560 GTX vs. Fermi/Core_17.fah/FahCore_17.exe
suprleg
Post by suprleg »
Just setup a new Win7 pro blade running a fresh 7.4.4 install with an NVIDIA 560 GTX card using 327.23 32-bit drivers.
Each time the server downloads a FahCore_17.exe wu Windows gives an error msg.:From event viewer
+ System
- Provider
[ Name] Windows Error Reporting
- EventID 1001
[ Qualifiers] 0
Level 4
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-06-08T15:50:04.000000000Z
EventRecordID 31033
Channel Application
Computer suprleg-PC
Security
- EventData
3949338615
1
APPCRASH
Not available
0
FahCore_17.exe
0.0.0.0
527bdd17
StackHash_e10b
6.1.7601.18247
521ea91c
c0000374
000c3873
C:\Users\suprleg\AppData\Local\Temp\WERFA77.tmp.WERInternalMetadata.xml
C:\Users\suprleg\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_FahCore_17.exe_73ef109843a332fc1639f3178c4eee5eb5681f7f_0ef3ef8f
0
577c189e-ef23-11e3-b198-8c89a5e17f54
0
I'm forced to shutdown the server and delete the work directory, upon restart if I'm given a FahCore_15.exe wu everything runs beautifully..
Sorry, I searched somewhat, realizing this has probably been discussed in detail....ideas?
Links to appropriate posts would be great. :)
davidcoton
Re: 560 GTX vs. Fermi/Core_17.fah/FahCore_17.exe
Post by davidcoton »
Can youpost your log? Details here viewtopic.php?p=261081&f=24#p261081. It may or may not help, but the Windows error log isn't much help.
David
As always please include the fah log showing the crash.
How much is the GPU overclocked?
suprleg
Post by suprleg »
14:57:18:WU00:FS00:0xa3:*------------------------------*
14:57:18:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
14:57:18:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
14:57:18:WU00:FS00:0xa3:Preparing to commence simulation
14:57:18:WU00:FS00:0xa3:- Looking at optimizations...
14:57:18:WU00:FS00:0xa3:- Files status OK
14:57:18:WU00:FS00:0xa3:- Expanded 3812355 -> 4136808 (decompressed 108.5 percent)
14:57:18:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3812355 data_size=4136808, decompressed_data_size=4136808 diff=0
14:57:18:WU00:FS00:0xa3:- Digital signature verified
14:57:18:WU00:FS00:0xa3:Project: 6098 (Run 8, Clone 72, Gen 455)
14:57:18:WU00:FS00:0xa3:Assembly optimizations on if available.
14:57:18:WU00:FS00:0xa3:Entering M.D.
14:57:18:WU02:FS01:0x17:Reading tar file system.xml
14:57:18:WU02:FS01:0x17:Reading tar file integrator.xml
14:57:18:WU02:FS01:0x17:Reading tar file core.xml
14:57:18:WU02:FS01:0x17:Digital signatures verified
14:57:18:WU02:FS01:0x17:Folding@home GPU core17
14:57:18:WU02:FS01:0x17:Version 0.0.52
14:57:23:WU00:FS00:0xa3:Using Gromacs checkpoints
14:57:24:WU00:FS00:0xa3:Mapping NT from 2 to 2
14:57:24:WU00:FS00:0xa3:Resuming from checkpoint
14:57:24:WU00:FS00:0xa3:Verified 00/wudata_01.log
14:57:24:WU00:FS00:0xa3:Verified 00/wudata_01.trr
14:57:24:WU00:FS00:0xa3:Verified 00/wudata_01.edr
14:57:25:WU00:FS00:0xa3:Completed 9815 out of 500000 steps  (1%)
14:58:11:Removing old file 'configs/config-20140607-133126.xml'
14:58:11:Saving configuration to config.xml
14:58:11:<config>
14:58:11:  <!-- Network -->
14:58:11:  <proxy v=':8080'/>
14:58:11:
14:58:11:  <!-- Slot Control -->
14:58:11:  <power v='full'/>
14:58:11:
14:58:11:  <!-- User Information -->
14:58:11:  <passkey v='********************************'/>
14:58:11:  <team v='4'/>
14:58:11:  <user v='suprleg'/>
14:58:11:
14:58:11:  <!-- Folding Slots -->
14:58:11:  <slot id='0' type='CPU'/>
14:58:11:  <slot id='1' type='GPU'/>
14:58:11:</config>
14:58:11:FS00:Shutting core down
14:58:13:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
14:58:18:Removing old file 'configs/config-20140607-133151.xml'
14:58:18:Saving configuration to config.xml
14:58:18:<config>
14:58:18:  <!-- Network -->
14:58:18:  <proxy v=':8080'/>
14:58:18:
14:58:18:  <!-- Slot Control -->
14:58:18:  <power v='full'/>
