NVIDIA OpenGL driver issue (windows 7)
- Hardware configuration: HP z600-dual 5650 xeons (6 cores-2.67 x2) , 32g ram, gtx780
Evening all,
Ok, so not sure if this is very similar to a post this week about driver issues on Linux with the latest 9 series cards-but i have created a new post in case it wasn’t.
To save asking, system specs are hp z600 workstation with windows 7, 32g of server ram, dual 5650 xeons (6 core each @ 2.67), 600watt psu, gigabyte windforce 780, 120g ssd and a 2tb storage drive...
Folding set to –gpu and I’ve been playing with various cpu settings but it’s now back to spending its life at 20 as after a little research this creates the most ppd its done it with whatever the cpu has been set at however. (Want to turn gpu off at some point and test big av before it dies tho but that’s another topic)
For a while now i keep getting an error message randomly when folding, windows tells me folding has an error and then dies, the only option is to close the program, if i try and reopen it it says inactive for as long as i leave it-total system restart job.
I believed this was down to an over clock on the gpu, turned it back to std and still the same, next thing i tried was if it was when cad was open and if i pushed the CAM side of the program hard enough i could get the same message, however even with cad closed it still does it now and then. Sometimes without folding running i can get cam to do it too
Driver version 340.52 I had to turn back a while ago to this as it auto updated and wrecked my ppd
Re: NVIDIA OpenGL driver issue (windows 7)
FAH doesn't use OpenGL. Did you mean OpenCL?
Also, I didn't see a single question mark in your post. Are you stating an issue, or asking about a problem? Either way, some fah logs would help. Also, when a Windows error pops, it is usually driver or hardware related, and not a client issue. So would more info from the Windows Event log for that error would help.
Nope as it says GL... i knew f@h used CL but i had never hurd of GL and didnt know if it was a issue with f@h or what it was... sometimes i get c++ but most of the time its this...
Both, im not sure if its an issue hardware or soft... as you lot know so much i was asking the masses!
Current log as requested:
Under the general side of a list of these errors is:
The NVIDIA OpenGL driver detected a problem with the display
driver and is unable to continue. The application must close.
Error code: 3
Visit http://www.nvidia.com/page/support.html for more information.
Under the details section:
- System
- Provider
[ Name] NVIDIA OpenGL Driver
- EventID 1
[ Qualifiers] 49152
Level 2
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-11-17T20:57:47.000000000Z
EventRecordID 11462
Channel Application
Computer BRG-PC
Security
- EventData
The NVIDIA OpenGL driver detected a problem with the display driver and is unable to continue. The application must close. Error code: 3 Visit http://www.nvidia.com/page/support.html for more information.
*********************** Log Started 2014-11-17T20:59:16Z ***********************
20:59:16:************************* Folding@home Client *************************
20:59:16: Website: http://folding.stanford.edu/
20:59:16: Copyright: (c) 2009-2014 Stanford University
20:59:16: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:59:16: Args:
20:59:16: Config: C:/ProgramData/FAHClient/config.xml
20:59:16:******************************** Build ********************************
20:59:16: Version: 7.4.4
20:59:16: Date: Mar 4 2014
20:59:16: Time: 20:26:54
20:59:16: SVN Rev: 4130
20:59:16: Branch: fah/trunk/client
20:59:16: Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:59:16: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:59:16: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:59:16: Platform: win32 XP
20:59:16: Bits: 32
20:59:16: Mode: Release
20:59:16:******************************* System ********************************
20:59:16: CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
20:59:16: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
20:59:16: CPUs: 24
20:59:16: Memory: 31.98GiB
20:59:16: Free Memory: 29.54GiB
20:59:16: Threads: WINDOWS_THREADS
20:59:16: OS Version: 6.1
20:59:16: Has Battery: false
20:59:16: On Battery: false
20:59:16: UTC Offset: 0
20:59:16: PID: 3504
20:59:16: CWD: C:/ProgramData/FAHClient
20:59:16: OS: Windows 7 Professional
20:59:16: OS Arch: AMD64
20:59:16: GPUs: 1
20:59:16: GPU 0: NVIDIA:3 GK110 [GeForce GTX 780]
20:59:16: CUDA: 3.5
20:59:16: CUDA Driver: 6050
20:59:16:Win32 Service: false
20:59:16:***********************************************************************
20:59:16:<config>
20:59:16: <!-- Folding Core -->
20:59:16: <checkpoint v='3'/>
20:59:16: <core-priority v='low'/>
20:59:16:
20:59:16: <!-- Network -->
20:59:16: <proxy v=':8080'/>
20:59:16:
20:59:16: <!-- Slot Control -->
20:59:16: <pause-on-battery v='false'/>
20:59:16: <power v='full'/>
20:59:16:
20:59:16: <!-- User Information -->
20:59:16: <passkey v='********************************'/>
20:59:16: <team v='44831'/>
20:59:16: <user v='Gooders'/>
20:59:16:
20:59:16: <!-- Folding Slots -->
20:59:16: <slot id='0' type='GPU'/>
20:59:16: <slot id='3' type='CPU'>
20:59:16: <cpus v='20'/>
20:59:16: </slot>
20:59:16:</config>
20:59:16:Trying to access database...
