*********************** Log Started 2014-11-05T15:24:55Z ***********************
15:24:55:************************* Folding@home Client *************************
15:24:55: Website: http://folding.stanford.edu/
15:24:55: Copyright: (c) 2009-2014 Stanford University
15:24:55: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:24:55: Args: --child --lifeline 45 --respawn
15:24:55: Config: /Library/Application Support/FAHClient/config.xml
15:24:55:******************************** Build ********************************
15:24:55: Version: 7.4.4
15:24:55: Date: Mar 4 2014
15:24:55: Time: 20:27:54
15:24:55: SVN Rev: 4130
15:24:55: Branch: fah/trunk/client
15:24:55: Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
15:24:55: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
15:24:55: -fno-unsafe-math-optimizations -msse3 -arch x86_64
15:24:55: -mmacosx-version-min=10.6
15:24:55: Platform: darwin 10.8.0
15:24:55: Bits: 64
15:24:55: Mode: Release
15:24:55:******************************* System ********************************
15:24:55: CPU: Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz
15:24:55: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
15:24:55: CPUs: 2
15:24:55: Memory: 4.00GiB
15:24:55:Free Memory: 3.01GiB
15:24:55: Threads: POSIX_THREADS
15:24:55: OS Version: 10.10
15:24:55:Has Battery: true
15:24:55: On Battery: false
15:24:55: UTC Offset: -5
15:24:55: PID: 201
15:24:55: CWD: /Library/Application Support/FAHClient
15:24:55: OS: Darwin 14.0.0 x86_64
15:24:55: OS Arch: AMD64
15:24:55: GPUs: 1
15:24:55: GPU 0: NVIDIA:1 C79 [GeForce 9400M]
15:24:55: CUDA: Not detected
15:24:55:***********************************************************************
15:24:55:<config>
15:24:55: <!-- Slot Control -->
15:24:55: <power v='LIGHT'/>
15:24:55:
15:24:55: <!-- User Information -->
15:24:55: <passkey v='********************************'/>
15:24:55: <user v='bodhi47'/>
15:24:55:
15:24:55: <!-- Folding Slots -->
15:24:55: <slot id='0' type='CPU'>
15:24:55: <idle v='true'/>
15:24:55: </slot>
15:24:55:</config>
15:24:55:Trying to access database...
15:24:55:Successfully acquired database lock
15:24:55:Enabled folding slot 00: PAUSED cpu:1 (waiting for idle)
15:24:55:ERROR:Failed to register for display power changes
15:26:08:WARNING:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: nodename nor servname provided, or not known
15:26:08:ERROR:WU00:FS00:Exception: Could not get an assignment
15:26:27:WU00:FS00:Connecting to 171.67.108.200:8080
15:26:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:26:29:WU00:FS00:Connecting to 171.67.108.204:80
15:26:30:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:26:30:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2014-11-06 *******************************
03:55:15:14:127.0.0.1:New Web connection
03:55:26:Saving configuration to config.xml
03:55:26:<config>
03:55:26: <!-- User Information -->
03:55:26: <passkey v='********************************'/>
03:55:26: <user v='bodhi47'/>
03:55:26:
03:55:26: <!-- Folding Slots -->
03:55:26: <slot id='0' type='CPU'>
03:55:26: <idle v='true'/>
03:55:26: </slot>
03:55:26:</config>
03:59:18:59:127.0.0.1:New Web connection
04:00:25:WU00:FS00:Connecting to 171.67.108.200:8080
04:00:32:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:00:32:WU00:FS00:Connecting to 171.67.108.204:80
04:00:33:Saving configuration to config.xml
04:00:33:<config>
04:00:33: <!-- Slot Control -->
04:00:33: <power v='medium'/>
04:00:33:
04:00:33: <!-- User Information -->
04:00:33: <passkey v='********************************'/>
04:00:33: <user v='bodhi47'/>
04:00:33:
04:00:33: <!-- Folding Slots -->
04:00:33: <slot id='0' type='CPU'/>
04:00:33:</config>
04:00:34:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:00:34:ERROR:WU00:FS00:Exception: Could not get an assignment
04:01:54:WU00:FS00:Connecting to 171.67.108.200:8080
04:01:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:01:54:WU00:FS00:Connecting to 171.67.108.204:80
04:01:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:01:55:ERROR:WU00:FS00:Exception: Could not get an assignment
04:04:31:WU00:FS00:Connecting to 171.67.108.200:8080
04:04:31:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:04:31:WU00:FS00:Connecting to 171.67.108.204:80
04:04:33:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:04:33:ERROR:WU00:FS00:Exception: Could not get an assignment
04:08:45:WU00:FS00:Connecting to 171.67.108.200:8080