14:58:18:
14:58:18:  <!-- User Information -->
14:58:18:  <passkey v='********************************'/>
14:58:18:  <team v='4'/>
14:58:18:  <user v='suprleg'/>
14:58:18:
14:58:18:  <!-- Folding Slots -->
14:58:18:  <slot id='0' type='CPU'/>
14:58:18:  <slot id='1' type='GPU'/>
14:58:18:</config>
14:58:18:WU00:FS00:0xa3:Client no longer detected. Shutting down core
14:58:18:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
14:58:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:58:18:WU00:FS00:Starting
14:58:18:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
14:58:18:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 2344 -checkpoint 15 -np 3
14:58:18:WU00:FS00:Started FahCore on PID 3220
14:58:18:WU00:FS00:Core PID:5224
14:58:18:WU00:FS00:FahCore 0xa3 started
14:58:19:WU00:FS00:0xa3:
14:58:19:WU00:FS00:0xa3:*------------------------------*
14:58:19:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
14:58:19:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
14:58:19:WU00:FS00:0xa3:Preparing to commence simulation
14:58:19:WU00:FS00:0xa3:- Looking at optimizations...
14:58:19:WU00:FS00:0xa3:- Files status OK
14:58:19:WU00:FS00:0xa3:- Expanded 3812355 -> 4136808 (decompressed 108.5 percent)
14:58:19:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3812355 data_size=4136808, decompressed_data_size=4136808 diff=0
14:58:19:WU00:FS00:0xa3:- Digital signature verified
14:58:19:WU00:FS00:0xa3:Project: 6098 (Run 8, Clone 72, Gen 455)
14:58:19:WU00:FS00:0xa3:Assembly optimizations on if available.
14:58:19:WU00:FS00:0xa3:Entering M.D.
14:58:25:WU00:FS00:0xa3:Using Gromacs checkpoints
14:58:25:WU00:FS00:0xa3:Mapping NT from 3 to 3
14:58:25:WU00:FS00:0xa3:Resuming from checkpoint
14:58:25:WU00:FS00:0xa3:Verified 00/wudata_01.log
14:58:25:WU00:FS00:0xa3:Verified 00/wudata_01.trr
14:58:25:WU00:FS00:0xa3:Verified 00/wudata_01.edr
14:58:26:WU00:FS00:0xa3:Completed 9815 out of 500000 steps  (1%)
14:58:34:Removing old file 'configs/config-20140607-133356.xml'
14:58:34:Saving configuration to config.xml
14:58:34:<config>
14:58:34:  <!-- Network -->
14:58:34:  <proxy v=':8080'/>
14:58:34:
14:58:34:  <!-- Slot Control -->
14:58:34:  <power v='full'/>
14:58:34:
14:58:34:  <!-- User Information -->
14:58:34:  <passkey v='********************************'/>
14:58:34:  <team v='4'/>
14:58:34:  <user v='suprleg'/>
14:58:34:
14:58:34:  <!-- Folding Slots -->
14:58:34:  <slot id='0' type='CPU'>
14:58:34:    <cpus v='2'/>
14:58:34:  </slot>
14:58:34:  <slot id='1' type='GPU'/>
14:58:34:</config>
14:58:34:FS00:Shutting core down
14:58:39:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:59:18:WU00:FS00:Starting
14:59:18:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
14:59:18:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 2344 -checkpoint 15 -np 2
14:59:18:WU00:FS00:Started FahCore on PID 3792
14:59:18:WU00:FS00:Core PID:5452
14:59:18:WU00:FS00:FahCore 0xa3 started
14:59:19:Removing old file 'configs/config-20140607-133429.xml'
14:59:19:Saving configuration to config.xml
14:59:19:<config>
14:59:19:  <!-- Network -->
14:59:19:  <proxy v=':8080'/>
14:59:19:
14:59:19:  <!-- Slot Control -->
14:59:19:  <power v='full'/>
14:59:19:
14:59:19:  <!-- User Information -->
14:59:19:  <passkey v='********************************'/>
14:59:19:  <team v='4'/>
14:59:19:  <user v='suprleg'/>
14:59:19:
14:59:19:  <!-- Folding Slots -->
14:59:19:  <slot id='0' type='CPU'>
14:59:19:    <cpus v='2'/>
14:59:19:  </slot>
14:59:19:  <slot id='1' type='GPU'/>
14:59:19:</config>
14:59:19:WU00:FS00:0xa3:
14:59:19:WU00:FS00:0xa3:*------------------------------*
14:59:19:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
14:59:19:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
14:59:19:WU00:FS00:0xa3:Preparing to commence simulation
14:59:19:WU00:FS00:0xa3:- Looking at optimizations...
