Conflicting results from Client & Info from GPU-Z
turkish2
Post by turkish2 »
Hello all,
My system info is as follows:
And here is a copy of my log:
*********************** Log Started 2013-12-18T01:26:47Z ***********************
01:26:47:************************* Folding@home Client *************************
01:26:47:      Website: http://folding.stanford.edu/
01:26:47:    Copyright: (c) 2009-2013 Stanford University
01:26:47:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:26:47:         Args: --open-web-control
01:26:47:       Config: C:/Users/LIVE/AppData/Roaming/FAHClient/config.xml
01:26:47:******************************** Build ********************************
01:26:47:      Version: 7.3.6
01:26:47:         Date: Feb 18 2013
01:26:47:         Time: 15:25:17
01:26:47:      SVN Rev: 3923
01:26:47:       Branch: fah/trunk/client
01:26:47:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:26:47:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:26:47:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:26:47:     Platform: win32 XP
01:26:47:         Bits: 32
01:26:47:         Mode: Release
01:26:47:******************************* System ********************************
01:26:47:          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
01:26:47:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
01:26:47:         CPUs: 8
01:26:47:       Memory: 15.98GiB
01:26:47:  Free Memory: 12.39GiB
01:26:47:      Threads: WINDOWS_THREADS
01:26:47:  Has Battery: false
01:26:47:   On Battery: false
01:26:47:   UTC offset: -8
01:26:47:          PID: 9812
01:26:47:          CWD: C:/Users/LIVE/AppData/Roaming/FAHClient
01:26:47:           OS: Windows 7 Ultimate
01:26:47:      OS Arch: AMD64
01:26:47:         GPUs: 3
01:26:47:        GPU 0: NVIDIA:1 GT200 [GeForce GTX 280]
01:26:47:        GPU 1: NVIDIA:2 GF110 [GeForce GTX 590]
01:26:47:        GPU 2: NVIDIA:2 GF110 [GeForce GTX 590]
01:26:47:         CUDA: 2.0
01:26:47:  CUDA Driver: 6000
01:26:47:Win32 Service: false
01:26:47:***********************************************************************
01:26:47:<config>
01:26:47:  <service-description v='Folding@home Client'/>
01:26:47:  <service-restart v='true'/>
01:26:47:  <service-restart-delay v='5000'/>
01:26:47:
01:26:47:  <!-- Client Control -->
01:26:47:  <client-threads v='4'/>
01:26:47:  <cycle-rate v='4'/>
01:26:47:  <cycles v='-1'/>
01:26:47:  <data-directory v='.'/>
01:26:47:  <disable-sleep-when-active v='true'/>
01:26:47:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
01:26:47:  <exit-when-done v='false'/>
01:26:47:  <fold-anon v='false'/>
01:26:47:  <open-web-control v='true'/>
01:26:47:
01:26:47:  <!-- Configuration -->
01:26:47:  <config-rotate v='true'/>
01:26:47:  <config-rotate-dir v='configs'/>
01:26:47:  <config-rotate-max v='16'/>
01:26:47:
01:26:47:  <!-- Debugging -->
01:26:47:  <assignment-servers>
01:26:47:    assign3.stanford.edu:8080 assign4.stanford.edu:80
01:26:47:  </assignment-servers>
01:26:47:  <capture-directory v='capture'/>
01:26:47:  <capture-on-error v='false'/>
01:26:47:  <capture-packets v='false'/>
01:26:47:  <capture-requests v='false'/>
01:26:47:  <capture-responses v='false'/>
01:26:47:  <capture-sockets v='false'/>
01:26:47:  <debug-sockets v='false'/>
01:26:47:  <exception-locations v='true'/>
01:26:47:  <gpu-assignment-servers>
01:26:47:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
01:26:47:  </gpu-assignment-servers>
01:26:47:  <stack-traces v='false'/>
01:26:47:
01:26:47:  <!-- Error Handling -->
01:26:47:  <max-slot-errors v='5'/>
01:26:47:  <max-unit-errors v='5'/>
01:26:47:
01:26:47:  <!-- Folding Core -->
01:26:47:  <checkpoint v='12'/>
01:26:47:  <core-dir v='cores'/>
01:26:47:  <core-priority v='low'/>
01:26:47:  <cpu-affinity v='false'/>
