F@H Worked for +/- 2 weeks, Now hangs and won't run?
I am very much a rookie, so I apologize in advance!
Computer Specs: i7 960 with an AMD HD6670.
Network Connection: Very fast Cable, no proxy.
Operating System: Windows 7 What distro/version? IDK, sorry! Latest patches applied? I check and apply updates daily
Overclocked?: Stock Dell.
Stable?: Never, ever had an issue. And again, F@H was working great for a while with no changes I know of before disaster struck.
Software: What version of the client are you using? 7.4.4 (I hope that's right). Remember that Beta and prerelease versions can be unstable. What version of the core(s) are you using? IDK
WU details: Gromacs, DGromacs, SMP, GPU? What WU? Run/Clone/Gen. IDK what this even means. sorry!
I have the program set to run only when idle @ medium. It worked fine for a couple weeks and then the other day I walked by and didn't hear the PC whirling away. I moved the mouse and the "thinking circle" icon for Windows popped up. After 30 seconds of that I hit ESC and my desktop appeared. There was a Windows error message but now when I just tried to replicate it the error message disappeared before I could read it. Something about an error and Windows will let me know when they find a solution to the issue. I know, not a great description, but it is what I have for now.
If I wasn't so passionate about this cause I would just give up, but I really am passionate about this and I appreciate your help in helping me more than I can express. Thanks so much to any and all help.
The "New Member Start Here" post says to post the log if appropriate. It is sure long, so I hope this is the right thing to do. Apologies for breaking any formalities or rules here, I am trying very hard to provide what is requested. Thank you so much again!
UPDATE: Actually, I can't post the log. Since I am new and it is my first post and first day, there is some sort of link in the log that prevents me from adding it. I will try to add it in a minute or PM it to anyone that is kind enough to request it.
davidcoton
Re: F@H Worked for +/- 2 weeks, Now hangs and won't run?
Welcome!
Yes, if in doubt, post the whole log (in code tags). Sometimes you need to prune it to fit the message limit -- be sure to include the stuff at the start and any error messages, but remove repetitions and complete successful units.
If you still can't post it PM me with it (if that works) -- but I won't be up much longer tonight.
Welcome to foldingforum.org, R.Ludt, and congratulations on composing a really good start toward debugging your problem.
If there was a windows error, even if you can't read the message, windows should have put and entry in it's "Event Log" which can be found in Control Panel under Administrative Tools.
Run, Clone, Gen (along with Project) are the identifiers that uniquely identify the Work Unit that was assigned to you. In the log, you'll see something like:
12:12:50:WU01:FS00:0x17:Project: 13000 (Run 222, Clone 1, Gen 37)
(where all of the numbers are probably different).
Most of the information will be found in the log, whether you know what all the questions mean or not. If, after trimming out the unneceswsary parts per davidcoton's instructions, you still can't post it, you can email it to me and I'll post the important segments for you. My email is in a Private Message to you.
I apologize for posting as much of the log below as I have, but so much of this is Greek to me I was afraid to leave out something critical. Another apology, after doing just a little more reading (which I should have done prior to posting / giving up) I found the simple instructions to properly (if lengthy) post this. A big thank you to all that lead me in the proper direction to doing so!
*********************** Log Started 2014-10-29T13:47:06Z ***********************
13:47:06:************************* Folding@home Client *************************
13:47:06: Website: http://folding.stanford.edu/
13:47:06: Copyright: (c) 2009-2014 Stanford University
13:47:06: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:47:06: Args:
13:47:06: Config: C:/Users/Roy Ludt/AppData/Roaming/FAHClient/config.xml
13:47:06:******************************** Build ********************************
13:47:06: Version: 7.4.4
13:47:06: Date: Mar 4 2014
13:47:06: Time: 20:26:54
13:47:06: SVN Rev: 4130
13:47:06: Branch: fah/trunk/client
13:47:06: Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:47:06: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:47:06: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
13:47:06: Platform: win32 XP
13:47:06: Bits: 32
13:47:06: Mode: Release
13:47:06:******************************* System ********************************
13:47:06: CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
13:47:06: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
13:47:06: CPUs: 8
13:47:06: Memory: 11.99GiB
13:47:06: Free Memory: 10.63GiB
13:47:06: Threads: WINDOWS_THREADS
13:47:06: OS Version: 6.1
13:47:06: Has Battery: false
13:47:06: On Battery: false
13:47:06: UTC Offset: -7
13:47:06: PID: 3672
13:47:06: CWD: C:/Users/Roy Ludt/AppData/Roaming/FAHClient
13:47:06: OS: Windows 7 Home Premium
13:47:06: OS Arch: AMD64
13:47:06: GPUs: 1
13:47:06: GPU 0: ATI:4 Whistler [Radeon HD 6600 Series]
13:47:06: CUDA: Not detected
13:47:06:Win32 Service: false
13:47:06:***********************************************************************
13:47:06:<config>
13:47:06: <!-- Folding Core -->
13:47:06: <core-priority v='low'/>
13:47:06:
13:47:06: <!-- Network -->
13:47:06: <proxy v=':8080'/>
13:47:06:
13:47:06: <!-- Slot Control -->
13:47:06: <pause-on-battery v='false'/>
13:47:06:
13:47:06: <!-- User Information -->
13:47:06: <user v='MrLudt'/>
13:47:06:
13:47:06: <!-- Folding Slots -->
13:47:06: <slot id='0' type='CPU'>
13:47:06: <idle v='true'/>
13:47:06: </slot>
13:47:06: <slot id='1' type='GPU'>
13:47:06: </slot>
13:47:06:</config>
13:47:06:Trying to access database...
13:47:06:Successfully acquired database lock
13:47:06:Enabled folding slot 00: PAUSED cpu:6 (waiting for idle)
13:47:06:Enabled folding slot 01: PAUSED gpu:0:Whistler [Radeon HD 6600 Series] (waiting for idle)
13:58:29:WU00:FS00:Starting
13:58:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
13:58:29:WU00:FS00:Started FahCore on PID 5404
13:58:29:WU00:FS00:Core PID:2364
13:58:29:WU00:FS00:FahCore 0xa3 started
13:58:29:WU01:FS01:Starting
13:58:29:WU01:FS01:Removing old file './work/01/logfile_01-20141025-174407.txt'
13:58:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
13:58:29:WU01:FS01:Started FahCore on PID 5864
13:58:29:WU01:FS01:Core PID:5064
13:58:29:WU01:FS01:FahCore 0x17 started
13:58:29:WU00:FS00:0xa3:
13:58:29:WU00:FS00:0xa3:*------------------------------*
13:58:29:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
13:58:29:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
13:58:29:WU00:FS00:0xa3:Preparing to commence simulation
13:58:29:WU00:FS00:0xa3:- Looking at optimizations...