14:59:19:WU00:FS00:0xa3:- Files status OK
14:59:19:WU00:FS00:0xa3:- Expanded 3812355 -> 4136808 (decompressed 108.5 percent)
14:59:19:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3812355 data_size=4136808, decompressed_data_size=4136808 diff=0
14:59:19:WU00:FS00:0xa3:- Digital signature verified
14:59:19:WU00:FS00:0xa3:Project: 6098 (Run 8, Clone 72, Gen 455)
14:59:19:WU00:FS00:0xa3:Assembly optimizations on if available.
14:59:19:WU00:FS00:0xa3:Entering M.D.
14:59:25:WU00:FS00:0xa3:Using Gromacs checkpoints
14:59:25:WU00:FS00:0xa3:Mapping NT from 2 to 2
14:59:25:WU00:FS00:0xa3:Resuming from checkpoint
14:59:25:WU00:FS00:0xa3:Verified 00/wudata_01.log
14:59:25:WU00:FS00:0xa3:Verified 00/wudata_01.trr
14:59:25:WU00:FS00:0xa3:Verified 00/wudata_01.edr
14:59:26:WU00:FS00:0xa3:Completed 9815 out of 500000 steps  (1%)
15:00:15:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
15:05:09:WARNING:WU02:FS01:FahCore returned: FAILED_3 (255 = 0xff)
15:05:09:WARNING:WU02:FS01:Too many errors, failing
15:05:09:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:13000 run:1752 clone:1 gen:25 core:0x17 unit:0x00000037538b3db753118b1f351c97b9
15:05:09:WU02:FS01:Connecting to 140.163.4.231:8080
15:05:10:WU01:FS01:Connecting to 171.67.108.201:80
15:05:10:WU02:FS01:Server responded WORK_ACK (400)
15:05:10:WU02:FS01:Cleaning up
15:05:10:WU01:FS01:Assigned to work server 140.163.4.231
15:05:10:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560] from 140.163.4.231
15:05:10:WU01:FS01:Connecting to 140.163.4.231:8080
15:05:10:WU01:FS01:Downloading 4.84MiB
15:05:13:WU01:FS01:Download complete
15:05:13:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:163 clone:6 gen:30 core:0x17 unit:0x0000003f538b3db753287e012b1b6f39
15:05:13:WU01:FS01:Starting
15:05:13:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2344 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
15:05:13:WU01:FS01:Started FahCore on PID 5712
15:05:13:WU01:FS01:Core PID:4220
15:05:13:WU01:FS01:FahCore 0x17 started
15:05:13:WU01:FS01:0x17:*********************** Log Started 2014-06-07T15:05:13Z ***********************
15:05:13:WU01:FS01:0x17:Project: 13001 (Run 163, Clone 6, Gen 30)
15:05:13:WU01:FS01:0x17:Unit: 0x0000003f538b3db753287e012b1b6f39
15:05:13:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
15:05:13:WU01:FS01:0x17:Machine: 1
15:05:13:WU01:FS01:0x17:Reading tar file state.xml
15:05:14:WU01:FS01:0x17:Reading tar file system.xml
15:05:14:WU01:FS01:0x17:Reading tar file integrator.xml
15:05:14:WU01:FS01:0x17:Reading tar file core.xml
15:05:14:WU01:FS01:0x17:Digital signatures verified
15:05:14:WU01:FS01:0x17:Folding@home GPU core17
15:05:14:WU01:FS01:0x17:Version 0.0.52
15:22:04:WU00:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
15:43:48:WU00:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
16:05:34:WU00:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
16:27:17:WU00:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
16:48:45:WU00:FS00:0xa3:Completed 35000 out of 500000 steps  (7%)
17:10:16:WU00:FS00:0xa3:Completed 40000 out of 500000 steps  (8%)
17:31:46:WU00:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
17:53:15:WU00:FS00:0xa3:Completed 50000 out of 500000 steps  (10%)
