Feature request for serverstat
rhavern
Post by rhavern »
On http://fah-web.stanford.edu/pybeta/serverstat.html there is a mouse over at the top of each column that explains the data in said column, with the exception of "Others". Most of the data in this column is self-explanatory, however GPU type is not. Could a similar mouse over help be added to this column to explain this item?
Thanks
Folding since 1 WU=1 point
Re: Feature request for serverstat
While I do hope that this feature is implemented, for those that are unaware, here are the details:
GP Type -> Indicates the WUs available for a particular GPU Type. It is broken into:
A) 1 -> WUs for ATI/AMD GPUs
B) 2 -> WUs for Nvidia GPUs
The servers should be upgraded to use the same designations as used in the GPUs file for more accurate work assignments, IMO.