13:58:29:WU00:FS00:0xa3:- Files status OK
13:58:29:WU01:FS01:0x17:*********************** Log Started 2014-10-29T13:58:29Z ***********************
13:58:29:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
13:58:29:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
13:58:29:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
13:58:29:WU01:FS01:0x17:Machine: 1
13:58:29:WU01:FS01:0x17:Digital signatures verified
13:58:29:WU01:FS01:0x17:Folding@home GPU core17
13:58:29:WU01:FS01:0x17:Version 0.0.52
13:58:29:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
13:58:29:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
13:58:29:WU00:FS00:0xa3:- Digital signature verified
13:58:29:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
13:58:29:WU00:FS00:0xa3:Assembly optimizations on if available.
13:58:29:WU00:FS00:0xa3:Entering M.D.
13:58:30:WU01:FS01:0x17: Found a checkpoint file
13:58:35:WU00:FS00:0xa3:Using Gromacs checkpoints
13:58:35:WU00:FS00:0xa3:Mapping NT from 6 to 6
13:58:36:WU00:FS00:0xa3:Resuming from checkpoint
13:58:36:WU00:FS00:0xa3:Verified 00/wudata_01.log
13:58:36:WU00:FS00:0xa3:Verified 00/wudata_01.trr
13:58:36:WU00:FS00:0xa3:Verified 00/wudata_01.edr
13:58:36:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
13:59:08:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
14:02:32:FS00:Shutting core down
14:02:32:FS01:Shutting core down
14:02:32:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 5064
14:02:32:WU01:FS01:0x17:Exiting, please wait. . .
14:02:40:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:03:10:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
14:03:10:WU01:FS01:0x17:Lost lifeline PID 5864, exiting
14:03:10:WU01:FS01:0x17:ERROR:103: Lost client lifeline
14:03:10:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
14:03:10:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:30:48:WU00:FS00:Starting
17:30:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
17:30:48:WU00:FS00:Started FahCore on PID 4316
17:30:48:WU00:FS00:Core PID:3080
17:30:48:WU00:FS00:FahCore 0xa3 started
17:30:48:WU01:FS01:Starting
17:30:48:WU01:FS01:Removing old file './work/01/logfile_01-20141025-180700.txt'
17:30:48:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:30:48:WU01:FS01:Started FahCore on PID 2660
17:30:48:WU01:FS01:Core PID:1380
17:30:48:WU01:FS01:FahCore 0x17 started
17:30:48:WU00:FS00:0xa3:
17:30:48:WU00:FS00:0xa3:*------------------------------*
17:30:48:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
17:30:48:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
17:30:48:WU00:FS00:0xa3:Preparing to commence simulation
17:30:48:WU00:FS00:0xa3:- Looking at optimizations...
17:30:48:WU00:FS00:0xa3:- Files status OK
17:30:48:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
17:30:48:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
17:30:48:WU00:FS00:0xa3:- Digital signature verified
17:30:48:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
17:30:48:WU00:FS00:0xa3:Assembly optimizations on if available.
17:30:48:WU00:FS00:0xa3:Entering M.D.
17:30:48:WU01:FS01:0x17:*********************** Log Started 2014-10-29T17:30:48Z ***********************
17:30:48:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
17:30:48:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
17:30:48:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:30:48:WU01:FS01:0x17:Machine: 1
17:30:48:WU01:FS01:0x17:Digital signatures verified
17:30:48:WU01:FS01:0x17:Folding@home GPU core17
17:30:48:WU01:FS01:0x17:Version 0.0.52
17:30:48:WU01:FS01:0x17: Found a checkpoint file
17:30:54:WU00:FS00:0xa3:Using Gromacs checkpoints
17:30:54:WU00:FS00:0xa3:Mapping NT from 6 to 6
17:30:55:WU00:FS00:0xa3:Resuming from checkpoint
17:30:55:WU00:FS00:0xa3:Verified 00/wudata_01.log
17:30:55:WU00:FS00:0xa3:Verified 00/wudata_01.trr
17:30:55:WU00:FS00:0xa3:Verified 00/wudata_01.edr
17:30:56:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
17:31:26:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
17:34:24:FS00:Shutting core down
17:34:24:FS01:Shutting core down
17:34:24:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 1380
17:34:24:WU01:FS01:0x17:Exiting, please wait. . .
17:34:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:35:15:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
17:35:15:WU01:FS01:0x17:Lost lifeline PID 2660, exiting
17:35:15:WU01:FS01:0x17:ERROR:103: Lost client lifeline
17:35:15:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
17:35:15:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
******************************* Date: 2014-10-30 *******************************
00:09:54:WU00:FS00:Starting
00:09:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
00:09:54:WU00:FS00:Started FahCore on PID 1292
00:09:54:WU00:FS00:Core PID:6140
00:09:54:WU00:FS00:FahCore 0xa3 started
00:09:54:WU01:FS01:Starting
00:09:54:WU01:FS01:Removing old file './work/01/logfile_01-20141025-181842.txt'
00:09:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:09:54:WU01:FS01:Started FahCore on PID 6584
00:09:54:WU01:FS01:Core PID:2512
00:09:54:WU01:FS01:FahCore 0x17 started
00:09:54:WU00:FS00:0xa3:
00:09:54:WU00:FS00:0xa3:*------------------------------*
00:09:54:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
00:09:54:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
00:09:54:WU00:FS00:0xa3:Preparing to commence simulation
00:09:54:WU00:FS00:0xa3:- Looking at optimizations...
00:09:54:WU00:FS00:0xa3:- Files status OK
00:09:54:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
00:09:54:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
00:09:54:WU00:FS00:0xa3:- Digital signature verified
00:09:54:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
00:09:54:WU00:FS00:0xa3:Assembly optimizations on if available.
00:09:54:WU00:FS00:0xa3:Entering M.D.
00:09:54:WU01:FS01:0x17:*********************** Log Started 2014-10-30T00:09:54Z ***********************
00:09:54:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
00:09:54:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
00:09:54:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:09:54:WU01:FS01:0x17:Machine: 1
00:09:54:WU01:FS01:0x17:Digital signatures verified
00:09:54:WU01:FS01:0x17:Folding@home GPU core17
00:09:54:WU01:FS01:0x17:Version 0.0.52
00:09:54:WU01:FS01:0x17: Found a checkpoint file
00:09:59:FS00:Shutting core down
00:09:59:FS01:Shutting core down
00:09:59:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 2512
00:09:59:WU01:FS01:0x17:Exiting, please wait. . .