18:14:42:WU00:FS00:0xa3:Completed 55000 out of 500000 steps  (11%)
18:36:13:WU00:FS00:0xa3:Completed 60000 out of 500000 steps  (12%)
18:57:41:WU00:FS00:0xa3:Completed 65000 out of 500000 steps  (13%)
19:19:09:WU00:FS00:0xa3:Completed 70000 out of 500000 steps  (14%)
19:40:37:WU00:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
20:02:07:WU00:FS00:0xa3:Completed 80000 out of 500000 steps  (16%)
20:23:35:WU00:FS00:0xa3:Completed 85000 out of 500000 steps  (17%)
20:45:03:WU00:FS00:0xa3:Completed 90000 out of 500000 steps  (18%)
******************************* Date: 2014-06-07 *******************************
21:06:32:WU00:FS00:0xa3:Completed 95000 out of 500000 steps  (19%)
21:27:59:WU00:FS00:0xa3:Completed 100000 out of 500000 steps  (20%)
21:49:28:WU00:FS00:0xa3:Completed 105000 out of 500000 steps  (21%)
22:10:59:WU00:FS00:0xa3:Completed 110000 out of 500000 steps  (22%)
22:32:51:WU00:FS00:0xa3:Completed 115000 out of 500000 steps  (23%)
22:39:45:FS00:Shutting core down
22:39:45:FS01:Shutting core down
22:39:46:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4220
22:39:46:WU01:FS01:0x17:Exiting, please wait. . .
22:39:49:WU00:FS00:0xa3:Client no longer detected. Shutting down core
22:39:49:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
22:40:46:WARNING:FS01:Killing WU01
22:40:46:Clean exit
I have cpu -2 and gpu -1 set for slots.
Also I'm not sure if this log reflects my current 327.23 drivers, however since this partial log was generated I've had more "0x17" failures with nvidia's 327.23 intalled. Again, "0x15" wu's run flawlessly..
We need more information. (You did not post the first few pages of the log.)
suprleg
Post by suprleg »
7im wrote:As always please include the fah log showing the crash.
No overclocking, GPU running at 99%, 69.0C
suprleg
Post by suprleg »
bruce wrote:We need more information. (You did not post the first few pages of the log.)
After this "0x15" wu completes I'll let the server generate a full log-file that reflects a "0x17" wu as soon as one is downloaded.
Thanks for the help.
suprleg
Post by suprleg »
Server downloaded a "0x17" wu and as per usual my Windows7 pro box gave the same error msg:"FahCore_17.exe has stopped working", with the only option available being, "close program". After choosing [close program] fah log shows the following warning: 10:19:14:WARNING:WU00:FS01:FahCore returned: FAILED_3 (255 = 0xff)
If I ignore the windows error msg the GPU client simply "hangs" showing the following ETA's:10.20 days/TPF 2.26hrs ...by the way these time estimates never change regardless of "0x17" wu downloaded.
Additionally the 560GTX statistics:GPU usage 2-4%, GPU Temp. 31.0 C....these are the gpu's normal operating stats with NO background apps running, in other words fah isn't utilizing the gpu.
Again, as soon as I download a "0x15" wu things will take off again and appear all's well, therefore the problem for me lies between windows and "FahCore_17.exe".
Oddly though I'm unable to find any information regarding this problem, hard to believe I'm the only person ever to have this issue..
*Yes I realize I'm having some DNS issues, thanks*, however that's a completely different issue. :oops:
Thanks for any useful responses.