20:59:16:Successfully acquired database lock
20:59:16:Enabled folding slot 00: READY gpu:0:GK110 [GeForce GTX 780]
20:59:16:Enabled folding slot 03: READY cpu:20
20:59:16:WU00:FS03:Starting
20:59:16:WU00:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 3504 -checkpoint 3 -np 20
20:59:16:WU00:FS03:Started FahCore on PID 4872
20:59:16:WU00:FS03:Core PID:4924
20:59:16:WU00:FS03:FahCore 0xa4 started
20:59:16:WU01:FS00:Starting
20:59:16:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 3504 -checkpoint 3 -gpu 0 -gpu-vendor nvidia
20:59:16:WU01:FS00:Started FahCore on PID 4948
20:59:16:WU01:FS00:Core PID:4976
20:59:16:WU01:FS00:FahCore 0x17 started
20:59:17:WU00:FS03:0xa4:
20:59:17:WU00:FS03:0xa4:*------------------------------*
20:59:17:WU00:FS03:0xa4:Folding@Home Gromacs GB Core
20:59:17:WU00:FS03:0xa4:Version 2.27 (Dec. 15, 2010)
20:59:17:WU00:FS03:0xa4:Preparing to commence simulation
20:59:17:WU00:FS03:0xa4:- Looking at optimizations...
20:59:17:WU00:FS03:0xa4:- Files status OK
20:59:17:WU00:FS03:0xa4:- Expanded 827457 -> 1400900 (decompressed 169.3 percent)
20:59:17:WU00:FS03:0xa4:Called DecompressByteArray: compressed_data_size=827457 data_size=1400900, decompressed_data_size=1400900 diff=0
20:59:17:WU00:FS03:0xa4:- Digital signature verified
20:59:17:WU00:FS03:0xa4:Project: 9007 (Run 899, Clone 1, Gen 85)
20:59:17:WU00:FS03:0xa4:Assembly optimizations on if available.
20:59:17:WU00:FS03:0xa4:Entering M.D.
20:59:17:WU01:FS00:0x17:*********************** Log Started 2014-11-17T20:59:17Z ***********************
20:59:17:WU01:FS00:0x17:Project: 13001 (Run 164, Clone 3, Gen 97)
20:59:17:WU01:FS00:0x17:Unit: 0x000000a9538b3db753287e330504679b
20:59:17:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
20:59:17:WU01:FS00:0x17:Machine: 0
20:59:17:WU01:FS00:0x17:Reading tar file state.xml
20:59:18:WU01:FS00:0x17:Reading tar file system.xml
20:59:19:WU01:FS00:0x17:Reading tar file integrator.xml
20:59:19:WU01:FS00:0x17:Reading tar file core.xml
20:59:19:WU01:FS00:0x17:Digital signatures verified
20:59:19:WU01:FS00:0x17:Folding@home GPU core17
20:59:19:WU01:FS00:0x17:Version 0.0.52
20:59:22:WU00:FS03:0xa4:Using Gromacs checkpoints
20:59:22:WU00:FS03:0xa4:Mapping NT from 20 to 20
20:59:23:WU00:FS03:0xa4:Resuming from checkpoint
20:59:23:WU00:FS03:0xa4:Verified 00/wudata_01.log
20:59:23:WU00:FS03:0xa4:Verified 00/wudata_01.trr
20:59:23:WU00:FS03:0xa4:Verified 00/wudata_01.xtc
20:59:23:WU00:FS03:0xa4:Verified 00/wudata_01.edr
20:59:23:WU00:FS03:0xa4:Completed 50980 out of 250000 steps (20%)
20:59:51:WU00:FS03:0xa4:Completed 52500 out of 250000 steps (21%)
21:00:37:WU00:FS03:0xa4:Completed 55000 out of 250000 steps (22%)
21:01:23:WU00:FS03:0xa4:Completed 57500 out of 250000 steps (23%)
21:02:09:WU00:FS03:0xa4:Completed 60000 out of 250000 steps (24%)
21:02:55:WU00:FS03:0xa4:Completed 62500 out of 250000 steps (25%)
21:03:41:WU00:FS03:0xa4:Completed 65000 out of 250000 steps (26%)
21:04:26:WU00:FS03:0xa4:Completed 67500 out of 250000 steps (27%)
21:04:38:WU01:FS00:0x17:Completed 0 out of 5000000 steps (0%)
21:04:38:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:05:12:WU00:FS03:0xa4:Completed 70000 out of 250000 steps (28%)