00:10:00:WU00:FS00:0xa3:Using Gromacs checkpoints
00:10:00:WU00:FS00:0xa3:Mapping NT from 6 to 6
00:10:01:WU00:FS00:0xa3:Resuming from checkpoint
00:10:01:WU00:FS00:0xa3:Verified 00/wudata_01.log
00:10:01:WU00:FS00:0xa3:Verified 00/wudata_01.trr
00:10:01:WU00:FS00:0xa3:Verified 00/wudata_01.edr
00:10:01:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
00:10:04:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:11:00:WARNING:FS01:Killing WU01
00:11:00:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:36:01:WU00:FS00:Starting
00:36:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
00:36:01:WU00:FS00:Started FahCore on PID 5864
00:36:01:WU00:FS00:Core PID:6468
00:36:01:WU00:FS00:FahCore 0xa3 started
00:36:01:WU01:FS01:Starting
00:36:01:WU01:FS01:Removing old file './work/01/logfile_01-20141025-210729.txt'
00:36:01:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:36:01:WU01:FS01:Started FahCore on PID 1156
00:36:01:WU01:FS01:Core PID:7144
00:36:01:WU01:FS01:FahCore 0x17 started
00:36:02:WU00:FS00:0xa3:
00:36:02:WU00:FS00:0xa3:*------------------------------*
00:36:02:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
00:36:02:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
00:36:02:WU00:FS00:0xa3:Preparing to commence simulation
00:36:02:WU00:FS00:0xa3:- Looking at optimizations...
00:36:02:WU00:FS00:0xa3:- Files status OK
00:36:02:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
00:36:02:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
00:36:02:WU00:FS00:0xa3:- Digital signature verified
00:36:02:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
00:36:02:WU00:FS00:0xa3:Assembly optimizations on if available.
00:36:02:WU00:FS00:0xa3:Entering M.D.
00:36:02:WU01:FS01:0x17:*********************** Log Started 2014-10-30T00:36:01Z ***********************
00:36:02:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
00:36:02:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
00:36:02:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:36:02:WU01:FS01:0x17:Machine: 1
00:36:02:WU01:FS01:0x17:Digital signatures verified
00:36:02:WU01:FS01:0x17:Folding@home GPU core17
00:36:02:WU01:FS01:0x17:Version 0.0.52
00:36:02:WU01:FS01:0x17: Found a checkpoint file
00:36:08:WU00:FS00:0xa3:Using Gromacs checkpoints
00:36:08:WU00:FS00:0xa3:Mapping NT from 6 to 6
00:36:09:WU00:FS00:0xa3:Resuming from checkpoint
00:36:09:WU00:FS00:0xa3:Verified 00/wudata_01.log
00:36:09:WU00:FS00:0xa3:Verified 00/wudata_01.trr
00:36:09:WU00:FS00:0xa3:Verified 00/wudata_01.edr
00:36:09:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
00:36:39:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
00:39:27:FS00:Shutting core down
00:39:27:FS01:Shutting core down
00:39:28:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 7144
00:39:28:WU01:FS01:0x17:Exiting, please wait. . .
00:39:32:WU00:FS00:0xa3:Client no longer detected. Shutting down core
00:39:32:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
00:39:32:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:40:28:WARNING:FS01:Killing WU01
00:40:28:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
01:18:36:WU00:FS00:Starting
01:18:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
01:18:36:WU00:FS00:Started FahCore on PID 2856
01:18:36:WU00:FS00:Core PID:5820
01:18:36:WU00:FS00:FahCore 0xa3 started
01:18:37:WU01:FS01:Starting
01:18:37:WU01:FS01:Removing old file './work/01/logfile_01-20141025-220009.txt'
01:18:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
01:18:37:WU01:FS01:Started FahCore on PID 6656
01:18:37:WU01:FS01:Core PID:3836
01:18:37:WU01:FS01:FahCore 0x17 started
01:18:37:WU00:FS00:0xa3:
01:18:37:WU00:FS00:0xa3:*------------------------------*
01:18:37:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
01:18:37:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
01:18:37:WU00:FS00:0xa3:Preparing to commence simulation
01:18:37:WU00:FS00:0xa3:- Looking at optimizations...
01:18:37:WU00:FS00:0xa3:- Files status OK
01:18:37:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
01:18:37:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
01:18:37:WU00:FS00:0xa3:- Digital signature verified
01:18:37:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
01:18:37:WU00:FS00:0xa3:Assembly optimizations on if available.
01:18:37:WU00:FS00:0xa3:Entering M.D.
01:18:37:WU01:FS01:0x17:*********************** Log Started 2014-10-30T01:18:37Z ***********************
01:18:37:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
01:18:37:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
01:18:37:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
01:18:37:WU01:FS01:0x17:Machine: 1
01:18:37:WU01:FS01:0x17:Digital signatures verified
01:18:37:WU01:FS01:0x17:Folding@home GPU core17
01:18:37:WU01:FS01:0x17:Version 0.0.52
01:18:37:WU01:FS01:0x17: Found a checkpoint file
01:18:43:WU00:FS00:0xa3:Using Gromacs checkpoints
01:18:43:WU00:FS00:0xa3:Mapping NT from 6 to 6
01:18:44:WU00:FS00:0xa3:Resuming from checkpoint
01:18:44:WU00:FS00:0xa3:Verified 00/wudata_01.log
01:18:44:WU00:FS00:0xa3:Verified 00/wudata_01.trr
01:18:44:WU00:FS00:0xa3:Verified 00/wudata_01.edr
01:18:44:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
01:19:14:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
01:22:13:FS00:Shutting core down
01:22:13:FS01:Shutting core down
01:22:13:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 3836
01:22:13:WU01:FS01:0x17:Exiting, please wait. . .
01:22:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:23:08:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
01:23:08:WU01:FS01:0x17:Lost lifeline PID 6656, exiting
01:23:08:WU01:FS01:0x17:ERROR:103: Lost client lifeline
01:23:08:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
01:23:08:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:54:46:WU00:FS00:Starting
02:54:46:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
02:54:46:WU00:FS00:Started FahCore on PID 1356
02:54:46:WU00:FS00:Core PID:6496
02:54:46:WU00:FS00:FahCore 0xa3 started
02:54:46:WU01:FS01:Starting
02:54:46:WU01:FS01:Removing old file './work/01/logfile_01-20141025-223918.txt'
02:54:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:54:46:WU01:FS01:Started FahCore on PID 4244
02:54:46:WU01:FS01:Core PID:6140
02:54:46:WU01:FS01:FahCore 0x17 started
02:54:47:WU00:FS00:0xa3:
02:54:47:WU00:FS00:0xa3:*------------------------------*
02:54:47:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
02:54:47:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
02:54:47:WU00:FS00:0xa3:Preparing to commence simulation
02:54:47:WU00:FS00:0xa3:- Looking at optimizations...