01:26:47:  <cpu-usage v='100'/>
01:26:47:  <gpu-usage v='100'/>
01:26:47:  <no-assembly v='false'/>
01:26:47:
01:26:47:  <!-- Folding Slot Configuration -->
01:26:47:  <cause v='ALZHEIMERS'/>
01:26:47:  <client-subtype v='STDCLI'/>
01:26:47:  <client-type v='normal'/>
01:26:47:  <cpu-species v='X86_PENTIUM_II'/>
01:26:47:  <cpu-type v='AMD64'/>
01:26:47:  <cpus v='-1'/>
01:26:47:  <cuda-index v='0'/>
01:26:47:  <gpu v='true'/>
01:26:47:  <max-packet-size v='normal'/>
01:26:47:  <opencl-index v='0'/>
01:26:47:  <os-species v='UNKNOWN'/>
01:26:47:  <os-type v='WIN32'/>
01:26:47:  <power v='full'/>
01:26:47:  <project-key v='0'/>
01:26:47:  <smp v='true'/>
01:26:47:
01:26:47:  <!-- HTTP Server -->
01:26:47:  <allow v='127.0.0.1'/>
01:26:47:  <connection-timeout v='60'/>
01:26:47:  <deny v='0/0'/>
01:26:47:  <http-addresses v='0:7396'/>
01:26:47:  <https-addresses v=''/>
01:26:47:  <max-connect-time v='900'/>
01:26:47:  <max-connections v='800'/>
01:26:47:  <max-request-length v='52428800'/>
01:26:47:  <min-connect-time v='300'/>
01:26:47:  <threads v='8'/>
01:26:47:
01:26:47:  <!-- Logging -->
01:26:47:  <log v='log.txt'/>
01:26:47:  <log-color v='false'/>
01:26:47:  <log-crlf v='true'/>
01:26:47:  <log-date v='false'/>
01:26:47:  <log-date-periodically v='21600'/>
01:26:47:  <log-debug v='true'/>
01:26:47:  <log-domain v='false'/>
01:26:47:  <log-header v='true'/>
01:26:47:  <log-level v='true'/>
01:26:47:  <log-no-info-header v='true'/>
01:26:47:  <log-redirect v='false'/>
01:26:47:  <log-rotate v='true'/>
01:26:47:  <log-rotate-dir v='logs'/>
01:26:47:  <log-rotate-max v='16'/>
01:26:47:  <log-short-level v='false'/>
01:26:47:  <log-simple-domains v='true'/>
01:26:47:  <log-thread-id v='false'/>
01:26:47:  <log-thread-prefix v='true'/>
01:26:47:  <log-time v='true'/>
01:26:47:  <log-to-screen v='true'/>
01:26:47:  <log-truncate v='false'/>
01:26:47:  <verbosity v='5'/>
01:26:47:
01:26:47:  <!-- Network -->
01:26:47:  <proxy v=':8080'/>
01:26:47:  <proxy-enable v='false'/>
01:26:47:  <proxy-pass v=''/>
01:26:47:  <proxy-user v=''/>
01:26:47:
01:26:47:  <!-- Process Control -->
01:26:47:  <child v='false'/>
01:26:47:  <daemon v='false'/>
01:26:47:  <pid v='false'/>
01:26:47:  <pid-file v='Folding@home Client.pid'/>
01:26:47:  <respawn v='false'/>
01:26:47:  <service v='false'/>
01:26:47:
01:26:47:  <!-- Remote Command Server -->
01:26:47:  <command-address v='0.0.0.0'/>
01:26:47:  <command-allow-no-pass v='127.0.0.1'/>
01:26:47:  <command-deny-no-pass v='0/0'/>
01:26:47:  <command-port v='36330'/>
01:26:47:
01:26:47:  <!-- Slot Control -->
01:26:47:  <idle v='false'/>
01:26:47:  <max-shutdown-wait v='60'/>
01:26:47:  <pause-on-battery v='false'/>
01:26:47:  <pause-on-start v='false'/>
01:26:47:
01:26:47:  <!-- User Information -->
01:26:47:  <machine-id v='0'/>
01:26:47:  <passkey v='********************************'/>
01:26:47:  <team v='0'/>
01:26:47:  <user v='Parham_Baik'/>
01:26:47:
01:26:47:  <!-- Web Server -->
01:26:47:  <session-timeout v='3600'/>
01:26:47:  <web-allow v='127.0.0.1'/>
01:26:47:  <web-deny v='0/0'/>
01:26:47:
01:26:47:  <!-- Work Unit Control -->
01:26:47:  <dump-after-deadline v='true'/>
01:26:47:  <max-queue v='16'/>
01:26:47:  <max-units v='0'/>
01:26:47:  <next-unit-percentage v='99'/>
01:26:47:
01:26:47:  <!-- Folding Slots -->
01:26:47:  <slot id='0' type='GPU'>
01:26:47:    <cuda-index v='2'/>
01:26:47:    <opencl-index v='2'/>
01:26:47:  </slot>
01:26:47:  <slot id='1' type='GPU'>
01:26:47:    <cuda-index v='1'/>
01:26:47:    <opencl-index v='1'/>
01:26:47:  </slot>
01:26:47:  <slot id='2' type='GPU'>
01:26:47:  </slot>
01:26:47:  <slot id='3' type='CPU'>
01:26:47:    <cpus v='4'/>
01:26:47:  </slot>
01:26:47:</config>
01:26:47:Trying to access database...