04:08:47:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:08:47:WU00:FS00:Connecting to 171.67.108.204:80
04:08:47:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:08:47:ERROR:WU00:FS00:Exception: Could not get an assignment
04:15:37:WU00:FS00:Connecting to 171.67.108.200:8080
04:15:38:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:15:38:WU00:FS00:Connecting to 171.67.108.204:80
04:15:39:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:15:39:ERROR:WU00:FS00:Exception: Could not get an assignment
04:26:42:WU00:FS00:Connecting to 171.67.108.200:8080
04:26:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:26:44:WU00:FS00:Connecting to 171.67.108.204:80
04:26:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:26:44:ERROR:WU00:FS00:Exception: Could not get an assignment
04:44:39:WU00:FS00:Connecting to 171.67.108.200:8080
04:44:39:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:44:39:WU00:FS00:Connecting to 171.67.108.204:80
04:44:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:44:44:ERROR:WU00:FS00:Exception: Could not get an assignment
05:13:41:WU00:FS00:Connecting to 171.67.108.200:8080
05:13:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
05:13:42:WU00:FS00:Connecting to 171.67.108.204:80
05:13:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:13:43:ERROR:WU00:FS00:Exception: Could not get an assignment
06:00:40:WU00:FS00:Connecting to 171.67.108.200:8080
06:00:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
06:00:41:WU00:FS00:Connecting to 171.67.108.204:80
06:00:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
06:00:42:ERROR:WU00:FS00:Exception: Could not get an assignment
07:16:41:WU00:FS00:Connecting to 171.67.108.200:8080
07:16:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
07:16:42:WU00:FS00:Connecting to 171.67.108.204:80
07:16:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:16:42:ERROR:WU00:FS00:Exception: Could not get an assignment
09:19:41:WU00:FS00:Connecting to 171.67.108.200:8080
09:19:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:19:41:WU00:FS00:Connecting to 171.67.108.204:80
09:19:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:19:42:ERROR:WU00:FS00:Exception: Could not get an assignment
12:38:41:WU00:FS00:Connecting to 171.67.108.200:8080
12:38:41:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
12:38:41:WU00:FS00:Connecting to 171.67.108.204:80
12:38:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
12:38:42:ERROR:WU00:FS00:Exception: Could not get an assignment
18:00:41:WU00:FS00:Connecting to 171.67.108.200:8080
18:00:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
18:00:42:WU00:FS00:Connecting to 171.67.108.204:80
18:00:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
18:00:42:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2014-11-07 *******************************
00:00:41:WU00:FS00:Connecting to 171.67.108.200:8080
00:00:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:00:42:WU00:FS00:Connecting to 171.67.108.204:80
00:00:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:00:43:ERROR:WU00:FS00:Exception: Could not get an assignment
06:00:41:WU00:FS00:Connecting to 171.67.108.200:8080
08:31:02:FS00:Finishing
08:32:24:Caught signal SIGPIPE(13) on PID 201
08:33:04:93:127.0.0.1:New Web connection
08:34:28:FS00:Paused
08:34:29:FS00:Unpaused
08:34:29:WU00:FS00:Connecting to 171.67.108.200:8080
08:34:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
08:34:29:WU00:FS00:Connecting to 171.67.108.204:80
08:34:30:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:34:30:ERROR:WU00:FS00:Exception: Could not get an assignment
08:36:06:WU00:FS00:Connecting to 171.67.108.200:8080
08:36:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
08:36:06:WU00:FS00:Connecting to 171.67.108.204:80
08:36:07:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:36:07:ERROR:WU00:FS00:Exception: Could not get an assignment
08:38:43:WU00:FS00:Connecting to 171.67.108.200:8080
08:38:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
08:38:43:WU00:FS00:Connecting to 171.67.108.204:80
08:38:45:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:38:45:ERROR:WU00:FS00:Exception: Could not get an assignment
08:42:57:WU00:FS00:Connecting to 171.67.108.200:8080
08:42:58:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
08:42:58:WU00:FS00:Connecting to 171.67.108.204:80
08:42:59:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:42:59:ERROR:WU00:FS00:Exception: Could not get an assignment