02:54:47:WU00:FS00:0xa3:- Files status OK
02:54:47:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
02:54:47:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
02:54:47:WU00:FS00:0xa3:- Digital signature verified
02:54:47:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
02:54:47:WU00:FS00:0xa3:Assembly optimizations on if available.
02:54:47:WU00:FS00:0xa3:Entering M.D.
02:54:47:WU01:FS01:0x17:*********************** Log Started 2014-10-30T02:54:46Z ***********************
02:54:47:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
02:54:47:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
02:54:47:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
02:54:47:WU01:FS01:0x17:Machine: 1
02:54:47:WU01:FS01:0x17:Digital signatures verified
02:54:47:WU01:FS01:0x17:Folding@home GPU core17
02:54:47:WU01:FS01:0x17:Version 0.0.52
02:54:47:WU01:FS01:0x17: Found a checkpoint file
02:54:50:FS00:Shutting core down
02:54:50:FS01:Shutting core down
02:54:50:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 6140
02:54:50:WU01:FS01:0x17:Exiting, please wait. . .
02:54:53:WU00:FS00:0xa3:Using Gromacs checkpoints
02:54:53:WU00:FS00:0xa3:Mapping NT from 6 to 6
02:54:53:WU00:FS00:0xa3:Resuming from checkpoint
02:54:54:WU00:FS00:0xa3:Verified 00/wudata_01.log
02:54:54:WU00:FS00:0xa3:Verified 00/wudata_01.trr
02:54:54:WU00:FS00:0xa3:Verified 00/wudata_01.edr
02:54:54:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
02:54:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:55:51:WARNING:FS01:Killing WU01
02:55:51:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:07:41:WU00:FS00:Starting
03:07:41:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
03:07:41:WU00:FS00:Started FahCore on PID 6300
03:07:41:WU00:FS00:Core PID:6400
03:07:41:WU00:FS00:FahCore 0xa3 started
03:07:41:WU01:FS01:Starting
03:07:41:WU01:FS01:Removing old file './work/01/logfile_01-20141025-231410.txt'
03:07:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:07:41:WU01:FS01:Started FahCore on PID 6708
03:07:41:WU01:FS01:Core PID:1204
03:07:41:WU01:FS01:FahCore 0x17 started
03:07:41:WU00:FS00:0xa3:
03:07:41:WU00:FS00:0xa3:*------------------------------*
03:07:41:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
03:07:41:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
03:07:41:WU00:FS00:0xa3:Preparing to commence simulation
03:07:41:WU00:FS00:0xa3:- Looking at optimizations...
03:07:41:WU00:FS00:0xa3:- Files status OK
03:07:41:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
03:07:41:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
03:07:41:WU00:FS00:0xa3:- Digital signature verified
03:07:41:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
03:07:41:WU00:FS00:0xa3:Assembly optimizations on if available.
03:07:41:WU00:FS00:0xa3:Entering M.D.
03:07:41:WU01:FS01:0x17:*********************** Log Started 2014-10-30T03:07:41Z ***********************
03:07:41:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
03:07:41:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
03:07:41:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
03:07:41:WU01:FS01:0x17:Machine: 1
03:07:41:WU01:FS01:0x17:Digital signatures verified
03:07:41:WU01:FS01:0x17:Folding@home GPU core17
03:07:41:WU01:FS01:0x17:Version 0.0.52
03:07:41:WU01:FS01:0x17: Found a checkpoint file
03:07:47:WU00:FS00:0xa3:Using Gromacs checkpoints
03:07:48:WU00:FS00:0xa3:Mapping NT from 6 to 6
03:07:48:WU00:FS00:0xa3:Resuming from checkpoint
03:07:48:WU00:FS00:0xa3:Verified 00/wudata_01.log
03:07:48:WU00:FS00:0xa3:Verified 00/wudata_01.trr
03:07:48:WU00:FS00:0xa3:Verified 00/wudata_01.edr
03:07:49:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
03:08:19:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
03:11:12:FS00:Shutting core down
03:11:12:FS01:Shutting core down
03:11:13:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 1204
03:11:13:WU01:FS01:0x17:Exiting, please wait. . .
03:11:13:WU00:FS00:0xa3:Client no longer detected. Shutting down core
03:11:13:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
03:11:13:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:12:09:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
12:47:37:WU00:FS00:Starting
12:47:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
12:47:37:WU00:FS00:Started FahCore on PID 6548
12:47:37:WU00:FS00:Core PID:3268
12:47:37:WU00:FS00:FahCore 0xa3 started
12:47:37:WU01:FS01:Starting
12:47:37:WU01:FS01:Removing old file './work/01/logfile_01-20141026-000345.txt'
12:47:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
12:47:37:WU01:FS01:Started FahCore on PID 6456
12:47:37:WU01:FS01:Core PID:4244
12:47:37:WU01:FS01:FahCore 0x17 started
12:47:37:WU00:FS00:0xa3:
12:47:37:WU00:FS00:0xa3:*------------------------------*
12:47:37:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
12:47:37:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
12:47:37:WU00:FS00:0xa3:Preparing to commence simulation
12:47:37:WU00:FS00:0xa3:- Looking at optimizations...
12:47:37:WU00:FS00:0xa3:- Files status OK
12:47:37:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
12:47:37:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
12:47:37:WU00:FS00:0xa3:- Digital signature verified
12:47:37:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
12:47:37:WU00:FS00:0xa3:Assembly optimizations on if available.
12:47:37:WU00:FS00:0xa3:Entering M.D.
12:47:37:WU01:FS01:0x17:*********************** Log Started 2014-10-30T12:47:37Z ***********************
12:47:37:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
12:47:37:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
12:47:37:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
12:47:37:WU01:FS01:0x17:Machine: 1
12:47:37:WU01:FS01:0x17:Digital signatures verified
12:47:37:WU01:FS01:0x17:Folding@home GPU core17
12:47:37:WU01:FS01:0x17:Version 0.0.52
12:47:37:WU01:FS01:0x17: Found a checkpoint file
12:47:43:WU00:FS00:0xa3:Using Gromacs checkpoints
12:47:43:WU00:FS00:0xa3:Mapping NT from 6 to 6
12:47:44:WU00:FS00:0xa3:Resuming from checkpoint
12:47:44:WU00:FS00:0xa3:Verified 00/wudata_01.log
12:47:44:WU00:FS00:0xa3:Verified 00/wudata_01.trr
12:47:44:WU00:FS00:0xa3:Verified 00/wudata_01.edr
12:47:44:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
12:48:14:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
12:51:08:FS00:Shutting core down
12:51:08:FS01:Shutting core down
12:51:08:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4244
12:51:08:WU01:FS01:0x17:Exiting, please wait. . .