21:05:58:WU00:FS03:0xa4:Completed 72500 out of 250000 steps (29%)
21:06:45:WU00:FS03:0xa4:Completed 75000 out of 250000 steps (30%)
21:07:31:WU00:FS03:0xa4:Completed 77500 out of 250000 steps (31%)
21:08:17:WU00:FS03:0xa4:Completed 80000 out of 250000 steps (32%)
21:09:03:WU00:FS03:0xa4:Completed 82500 out of 250000 steps (33%)
21:09:49:WU00:FS03:0xa4:Completed 85000 out of 250000 steps (34%)
21:10:36:WU00:FS03:0xa4:Completed 87500 out of 250000 steps (35%)
21:11:20:WU01:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
21:11:23:WU00:FS03:0xa4:Completed 90000 out of 250000 steps (36%)
21:12:09:WU00:FS03:0xa4:Completed 92500 out of 250000 steps (37%)
21:12:54:WU00:FS03:0xa4:Completed 95000 out of 250000 steps (38%)
21:13:40:WU00:FS03:0xa4:Completed 97500 out of 250000 steps (39%)
21:14:26:WU00:FS03:0xa4:Completed 100000 out of 250000 steps (40%)
21:15:12:WU00:FS03:0xa4:Completed 102500 out of 250000 steps (41%)
21:15:59:WU00:FS03:0xa4:Completed 105000 out of 250000 steps (42%)
21:16:45:WU00:FS03:0xa4:Completed 107500 out of 250000 steps (43%)
21:17:31:WU00:FS03:0xa4:Completed 110000 out of 250000 steps (44%)
21:17:38:WU01:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
21:18:17:WU00:FS03:0xa4:Completed 112500 out of 250000 steps (45%)
21:19:04:WU00:FS03:0xa4:Completed 115000 out of 250000 steps (46%)
21:19:50:WU00:FS03:0xa4:Completed 117500 out of 250000 steps (47%)
21:20:36:WU00:FS03:0xa4:Completed 120000 out of 250000 steps (48%)
21:21:22:WU00:FS03:0xa4:Completed 122500 out of 250000 steps (49%)
21:22:01:9:127.0.0.1:New Web connection
21:22:08:WU00:FS03:0xa4:Completed 125000 out of 250000 steps (50%)
21:22:55:WU00:FS03:0xa4:Completed 127500 out of 250000 steps (51%)
21:23:41:WU00:FS03:0xa4:Completed 130000 out of 250000 steps (52%)
21:24:25:WU01:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
21:24:28:WU00:FS03:0xa4:Completed 132500 out of 250000 steps (53%)
21:25:14:WU00:FS03:0xa4:Completed 135000 out of 250000 steps (54%)
21:26:00:WU00:FS03:0xa4:Completed 137500 out of 250000 steps (55%)
21:26:47:WU00:FS03:0xa4:Completed 140000 out of 250000 steps (56%)
21:27:33:WU00:FS03:0xa4:Completed 142500 out of 250000 steps (57%)
21:28:19:WU00:FS03:0xa4:Completed 145000 out of 250000 steps (58%)
21:29:05:WU00:FS03:0xa4:Completed 147500 out of 250000 steps (59%)
21:29:51:WU00:FS03:0xa4:Completed 150000 out of 250000 steps (60%)
21:30:38:WU00:FS03:0xa4:Completed 152500 out of 250000 steps (61%)
21:30:41:WU01:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
21:31:24:WU00:FS03:0xa4:Completed 155000 out of 250000 steps (62%)
21:32:11:WU00:FS03:0xa4:Completed 157500 out of 250000 steps (63%)
21:32:57:WU00:FS03:0xa4:Completed 160000 out of 250000 steps (64%)
21:33:43:WU00:FS03:0xa4:Completed 162500 out of 250000 steps (65%)
21:34:30:WU00:FS03:0xa4:Completed 165000 out of 250000 steps (66%)
21:35:16:WU00:FS03:0xa4:Completed 167500 out of 250000 steps (67%)
21:36:02:WU00:FS03:0xa4:Completed 170000 out of 250000 steps (68%)
21:36:49:WU00:FS03:0xa4:Completed 172500 out of 250000 steps (69%)
21:36:58:WU01:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