01:26:47:Successfully acquired database lock
01:26:47:Enabled folding slot 00: READY gpu:0:GT200 [GeForce GTX 280]
01:26:47:Enabled folding slot 01: READY gpu:1:GF110 [GeForce GTX 590]
01:26:47:Enabled folding slot 02: READY gpu:2:GF110 [GeForce GTX 590]
01:26:47:Enabled folding slot 03: READY cpu:4
01:26:47:Started thread 4 on PID 9812
01:26:47:Started thread 5 on PID 9812
01:26:47:Started thread 7 on PID 9812
01:26:47:WU00:FS00:Starting
01:26:47:Started thread 6 on PID 9812
01:26:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 2 -gpu-vendor nvidia
01:26:47:WU00:FS00:Started FahCore on PID 8828
01:26:47:Started thread 8 on PID 9812
01:26:47:WU00:FS00:Core PID:5708
01:26:47:WU00:FS00:FahCore 0x11 started
01:26:47:WU02:FS02:Starting
01:26:47:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 0 -gpu-vendor nvidia
01:26:47:WU02:FS02:Started FahCore on PID 3152
01:26:47:Started thread 9 on PID 9812
01:26:47:WU02:FS02:Core PID:1712
01:26:47:WU02:FS02:FahCore 0x15 started
01:26:47:WU01:FS01:Starting
01:26:47:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:26:47:WU01:FS01:Started FahCore on PID 9320
01:26:47:Started thread 10 on PID 9812
01:26:47:WU01:FS01:Core PID:9560
01:26:47:WU01:FS01:FahCore 0x15 started
01:26:47:WU03:FS03:Starting
01:26:47:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 03 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -np 4
01:26:47:WU03:FS03:Started FahCore on PID 10124
01:26:47:Started thread 11 on PID 9812
01:26:47:WU03:FS03:Core PID:4112
01:26:47:WU03:FS03:FahCore 0xa3 started
01:26:48:WU00:FS00:0x11:
01:26:48:WU00:FS00:0x11:*------------------------------*
01:26:48:WU00:FS00:0x11:Folding@Home GPU Core
01:26:48:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
01:26:48:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
01:26:48:WU00:FS00:0x11:Build host: amoeba
01:26:48:WU00:FS00:0x11:Board Type: Nvidia
01:26:48:WU00:FS00:0x11:Core      :
01:26:48:WU00:FS00:0x11:Preparing to commence simulation
01:26:48:WU00:FS00:0x11:- Ensuring status. Please wait.
01:26:48:WU02:FS02:0x15:
01:26:48:WU02:FS02:0x15:*------------------------------*
01:26:48:WU02:FS02:0x15:Folding@Home GPU Core
01:26:48:WU02:FS02:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:26:48:WU02:FS02:0x15:Build host             AmoebaRemote
01:26:48:WU02:FS02:0x15:Board Type             NVIDIA/CUDA
01:26:48:WU02:FS02:0x15:Core                   15
01:26:48:WU02:FS02:0x15:Window's signal control handler registered.
01:26:48:WU02:FS02:0x15:Preparing to commence simulation
01:26:48:WU02:FS02:0x15:- Looking at optimizations...
01:26:48:WU02:FS02:0x15:- Files status OK
01:26:48:WU02:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:26:48:WU02:FS02:0x15:- Expanded 126919 -> 507182 (decompressed 399.6 percent)
01:26:48:WU02:FS02:0x15:Called DecompressByteArray: compressed_data_size=126919 data_size=507182, decompressed_data_size=507182 diff=0
01:26:48:WU02:FS02:0x15:- Digital signature verified
01:26:48:WU02:FS02:0x15:Project: 7624 (Run 355, Clone 0, Gen 287)
01:26:48:WU02:FS02:0x15:Assembly optimizations on if available.
01:26:48:WU02:FS02:0x15:Entering M.D.
01:26:48:WU01:FS01:0x15:
01:26:48:WU01:FS01:0x15:*------------------------------*
01:26:48:WU01:FS01:0x15:Folding@Home GPU Core
01:26:48:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:26:48:WU01:FS01:0x15:Build host             AmoebaRemote
01:26:48:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
01:26:48:WU01:FS01:0x15:Core                   15
01:26:48:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:26:48:WU01:FS01:0x15:Window's signal control handler registered.
01:26:48:WU01:FS01:0x15:Preparing to commence simulation
01:26:48:WU01:FS01:0x15:- Looking at optimizations...
01:26:48:WU01:FS01:0x15:- Files status OK
01:26:48:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:26:48:WU01:FS01:0x15:- Expanded 124917 -> 502918 (decompressed 402.6 percent)
01:26:48:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124917 data_size=502918, decompressed_data_size=502918 diff=0
01:26:48:WU01:FS01:0x15:- Digital signature verified
01:26:48:WU01:FS01:0x15:Project: 7625 (Run 162, Clone 0, Gen 216)
01:26:48:WU01:FS01:0x15:Assembly optimizations on if available.
01:26:48:WU01:FS01:0x15:Entering M.D.
01:26:48:WU03:FS03:0xa3:
01:26:48:WU03:FS03:0xa3:*------------------------------*
01:26:48:WU03:FS03:0xa3:Folding@Home Gromacs SMP Core
01:26:48:WU03:FS03:0xa3:Version 2.27 (Dec. 15, 2010)
01:26:48:WU03:FS03:0xa3:Preparing to commence simulation
01:26:48:WU03:FS03:0xa3:- Looking at optimizations...
01:26:48:WU03:FS03:0xa3:- Files status OK
01:26:48:WU03:FS03:0xa3:- Expanded 3849760 -> 4387808 (decompressed 113.9 percent)
01:26:48:WU03:FS03:0xa3:Called DecompressByteArray: compressed_data_size=3849760 data_size=4387808, decompressed_data_size=4387808 diff=0
01:26:48:WU03:FS03:0xa3:- Digital signature verified
01:26:48:WU03:FS03:0xa3:Project: 8580 (Run 0, Clone 9, Gen 345)
01:26:48:WU03:FS03:0xa3:Assembly optimizations on if available.
01:26:48:WU03:FS03:0xa3:Entering M.D.
01:26:49:WU02:FS02:0x15:Will resume from checkpoint file 02/wudata_01.ckp
01:26:49:WU02:FS02:0x15:Tpr hash 02/wudata_01.tpr:  798714591 686686666 2176552828 2140484949 1723568165
01:26:49:WU02:FS02:0x15:GPU device id=0
01:26:49:WU02:FS02:0x15:Working on Protein
01:26:49:WU02:FS02:0x15:Client config unavailable.
