file integrator.xml
09:02:01:WU01:FS01:0x18:Reading tar file core.xml
09:02:01:WU01:FS01:0x18:Digital signatures verified
09:02:01:WU01:FS01:0x18:Folding@home GPU core18
09:02:01:WU01:FS01:0x18:Version 0.0.3
09:02:04:WU00:FS00:0xa4:Mapping NT from 9 to 9
09:02:04:WU00:FS00:0xa4:Completed 0 out of 1500000 steps (0%)
09:02:09:WU02:FS02:0x17:Completed 0 out of 5000000 steps (0%)
09:02:09:WU02:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:02:12:WU03:FS03:0x17:Completed 0 out of 5000000 steps (0%)
09:02:12:WU03:FS03:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:02:32:WU01:FS01:0x18:Completed 0 out of 5000000 steps (0%)
09:02:32:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:03:55:WU02:FS02:0x17:Completed 50000 out of 5000000 steps (1%)
09:04:00:WU03:FS03:0x17:Completed 50000 out of 5000000 steps (1%)
09:05:42:WU02:FS02:0x17:Completed 100000 out of 5000000 steps (2%)
09:05:49:WU03:FS03:0x17:Completed 100000 out of 5000000 steps (2%)
09:07:30:WU02:FS02:0x17:Completed 150000 out of 5000000 steps (3%)
09:07:39:WU03:FS03:0x17:Completed 150000 out of 5000000 steps (3%)
09:09:02:WU00:FS00:0xa4:Completed 15000 out of 1500000 steps (1%)
09:09:19:WU02:FS02:0x17:Completed 200000 out of 5000000 steps (4%)
09:09:29:WU03:FS03:0x17:Completed 200000 out of 5000000 steps (4%)
09:11:08:WU02:FS02:0x17:Completed 250000 out of 5000000 steps (5%)
09:11:19:WU03:FS03:0x17:Completed 250000 out of 5000000 steps (5%)
09:12:16:WU01:FS01:0x18:Completed 50000 out of 5000000 steps (1%)
09:12:58:WU02:FS02:0x17:Completed 300000 out of 5000000 steps (6%)
09:13:09:WU03:FS03:0x17:Completed 300000 out of 5000000 steps (6%)
09:14:48:WU02:FS02:0x17:Completed 350000 out of 5000000 steps (7%)
Thanks!
