Computer Specs:
Windows 7 Pro 64bit
Celeron G1820
MSI R9 280x
Gskill 1866 DDR3 8gb
asrock pro btc
Corsair 1200i 1200w psu
USB x1 to x16 risers
120gb SSD
Network Connection: DSL
Operating System: service packs updated but windows update is off.
Overclocked?: Two cards are +20mhz on gpu core. Two are +60mhz.
Stable?: 24/7 stable. Best speed of card was found while litecoin mining.
Software: 7.4.4 ?
WU details: No idea what this is
One of my 4 card R9 280x rigs is steady at 100% cpu usage.
I do not CPU mine (paused the CPU miner)
It is getting around 80k ppd per card instead of the expected 115k ppd. (i let it normalize, this is after at least 24 hours of folding)
I assume it is because they are using 100% of the cpu load and it cannot keep up.
75% GPU usage in GPU-Z
Instead of throwing $100 at a hyperthreading i3 or an i5, i wanted to get someone to look at my log file and see what they think.
Two of my other rigs are on the same celeron and they do not have this same problem. They are folding at the expected PPD per card.
This rig performed flawlessly litecoin mining for a couple months 24/7
The cards are connected to the mobo via USB x1 to x16 powered risers. (i can test standard ribbon risers to rule that out as a problem)
The motherboard is an AsRock PRO BTC, I am not sure if this is a problem, The other rigs i have are gaming motherboards. (all socket 1150, all 8gb ddr3)
below is my log file.
Any info is helpful.
Thanks,
- Casey
*********************** Log Started 2014-05-18T06:42:03Z ***********************
06:42:03:************************* Folding@home Client *************************
06:42:03: Website: http://folding.stanford.edu/
06:42:03: Copyright: (c) 2009-2014 Stanford University
06:42:03: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:42:03: Args:
06:42:03: Config: C:/Users/MINE RIGGER/AppData/Roaming/FAHClient/config.xml
06:42:03:******************************** Build ********************************
06:42:03: Version: 7.4.4
06:42:03: Date: Mar 4 2014
06:42:03: Time: 20:26:54
06:42:03: SVN Rev: 4130
06:42:03: Branch: fah/trunk/client
06:42:03: Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:42:03: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:42:03: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:42:03: Platform: win32 XP
06:42:03: Bits: 32
06:42:03: Mode: Release
06:42:03:******************************* System ********************************
06:42:03: CPU: Intel(R) Celeron(R) CPU G1820 @ 2.70GHz
06:42:03: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:42:03: CPUs: 2
06:42:03: Memory: 7.94GiB
06:42:03: Free Memory: 7.14GiB
06:42:03: Threads: WINDOWS_THREADS
06:42:03: OS Version: 6.1
06:42:03: Has Battery: false
06:42:03: On Battery: false
06:42:03: UTC Offset: -4
06:42:03: PID: 2504
06:42:03: CWD: C:/Users/MINE RIGGER/AppData/Roaming/FAHClient
06:42:03: OS: Windows 7 Professional
06:42:03: OS Arch: AMD64
06:42:03: GPUs: 4
06:42:03: GPU 0: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03: GPU 1: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03: GPU 2: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03: GPU 3: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03: CUDA: Not detected
06:42:03:Win32 Service: false
06:42:03:***********************************************************************
06:42:03:<config>
06:42:03: <!-- Slot Control -->
06:42:03: <power v='full'/>
06:42:03:
06:42:03: <!-- User Information -->
06:42:03: <passkey v='********************************'/>
06:42:03: <team v='224497'/>
06:42:03: <user v='viperbite'/>
06:42:03:
06:42:03: <!-- Folding Slots -->
06:42:03: <slot id='0' type='CPU'>
06:42:03: <paused v='true'/>
06:42:03: </slot>
06:42:03: <slot id='1' type='GPU'/>
06:42:03: <slot id='2' type='GPU'/>
06:42:03: <slot id='3' type='GPU'/>
06:42:03: <slot id='4' type='GPU'/>
06:42:03:</config>
06:42:03:Trying to access database...