08:49:49:WU00:FS00:Connecting to 171.67.108.200:8080
08:49:49:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
08:49:49:WU00:FS00:Connecting to 171.67.108.204:80
08:49:50:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:49:50:ERROR:WU00:FS00:Exception: Could not get an assignment
09:00:54:WU00:FS00:Connecting to 171.67.108.200:8080
09:00:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:00:55:WU00:FS00:Connecting to 171.67.108.204:80
09:00:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:00:55:ERROR:WU00:FS00:Exception: Could not get an assignment
09:18:51:WU00:FS00:Connecting to 171.67.108.200:8080
09:18:52:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:18:52:WU00:FS00:Connecting to 171.67.108.204:80
09:18:52:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:18:52:ERROR:WU00:FS00:Exception: Could not get an assignment
09:47:53:WU00:FS00:Connecting to 171.67.108.200:8080
09:47:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
09:47:54:WU00:FS00:Connecting to 171.67.108.204:80
09:47:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
09:47:54:ERROR:WU00:FS00:Exception: Could not get an assignment
10:34:52:WU00:FS00:Connecting to 171.67.108.200:8080
10:34:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
10:34:53:WU00:FS00:Connecting to 171.67.108.204:80
10:34:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
10:34:53:ERROR:WU00:FS00:Exception: Could not get an assignment
11:50:53:WU00:FS00:Connecting to 171.67.108.200:8080
11:50:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
11:50:53:WU00:FS00:Connecting to 171.67.108.204:80
11:50:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:50:54:ERROR:WU00:FS00:Exception: Could not get an assignment
13:53:52:WU00:FS00:Connecting to 171.67.108.200:8080
13:53:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
13:53:53:WU00:FS00:Connecting to 171.67.108.204:80
13:53:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
13:53:54:ERROR:WU00:FS00:Exception: Could not get an assignment
17:12:53:WU00:FS00:Connecting to 171.67.108.200:8080
17:12:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
17:12:53:WU00:FS00:Connecting to 171.67.108.204:80
17:12:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
17:12:54:ERROR:WU00:FS00:Exception: Could not get an assignment
22:34:53:WU00:FS00:Connecting to 171.67.108.200:8080
22:34:53:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
22:34:53:WU00:FS00:Connecting to 171.67.108.204:80
22:34:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
22:34:55:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2014-11-08 *******************************
04:34:53:WU00:FS00:Connecting to 171.67.108.200:8080
04:34:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
04:34:54:WU00:FS00:Connecting to 171.67.108.204:80
04:34:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
04:34:54:ERROR:WU00:FS00:Exception: Could not get an assignment
10:34:53:WU00:FS00:Connecting to 171.67.108.200:8080
10:34:54:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
10:34:54:WU00:FS00:Connecting to 171.67.108.204:80
10:34:57:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
10:34:57:ERROR:WU00:FS00:Exception: Could not get an assignment
15:22:52:119:127.0.0.1:New Web connection
15:23:47:FS00:Paused
15:23:58:FS00:Unpaused
15:24:00:WU00:FS00:Connecting to 171.67.108.200:8080
15:24:01:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:24:01:WU00:FS00:Connecting to 171.67.108.204:80
15:24:02:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:24:02:ERROR:WU00:FS00:Exception: Could not get an assignment
15:24:05:Caught signal SIGPIPE(13) on PID 201
15:25:37:WU00:FS00:Connecting to 171.67.108.200:8080
15:25:38:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:25:38:WU00:FS00:Connecting to 171.67.108.204:80
15:25:38:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:25:38:ERROR:WU00:FS00:Exception: Could not get an assignment
15:28:14:WU00:FS00:Connecting to 171.67.108.200:8080
15:28:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:28:14:WU00:FS00:Connecting to 171.67.108.204:80
15:28:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:28:14:ERROR:WU00:FS00:Exception: Could not get an assignment
15:32:28:WU00:FS00:Connecting to 171.67.108.200:8080
15:32:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
15:32:29:WU00:FS00:Connecting to 171.67.108.204:80
15:32:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
15:32:29:ERROR:WU00:FS00:Exception: Could not get an assignment