01:26:49:WU01:FS01:0x15:Will resume from checkpoint file 01/wudata_01.ckp
01:26:49:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  3698933742 3279887221 3469712472 499215661 891839263
01:26:49:WU01:FS01:0x15:GPU device id=1
01:26:49:WU01:FS01:0x15:Working on Protein
01:26:49:WU01:FS01:0x15:Client config unavailable.
01:26:50:WU02:FS02:0x15:Starting GUI Server
01:26:50:WU01:FS01:0x15:Starting GUI Server
01:26:52:1:127.0.0.1 GET /ping?_=1387330012367&callback=jQuery19007490860924590379_1387330012366
01:26:54:2:127.0.0.1 GET /?nocache=0.82420948962681
01:26:54:WU03:FS03:0xa3:Using Gromacs checkpoints
01:26:54:WU03:FS03:0xa3:Mapping NT from 4 to 4
01:26:54:WU03:FS03:0xa3:Resuming from checkpoint
01:26:54:WU03:FS03:0xa3:Verified 03/wudata_01.log
01:26:54:WU03:FS03:0xa3:Verified 03/wudata_01.trr
01:26:54:WU03:FS03:0xa3:Verified 03/wudata_01.edr
01:26:55:WU03:FS03:0xa3:Completed 4005 out of 500000 steps  (0%)
01:26:55:3:127.0.0.1 GET /js/main.js?nocache=0.7569965946022421
01:26:55:3:127.0.0.1:New Web connection
01:26:55:4:127.0.0.1 GET /css/style.css?nocache=0.40075689693912864
01:26:56:5:127.0.0.1 GET /api/updates/set?sid=0xf29517ab31d96e3ffc715cd3ba72da2c&update_id=0&update_path=/api/basic&update_rate=1
01:26:56:6:127.0.0.1 GET /api/updates/set?sid=0xf29517ab31d96e3ffc715cd3ba72da2c&update_id=1&update_path=/api/slots&update_rate=1
01:26:56:7:127.0.0.1 GET /api/configured?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:26:56:Started thread 12 on PID 9812
01:26:56:8:127.0.0.1 GET /api/updates?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:26:57:8:127.0.0.1 GET /api/updates?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:26:57:WU00:FS00:0x11:- Looking at optimizations...
01:26:57:WU00:FS00:0x11:- Working with standard loops on this execution.
01:26:57:WU00:FS00:0x11:- Previous termination of core was improper.
01:26:57:WU00:FS00:0x11:- Going to use standard loops.
01:26:57:WU00:FS00:0x11:- Files status OK
01:26:57:WU00:FS00:0x11:- Expanded 46634 -> 252912 (decompressed 542.3 percent)
01:26:57:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=46634 data_size=252912, decompressed_data_size=252912 diff=0
01:26:57:WU00:FS00:0x11:- Digital signature verified
01:26:57:WU00:FS00:0x11:Project: 5767 (Run 8, Clone 228, Gen 4728)
01:26:57:WU00:FS00:0x11:Entering M.D.
01:26:59:8:127.0.0.1 GET /api/updates?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:27:03:WU00:FS00:0x11:Will resume from checkpoint file
01:27:03:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  394006242 3810108060 3329037550 2918953945 3075991337
01:27:03:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
01:27:04:8:127.0.0.1 GET /api/updates?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:27:11:8:127.0.0.1 GET /api/updates?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:27:13:8:127.0.0.1 GET /api/updates?sid=0xf29517ab31d96e3ffc715cd3ba72da2c
01:27:50:WU01:FS01:0x15:Finished fah_main status=59
01:27:50:WU01:FS01:0x15:mdrun_gpu returned 59
01:27:50:WU01:FS01:0x15:GPU memtest failure
01:27:50:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
01:27:50:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:27:51:WU01:FS01:Starting
01:27:51:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:27:51:WU01:FS01:Started FahCore on PID 10584
01:27:51:Started thread 13 on PID 9812
01:27:51:WU01:FS01:Core PID:10596
01:27:51:WU01:FS01:FahCore 0x15 started
01:27:51:WU01:FS01:0x15:
01:27:51:WU01:FS01:0x15:*------------------------------*
01:27:51:WU01:FS01:0x15:Folding@Home GPU Core
01:27:51:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:27:51:WU01:FS01:0x15:Build host             AmoebaRemote
01:27:51:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
01:27:51:WU01:FS01:0x15:Core                   15
01:27:51:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:27:51:WU01:FS01:0x15:Window's signal control handler registered.
01:27:51:WU01:FS01:0x15:Preparing to commence simulation
01:27:51:WU01:FS01:0x15:- Looking at optimizations...
01:27:51:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
01:27:51:WU01:FS01:0x15:- Created dyn
01:27:51:WU01:FS01:0x15:- Files status OK
01:27:51:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:27:51:WU01:FS01:0x15:- Expanded 124917 -> 502918 (decompressed 402.6 percent)
01:27:51:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124917 data_size=502918, decompressed_data_size=502918 diff=0
01:27:51:WU01:FS01:0x15:- Digital signature verified
01:27:51:WU01:FS01:0x15:Project: 7625 (Run 162, Clone 0, Gen 216)
01:27:51:WU01:FS01:0x15:Assembly optimizations on if available.
01:27:51:WU01:FS01:0x15:Entering M.D.
