Q9550@3570MHz, R9 290X@1047MHz, Win7 Prof 64Bit, Catalyst 14.2 Beta v1.3
Project: 8900 (Run 278, Clone 4, Gen 108)
I finished this Project at 21:57:19 UTC (Received points 35.364)
There was no other WU uploaded for the Stats, but i got for only one WU more points (38.900) than the log shows . . .
Log:
After downloading this WU, i restarted Sys to install Win-updates:
17:23:28:<config>
17:23:28: <!-- Folding Slot Configuration -->
17:23:28: <power v='full'/>
17:23:28:
17:23:28: <!-- HTTP Server -->
17:23:28: <allow v='192.168.2.100-192.168.2.110 127.0.0.1'/>
17:23:28:
17:23:28: <!-- Logging -->
17:23:28: <log-rotate-max v='50'/>
17:23:28:
17:23:28: <!-- Network -->
17:23:28: <proxy v=':8080'/>
17:23:28:
17:23:28: <!-- Remote Command Server -->
17:23:28: <command-allow-no-pass v='192.168.2.100-192.168.2.110 127.0.0.1'/>
17:23:28:
17:23:28: <!-- User Information -->
17:23:28: <passkey v='********************************'/>
17:23:28: <team v='70335'/>
17:23:28: <user v='folding_hoomer'/>
17:23:28:
17:23:28: <!-- Folding Slots -->
17:23:28: <slot id='0' type='GPU'>
17:23:28: <client-type v='advanced'/>
17:23:28: <next-unit-percentage v='100'/>
17:23:28: <pause-on-start v='true'/>
17:23:28: <project-key v='0'/>
17:23:28: </slot>
17:23:28:</config>
17:23:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
17:23:45:WU00:FS00:News: Welcome to Folding@Home
17:23:45:WU00:FS00:Assigned to work server 171.64.65.69
17:23:45:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Hawaii [Radeon R9 200X Series] from 171.64.65.69
17:23:45:WU00:FS00:Connecting to 171.64.65.69:8080
17:23:51:WU00:FS00:Downloading 4.17MiB
17:23:58:WU00:FS00:Download 73.37%
17:23:59:WU00:FS00:Download complete
17:23:59:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:278 clone:4 gen:108 core:0x17 unit:0x000000b4028c126651a6647e62652d35
17:23:59:WU00:FS00:Starting
17:23:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 3552 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:23:59:WU00:FS00:Started FahCore on PID 4652
17:23:59:WU00:FS00:Core PID:7540
17:23:59:WU00:FS00:FahCore 0x17 started
17:23:59:WU00:FS00:0x17:*********************** Log Started 2014-03-15T17:23:59Z ***********************
17:23:59:WU00:FS00:0x17:Project: 8900 (Run 278, Clone 4, Gen 108)
17:23:59:WU00:FS00:0x17:Unit: 0x000000b4028c126651a6647e62652d35
17:23:59:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
17:23:59:WU00:FS00:0x17:Machine: 0
17:23:59:WU00:FS00:0x17:Reading tar file state.xml
17:24:00:WU00:FS00:0x17:Reading tar file system.xml
17:24:00:WU00:FS00:0x17:Reading tar file integrator.xml
17:24:00:WU00:FS00:0x17:Reading tar file core.xml
17:24:00:WU00:FS00:0x17:Digital signatures verified
17:24:00:WU00:FS00:0x17:Folding@home GPU core17
17:24:00:WU00:FS00:0x17:Version 0.0.52
17:24:03:FS00:Paused
17:24:03:FS00:Shutting core down
17:24:04:WU00:FS00:0x17:WARNING:Console control signal 1 on PID 7540
17:24:04:WU00:FS00:0x17:Exiting, please wait. . .