*********************** Log Started 2014-06-09T10:18:31Z ***********************
10:18:31:************************* Folding@home Client *************************
10:18:31:      Website: http://folding.stanford.edu/
10:18:31:    Copyright: (c) 2009-2014 Stanford University
10:18:31:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:18:31:         Args: --open-web-control
10:18:31:       Config: C:/Users/suprleg/AppData/Roaming/FAHClient/config.xml
10:18:31:******************************** Build ********************************
10:18:31:      Version: 7.4.4
10:18:31:         Date: Mar 4 2014
10:18:31:         Time: 20:26:54
10:18:31:      SVN Rev: 4130
10:18:31:       Branch: fah/trunk/client
10:18:31:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
10:18:31:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
10:18:31:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
10:18:31:     Platform: win32 XP
10:18:31:         Bits: 32
10:18:31:         Mode: Release
10:18:31:******************************* System ********************************
10:18:31:          CPU: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
10:18:31:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
10:18:31:         CPUs: 4
10:18:31:       Memory: 3.47GiB
10:18:31:  Free Memory: 2.33GiB
10:18:31:      Threads: WINDOWS_THREADS
10:18:31:   OS Version: 6.1
10:18:31:  Has Battery: false
10:18:31:   On Battery: false
10:18:31:   UTC Offset: -7
10:18:31:          PID: 4208
10:18:31:          CWD: C:/Users/suprleg/AppData/Roaming/FAHClient
10:18:31:           OS: Windows 7 Professional Service Pack 1
10:18:31:      OS Arch: X86
10:18:31:         GPUs: 1
10:18:31:        GPU 0: NVIDIA:2 GF114 [GeForce GTX 560]
10:18:31:         CUDA: 2.1
10:18:31:  CUDA Driver: 5050
10:18:31:Win32 Service: false
10:18:31:***********************************************************************
10:18:31:<config>
10:18:31:  <!-- HTTP Server -->
10:18:31:  <allow v='127.0.0.1 192.168.1.1-192.168.1.254'/>
10:18:31:
10:18:31:  <!-- Network -->
10:18:31:  <proxy v=':8080'/>
10:18:31:
10:18:31:  <!-- Remote Command Server -->
10:18:31:  <command-allow-no-pass v='127.0.0.1 192.168.1.1-192.168.1.254'/>
10:18:31:
10:18:31:  <!-- Slot Control -->
10:18:31:  <power v='full'/>
10:18:31:
10:18:31:  <!-- User Information -->
10:18:31:  <passkey v='********************************'/>
10:18:31:  <team v='4'/>
10:18:31:  <user v='suprleg'/>
10:18:31:
10:18:31:  <!-- Folding Slots -->
10:18:31:  <slot id='0' type='CPU'>
10:18:31:    <cpus v='2'/>
10:18:31:  </slot>
10:18:31:  <slot id='1' type='GPU'/>
10:18:31:</config>
10:18:31:Trying to access database...
10:18:31:Successfully acquired database lock
10:18:31:Enabled folding slot 00: READY cpu:2
10:18:31:Enabled folding slot 01: READY gpu:0:GF114 [GeForce GTX 560]
10:18:31:WU02:FS00:Starting
10:18:31:WU02:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 704 -lifeline 4208 -checkpoint 15 -np 2
10:18:31:WU02:FS00:Started FahCore on PID 3008
10:18:31:WU02:FS00:Core PID:2832
10:18:31:WU02:FS00:FahCore 0xa3 started
10:18:31:WU02:FS00:0xa3:
10:18:31:WU02:FS00:0xa3:*------------------------------*
10:18:31:WU02:FS00:0xa3:Folding@Home Gromacs SMP Core
10:18:31:WU02:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
10:18:31:WU02:FS00:0xa3:Preparing to commence simulation
10:18:31:WU02:FS00:0xa3:- Looking at optimizations...
10:18:31:WU02:FS00:0xa3:- Files status OK
10:18:31:WU02:FS00:0xa3:- Expanded 3851026 -> 4394668 (decompressed 114.1 percent)
10:18:31:WU02:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3851026 data_size=4394668, decompressed_data_size=4394668 diff=0
10:18:31:WU02:FS00:0xa3:- Digital signature verified
10:18:31:WU02:FS00:0xa3:Project: 8585 (Run 1, Clone 5, Gen 451)
10:18:31:WU02:FS00:0xa3:Assembly optimizations on if available.
10:18:31:WU02:FS00:0xa3:Entering M.D.
10:18:37:WU02:FS00:0xa3:Using Gromacs checkpoints
10:18:38:WU02:FS00:0xa3:Mapping NT from 2 to 2
10:18:38:WU02:FS00:0xa3:Resuming from checkpoint
10:18:38:WU02:FS00:0xa3:Verified 02/wudata_01.log
10:18:38:WU02:FS00:0xa3:Verified 02/wudata_01.trr
10:18:38:WU02:FS00:0xa3:Verified 02/wudata_01.edr
10:18:39:WU02:FS00:0xa3:Completed 159465 out of 500000 steps  (31%)
10:18:43:WARNING:WU00:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: No such host is known.