01:27:51:WU02:FS02:0x15:Resuming from checkpoint
01:27:51:WU02:FS02:0x15:fcCheckPointResume: retreived and current tpr file hash:
01:27:51:WU02:FS02:0x15:   0    798714591    798714591
01:27:51:WU02:FS02:0x15:   1    686686666    686686666
01:27:51:WU02:FS02:0x15:   2   2176552828   2176552828
01:27:51:WU02:FS02:0x15:   3   2140484949   2140484949
01:27:51:WU02:FS02:0x15:   4   1723568165   1723568165
01:27:51:WU02:FS02:0x15:fcCheckPointResume: file hashes same.
01:27:51:WU02:FS02:0x15:fcCheckPointResume: state restored.
01:27:51:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
01:27:51:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
01:27:51:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
01:27:51:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
01:27:51:WU02:FS02:0x15:fcCheckPointResume: state restored 2
01:27:51:WU02:FS02:0x15:Resumed from checkpoint
01:27:51:WU02:FS02:0x15:Setting checkpoint frequency: 400000
01:27:51:WU02:FS02:0x15:Completed   4000001 out of 40000000 steps (10%).
01:27:52:WARNING:WU02:FS02:Detected clock skew (1 mins 05 secs), adjusting time estimates
01:27:53:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  3698933742 3279887221 3469712472 499215661 891839263
01:27:53:WU01:FS01:0x15:GPU device id=1
01:27:53:WU01:FS01:0x15:Working on Protein
01:27:53:WU01:FS01:0x15:Client config unavailable.
01:27:53:WU01:FS01:0x15:Starting GUI Server
01:28:53:WU01:FS01:0x15:Finished fah_main status=59
01:28:53:WU01:FS01:0x15:mdrun_gpu returned 59
01:28:53:WU01:FS01:0x15:GPU memtest failure
01:28:53:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
01:28:54:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:28:54:WU01:FS01:Starting
01:28:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:28:54:WU01:FS01:Started FahCore on PID 10852
01:28:54:Started thread 14 on PID 9812
01:28:54:WU01:FS01:Core PID:10864
01:28:54:WU01:FS01:FahCore 0x15 started
01:28:54:WU01:FS01:0x15:
01:28:54:WU01:FS01:0x15:*------------------------------*
01:28:54:WU01:FS01:0x15:Folding@Home GPU Core
01:28:54:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:28:54:WU01:FS01:0x15:Build host             AmoebaRemote
01:28:54:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
01:28:54:WU01:FS01:0x15:Core                   15
01:28:54:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:28:54:WU01:FS01:0x15:Window's signal control handler registered.
01:28:54:WU01:FS01:0x15:Preparing to commence simulation
01:28:54:WU01:FS01:0x15:- Looking at optimizations...
01:28:54:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
01:28:54:WU01:FS01:0x15:- Created dyn
01:28:54:WU01:FS01:0x15:- Files status OK
01:28:54:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:28:54:WU01:FS01:0x15:- Expanded 124917 -> 502918 (decompressed 402.6 percent)
01:28:54:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124917 data_size=502918, decompressed_data_size=502918 diff=0
01:28:54:WU01:FS01:0x15:- Digital signature verified
01:28:54:WU01:FS01:0x15:Project: 7625 (Run 162, Clone 0, Gen 216)
01:28:54:WU01:FS01:0x15:Assembly optimizations on if available.
01:28:54:WU01:FS01:0x15:Entering M.D.
01:28:56:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  3698933742 3279887221 3469712472 499215661 891839263
01:28:56:WU01:FS01:0x15:GPU device id=1
01:28:56:WU01:FS01:0x15:Working on Protein
01:28:56:WU01:FS01:0x15:Client config unavailable.
01:28:56:WU01:FS01:0x15:Starting GUI Server
01:29:57:WU01:FS01:0x15:Finished fah_main status=59
01:29:57:WU01:FS01:0x15:mdrun_gpu returned 59
01:29:57:WU01:FS01:0x15:GPU memtest failure
01:29:57:WU01:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
01:29:57:WARNING:WU01:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:29:57:WARNING:WU01:FS01:Too many errors, failing
01:29:57:WU01:FS01:Sending unit results: id:01 state:SEND error:FAILED project:7625 run:162 clone:0 gen:216 core:0x15 unit:0x0000012d664f2dd14fe6160f228262fd
01:29:57:WU01:FS01:Connecting to 171.64.65.105:8080
01:29:58:WU01:FS01:Server responded WORK_QUIT (404)
01:29:58:WARNING:WU01:FS01:Server did not like results, dumping
01:29:58:WU01:FS01:Cleaning up
01:29:58:WU04:FS01:Connecting to assign-GPU.stanford.edu:80
01:29:58:WU04:FS01:News: Welcome to Folding@Home
01:29:58:WU04:FS01:Assigned to work server 171.64.65.105
01:29:58:WU04:FS01:Requesting new work unit for slot 01: READY gpu:1:GF110 [GeForce GTX 590] from 171.64.65.105
01:29:58:WU04:FS01:Connecting to 171.64.65.105:8080
01:29:58:WU04:FS01:Downloading 78.78KiB
01:29:58:WU04:FS01:Download complete
01:29:59:WU04:FS01:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:7660 run:300 clone:0 gen:348 core:0x15 unit:0x000002be664f2dd150f83f5008b16b54
01:29:59:WU04:FS01:Starting
01:29:59:WU04:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:29:59:WU04:FS01:Started FahCore on PID 11116
01:29:59:Started thread 15 on PID 9812
01:29:59:WU04:FS01:Core PID:11128
01:29:59:WU04:FS01:FahCore 0x15 started
01:29:59:WU04:FS01:0x15:
01:29:59:WU04:FS01:0x15:*------------------------------*
01:29:59:WU04:FS01:0x15:Folding@Home GPU Core
01:29:59:WU04:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:29:59:WU04:FS01:0x15:Build host             AmoebaRemote
01:29:59:WU04:FS01:0x15:Board Type             NVIDIA/CUDA
01:29:59:WU04:FS01:0x15:Core                   15
01:29:59:WU04:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:29:59:WU04:FS01:0x15:Window's signal control handler registered.