12:51:17:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:52:04:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:30:48:WU00:FS00:Starting
13:30:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
13:30:48:WU00:FS00:Started FahCore on PID 6584
13:30:48:WU00:FS00:Core PID:2180
13:30:48:WU00:FS00:FahCore 0xa3 started
13:30:48:WU01:FS01:Starting
13:30:49:WU01:FS01:Removing old file './work/01/logfile_01-20141026-000921.txt'
13:30:49:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
13:30:49:WU01:FS01:Started FahCore on PID 4100
13:30:49:WU01:FS01:Core PID:4868
13:30:49:WU01:FS01:FahCore 0x17 started
13:30:49:WU00:FS00:0xa3:
13:30:49:WU00:FS00:0xa3:*------------------------------*
13:30:49:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
13:30:49:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
13:30:49:WU00:FS00:0xa3:Preparing to commence simulation
13:30:49:WU00:FS00:0xa3:- Looking at optimizations...
13:30:49:WU00:FS00:0xa3:- Files status OK
13:30:49:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
13:30:49:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
13:30:49:WU00:FS00:0xa3:- Digital signature verified
13:30:49:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
13:30:49:WU00:FS00:0xa3:Assembly optimizations on if available.
13:30:49:WU00:FS00:0xa3:Entering M.D.
13:30:49:WU01:FS01:0x17:*********************** Log Started 2014-10-30T13:30:49Z ***********************
13:30:49:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
13:30:49:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
13:30:49:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
13:30:49:WU01:FS01:0x17:Machine: 1
13:30:49:WU01:FS01:0x17:Digital signatures verified
13:30:49:WU01:FS01:0x17:Folding@home GPU core17
13:30:49:WU01:FS01:0x17:Version 0.0.52
13:30:49:WU01:FS01:0x17: Found a checkpoint file
13:30:55:WU00:FS00:0xa3:Using Gromacs checkpoints
13:30:55:WU00:FS00:0xa3:Mapping NT from 6 to 6
13:30:56:WU00:FS00:0xa3:Resuming from checkpoint
13:30:56:WU00:FS00:0xa3:Verified 00/wudata_01.log
13:30:56:WU00:FS00:0xa3:Verified 00/wudata_01.trr
13:30:56:WU00:FS00:0xa3:Verified 00/wudata_01.edr
13:30:56:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
13:31:26:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
13:34:21:FS00:Shutting core down
13:34:21:FS01:Shutting core down
13:34:24:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:34:24:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4868
13:34:24:WU01:FS01:0x17:Exiting, please wait. . .
13:35:17:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
13:35:17:WU01:FS01:0x17:Lost lifeline PID 4100, exiting
13:35:17:WU01:FS01:0x17:ERROR:103: Lost client lifeline
13:35:17:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
13:35:17:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
14:21:54:WU00:FS00:Starting
14:21:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
14:21:54:WU00:FS00:Started FahCore on PID 6724
14:21:54:WU00:FS00:Core PID:6688
14:21:54:WU00:FS00:FahCore 0xa3 started
14:21:54:WU01:FS01:Starting
14:21:54:WU01:FS01:Removing old file './work/01/logfile_01-20141026-005658.txt'
14:21:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:21:54:WU01:FS01:Started FahCore on PID 1380
14:21:54:WU01:FS01:Core PID:4264
14:21:54:WU01:FS01:FahCore 0x17 started
14:21:54:WU00:FS00:0xa3:
14:21:54:WU00:FS00:0xa3:*------------------------------*
14:21:54:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
14:21:54:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
14:21:54:WU00:FS00:0xa3:Preparing to commence simulation
14:21:54:WU00:FS00:0xa3:- Looking at optimizations...
14:21:54:WU00:FS00:0xa3:- Files status OK
14:21:54:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
14:21:54:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
14:21:54:WU00:FS00:0xa3:- Digital signature verified
14:21:54:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
14:21:54:WU00:FS00:0xa3:Assembly optimizations on if available.
14:21:54:WU00:FS00:0xa3:Entering M.D.
14:21:54:WU01:FS01:0x17:*********************** Log Started 2014-10-30T14:21:54Z ***********************
14:21:54:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
14:21:54:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
14:21:54:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
14:21:54:WU01:FS01:0x17:Machine: 1
14:21:54:WU01:FS01:0x17:Digital signatures verified
14:21:54:WU01:FS01:0x17:Folding@home GPU core17
14:21:54:WU01:FS01:0x17:Version 0.0.52
14:21:54:WU01:FS01:0x17: Found a checkpoint file
14:22:00:WU00:FS00:0xa3:Using Gromacs checkpoints
14:22:00:WU00:FS00:0xa3:Mapping NT from 6 to 6
14:22:01:WU00:FS00:0xa3:Resuming from checkpoint
14:22:01:WU00:FS00:0xa3:Verified 00/wudata_01.log
14:22:01:WU00:FS00:0xa3:Verified 00/wudata_01.trr
14:22:01:WU00:FS00:0xa3:Verified 00/wudata_01.edr
14:22:01:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
14:22:31:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
14:25:34:FS00:Shutting core down
14:25:34:FS01:Shutting core down
14:25:34:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4264
14:25:34:WU01:FS01:0x17:Exiting, please wait. . .
14:25:44:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:26:27:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
14:26:27:WU01:FS01:0x17:Lost lifeline PID 1380, exiting
14:26:27:WU01:FS01:0x17:ERROR:103: Lost client lifeline
14:26:27:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
14:26:27:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:26:28:WU00:FS00:Starting
23:26:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
23:26:28:WU00:FS00:Started FahCore on PID 3748
23:26:28:WU00:FS00:Core PID:6960
23:26:28:WU00:FS00:FahCore 0xa3 started
23:26:28:WU01:FS01:Starting
23:26:28:WU01:FS01:Removing old file './work/01/logfile_01-20141026-022015.txt'
23:26:28:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
23:26:28:WU01:FS01:Started FahCore on PID 6608
23:26:28:WU01:FS01:Core PID:6312
23:26:28:WU01:FS01:FahCore 0x17 started
23:26:28:WU00:FS00:0xa3:
23:26:28:WU00:FS00:0xa3:*------------------------------*
23:26:28:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
23:26:28:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
23:26:28:WU00:FS00:0xa3:Preparing to commence simulation
23:26:28:WU00:FS00:0xa3:- Looking at optimizations...