17:25:04:WARNING:FS00:Killing WU00
17:25:04:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Restarted Sys
*********************** Log Started 2014-03-15T17:25:49Z ***********************
17:25:49:************************* Folding@home Client *************************
17:25:49: Website: http://folding.stanford.edu/
17:25:49: Copyright: (c) 2009-2013 Stanford University
17:25:49: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:25:49: Args:
17:25:49: Config: C:/Users/Markus/AppData/Roaming/FAHClient/config.xml
17:25:49:******************************** Build ********************************
17:25:49: Version: 7.3.6
17:25:49: Date: Feb 18 2013
17:25:49: Time: 15:25:17
17:25:49: SVN Rev: 3923
17:25:49: Branch: fah/trunk/client
17:25:49: Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:25:49: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:25:49: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:25:49: Platform: win32 XP
17:25:49: Bits: 32
17:25:49: Mode: Release
17:25:49:******************************* System ********************************
17:25:49: CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
17:25:49: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
17:25:49: CPUs: 4
17:25:49: Memory: 2.00GiB
17:25:49: Free Memory: 1.08GiB
17:25:49: Threads: WINDOWS_THREADS
17:25:49: Has Battery: false
17:25:49: On Battery: false
17:25:49: UTC offset: 1
17:25:49: PID: 3188
17:25:49: CWD: C:/Users/Markus/AppData/Roaming/FAHClient
17:25:49: OS: Windows 7 Professional
17:25:49: OS Arch: AMD64
17:25:49: GPUs: 1
17:25:49: GPU 0: ATI:5 Hawaii [Radeon R9 200X Series]
17:25:49: CUDA: Not detected
17:25:49:Win32 Service: false
17:25:49:***********************************************************************
17:25:49:<config>
17:25:49: <!-- Folding Slot Configuration -->
17:25:49: <power v='full'/>
17:25:49:
17:25:49: <!-- HTTP Server -->
17:25:49: <allow v='192.168.2.100-192.168.2.110 127.0.0.1'/>
17:25:49:
17:25:49: <!-- Logging -->
17:25:49: <log-rotate-max v='50'/>
17:25:49:
17:25:49: <!-- Network -->
17:25:49: <proxy v=':8080'/>
17:25:49:
17:25:49: <!-- Remote Command Server -->
17:25:49: <command-allow-no-pass v='192.168.2.100-192.168.2.110 127.0.0.1'/>
17:25:49:
17:25:49: <!-- User Information -->
17:25:49: <passkey v='********************************'/>
17:25:49: <team v='70335'/>
17:25:49: <user v='folding_hoomer'/>
17:25:49:
17:25:49: <!-- Folding Slots -->
17:25:49: <slot id='0' type='GPU'>
17:25:49: <client-type v='advanced'/>
17:25:49: <next-unit-percentage v='100'/>
17:25:49: <pause-on-start v='true'/>
17:25:49: <project-key v='0'/>
17:25:49: </slot>
17:25:49:</config>
17:25:49:Trying to access database...
17:25:49:Successfully acquired database lock
17:25:49:Enabled folding slot 00: PAUSED gpu:0:Hawaii [Radeon R9 200X Series] (paused)
17:26:14:FS00:Unpaused
17:26:14:WU00:FS00:Starting
17:26:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 3188 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:26:14:WU00:FS00:Started FahCore on PID 4884
17:26:15:WU00:FS00:Core PID:4896
17:26:15:WU00:FS00:FahCore 0x17 started
17:26:15:WU00:FS00:0x17:*********************** Log Started 2014-03-15T17:26:15Z ***********************
17:26:15:WU00:FS00:0x17:Project: 8900 (Run 278, Clone 4, Gen 108)
17:26:15:WU00:FS00:0x17:Unit: 0x000000b4028c126651a6647e62652d35
17:26:15:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
17:26:15:WU00:FS00:0x17:Machine: 0
17:26:15:WU00:FS00:0x17:Reading tar file state.xml
17:26:15:WU00:FS00:0x17:Reading tar file system.xml
17:26:16:WU00:FS00:0x17:Reading tar file integrator.xml
17:26:16:WU00:FS00:0x17:Reading tar file core.xml
17:26:16:WU00:FS00:0x17:Digital signatures verified
17:26:16:WU00:FS00:0x17:Folding@home GPU core17
17:26:16:WU00:FS00:0x17:Version 0.0.52