10:18:43:ERROR:WU00:FS01:Exception: Could not get an assignment
10:19:00:WARNING:WU00:FS01:Exception: Could not get IP address for assign-GPU2.stanford.edu: No such host is known.
10:19:00:WU00:FS01:Connecting to 171.67.108.201:80
10:19:01:WU00:FS01:Assigned to work server 140.163.4.231
10:19:01:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560] from 140.163.4.231
10:19:01:WU00:FS01:Connecting to 140.163.4.231:8080
10:19:01:WU00:FS01:Downloading 4.83MiB
10:19:04:WU00:FS01:Download complete
10:19:04:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13001 run:247 clone:8 gen:20 core:0x17 unit:0x00000027538b3db7532895e8f4028d8d
10:19:04:WU00:FS01:Starting
10:19:04:WU00:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 4208 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
10:19:04:WU00:FS01:Started FahCore on PID 5752
10:19:04:WU00:FS01:Core PID:4736
10:19:04:WU00:FS01:FahCore 0x17 started
10:19:04:WU00:FS01:0x17:*********************** Log Started 2014-06-09T10:19:04Z ***********************
10:19:04:WU00:FS01:0x17:Project: 13001 (Run 247, Clone 8, Gen 20)
10:19:04:WU00:FS01:0x17:Unit: 0x00000027538b3db7532895e8f4028d8d
10:19:04:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:19:04:WU00:FS01:0x17:Machine: 1
10:19:04:WU00:FS01:0x17:Reading tar file state.xml
10:19:05:WU00:FS01:0x17:Reading tar file system.xml
10:19:06:WU00:FS01:0x17:Reading tar file integrator.xml
10:19:06:WU00:FS01:0x17:Reading tar file core.xml
10:19:06:WU00:FS01:0x17:Digital signatures verified
10:19:06:WU00:FS01:0x17:Folding@home GPU core17
10:19:06:WU00:FS01:0x17:Version 0.0.52
10:19:14:WU00:FS01:Starting
10:19:14:WU00:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 4208 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
10:19:14:WU00:FS01:Started FahCore on PID 5528
10:19:14:WU00:FS01:Core PID:4288
10:19:14:WU00:FS01:FahCore 0x17 started
10:19:15:WU00:FS01:0x17:*********************** Log Started 2014-06-09T10:19:14Z ***********************
10:19:15:WU00:FS01:0x17:Project: 13001 (Run 247, Clone 8, Gen 20)
10:19:15:WU00:FS01:0x17:Unit: 0x00000027538b3db7532895e8f4028d8d
10:19:15:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:19:15:WU00:FS01:0x17:Machine: 1
10:19:15:WU00:FS01:0x17:Reading tar file state.xml
10:19:15:WU00:FS01:0x17:Reading tar file system.xml
10:19:16:WU00:FS01:0x17:Reading tar file integrator.xml
10:19:16:WU00:FS01:0x17:Reading tar file core.xml
10:19:16:WU00:FS01:0x17:Digital signatures verified
10:19:16:WU00:FS01:0x17:Folding@home GPU core17
10:19:16:WU00:FS01:0x17:Version 0.0.52
10:19:27:WARNING:WU00:FS01:FahCore returned: FAILED_3 (255 = 0xff)
10:20:14:WU00:FS01:Starting
10:20:14:WU00:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 4208 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
10:20:14:WU00:FS01:Started FahCore on PID 3788
10:20:14:WU00:FS01:Core PID:5260
10:20:14:WU00:FS01:FahCore 0x17 started
10:20:15:WU00:FS01:0x17:*********************** Log Started 2014-06-09T10:20:14Z ***********************
10:20:15:WU00:FS01:0x17:Project: 13001 (Run 247, Clone 8, Gen 20)
10:20:15:WU00:FS01:0x17:Unit: 0x00000027538b3db7532895e8f4028d8d
10:20:15:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:20:15:WU00:FS01:0x17:Machine: 1
10:20:15:WU00:FS01:0x17:Reading tar file state.xml
10:20:15:WU00:FS01:0x17:Reading tar file system.xml
10:20:16:WU00:FS01:0x17:Reading tar file integrator.xml
10:20:16:WU00:FS01:0x17:Reading tar file core.xml
10:20:16:WU00:FS01:0x17:Digital signatures verified
10:20:16:WU00:FS01:0x17:Folding@home GPU core17
10:20:16:WU00:FS01:0x17:Version 0.0.52
10:20:27:WARNING:WU00:FS01:FahCore returned: FAILED_3 (255 = 0xff)
10:21:14:WU00:FS01:Starting
10:21:14:WU00:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/suprleg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 4208 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