01:29:59:WU04:FS01:0x15:Preparing to commence simulation
01:29:59:WU04:FS01:0x15:- Looking at optimizations...
01:29:59:WU04:FS01:0x15:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
01:29:59:WU04:FS01:0x15:- Created dyn
01:29:59:WU04:FS01:0x15:- Files status OK
01:29:59:WU04:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:29:59:WU04:FS01:0x15:- Expanded 80159 -> 307810 (decompressed 383.9 percent)
01:29:59:WU04:FS01:0x15:Called DecompressByteArray: compressed_data_size=80159 data_size=307810, decompressed_data_size=307810 diff=0
01:29:59:WU04:FS01:0x15:- Digital signature verified
01:29:59:WU04:FS01:0x15:Project: 7660 (Run 300, Clone 0, Gen 348)
01:29:59:WU04:FS01:0x15:Assembly optimizations on if available.
01:29:59:WU04:FS01:0x15:Entering M.D.
01:30:01:WU04:FS01:0x15:Tpr hash 04/wudata_01.tpr:  1438349217 23977469 1270997619 2170668314 2861248100
01:30:01:WU04:FS01:0x15:GPU device id=1
01:30:01:WU04:FS01:0x15:Working on Protein
01:30:01:WU04:FS01:0x15:Client config unavailable.
01:30:01:WU04:FS01:0x15:Starting GUI Server
01:30:05:WU03:FS03:0xa3:Completed 5000 out of 500000 steps  (1%)
01:31:01:WU04:FS01:0x15:Finished fah_main status=59
01:31:01:WU04:FS01:0x15:mdrun_gpu returned 59
01:31:01:WU04:FS01:0x15:GPU memtest failure
01:31:01:WU04:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
01:31:02:WARNING:WU04:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:31:02:WU04:FS01:Starting
01:31:02:WU04:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:31:02:WU04:FS01:Started FahCore on PID 10324
01:31:02:Started thread 16 on PID 9812
01:31:02:WU04:FS01:Core PID:10340
01:31:02:WU04:FS01:FahCore 0x15 started
01:31:02:WU04:FS01:0x15:
01:31:02:WU04:FS01:0x15:*------------------------------*
01:31:02:WU04:FS01:0x15:Folding@Home GPU Core
01:31:02:WU04:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:31:02:WU04:FS01:0x15:Build host             AmoebaRemote
01:31:02:WU04:FS01:0x15:Board Type             NVIDIA/CUDA
01:31:02:WU04:FS01:0x15:Core                   15
01:31:02:WU04:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:31:02:WU04:FS01:0x15:Window's signal control handler registered.
01:31:02:WU04:FS01:0x15:Preparing to commence simulation
01:31:02:WU04:FS01:0x15:- Looking at optimizations...
01:31:02:WU04:FS01:0x15:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
01:31:02:WU04:FS01:0x15:- Created dyn
01:31:02:WU04:FS01:0x15:- Files status OK
01:31:02:WU04:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:31:02:WU04:FS01:0x15:- Expanded 80159 -> 307810 (decompressed 383.9 percent)
01:31:02:WU04:FS01:0x15:Called DecompressByteArray: compressed_data_size=80159 data_size=307810, decompressed_data_size=307810 diff=0
01:31:02:WU04:FS01:0x15:- Digital signature verified
01:31:02:WU04:FS01:0x15:Project: 7660 (Run 300, Clone 0, Gen 348)
01:31:02:WU04:FS01:0x15:Assembly optimizations on if available.
01:31:02:WU04:FS01:0x15:Entering M.D.
01:31:04:WU04:FS01:0x15:Tpr hash 04/wudata_01.tpr:  1438349217 23977469 1270997619 2170668314 2861248100
01:31:04:WU04:FS01:0x15:GPU device id=1
01:31:04:WU04:FS01:0x15:Working on Protein
01:31:04:WU04:FS01:0x15:Client config unavailable.
01:31:04:WU04:FS01:0x15:Starting GUI Server
01:32:05:WU04:FS01:0x15:Finished fah_main status=59
01:32:05:WU04:FS01:0x15:mdrun_gpu returned 59
01:32:05:WU04:FS01:0x15:GPU memtest failure
01:32:05:WU04:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
01:32:05:WARNING:WU04:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:32:05:WU04:FS01:Starting
01:32:05:WU04:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:32:05:WU04:FS01:Started FahCore on PID 9628
01:32:05:Started thread 17 on PID 9812
01:32:05:WU04:FS01:Core PID:9396
01:32:05:WU04:FS01:FahCore 0x15 started
01:32:06:WU04:FS01:0x15:
01:32:06:WU04:FS01:0x15:*------------------------------*
01:32:06:WU04:FS01:0x15:Folding@Home GPU Core
01:32:06:WU04:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:32:06:WU04:FS01:0x15:Build host             AmoebaRemote
01:32:06:WU04:FS01:0x15:Board Type             NVIDIA/CUDA
01:32:06:WU04:FS01:0x15:Core                   15
01:32:06:WU04:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:32:06:WU04:FS01:0x15:Window's signal control handler registered.