23:26:28:WU00:FS00:0xa3:- Files status OK
23:26:28:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
23:26:28:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
23:26:28:WU00:FS00:0xa3:- Digital signature verified
23:26:28:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
23:26:28:WU00:FS00:0xa3:Assembly optimizations on if available.
23:26:28:WU00:FS00:0xa3:Entering M.D.
23:26:28:WU01:FS01:0x17:*********************** Log Started 2014-10-30T23:26:28Z ***********************
23:26:28:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
23:26:28:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
23:26:28:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:26:28:WU01:FS01:0x17:Machine: 1
23:26:28:WU01:FS01:0x17:Digital signatures verified
23:26:28:WU01:FS01:0x17:Folding@home GPU core17
23:26:28:WU01:FS01:0x17:Version 0.0.52
23:26:28:WU01:FS01:0x17: Found a checkpoint file
23:26:30:FS00:Shutting core down
23:26:30:FS01:Shutting core down
23:26:30:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 6312
23:26:30:WU01:FS01:0x17:Exiting, please wait. . .
23:26:34:WU00:FS00:0xa3:Using Gromacs checkpoints
23:26:34:WU00:FS00:0xa3:Mapping NT from 6 to 6
23:26:35:WU00:FS00:0xa3:Resuming from checkpoint
23:26:35:WU00:FS00:0xa3:Verified 00/wudata_01.log
23:26:35:WU00:FS00:0xa3:Verified 00/wudata_01.trr
23:26:35:WU00:FS00:0xa3:Verified 00/wudata_01.edr
23:26:36:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
23:26:38:WU00:FS00:0xa3:Client no longer detected. Shutting down core
23:26:38:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
23:26:38:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:27:31:WARNING:FS01:Killing WU01
23:27:31:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:27:37:WU00:FS00:Starting
23:27:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
23:27:37:WU00:FS00:Started FahCore on PID 6284
23:27:37:WU00:FS00:Core PID:6240
23:27:37:WU00:FS00:FahCore 0xa3 started
23:27:37:WU01:FS01:Starting
23:27:37:WU01:FS01:Removing old file './work/01/logfile_01-20141026-022458.txt'
23:27:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
23:27:37:WU01:FS01:Started FahCore on PID 3628
23:27:37:WU01:FS01:Core PID:4164
23:27:37:WU01:FS01:FahCore 0x17 started
23:27:37:WU00:FS00:0xa3:
23:27:37:WU00:FS00:0xa3:*------------------------------*
23:27:37:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
23:27:37:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
23:27:37:WU00:FS00:0xa3:Preparing to commence simulation
23:27:37:WU00:FS00:0xa3:- Looking at optimizations...
23:27:37:WU00:FS00:0xa3:- Files status OK
23:27:37:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
23:27:37:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
23:27:37:WU00:FS00:0xa3:- Digital signature verified
23:27:37:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
23:27:37:WU00:FS00:0xa3:Assembly optimizations on if available.
23:27:37:WU00:FS00:0xa3:Entering M.D.
23:27:37:WU01:FS01:0x17:*********************** Log Started 2014-10-30T23:27:37Z ***********************
23:27:37:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
23:27:37:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
23:27:37:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:27:37:WU01:FS01:0x17:Machine: 1
23:27:37:WU01:FS01:0x17:Digital signatures verified
23:27:37:WU01:FS01:0x17:Folding@home GPU core17
23:27:37:WU01:FS01:0x17:Version 0.0.52
23:27:37:WU01:FS01:0x17: Found a checkpoint file
23:27:43:WU00:FS00:0xa3:Using Gromacs checkpoints
23:27:44:WU00:FS00:0xa3:Mapping NT from 6 to 6
23:27:44:WU00:FS00:0xa3:Resuming from checkpoint
23:27:44:WU00:FS00:0xa3:Verified 00/wudata_01.log
23:27:44:WU00:FS00:0xa3:Verified 00/wudata_01.trr
23:27:44:WU00:FS00:0xa3:Verified 00/wudata_01.edr
23:27:45:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
23:28:03:FS00:Shutting core down
23:28:03:FS01:Shutting core down
23:28:03:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4164
23:28:03:WU01:FS01:0x17:Exiting, please wait. . .
23:28:07:WU00:FS00:0xa3:Client no longer detected. Shutting down core
23:28:07:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
23:28:08:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:29:04:WARNING:FS01:Killing WU01
23:29:04:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:54:20:WU00:FS00:Starting
23:54:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
23:54:20:WU00:FS00:Started FahCore on PID 896
23:54:20:WU00:FS00:Core PID:6804
23:54:20:WU00:FS00:FahCore 0xa3 started
23:54:20:WU01:FS01:Starting
23:54:20:WU01:FS01:Removing old file './work/01/logfile_01-20141026-035452.txt'
23:54:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
23:54:20:WU01:FS01:Started FahCore on PID 4868
23:54:20:WU01:FS01:Core PID:7012
23:54:20:WU01:FS01:FahCore 0x17 started
23:54:21:WU00:FS00:0xa3:
23:54:21:WU00:FS00:0xa3:*------------------------------*
23:54:21:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
23:54:21:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
23:54:21:WU00:FS00:0xa3:Preparing to commence simulation
23:54:21:WU00:FS00:0xa3:- Looking at optimizations...
23:54:21:WU00:FS00:0xa3:- Files status OK
23:54:21:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
23:54:21:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
23:54:21:WU00:FS00:0xa3:- Digital signature verified
23:54:21:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
23:54:21:WU00:FS00:0xa3:Assembly optimizations on if available.
23:54:21:WU00:FS00:0xa3:Entering M.D.
23:54:21:WU01:FS01:0x17:*********************** Log Started 2014-10-30T23:54:20Z ***********************
23:54:21:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
23:54:21:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
23:54:21:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:54:21:WU01:FS01:0x17:Machine: 1
23:54:21:WU01:FS01:0x17:Digital signatures verified
23:54:21:WU01:FS01:0x17:Folding@home GPU core17
23:54:21:WU01:FS01:0x17:Version 0.0.52
23:54:21:WU01:FS01:0x17: Found a checkpoint file
23:54:23:FS00:Shutting core down
23:54:23:FS01:Shutting core down
23:54:23:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 7012
23:54:23:WU01:FS01:0x17:Exiting, please wait. . .