06:42:03:Successfully acquired database lock
06:42:03:Enabled folding slot 00: PAUSED cpu:1 (by user)
06:42:03:Enabled folding slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03:Enabled folding slot 02: READY gpu:1:Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03:Enabled folding slot 03: READY gpu:2:Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03:Enabled folding slot 04: READY gpu:3:Tahiti XT [Radeon R9 200/HD 7900/8970]
06:42:03:WU03:FS01:Starting
06:42:03:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/MINE RIGGER/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 03 -suffix 01 -version 704 -lifeline 2504 -checkpoint 15 -gpu 0 -gpu-vendor ati
06:42:03:WU03:FS01:Started FahCore on PID 2772
06:42:03:WU03:FS01:Core PID:2724
06:42:03:WU03:FS01:FahCore 0x17 started
06:42:03:WU06:FS04:Starting
06:42:03:WU06:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/MINE RIGGER/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 06 -suffix 01 -version 704 -lifeline 2504 -checkpoint 15 -gpu 3 -gpu-vendor ati
06:42:03:WU06:FS04:Started FahCore on PID 2824
06:42:03:WU06:FS04:Core PID:2832
06:42:03:WU06:FS04:FahCore 0x17 started
06:42:03:WU07:FS02:Starting
06:42:03:WU07:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/MINE RIGGER/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 07 -suffix 01 -version 704 -lifeline 2504 -checkpoint 15 -gpu 1 -gpu-vendor ati
06:42:03:WU07:FS02:Started FahCore on PID 2804
06:42:03:WU07:FS02:Core PID:2856
06:42:03:WU07:FS02:FahCore 0x17 started
06:42:03:WU05:FS03:Starting
06:42:03:WU05:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/MINE RIGGER/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 05 -suffix 01 -version 704 -lifeline 2504 -checkpoint 15 -gpu 2 -gpu-vendor ati
06:42:03:WU05:FS03:Started FahCore on PID 1044
06:42:03:WU05:FS03:Core PID:2892
06:42:03:WU05:FS03:FahCore 0x17 started
06:42:03:WU06:FS04:0x17:*********************** Log Started 2014-05-18T06:42:03Z ***********************
06:42:03:WU06:FS04:0x17:Project: 13001 (Run 91, Clone 6, Gen 11)
06:42:03:WU06:FS04:0x17:Unit: 0x00000028538b3db753286996ef556401
06:42:03:WU06:FS04:0x17:CPU: 0x00000000000000000000000000000000
06:42:03:WU06:FS04:0x17:Machine: 4
06:42:03:WU06:FS04:0x17:Digital signatures verified
06:42:03:WU06:FS04:0x17:Folding@home GPU core17
06:42:03:WU06:FS04:0x17:Version 0.0.52
06:42:03:WU07:FS02:0x17:*********************** Log Started 2014-05-18T06:42:03Z ***********************
06:42:03:WU07:FS02:0x17:Project: 13001 (Run 178, Clone 4, Gen 4)
06:42:03:WU07:FS02:0x17:Unit: 0x0000000a538b3db753288236ce513dd8
06:42:03:WU07:FS02:0x17:CPU: 0x00000000000000000000000000000000
06:42:03:WU07:FS02:0x17:Machine: 2
06:42:03:WU07:FS02:0x17:Digital signatures verified
06:42:03:WU07:FS02:0x17:Folding@home GPU core17
06:42:03:WU07:FS02:0x17:Version 0.0.52
06:42:03:WU05:FS03:0x17:*********************** Log Started 2014-05-18T06:42:03Z ***********************
06:42:03:WU05:FS03:0x17:Project: 13001 (Run 135, Clone 7, Gen 23)
06:42:03:WU05:FS03:0x17:Unit: 0x00000031538b3db753287612b6645ded
06:42:03:WU05:FS03:0x17:CPU: 0x00000000000000000000000000000000
06:42:03:WU05:FS03:0x17:Machine: 3
06:42:03:WU05:FS03:0x17:Digital signatures verified
06:42:03:WU05:FS03:0x17:Folding@home GPU core17
06:42:03:WU05:FS03:0x17:Version 0.0.52
06:42:04:WU03:FS01:0x17:*********************** Log Started 2014-05-18T06:42:03Z ***********************
06:42:04:WU03:FS01:0x17:Project: 13001 (Run 252, Clone 7, Gen 13)
06:42:04:WU03:FS01:0x17:Unit: 0x00000020538b3db75328974c94cab1fd
06:42:04:WU03:FS01:0x17:CPU: 0x00000000000000000000000000000000
06:42:04:WU03:FS01:0x17:Machine: 1
06:42:04:WU03:FS01:0x17:Digital signatures verified
06:42:04:WU03:FS01:0x17:Folding@home GPU core17
06:42:04:WU03:FS01:0x17:Version 0.0.52
06:42:04:WU06:FS04:0x17: Found a checkpoint file
06:42:05:WU07:FS02:0x17: Found a checkpoint file
06:42:05:WU03:FS01:0x17: Found a checkpoint file
06:42:06:WU05:FS03:0x17: Found a checkpoint file
06:45:53:WU05:FS03:0x17:Completed 4625000 out of 5000000 steps (92%)
06:45:53:WU05:FS03:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:48:18:WU07:FS02:0x17:Completed 4500000 out of 5000000 steps (90%)
06:48:18:WU07:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:48:33:WU03:FS01:0x17:Completed 4375000 out of 5000000 steps (87%)
06:48:34:WU03:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:48:56:WU06:FS04:0x17:Completed 4375000 out of 5000000 steps (87%)
06:48:56:WU06:FS04:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:52:42:WU05:FS03:0x17:Completed 4650000 out of 5000000 steps (93%)
06:53:27:WU03:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
06:53:42:WU06:FS04:0x17:Completed 4400000 out of 5000000 steps (88%)
06:57:57:WU07:FS02:0x17:Completed 4550000 out of 5000000 steps (91%)
07:01:39:WU05:FS03:0x17:Completed 4700000 out of 5000000 steps (94%)