01:32:06:WU04:FS01:0x15:Preparing to commence simulation
01:32:06:WU04:FS01:0x15:- Looking at optimizations...
01:32:06:WU04:FS01:0x15:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
01:32:06:WU04:FS01:0x15:- Created dyn
01:32:06:WU04:FS01:0x15:- Files status OK
01:32:06:WU04:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:32:06:WU04:FS01:0x15:- Expanded 80159 -> 307810 (decompressed 383.9 percent)
01:32:06:WU04:FS01:0x15:Called DecompressByteArray: compressed_data_size=80159 data_size=307810, decompressed_data_size=307810 diff=0
01:32:06:WU04:FS01:0x15:- Digital signature verified
01:32:06:WU04:FS01:0x15:Project: 7660 (Run 300, Clone 0, Gen 348)
01:32:06:WU04:FS01:0x15:Assembly optimizations on if available.
01:32:06:WU04:FS01:0x15:Entering M.D.
01:32:07:WU04:FS01:0x15:Tpr hash 04/wudata_01.tpr:  1438349217 23977469 1270997619 2170668314 2861248100
01:32:07:WU04:FS01:0x15:GPU device id=1
01:32:07:WU04:FS01:0x15:Working on Protein
01:32:07:WU04:FS01:0x15:Client config unavailable.
01:32:08:WU04:FS01:0x15:Starting GUI Server
01:33:08:WARNING:WU04:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:33:08:WU04:FS01:Starting
01:33:08:WU04:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:33:08:WU04:FS01:Started FahCore on PID 9860
01:33:08:Started thread 18 on PID 9812
01:33:08:WU04:FS01:Core PID:1660
01:33:08:WU04:FS01:FahCore 0x15 started
01:33:09:WU04:FS01:0x15:
01:33:09:WU04:FS01:0x15:*------------------------------*
01:33:09:WU04:FS01:0x15:Folding@Home GPU Core
01:33:09:WU04:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:33:09:WU04:FS01:0x15:Build host             AmoebaRemote
01:33:09:WU04:FS01:0x15:Board Type             NVIDIA/CUDA
01:33:09:WU04:FS01:0x15:Core                   15
01:33:09:WU04:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:33:09:WU04:FS01:0x15:Window's signal control handler registered.
01:33:09:WU04:FS01:0x15:Preparing to commence simulation
01:33:09:WU04:FS01:0x15:- Looking at optimizations...
01:33:09:WU04:FS01:0x15:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
01:33:09:WU04:FS01:0x15:- Created dyn
01:33:09:WU04:FS01:0x15:- Files status OK
01:33:09:WU04:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:33:09:WU04:FS01:0x15:- Expanded 80159 -> 307810 (decompressed 383.9 percent)
01:33:09:WU04:FS01:0x15:Called DecompressByteArray: compressed_data_size=80159 data_size=307810, decompressed_data_size=307810 diff=0
01:33:09:WU04:FS01:0x15:- Digital signature verified
01:33:09:WU04:FS01:0x15:Project: 7660 (Run 300, Clone 0, Gen 348)
01:33:09:WU04:FS01:0x15:Assembly optimizations on if available.
01:33:09:WU04:FS01:0x15:Entering M.D.
01:33:11:WU04:FS01:0x15:Tpr hash 04/wudata_01.tpr:  1438349217 23977469 1270997619 2170668314 2861248100
01:33:11:WU04:FS01:0x15:GPU device id=1
01:33:11:WU04:FS01:0x15:Working on Protein
01:33:11:WU04:FS01:0x15:Client config unavailable.
01:33:11:WU04:FS01:0x15:Starting GUI Server
01:34:11:WARNING:WU04:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:34:11:WU04:FS01:Starting
01:34:11:WU04:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 04 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:34:11:WU04:FS01:Started FahCore on PID 10684
01:34:11:Started thread 19 on PID 9812
01:34:11:WU04:FS01:Core PID:10656
01:34:11:WU04:FS01:FahCore 0x15 started
01:34:12:WU04:FS01:0x15:
01:34:12:WU04:FS01:0x15:*------------------------------*
01:34:12:WU04:FS01:0x15:Folding@Home GPU Core
01:34:12:WU04:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:34:12:WU04:FS01:0x15:Build host             AmoebaRemote
01:34:12:WU04:FS01:0x15:Board Type             NVIDIA/CUDA
01:34:12:WU04:FS01:0x15:Core                   15
01:34:12:WU04:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:34:12:WU04:FS01:0x15:Window's signal control handler registered.
01:34:12:WU04:FS01:0x15:Preparing to commence simulation
01:34:12:WU04:FS01:0x15:- Looking at optimizations...
01:34:12:WU04:FS01:0x15:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
01:34:12:WU04:FS01:0x15:- Created dyn
01:34:12:WU04:FS01:0x15:- Files status OK
01:34:12:WU04:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:34:12:WU04:FS01:0x15:- Expanded 80159 -> 307810 (decompressed 383.9 percent)
01:34:12:WU04:FS01:0x15:Called DecompressByteArray: compressed_data_size=80159 data_size=307810, decompressed_data_size=307810 diff=0
01:34:12:WU04:FS01:0x15:- Digital signature verified
01:34:12:WU04:FS01:0x15:Project: 7660 (Run 300, Clone 0, Gen 348)
01:34:12:WU04:FS01:0x15:Assembly optimizations on if available.