23:54:27:WU00:FS00:0xa3:Using Gromacs checkpoints
23:54:27:WU00:FS00:0xa3:Mapping NT from 6 to 6
23:54:28:WU00:FS00:0xa3:Resuming from checkpoint
23:54:28:WU00:FS00:0xa3:Verified 00/wudata_01.log
23:54:28:WU00:FS00:0xa3:Verified 00/wudata_01.trr
23:54:28:WU00:FS00:0xa3:Verified 00/wudata_01.edr
23:54:28:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
23:54:31:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:55:24:WARNING:FS01:Killing WU01
23:55:24:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:07:22:WU00:FS00:Starting
00:07:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
00:07:22:WU00:FS00:Started FahCore on PID 3772
00:07:22:WU00:FS00:Core PID:436
00:07:22:WU00:FS00:FahCore 0xa3 started
00:07:22:WU01:FS01:Starting
00:07:22:WU01:FS01:Removing old file './work/01/logfile_01-20141026-040019.txt'
00:07:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:07:22:WU01:FS01:Started FahCore on PID 6044
00:07:22:WU01:FS01:Core PID:1048
00:07:22:WU01:FS01:FahCore 0x17 started
00:07:22:WU00:FS00:0xa3:
00:07:22:WU00:FS00:0xa3:*------------------------------*
00:07:22:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
00:07:22:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
00:07:22:WU00:FS00:0xa3:Preparing to commence simulation
00:07:22:WU00:FS00:0xa3:- Looking at optimizations...
00:07:22:WU00:FS00:0xa3:- Files status OK
00:07:22:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
00:07:22:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
00:07:22:WU00:FS00:0xa3:- Digital signature verified
00:07:22:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
00:07:22:WU00:FS00:0xa3:Assembly optimizations on if available.
00:07:22:WU00:FS00:0xa3:Entering M.D.
00:07:23:WU01:FS01:0x17:*********************** Log Started 2014-10-31T00:07:22Z ***********************
00:07:23:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
00:07:23:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
00:07:23:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:07:23:WU01:FS01:0x17:Machine: 1
00:07:23:WU01:FS01:0x17:Digital signatures verified
00:07:23:WU01:FS01:0x17:Folding@home GPU core17
00:07:23:WU01:FS01:0x17:Version 0.0.52
00:07:23:WU01:FS01:0x17: Found a checkpoint file
00:07:28:WU00:FS00:0xa3:Using Gromacs checkpoints
00:07:29:WU00:FS00:0xa3:Mapping NT from 6 to 6
00:07:29:WU00:FS00:0xa3:Resuming from checkpoint
00:07:29:WU00:FS00:0xa3:Verified 00/wudata_01.log
00:07:29:WU00:FS00:0xa3:Verified 00/wudata_01.trr
00:07:29:WU00:FS00:0xa3:Verified 00/wudata_01.edr
00:07:30:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
00:07:59:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
00:11:02:FS00:Shutting core down
00:11:02:FS01:Shutting core down
00:11:02:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 1048
00:11:02:WU01:FS01:0x17:Exiting, please wait. . .
00:11:02:WU00:FS00:0xa3:Client no longer detected. Shutting down core
00:11:02:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
00:11:03:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:11:55:WU01:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
00:11:55:WU01:FS01:0x17:Lost lifeline PID 6044, exiting
00:11:55:WU01:FS01:0x17:ERROR:103: Lost client lifeline
00:11:55:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
00:11:55:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:36:16:WU00:FS00:Starting
00:36:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
00:36:16:WU00:FS00:Started FahCore on PID 1204
00:36:16:WU00:FS00:Core PID:6432
00:36:16:WU00:FS00:FahCore 0xa3 started
00:36:16:WU01:FS01:Starting
00:36:16:WU01:FS01:Removing old file './work/01/logfile_01-20141026-041547.txt'
00:36:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:36:16:WU01:FS01:Started FahCore on PID 6044
00:36:16:WU01:FS01:Core PID:6840
00:36:16:WU01:FS01:FahCore 0x17 started
00:36:16:WU00:FS00:0xa3:
00:36:16:WU00:FS00:0xa3:*------------------------------*
00:36:16:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
00:36:16:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
00:36:16:WU00:FS00:0xa3:Preparing to commence simulation
00:36:16:WU00:FS00:0xa3:- Looking at optimizations...
00:36:16:WU00:FS00:0xa3:- Files status OK
00:36:16:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
00:36:16:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
00:36:16:WU00:FS00:0xa3:- Digital signature verified
00:36:16:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
00:36:16:WU00:FS00:0xa3:Assembly optimizations on if available.
00:36:16:WU00:FS00:0xa3:Entering M.D.
00:36:16:WU01:FS01:0x17:*********************** Log Started 2014-10-31T00:36:16Z ***********************
00:36:16:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
00:36:16:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
00:36:16:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:36:16:WU01:FS01:0x17:Machine: 1
00:36:16:WU01:FS01:0x17:Digital signatures verified
00:36:16:WU01:FS01:0x17:Folding@home GPU core17
00:36:16:WU01:FS01:0x17:Version 0.0.52
00:36:16:WU01:FS01:0x17: Found a checkpoint file
00:36:22:WU00:FS00:0xa3:Using Gromacs checkpoints
00:36:23:WU00:FS00:0xa3:Mapping NT from 6 to 6
00:36:23:WU00:FS00:0xa3:Resuming from checkpoint
00:36:23:WU00:FS00:0xa3:Verified 00/wudata_01.log
00:36:23:WU00:FS00:0xa3:Verified 00/wudata_01.trr
00:36:23:WU00:FS00:0xa3:Verified 00/wudata_01.edr
00:36:24:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
00:36:53:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
00:38:03:FS00:Shutting core down
00:38:03:FS01:Shutting core down
00:38:04:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 6840
00:38:04:WU01:FS01:0x17:Exiting, please wait. . .
00:38:07:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:39:04:WARNING:FS01:Killing WU01
00:39:04:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:56:34:WU00:FS00:Starting
00:56:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -np 6
00:56:34:WU00:FS00:Started FahCore on PID 4500
00:56:34:WU00:FS00:Core PID:6824
00:56:34:WU00:FS00:FahCore 0xa3 started
00:56:34:WU01:FS01:Starting
00:56:34:WU01:FS01:Removing old file './work/01/logfile_01-20141026-175702.txt'
00:56:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Roy Ludt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 3672 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:56:34:WU01:FS01:Started FahCore on PID 2564
00:56:34:WU01:FS01:Core PID:4388
00:56:34:WU01:FS01:FahCore 0x17 started
00:56:34:WU00:FS00:0xa3:
00:56:34:WU00:FS00:0xa3:*------------------------------*
00:56:34:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
00:56:34:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
00:56:34:WU00:FS00:0xa3:Preparing to commence simulation
00:56:34:WU00:FS00:0xa3:- Looking at optimizations...
