Linux Install Errors Out
perseus778
Post by perseus778 »
sudo dpkg -i --force-depends fahclient_7.3.6_amd64.deb
[sudo] password for perseus778:
Selecting previously unselected package fahclient.
(Reading database ... 136173 files and directories currently installed.)
Unpacking fahclient (from fahclient_7.3.6_amd64.deb) ...
Adding system user fahclient...done
Setting up fahclient (7.3.6) ...
update-rc.d: error: no runlevel symlinks to modify, aborting!
dpkg: error processing fahclient (--install):
subprocess installed post-installation script returned error exit status 1
Processing triggers for gnome-menus ...
Processing triggers for desktop-file-utils ...
Processing triggers for mime-support ...
Errors were encountered while processing:
fahclient
Re: Linux Install Errors Out
Welcome to the folding forum, perseus778.
What flavor and version of Linux? Did you follow the Linux install guide?
perseus778
Debian Jessie. I followed the guide (manual install since this distro doesn't have a extra-repository package installer).
bollix47
Post by bollix47 »
I gave Jessie a try in VirtualBox and here is what I found:
One of the first things I did was add my user name to sudoers(this may have been part of the problem if you were trying to set up a service install .. i.e. start automatically ... as users are not allowed to use sudo by default in this version of linux).
Open a root terminal by typing terminal in the Activities search window:
adduser yourusername sudo
For the installers I did a right click on them and selected Open with gdebi.
I entered my identity info but removed the check in start automatically since I was testing and didn't want anything to start automatically.
The FAHClient installer terminal log did show an error status code 1 but didn't explain the cause of error. However, the client did install. I then created a sub-folder called fah in my home folder, switched to it and typed FAHClient. The client paused because there was no config.xml file in that folder. I should have copied config.xml from /etc/fahclient to my /home/username/fah first. My first connection attempt to the assignment server did time out for some unexplained reason but after the time out (~2 minutes) everything worked as expected.
FAHControl did install using gdebi with no problems and when I first ran it there was a message saying my identity was not setup and asking for the info which I did enter again. After doing so the client downloaded a work unit and commenced processing.
The client appears to be running fine and the work unit is showing progress in the log.