21:37:35:WU00:FS03:0xa4:Completed 175000 out of 250000 steps (70%)
21:38:21:WU00:FS03:0xa4:Completed 177500 out of 250000 steps (71%)
21:39:07:WU00:FS03:0xa4:Completed 180000 out of 250000 steps (72%)
21:39:54:WU00:FS03:0xa4:Completed 182500 out of 250000 steps (73%)
21:40:40:WU00:FS03:0xa4:Completed 185000 out of 250000 steps (74%)
21:41:26:WU00:FS03:0xa4:Completed 187500 out of 250000 steps (75%)
21:42:12:WU00:FS03:0xa4:Completed 190000 out of 250000 steps (76%)
21:42:59:WU00:FS03:0xa4:Completed 192500 out of 250000 steps (77%)
21:43:43:WU01:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
21:43:45:WU00:FS03:0xa4:Completed 195000 out of 250000 steps (78%)
21:44:31:WU00:FS03:0xa4:Completed 197500 out of 250000 steps (79%)
21:45:17:WU00:FS03:0xa4:Completed 200000 out of 250000 steps (80%)
21:46:04:WU00:FS03:0xa4:Completed 202500 out of 250000 steps (81%)
21:46:50:WU00:FS03:0xa4:Completed 205000 out of 250000 steps (82%)
21:47:36:WU00:FS03:0xa4:Completed 207500 out of 250000 steps (83%)
21:48:23:WU00:FS03:0xa4:Completed 210000 out of 250000 steps (84%)
21:49:09:WU00:FS03:0xa4:Completed 212500 out of 250000 steps (85%)
21:49:55:WU00:FS03:0xa4:Completed 215000 out of 250000 steps (86%)
21:50:00:WU01:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
21:50:42:WU00:FS03:0xa4:Completed 217500 out of 250000 steps (87%)
21:51:28:WU00:FS03:0xa4:Completed 220000 out of 250000 steps (88%)
21:52:14:WU00:FS03:0xa4:Completed 222500 out of 250000 steps (89%)
21:53:00:WU00:FS03:0xa4:Completed 225000 out of 250000 steps (90%)
21:53:46:WU00:FS03:0xa4:Completed 227500 out of 250000 steps (91%)
21:54:32:WU00:FS03:0xa4:Completed 230000 out of 250000 steps (92%)
21:55:19:WU00:FS03:0xa4:Completed 232500 out of 250000 steps (93%)
21:56:05:WU00:FS03:0xa4:Completed 235000 out of 250000 steps (94%)
21:56:46:WU01:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
21:56:51:WU00:FS03:0xa4:Completed 237500 out of 250000 steps (95%)
21:57:37:WU00:FS03:0xa4:Completed 240000 out of 250000 steps (96%)
21:58:24:WU00:FS03:0xa4:Completed 242500 out of 250000 steps (97%)
21:59:10:WU00:FS03:0xa4:Completed 245000 out of 250000 steps (98%)
21:59:56:WU00:FS03:0xa4:Completed 247500 out of 250000 steps (99%)
21:59:58:WU02:FS03:Connecting to 171.67.108.200:8080
21:59:59:WU02:FS03:Assigned to work server 128.143.231.202
21:59:59:WU02:FS03:Requesting new work unit for slot 03: RUNNING cpu:20 from 128.143.231.202
21:59:59:WU02:FS03:Connecting to 128.143.231.202:8080
22:00:00:WU02:FS03:Downloading 3.64MiB
22:00:06:WU02:FS03:Download 80.76%
22:00:13:WU02:FS03:Download 87.63%
22:00:15:WU02:FS03:Download complete
22:00:15:WU02:FS03:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:6095 run:5 clone:30 gen:28 core:0xa3 unit:0x0000002b0a3b1e594f1af5950062d0ff
22:00:43:WU00:FS03:0xa4:Completed 250000 out of 250000 steps (100%)
22:00:43:WU00:FS03:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
22:00:53:WU00:FS03:0xa4:
22:00:53:WU00:FS03:0xa4:Finished Work Unit:
22:00:53:WU00:FS03:0xa4:- Reading up to 811800 from "00/wudata_01.trr": Read 811800
22:00:53:WU00:FS03:0xa4:trr file hash check passed.