10:21:14:WU00:FS01:Started FahCore on PID 5708
10:21:14:WU00:FS01:Core PID:5608
10:21:14:WU00:FS01:FahCore 0x17 started
10:21:15:WU00:FS01:0x17:*********************** Log Started 2014-06-09T10:21:14Z ***********************
10:21:15:WU00:FS01:0x17:Project: 13001 (Run 247, Clone 8, Gen 20)
10:21:15:WU00:FS01:0x17:Unit: 0x00000027538b3db7532895e8f4028d8d
10:21:15:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
10:21:15:WU00:FS01:0x17:Machine: 1
10:21:15:WU00:FS01:0x17:Reading tar file state.xml
10:21:15:WU02:FS00:0xa3:Completed 160000 out of 500000 steps  (32%)
10:21:15:WU00:FS01:0x17:Reading tar file system.xml
10:21:16:WU00:FS01:0x17:Reading tar file integrator.xml
10:21:16:WU00:FS01:0x17:Reading tar file core.xml
10:21:16:WU00:FS01:0x17:Digital signatures verified
10:21:16:WU00:FS01:0x17:Folding@home GPU core17
10:21:16:WU00:FS01:0x17:Version 0.0.52
10:45:36:WU02:FS00:0xa3:Completed 165000 out of 500000 steps  (33%)
11:09:56:WU02:FS00:0xa3:Completed 170000 out of 500000 steps  (34%)
11:34:20:WU02:FS00:0xa3:Completed 175000 out of 500000 steps  (35%)
11:58:35:WU02:FS00:0xa3:Completed 180000 out of 500000 steps  (36%)
12:22:49:WU02:FS00:0xa3:Completed 185000 out of 500000 steps  (37%)
What is the source for the GPU drivers that you are using on this system? Core_17 uses OpenCL while Core_15 uses CUDA to process WU's, drivers downloaded through Windows Update or provided by the OEM may not include OpenCL support. If the download was directly from nVidia, make certain the OpenCL support is installed.
suprleg
Post by suprleg »
Joe_H wrote:What is the source for the GPU drivers that you are using on this system? Core_17 uses OpenCL while Core_15 uses CUDA to process WU's, drivers downloaded through Windows Update or provided by the OEM may not include OpenCL support. If the download was directly from nVidia, make certain the OpenCL support is installed.
Ah, thanks for that. How would I go about verifying OpenCl support? Yes the 327.23 drivers were downloaded from NVIDIA directly.
suprleg
Post by suprleg »
In doing a little more research I'm finding Nvidia has *no or limited* OpenCL support in their drivers...I'm wondering how people are utilizing Core_17 wu's on their NVIDIA cards..a Teamate of mine does well with a 550Ti.. :e?:
What is the source of that research because it is wrong, and I would like that misinformation wiped clean. When I can fold core 17 WUs on my GT 430, anything newer should fold ever better.
If I had to guess, it's either a driver issue, and you should use a driver cleaner, then reinstall v327.xx, or it's a power issue, because core 17 pulls more juice.
suprleg
Post by suprleg »
7im wrote:What is the source of that research because it is wrong, and I would like that misinformation wiped clean. When I can fold core 17 WUs on my GT 430, anything newer should fold ever better.
1.Countless Nvidia forum posts, including developer input.
2.Drivers have been thoroughly "scrubbed" and v327.23 re-installed.
3. I think a Corsair 850 provides adequate power to the GTX560.
*4. " I would like that misinformation wiped clean."...yes, so would I, be very happy if you could help me dispel these unfounded rumors and innuendo.
Power issues include loose connections, overloaded rails if the PSU has more than one, etc.
NV devs? That I would like to see.
OpenCL is still a developing standard, so there are various ways of looking at "limited" support, but with the right drivers, the NV's support is enough to work with the current version of Core_17. Is better support improve what FAH can do through OpenCL? Most decidedly yes but it should work with the NV-provided drivers provided you've cleaned out earlier versions and provided Windows Update doesn't come along and "fix" what isn't broken.
Follow the other suggestions provided above.