01:34:12:WU04:FS01:0x15:Entering M.D.
01:34:14:WU04:FS01:0x15:Tpr hash 04/wudata_01.tpr:  1438349217 23977469 1270997619 2170668314 2861248100
01:34:14:WU04:FS01:0x15:GPU device id=1
01:34:14:WU04:FS01:0x15:Working on Protein
01:34:14:WU04:FS01:0x15:Client config unavailable.
01:34:14:WU04:FS01:0x15:Starting GUI Server
01:35:14:WU04:FS01:0x15:Finished fah_main status=59
01:35:14:WU04:FS01:0x15:mdrun_gpu returned 59
01:35:14:WU04:FS01:0x15:GPU memtest failure
01:35:14:WU04:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
01:35:14:WARNING:WU04:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
01:35:14:WARNING:WU04:FS01:Too many errors, failing
01:35:14:WU04:FS01:Sending unit results: id:04 state:SEND error:FAILED project:7660 run:300 clone:0 gen:348 core:0x15 unit:0x000002be664f2dd150f83f5008b16b54
01:35:14:WU04:FS01:Connecting to 171.64.65.105:8080
01:35:15:WU04:FS01:Server responded WORK_QUIT (404)
01:35:15:WARNING:WU04:FS01:Server did not like results, dumping
01:35:15:WU04:FS01:Cleaning up
01:35:15:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
01:35:15:WU01:FS01:News: Welcome to Folding@Home
01:35:15:WU01:FS01:Assigned to work server 171.64.65.105
01:35:15:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GF110 [GeForce GTX 590] from 171.64.65.105
01:35:15:WU01:FS01:Connecting to 171.64.65.105:8080
01:35:16:WU01:FS01:Downloading 122.63KiB
01:35:16:WU01:FS01:Download complete
01:35:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7625 run:227 clone:0 gen:226 core:0x15 unit:0x00000181664f2dd14fe6166f2424c23d
01:35:16:WU01:FS01:Starting
01:35:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/LIVE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 9812 -checkpoint 12 -gpu 1 -gpu-vendor nvidia
01:35:16:WU01:FS01:Started FahCore on PID 10520
01:35:16:Started thread 20 on PID 9812
01:35:16:WU01:FS01:Core PID:7492
01:35:16:WU01:FS01:FahCore 0x15 started
01:35:16:WU01:FS01:0x15:
01:35:16:WU01:FS01:0x15:*------------------------------*
01:35:16:WU01:FS01:0x15:Folding@Home GPU Core
01:35:16:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
01:35:16:WU01:FS01:0x15:Build host             AmoebaRemote
01:35:16:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
01:35:16:WU01:FS01:0x15:Core                   15
01:35:16:WU01:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
01:35:16:WU01:FS01:0x15:Window's signal control handler registered.
01:35:16:WU01:FS01:0x15:Preparing to commence simulation
01:35:16:WU01:FS01:0x15:- Looking at optimizations...
01:35:16:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
01:35:16:WU01:FS01:0x15:- Created dyn
01:35:16:WU01:FS01:0x15:- Files status OK
01:35:16:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:35:16:WU01:FS01:0x15:- Expanded 125066 -> 502918 (decompressed 402.1 percent)
01:35:16:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=125066 data_size=502918, decompressed_data_size=502918 diff=0
01:35:16:WU01:FS01:0x15:- Digital signature verified
01:35:16:WU01:FS01:0x15:Project: 7625 (Run 227, Clone 0, Gen 226)
01:35:16:WU01:FS01:0x15:Assembly optimizations on if available.
01:35:16:WU01:FS01:0x15:Entering M.D.
01:35:18:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  3470996195 2697757964 1373095664 599128033 2587983246
01:35:18:WU01:FS01:0x15:GPU device id=1
01:35:18:WU01:FS01:0x15:Working on Protein
01:35:18:WU01:FS01:0x15:Client config unavailable.
01:35:18:WU01:FS01:0x15:Starting GUI Server
GPU-Z is showing the following in order:
GTX 590 0% GPU LOAD
GTX 590 99% GPU LOAD
GTX 280 at 76% GPU LOAD
Just a minute ago all GPU's seemed to be working and I added the CPU in there and now the GTX 280 & first GTX 590 in Folding Client aren't doing anything, yet GPU-Z shows the 280 to be busy....???
Help?
Re: Conflicting results from Client & Info from GPU-Z
Welcome to the F@H Forum turkish2,
Please note that using the default verbosity level of 3 is recommended as it only shows the changes from default in the log. With verbosity level 5, it prints all the settings so finding out what settings have changed is rather difficult. Thus, can you please change it from 5 to 3?
Given that you have Non-Fermi and Fermi GPUs in a single system, it is quite possible that the GPU Slots aren't mapped correctly to the actual physical slots. Moreover, a possible reason that your GPU has stopped is because you were getting repeated failures:
I would suggest that you read these two posts which deal with setting up GPU Slots in a mixed environment (viewtopic.php?f=67&t=19989&p=199379#p199379) and (viewtopic.php?f=61&t=24125#p241145). If you need additional information to help you with the setup, feel free to ask.