22:00:53:WU00:FS03:0xa4:- Reading up to 746384 from "00/wudata_01.xtc": Read 746384
22:00:53:WU00:FS03:0xa4:xtc file hash check passed.
22:00:53:WU00:FS03:0xa4:edr file hash check passed.
22:00:53:WU00:FS03:0xa4:logfile size: 25443
22:00:53:WU00:FS03:0xa4:Leaving Run
22:00:56:WU00:FS03:0xa4:- Writing 1586115 bytes of core data to disk...
22:00:57:WU00:FS03:0xa4:Done: 1585603 -> 1539211 (compressed to 97.0 percent)
22:00:57:WU00:FS03:0xa4: ... Done.
22:00:57:WU00:FS03:0xa4:- Shutting down core
22:00:57:WU00:FS03:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:00:57:WU00:FS03:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:00:57:WU00:FS03:Sending unit results: id:00 state:SEND error:NO_ERROR project:9007 run:899 clone:1 gen:85 core:0xa4 unit:0x00000063664f2de4533b3769fc951cf0
22:00:57:WU00:FS03:Uploading 1.47MiB to 171.64.65.124
22:00:57:WU00:FS03:Connecting to 171.64.65.124:8080
22:00:57:WU02:FS03:Starting
22:00:57:WU02:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 704 -lifeline 3504 -checkpoint 3 -np 20
22:00:57:WU02:FS03:Started FahCore on PID 4220
22:00:57:WU02:FS03:Core PID:6940
22:00:57:WU02:FS03:FahCore 0xa3 started
22:00:58:WU02:FS03:0xa3:
22:00:58:WU02:FS03:0xa3:*------------------------------*
22:00:58:WU02:FS03:0xa3:Folding@Home Gromacs SMP Core
22:00:58:WU02:FS03:0xa3:Version 2.27 (Dec. 15, 2010)
22:00:58:WU02:FS03:0xa3:Preparing to commence simulation
22:00:58:WU02:FS03:0xa3:- Looking at optimizations...
22:00:58:WU02:FS03:0xa3:- Created dyn
22:00:58:WU02:FS03:0xa3:- Files status OK
22:00:58:WU02:FS03:0xa3:- Expanded 3813644 -> 4182748 (decompressed 109.6 percent)
22:00:58:WU02:FS03:0xa3:Called DecompressByteArray: compressed_data_size=3813644 data_size=4182748, decompressed_data_size=4182748 diff=0
22:00:58:WU02:FS03:0xa3:- Digital signature verified
22:00:58:WU02:FS03:0xa3:Project: 6095 (Run 5, Clone 30, Gen 28)
22:00:58:WU02:FS03:0xa3:Assembly optimizations on if available.
22:00:58:WU02:FS03:0xa3:Entering M.D.