00:56:34:WU00:FS00:0xa3:- Files status OK
00:56:34:WU00:FS00:0xa3:- Expanded 3814948 -> 4182748 (decompressed 109.6 percent)
00:56:34:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3814948 data_size=4182748, decompressed_data_size=4182748 diff=0
00:56:34:WU00:FS00:0xa3:- Digital signature verified
00:56:34:WU00:FS00:0xa3:Project: 6095 (Run 8, Clone 17, Gen 36)
00:56:34:WU00:FS00:0xa3:Assembly optimizations on if available.
00:56:34:WU00:FS00:0xa3:Entering M.D.
00:56:34:WU01:FS01:0x17:*********************** Log Started 2014-10-31T00:56:34Z ***********************
00:56:34:WU01:FS01:0x17:Project: 13001 (Run 524, Clone 6, Gen 24)
00:56:34:WU01:FS01:0x17:Unit: 0x0000002d538b3db7532c90da35ecdb80
00:56:34:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:56:34:WU01:FS01:0x17:Machine: 1
00:56:34:WU01:FS01:0x17:Digital signatures verified
00:56:34:WU01:FS01:0x17:Folding@home GPU core17
00:56:34:WU01:FS01:0x17:Version 0.0.52
00:56:34:WU01:FS01:0x17: Found a checkpoint file
00:56:40:WU00:FS00:0xa3:Using Gromacs checkpoints
00:56:41:WU00:FS00:0xa3:Mapping NT from 6 to 6
00:56:41:WU00:FS00:0xa3:Resuming from checkpoint
00:56:41:WU00:FS00:0xa3:Verified 00/wudata_01.log
00:56:41:WU00:FS00:0xa3:Verified 00/wudata_01.trr
00:56:41:WU00:FS00:0xa3:Verified 00/wudata_01.edr
00:56:42:WU00:FS00:0xa3:Completed 9815 out of 500000 steps (1%)
00:57:12:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
01:00:14:FS00:Shutting core down
01:00:14:FS01:Shutting core down
01:00:14:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4388
01:00:14:WU01:FS01:0x17:Exiting, please wait. . .
01:00:14:WU00:FS00:0xa3:Client no longer detected. Shutting down core
01:00:14:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
01:00:15:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:01:07:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
Oh heck, the Windows error! I forgot to mention that I did catch the Windows error message, it reads:
FAHScreensaver.scr has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
davidcoton
OK, so the screensaver -- which triggers work on idle -- seems to have crashed. Try rebooting to see if that fixes it. If the screensaver crashes again we'll have to dig deeper.
I would go one further and have you disable the FAH screensaver. By looking at the log, the screensaver engaged and crashed many times. Just set the display to power down after 5 or 10 minutes of being idle and that will trigger the client to fold.
Thanks so much. I should have added that many, many restarts had already taken place to no avail during this past week of issues and before my original post.7im wrote:I would go one further and have you disable the FAH screensaver. By looking at the log, the screensaver engaged and crashed many times. Just set the display to power down after 5 or 10 minutes of being idle and that will trigger the client to fold.
I have just now set my screensaver to "Blank" and to start after 5 minutes of inactivity (as opposed to FAH Screensaver I previously had it set to, same time delay). I hope this does the trick.
Thank you again. It feels so nice to know I am helping (in a small capacity) to fighting these diseases and I actually get sad every time I walk in and see the PC hung up and not "working away". I'll be happy to have the issue resolved.
The fah screensaver is nice to look at, but in the end, displaying those images actually takes resources away from the GPU, so the GPU slot would be folding slower. And that may be where the conflict was to cause it not to run.
I still do not believe it is kicking on, I never hear the PC spooled up. Below is the log lately, hope this helps.
As has been the case since my last post, the F@H screensaver is not selected and the "Blank" Windows screensaver is and is set to be active after 5 minutes. The PC is not set to ever fall asleep under any circumstances.
Thanks again to all!
23:54:21:WU00:FS00:0xa3:P-
The PC should not sleep or folding will stop. As mentioned above, the monitor does need to sleep to trigger idle folding.
The PC has always been set to never sleep, as was the monitor. I have now turned the screen to turn off after 10 minutes (sleep and go "Blank" after 5 minutes), although I was hoping to avoid that. I will see what that does. Thanks again for the guidance!
The above mentioned setting has proved fruitful! The machine now kicks on and appears to be running, though having to turn on the screen each time I need it (this is a work-from-home PC and I am always on call and needing to access it) is something I had wanted to avoid but if it is required I can live with it (I hope).
Thanks again to all for the support and patience with a newbie. It is much appreciated!
A couple of recommendations -- although you should evaluate them carefully in terms of using your computer for work at any time.
First, I would remove the "idle=true" setting (or changing it to false) for the CPU slot (slot 0). Your i7 is a pretty powerful CPU and FahCore_a3 or FahCore_a4 runs at a very low priority, so it is my guess that allowing the CPU to fold while you're using the computer will not cause a noticeable change in your foreground activities. I predict you will increase your FAH production without any sacrifice to your working activities. Naturally this depends somewhat on what your work entails and you'll have to take objective look at whether CPU-folding is, in fact, noticeable.
Second, after you've accpeted that change, you can try removing the idle=true from your GPU slot. There will be a higher risk of noticeable screen-delays but if foreground performance is still acceptable, you'll increase your FAH throughput even more. Only you can be the judge of whether you can still work "normally" with FAH continuing to fold, but it's worth testing.
bruce wrote:A couple of recommendations -- although you should evaluate them carefully in terms of using your computer for work at any time.
Bruce, you are a fine gentleman and a scholar! I will give these settings a whirl soon.
Today when I woke up I heard the PC buzzing along and the screen off when I approached. When I wiggled the mouse nothing happened. I hit ESC, Cntrl Alt Delete, all manner of things to no avail (including turning the monitor on/off). The screen would flicker a little, showing the desktop for very brief glimpses, but it was fuzzy and lots of static. Then all went black again and stayed that way (monitor was on as I saw "No Input" on it). I had to press and hold the power button to get it to shut off, then restart and all was well. When I came home from working in the field it had been idle another 5-6 hours and it awoke just fine but I do not rtecall hearing the PC working wither. I will monitor and report.