17:28:41:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
17:28:41:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:31:25:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
cut
21:46:42:WU00:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
21:49:09:WU00:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
21:49:10:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
21:49:11:WU01:FS00:News: Welcome to Folding@Home
21:49:11:WU01:FS00:Assigned to work server 140.163.4.231
21:49:11:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Hawaii [Radeon R9 200X Series] from 140.163.4.231
21:49:11:WU01:FS00:Connecting to 140.163.4.231:8080
21:49:17:WU01:FS00:Downloading 5.22MiB
21:49:24:WU01:FS00:Download 58.65%
21:49:27:WU01:FS00:Download complete
21:49:27:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:128 clone:4 gen:0 core:0x17 unit:0x00000000538b3db7530fc03dd46fd857
21:49:27:WU00:FS00:0x17:Saving result file logfile_01.txt
21:49:27:WU00:FS00:0x17:Saving result file checkpointState.xml
21:49:29:WU00:FS00:0x17:Saving result file checkpt.crc
21:49:29:WU00:FS00:0x17:Saving result file log.txt
21:49:29:WU00:FS00:0x17:Saving result file positions.xtc
21:49:31:WU00:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
21:49:31:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:49:31:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8900 run:278 clone:4 gen:108 core:0x17 unit:0x000000b4028c126651a6647e62652d35
21:49:31:WU00:FS00:Uploading 12.96MiB to 171.64.65.69
21:49:31:WU00:FS00:Connecting to 171.64.65.69:8080
21:49:31:WU01:FS00:Starting
21:49:31:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 3188 -checkpoint 15 -gpu 0 -gpu-vendor ati
21:49:32:WU01:FS00:Started FahCore on PID 2736
21:49:32:WU01:FS00:Core PID:6856
21:49:32:WU01:FS00:FahCore 0x17 started
21:49:32:WU01:FS00:0x17:*********************** Log Started 2014-03-15T21:49:32Z ***********************
21:49:32:WU01:FS00:0x17:Project: 13000 (Run 128, Clone 4, Gen 0)
21:49:32:WU01:FS00:0x17:Unit: 0x00000000538b3db7530fc03dd46fd857
21:49:32:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
21:49:32:WU01:FS00:0x17:Machine: 0
21:49:32:WU01:FS00:0x17:Reading tar file system.xml
21:49:32:WU01:FS00:0x17:Reading tar file integrator.xml
21:49:32:WU01:FS00:0x17:Reading tar file state.xml
21:49:33:WU01:FS00:0x17:Reading tar file core.xml
21:49:33:WU01:FS00:0x17:Digital signatures verified
21:49:33:WU01:FS00:0x17:Folding@home GPU core17
21:49:33:WU01:FS00:0x17:Version 0.0.52
21:49:33:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
21:49:33:WU00:FS00:Connecting to 171.64.65.69:80
21:49:35:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.69:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
21:49:35:WU00:FS00:Trying to send results to collection server
21:49:35:WU00:FS00:Uploading 12.96MiB to 171.65.103.160
21:49:35:WU00:FS00:Connecting to 171.65.103.160:8080
21:49:42:WU00:FS00:Upload 2.89%
cut
21:52:40:WU00:FS00:Upload 40.50%
21:52:41:WU01:FS00:0x17:Completed 0 out of 5000000 steps (0%)
21:52:41:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:52:50:WU00:FS00:Upload 42.43%
cut
21:57:13:WU00:FS00:Upload 99.81%
21:57:19:WU00:FS00:Upload complete
21:57:19:WU00:FS00:Server responded WORK_ACK (400)
21:57:19:WU00:FS00:Final credit estimate, 35364.00 points
21:57:19:WU00:FS00:Cleaning upCode: Select all
Sat Mar 15 21:00:01 UTC 2014
Date of last work unit 2014-03-15 11:13:44
Total score 146345711
Overall rank . . .
Contributions by team and project:
Donor folding_hoomer
Score 146345711 (certificate)
WU 18296 (certificate)
Date of last
Active clients
(within 50 days) 12
Active clients
(within 7 days) 9 Code: Select all
Sat Mar 15 23:00:02 UTC 2014
Date of last work unit 2014-03-15 15:07:07
Total score 146384611
Overall rank . . .