22:01:03:WU00:FS03:Upload 63.85%
22:01:04:WU02:FS03:0xa3:Mapping NT from 20 to 20
22:01:04:WU02:FS03:0xa3:Completed 0 out of 500000 steps (0%)
22:01:13:WU00:FS03:Upload complete
22:01:13:WU00:FS03:Server responded WORK_ACK (400)
22:01:13:WU00:FS03:Final credit estimate, 2170.00 points
22:01:13:WU00:FS03:Cleaning up
22:03:01:WU01:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
22:06:35:WU02:FS03:0xa3:Completed 5000 out of 500000 steps (1%)
22:09:19:WU01:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
22:12:06:WU02:FS03:0xa3:Completed 10000 out of 500000 steps (2%)
22:16:07:WU01:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
22:17:40:WU02:FS03:0xa3:Completed 15000 out of 500000 steps (3%)
22:22:21:WU01:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
22:23:09:WU02:FS03:0xa3:Completed 20000 out of 500000 steps (4%)
22:28:38:WU02:FS03:0xa3:Completed 25000 out of 500000 steps (5%)
22:29:04:WU01:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
22:34:07:WU02:FS03:0xa3:Completed 30000 out of 500000 steps (6%)
22:35:19:WU01:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
22:39:36:WU02:FS03:0xa3:Completed 35000 out of 500000 steps (7%)
22:41:34:WU01:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
22:45:06:WU02:FS03:0xa3:Completed 40000 out of 500000 steps (8%)
22:48:18:WU01:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
22:50:35:WU02:FS03:0xa3:Completed 45000 out of 500000 steps (9%)
22:54:33:WU01:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
22:56:05:WU02:FS03:0xa3:Completed 50000 out of 500000 steps (10%)
23:01:20:WU01:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
23:01:37:WU02:FS03:0xa3:Completed 55000 out of 500000 steps (11%)
23:07:09:WU02:FS03:0xa3:Completed 60000 out of 500000 steps (12%)
23:07:39:WU01:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
23:12:39:WU02:FS03:0xa3:Completed 65000 out of 500000 steps (13%)
23:13:54:WU01:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
23:18:08:WU02:FS03:0xa3:Completed 70000 out of 500000 steps (14%)
23:20:37:WU01:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
23:23:37:WU02:FS03:0xa3:Completed 75000 out of 500000 steps (15%)
23:26:53:WU01:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
23:29:07:WU02:FS03:0xa3:Completed 80000 out of 500000 steps (16%)
23:33:38:WU01:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
23:34:37:WU02:FS03:0xa3:Completed 85000 out of 500000 steps (17%)
23:39:54:WU01:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
23:40:06:WU02:FS03:0xa3:Completed 90000 out of 500000 steps (18%)
23:45:35:WU02:FS03:0xa3:Completed 95000 out of 500000 steps (19%)
23:46:10:WU01:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
23:51:04:WU02:FS03:0xa3:Completed 100000 out of 500000 steps (20%)
23:52:55:WU01:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
23:56:33:WU02:FS03:0xa3:Completed 105000 out of 500000 steps (21%)
23:59:11:WU01:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
00:02:02:WU02:FS03:0xa3:Completed 110000 out of 500000 steps (22%)
00:05:56:WU01:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
00:07:31:WU02:FS03:0xa3:Completed 115000 out of 500000 steps (23%)
00:12:11:WU01:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
00:13:01:WU02:FS03:0xa3:Completed 120000 out of 500000 steps (24%)
00:18:27:WU01:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
00:18:30:WU02:FS03:0xa3:Completed 125000 out of 500000 steps (25%)
00:24:00:WU02:FS03:0xa3:Completed 130000 out of 500000 steps (26%)
00:25:11:WU01:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
00:29:29:WU02:FS03:0xa3:Completed 135000 out of 500000 steps (27%)
00:31:27:WU01:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
00:34:59:WU02:FS03:0xa3:Completed 140000 out of 500000 steps (28%)
00:38:11:WU01:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
00:40:28:WU02:FS03:0xa3:Completed 145000 out of 500000 steps (29%)
00:44:28:WU01:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
00:45:57:WU02:FS03:0xa3:Completed 150000 out of 500000 steps (30%)
00:50:44:WU01:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
00:51:26:WU02:FS03:0xa3:Completed 155000 out of 500000 steps (31%)
00:56:55:WU02:FS03:0xa3:Completed 160000 out of 500000 steps (32%)
00:57:28:WU01:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
01:02:24:WU02:FS03:0xa3:Completed 165000 out of 500000 steps (33%)
01:03:44:WU01:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
01:07:54:WU02:FS03:0xa3:Completed 170000 out of 500000 steps (34%)
01:10:29:WU01:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
01:13:23:WU02:FS03:0xa3:Completed 175000 out of 500000 steps (35%)
