BAD_WORK_UNIT (114 = 0x72) p9408 1267,0,0
rhavern
Post by rhavern »
*********************** Log Started 2014-04-17T07:52:49Z ***********************
07:52:49:************************* Folding@home Client *************************
07:52:49:      Website: http://folding.stanford.edu/
07:52:49:    Copyright: (c) 2009-2013 Stanford University
07:52:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:52:49:         Args:
07:52:49:       Config: C:/Users/Rick/AppData/Roaming/FAHClient/config.xml
07:52:49:******************************** Build ********************************
07:52:49:      Version: 7.3.6
07:52:49:         Date: Feb 18 2013
07:52:49:         Time: 15:25:17
07:52:49:      SVN Rev: 3923
07:52:49:       Branch: fah/trunk/client
07:52:49:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
07:52:49:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
07:52:49:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
07:52:49:     Platform: win32 XP
07:52:49:         Bits: 32
07:52:49:         Mode: Release
07:52:49:******************************* System ********************************
07:52:49:          CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
07:52:49:       CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
07:52:49:         CPUs: 4
07:52:49:       Memory: 1023.29MiB
07:52:49:  Free Memory: 263.05MiB
07:52:49:      Threads: WINDOWS_THREADS
07:52:49:  Has Battery: false
07:52:49:   On Battery: false
07:52:49:   UTC offset: 1
07:52:49:          PID: 3512
07:52:49:          CWD: C:/Users/Rick/AppData/Roaming/FAHClient
07:52:49:           OS: Windows 7 Professional Service Pack 1
07:52:49:      OS Arch: X86
07:52:49:         GPUs: 2
07:52:49:        GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
07:52:49:        GPU 1: ATI:5 Tahiti XT [Radeon HD 7970]
07:52:49:         CUDA: Not detected
07:52:49:Win32 Service: false
07:52:49:***********************************************************************
07:52:49:<config>
07:52:49:  <!-- Folding Core -->
07:52:49:  <core-priority v='low'/>
07:52:49:
07:52:49:  <!-- Folding Slot Configuration -->
07:52:49:  <client-type v='beta'/>
07:52:49:  <power v='full'/>
07:52:49:  <smp v='false'/>
07:52:49:
07:52:49:  <!-- HTTP Server -->
07:52:49:  <allow v='127.0.0.1, 192.168.1.0/24'/>
07:52:49:
07:52:49:  <!-- Network -->
07:52:49:  <proxy v=':8080'/>
07:52:49:
07:52:49:  <!-- Remote Command Server -->
07:52:49:  <command-allow-no-pass v='127.0.0.1, 192.168.1.0/24'/>
07:52:49:
07:52:49:  <!-- User Information -->
07:52:49:  <passkey v='********************************'/>
07:52:49:  <team v='33'/>
07:52:49:  <user v='rhavern'/>
07:52:49:
07:52:49:  <!-- Work Unit Control -->
07:52:49:  <next-unit-percentage v='100'/>
07:52:49:
07:52:49:  <!-- Folding Slots -->
07:52:49:  <slot id='0' type='GPU'/>
07:52:49:  <slot id='1' type='GPU'/>
07:52:49:</config>
07:52:49:Trying to access database...
07:52:49:Successfully acquired database lock
07:52:49:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
07:52:49:Enabled folding slot 01: READY gpu:1:Tahiti XT [Radeon HD 7970]
<snip>
09:20:32:WU01:FS01:Starting
09:20:32:WU01:FS01:Running FahCore: \"C:\\Program Files\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Rick/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 3512 -checkpoint 15 -gpu 1 -gpu-vendor ati
09:20:32:WU01:FS01:Started FahCore on PID 5840
09:20:32:WU01:FS01:Core PID:5972
09:20:32:WU01:FS01:FahCore 0x17 started
09:20:34:WU01:FS01:0x17:*********************** Log Started 2014-04-28T09:20:33Z ***********************
09:20:34:WU01:FS01:0x17:Project: 9408 (Run 1267, Clone 0, Gen 0)
09:20:34:WU01:FS01:0x17:Unit: 0x000000030a3b1e5c5342f376cf73c709
09:20:34:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
09:20:34:WU01:FS01:0x17:Machine: 1
09:20:34:WU01:FS01:0x17:Reading tar file system.xml
09:20:35:WU01:FS01:0x17:Reading tar file integrator.xml
09:20:35:WU01:FS01:0x17:Reading tar file state.xml
09:20:36:WU01:FS01:0x17:Reading tar file core.xml
09:20:36:WU01:FS01:0x17:Digital signatures verified
<snip>
09:26:09:WU01:FS01:0x17:ERROR:exception: Potential energy error of 20.3377, threshold of 10
09:26:09:WU01:FS01:0x17:ERROR:Reference Potential Energy: -677236 | Given Potential Energy: -677256
09:26:09:WU01:FS01:0x17:Saving result file logfile_01.txt
09:26:09:WU01:FS01:0x17:Saving result file badStateCheckpoint_41
09:26:11:WU01:FS01:0x17:Saving result file badStateForceGroup0_41Core.xml
09:26:15:WU01:FS01:0x17:Saving result file badStateForceGroup0_41Ref.xml
09:26:17:WU00:FS00:0x17:Completed 160000 out of 2000000 steps (8%)
09:26:19:WU01:FS01:0x17:Saving result file badStateForceGroup1_41Core.xml
09:26:22:WU01:FS01:0x17:Saving result file badStateForceGroup1_41Ref.xml
09:26:25:WU01:FS01:0x17:Saving result file badStateForceGroup2_41Core.xml
09:26:28:WU01:FS01:0x17:Saving result file badStateForceGroup2_41Ref.xml
09:26:31:WU01:FS01:0x17:Saving result file log.txt
09:26:31:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
09:26:32:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:26:32:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9408 run:1267 clone:0 gen:0 core:0x17 unit:0x000000030a3b1e5c5342f376cf73c709
09:26:32:WU01:FS01:Uploading 19.30MiB to 171.64.65.56
09:26:32:WU01:FS01:Connecting to 171.64.65.56:8080
Folding since 1 WU=1 point
bollix47
Re: BAD_WORK_UNIT (114 = 0x72) p9408 1267,0,0
Post by bollix47 »
Thanks for your report ... there are numerous failures in the database:
The WU (P9408,R1267,C0,G0) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
rhavern
Post by rhavern »
Cheers bollix47