Score 146384611 (certificate)
WU 18297 (certificate)
Date of last
Active clients
(within 50 days) 12
Active clients
(within 7 days) 9 Number of WU´s increased by 1
Points increased by 38.900
You can find the relevant data on my EOC-Stats-page listed at:
15.03. 6pm (http://folding.extremeoverclocking.com/ ... =&u=418046)
and on my Kakao-Stats-page listed at:
15.03. 22:00 (http://kakaostats.com/usum.php?u=1450999)
The same happend on a second Sys:
i7 875K@3826MHz, HD7870@1200MHz, Win7 Prof 64Bit, Catalyst 14.1 Beta V1.6
Project: 8900 (Run 828, Clone 4, Gen 73)
Points received (Log): 26.868 points
17:18:43:WU00:FS01:Assigned to work server 171.64.65.69
17:18:43:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.69
17:18:43:WU00:FS01:Connecting to 171.64.65.69:8080
17:18:49:WU00:FS01:Downloading 4.18MiB
17:18:56:WU00:FS01:Download 73.33%
17:18:56:WU00:FS01:Download complete
17:18:57:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:828 clone:4 gen:73 core:0x17 unit:0x00000068028c126651a6dee664b3e50a
17:18:57:WU00:FS01:Starting
17:18:57:WU00:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 3444 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:18:57:WU00:FS01:Started FahCore on PID 6004
17:18:57:WU00:FS01:Core PID:6040
17:18:57:WU00:FS01:FahCore 0x17 started
17:18:57:WU00:FS01:0x17:*********************** Log Started 2014-03-15T17:18:57Z ***********************
17:18:57:WU00:FS01:0x17:Project: 8900 (Run 828, Clone 4, Gen 73)
17:18:57:WU00:FS01:0x17:Unit: 0x00000068028c126651a6dee664b3e50a
17:18:57:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:18:57:WU00:FS01:0x17:Machine: 1
17:18:57:WU00:FS01:0x17:Reading tar file state.xml
17:18:58:WU00:FS01:0x17:Reading tar file system.xml
17:18:58:WU00:FS01:0x17:Reading tar file integrator.xml
17:18:58:WU00:FS01:0x17:Reading tar file core.xml
17:18:58:WU00:FS01:0x17:Digital signatures verified
17:18:58:WU00:FS01:0x17:Folding@home GPU core17
17:18:58:WU00:FS01:0x17:Version 0.0.52
17:21:11:WU00:FS01:0x17:Completed 0 out of 2500000 steps (0%)
17:21:11:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:25:55:WU00:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
17:49:44:FS01:Finishing
17:53:43:WU00:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
01:00:15:WU00:FS01:0x17:Completed 2475000 out of 2500000 steps (99%)
01:04:47:WU00:FS01:0x17:Completed 2500000 out of 2500000 steps (100%)
01:05:01:WU00:FS01:0x17:Saving result file logfile_01.txt
01:05:01:WU00:FS01:0x17:Saving result file checkpointState.xml
01:05:03:WU00:FS01:0x17:Saving result file checkpt.crc
01:05:03:WU00:FS01:0x17:Saving result file log.txt
01:05:03:WU00:FS01:0x17:Saving result file positions.xtc
01:05:05:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
01:05:06:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:05:06:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:8900 run:828 clone:4 gen:73 core:0x17 unit:0x00000068028c126651a6dee664b3e50a
01:05:06:WU00:FS01:Uploading 12.97MiB to 171.64.65.69
01:05:06:WU00:FS01:Connecting to 171.64.65.69:8080
01:05:08:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
01:05:08:WU00:FS01:Connecting to 171.64.65.69:80
01:05:10:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.69:80: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.
01:05:10:WU00:FS01:Trying to send results to collection server
01:05:10:WU00:FS01:Uploading 12.97MiB to 171.65.103.160
01:05:10:WU00:FS01:Connecting to 171.65.103.160:8080
01:05:25:WU00:FS01:Upload 5.30%
01:12:13:WU00:FS01:Upload 96.90%
01:12:23:WU00:FS01:Upload 99.31%
01:12:32:WU00:FS01:Upload complete
01:12:32:WU00:FS01:Server responded WORK_ACK (400)
01:12:32:WU00:FS01:Final credit estimate, 26868.00 points
01:12:32:WU00:FS01:Cleaning up
New folding@home-Stats-Server-entry:
Sun Mar 16 01:00:02 UTC 2014
Date of last work unit 2014-03-15 19:06:46
Total score 146477307
Overall rank . . .
Team . . .
Score 146477307 (certificate)
WU 18300 (certificate)
Date of last
Active clients
(within 50 days) 12
Active clients
(within 7 days) 9 Points: 92.696
WU: 3
Two of the WU´s belonges to the former Stats-Update (Points: 63141, WU: 2) including the following Data:
Project: 7512 (Run 0, Clone 81, Gen 396): Final credit estimate, 6292.00 points
Project: 9401 (Run 1114, Clone 0, Gen 41): Final credit estimate, 56847.00 points
See EOC-Stats-Update at:
15.3. 9pm (http://folding.extremeoverclocking.com/ ... =&u=418046)
92.696 - 63.141 = 29.555 points for the WU listed with 26.868 points (Log).
The only abnormality in both Client-Logs:
The client tries to upload the finished WU first to Server 171.64.65.69 using port 8080 and 80, but failed :
. . .It seems to me that the CollectionServer added additional 10% to each WU:
Project: 8900 (278, 4, 108) Log: 35.364 points + 10% (3.536,4) = 38.900,4 points
Project: 8900 (828, 4, 73) Log: 26.868 points + 10% (2.686,8) = 29.554,8 points
Has anyone of you a better clarification what has happend?