01:16:44:WU01:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
01:18:52:WU02:FS03:0xa3:Completed 180000 out of 500000 steps (36%)
01:23:00:WU01:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
01:24:21:WU02:FS03:0xa3:Completed 185000 out of 500000 steps (37%)
01:29:44:WU01:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
01:29:50:WU02:FS03:0xa3:Completed 190000 out of 500000 steps (38%)
01:35:19:WU02:FS03:0xa3:Completed 195000 out of 500000 steps (39%)
01:35:59:WU01:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
01:40:48:WU02:FS03:0xa3:Completed 200000 out of 500000 steps (40%)
01:42:43:WU01:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
01:46:17:WU02:FS03:0xa3:Completed 205000 out of 500000 steps (41%)
01:48:59:WU01:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
01:51:46:WU02:FS03:0xa3:Completed 210000 out of 500000 steps (42%)
01:55:15:WU01:FS00:0x17:Completed 2250000 out of 5000000 steps (45%)
01:57:14:WU02:FS03:0xa3:Completed 215000 out of 500000 steps (43%)
02:02:00:WU01:FS00:0x17:Completed 2300000 out of 5000000 steps (46%)
02:02:43:WU02:FS03:0xa3:Completed 220000 out of 500000 steps (44%)
02:08:12:WU02:FS03:0xa3:Completed 225000 out of 500000 steps (45%)
02:08:16:WU01:FS00:0x17:Completed 2350000 out of 5000000 steps (47%)
02:13:41:WU02:FS03:0xa3:Completed 230000 out of 500000 steps (46%)
02:15:01:WU01:FS00:0x17:Completed 2400000 out of 5000000 steps (48%)
Error code: 3
- System
- Provider
- EventID 1
[ Qualifiers] 49152
Level 2
Task 0
- TimeCreated
EventRecordID 11462
Channel Application
Computer BRG-PC
Security
- EventData
Were you running FAHViewer or was it just FAHClient plus one of FAH's Control programs?
I have the advanced control page open and thats it Bruce...
It's probably prudent to talk to NVidia support, as the messages suggest. Moreover, there's a pretty good chance that it's not related to FAH, especially since the message specifies that the Display had a problem with the OpenGL drivers.
If the errors happen frequently enough, you might try closing the Advanced Control page overnight(?) and confirm that nothing FAH is putting on your screen has anything to do with OpenGL. [FAHClient runs fine in the background or in a text screen -- it doesn't produce any graphics -- and Advanced Control need not be running to Fold.]
Will give that a shot tonight Bruce...
*goes off to google open GL*
Guys just providing some feedback to this, spent 4 hours plus trawling google and working out the issue, seems to come down to 3 possible things-there is others but the main 3.
1, Driver error, this was based on infomation found on the developers forum from nvidia. i have downloaded the drivers they listed when having this issue, according to Adv viewer it has increased my ppd by a few 1000 but im not fussed on if it does or doesnt-i need to benchmark the system again and see if it has made things any better.
2, Overclocked cards, mine is as std an over clocked card, it seems memory overclocks create this error, i tried turning down the speeds that came with the card, no changes at all.
3, PCI E slots, my card (gtx 780) is a PCI e 3 card and im running it in a PCI e 2 board there is a few reports that this can create problems when pushing data thro cards, i dont have a PCI e 3 board to test it in so there is nothing i can do about this. many have said this is rubbish but i thought i would add it as i have found a few reports.
Googled terms: Open GL error code, open GL error code fix, open GL error code 3, gtx GL error code fix, open gl error code registry edit, open Gl error code driver 340.82 fix, open GL error code 3 black screen crashing, Open GL crashing, Open GL windows updates, Open GL error 3 gtx780, open GL error code Nivida, open GL faults
Im sure there was more but thats the ones i wrote down.
I cant help you sort out those choices ... I dont get those errors.
By the way, overclocking memory is MUCH less important to your PPD than overclocking the shaders. In fact, many people who run FAH and not much else do not overclock memory or even underclock it to reduce the heat and leave a little more margin for the shaders. YMMV.
Ive made my choices bruce and all seems ok for now.
Thank you for details on the memory over clock, might turn that right down, so that way i reduce power usage too... ive not touched the memory OC from standard but turning it down wont hurt.
I will do some more looking into this.
And its done it again... will start turning the OC down again and see what happy level i can get it too before it does it again :@
EDIT: died on a core 18- 10472 (0, 18, 31)
Have you tried Fahbench to see if you that works at the current speeds? It's on the Utilities page at fah.
