NVIDIA GeForce GTX 750 Ti / 10DE-1380
ravedj
Post by ravedj »
*********************** Log Started 2014-10-18T12:13:40Z ***********************
12:13:40:************************* Folding@home Client *************************
12:13:40:      Website: http://folding.stanford.edu/
12:13:40:    Copyright: (c) 2009-2014 Stanford University
12:13:40:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:13:40:         Args: --open-web-control
12:13:40:       Config: C:/ProgramData/FAHClient/config.xml
12:13:40:******************************** Build ********************************
12:13:40:      Version: 7.4.4
12:13:40:         Date: Mar 4 2014
12:13:40:         Time: 20:26:54
12:13:40:      SVN Rev: 4130
12:13:40:       Branch: fah/trunk/client
12:13:40:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:13:40:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:13:40:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:13:40:     Platform: win32 XP
12:13:40:         Bits: 32
12:13:40:         Mode: Release
12:13:40:******************************* System ********************************
12:13:40:          CPU: AMD FX(tm)-8350 Eight-Core Processor
12:13:40:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
12:13:40:         CPUs: 8
12:13:40:       Memory: 15.96GiB
12:13:40:  Free Memory: 13.60GiB
12:13:40:      Threads: WINDOWS_THREADS
12:13:40:   OS Version: 6.2
12:13:40:  Has Battery: false
12:13:40:   On Battery: false
12:13:40:   UTC Offset: 2
12:13:40:          PID: 1732
12:13:40:          CWD: C:/ProgramData/FAHClient
12:13:40:           OS: Windows 8.1 Pro
12:13:40:      OS Arch: AMD64
12:13:40:         GPUs: 1
12:13:40:        GPU 0: UNSUPPORTED: GM107 [GeForce GTX 750 Ti]
12:13:40:         CUDA: 5.0
12:13:40:  CUDA Driver: 6050
12:13:40:Win32 Service: false
12:13:40:***********************************************************************
12:13:40:<config>
12:13:40:  <!-- Folding Slot Configuration -->
12:13:40:  <cause v='CANCER'/>
12:13:40:
12:13:40:  <!-- Network -->
12:13:40:  <proxy v=':8080'/>
12:13:40:
12:13:40:  <!-- Slot Control -->
12:13:40:  <power v='full'/>
12:13:40:
12:13:40:  <!-- User Information -->
12:13:40:  <passkey v='********************************'/>
12:13:40:  <team v='86565'/>
12:13:40:  <user v='RaveDJ'/>
12:13:40:
12:13:40:  <!-- Folding Slots -->
12:13:40:  <slot id='0' type='CPU'/>
12:13:40:</config>
12:13:40:Connecting to assign-GPU.stanford.edu:80
12:13:41:Updated GPUs.txt
12:13:42:Read GPUs.txt
12:13:42:Trying to access database...
12:13:42:Successfully acquired database lock
12:13:42:Enabled folding slot 00: READY cpu:8
12:13:42:WU00:FS00:Starting
12:13:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 1732 -checkpoint 15 -np 8
12:13:42:WU00:FS00:Started FahCore on PID 3332
12:13:42:WU00:FS00:Core PID:5036
12:13:42:WU00:FS00:FahCore 0xa3 started
12:13:42:WU00:FS00:0xa3:
12:13:42:WU00:FS00:0xa3:*------------------------------*
12:13:42:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
12:13:42:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
12:13:42:WU00:FS00:0xa3:Preparing to commence simulation
12:13:42:WU00:FS00:0xa3:- Looking at optimizations...
12:13:42:WU00:FS00:0xa3:- Files status OK
12:13:42:WU00:FS00:0xa3:- Expanded 3802671 -> 4166092 (decompressed 109.5 percent)
12:13:42:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3802671 data_size=4166092, decompressed_data_size=4166092 diff=0
12:13:42:WU00:FS00:0xa3:- Digital signature verified
12:13:42:WU00:FS00:0xa3:Project: 8825 (Run 0, Clone 16, Gen 327)
12:13:42:WU00:FS00:0xa3:Assembly optimizations on if available.
12:13:42:WU00:FS00:0xa3:Entering M.D.
12:13:46:14:127.0.0.1:New Web connection
12:13:48:WU00:FS00:0xa3:Using Gromacs checkpoints
12:13:48:WU00:FS00:0xa3:Mapping NT from 8 to 8
12:13:49:WU00:FS00:0xa3:Resuming from checkpoint
12:13:49:WU00:FS00:0xa3:Verified 00/wudata_01.log
12:13:49:WU00:FS00:0xa3:Verified 00/wudata_01.trr
12:13:49:WU00:FS00:0xa3:Verified 00/wudata_01.edr
12:13:50:WU00:FS00:0xa3:Completed 6100 out of 500000 steps  (1%)
bollix47
Re: NVIDIA GeForce GTX 750 Ti / 10DE-1380
Post by bollix47 »
Welcome to the folding@home support forum ravedj.
If you check the GPUs.txt file you will see that your GPU is listed as being supported:
0x10de:0x1380:2:4:GM107 [GeForce GTX 750 Ti]
Adding a gpu slot should get you work if that's your purpose in posting your log but if you do add a gpu slot I recommend you decrease the no of threads being used by your cpu slot (cpu:8) to 6 as your gpu will require a cpu core/thread in order to fold efficiently. Your config for your cpu and gpu slot should end up looking something like the following after you make the changes via Advanced Control (aka FAHControl):
  <slot id='0' type='CPU'>
    <cpus v='6'/>
  </slot>
  < <slot id='1' type='GPU'>
  </slot>
</config>
If you do set up a gpu slot but get no work make sure you're using recent drivers from nvidia and also try changing your cause preference to Any in case the work servers aren't quite ready to work with your preference yet.
If I've misunderstood your purpose in posting your log please don't hesitate to clarify.
The default windows driver often does not include all the features needed to fold. Please download and install the full driver from Nvidia.
davidcoton
Post by davidcoton »
It may need a reboot before adding the GPU slot. From the log it looks as though the hardware was scanned (and the GPU marked as unsupported) before the gpus.txt file was downloaded.
The easiest way to upgrade the GPUs.txt file is to restart FAHClient after your internet connection has completed initialization. (It can be upgraded manually, too.)
