This has been an on and off problem for about two weeks.
Server 171.64.65.98 out of WUs
I am successfully connecting to 171.64.65.98 but not getting a GPU WU.
Re: Server 171.64.65.98 out of WUs
That server is working fine here and has been for some time.
Please post your log including the System Info and Config sections and a portion of the log showing the failure to get a work unit.
Typical! The moment I make a post about not getting a WU, I get a WU. It was about 11 hours of no WU.
Here is a representative section of the log.
18:17:10:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:17:10:WU00:FS00:News: Welcome to Folding@Home
18:17:10:WU00:FS00:Assigned to work server 171.64.65.98
18:17:10:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.98
18:17:10:WU00:FS00:Connecting to 171.64.65.98:8080
18:17:13:ERROR:WU00:FS00:Exception: Server did not assign work unit
commissar0617
client-tye: advanced set? core_16 is EOL. i'm running core_17 on my 7970 just fine.
Back to problems getting both CPU and GPU WUs. I generally have to go 40 to 70 tries to get a WU to fold.
Once I get a WU everything is fine.
Is there a shortage of WUs?
Again, post your log. Include the beginning section that shows the version of the client, the system information and the folding configuration. There are WU's available and the servers have been supplying them to systems capable of processing them. Since CPU assignments would be coming from different servers than for your GPU, the causes for your problems might be related or not.
OK, here you go. The initial start up plus a recent issue with a server.
*********************** Log Started 2013-10-06T00:27:09Z ***********************
00:27:09:************************* Folding@home Client *************************
00:27:09: Website: http://folding.stanford.edu/
00:27:09: Copyright: (c) 2009-2013 Stanford University
00:27:09: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:27:09: Args: --open-web-control
00:27:09: Config: C:/ProgramData/FAHClient/config.xml
00:27:09:******************************** Build ********************************
00:27:09: Version: 7.3.6
00:27:09: Date: Feb 18 2013
00:27:09: Time: 15:25:17
00:27:09: SVN Rev: 3923
00:27:09: Branch: fah/trunk/client
00:27:09: Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:27:09: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:27:09: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:27:09: Platform: win32 XP
00:27:09: Bits: 32
00:27:09: Mode: Release
00:27:09:******************************* System ********************************
00:27:09: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
00:27:09: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
00:27:09: CPUs: 8
00:27:09: Memory: 7.96GiB
00:27:09: Free Memory: 5.62GiB
00:27:09: Threads: WINDOWS_THREADS
00:27:09: Has Battery: false
00:27:09: On Battery: false
00:27:09: UTC offset: -4
00:27:09: PID: 6764
00:27:09: CWD: C:/ProgramData/FAHClient
00:27:09: OS: Windows 7 Professional
00:27:09: OS Arch: AMD64
00:27:09: GPUs: 1
00:27:09: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
00:27:09: CUDA: Not detected
00:27:09:Win32 Service: false
00:27:09:***********************************************************************
00:27:09:<config>
00:27:09: <service-description v='Folding@home Client'/>
00:27:09: <service-restart v='true'/>
00:27:09: <service-restart-delay v='5000'/>
00:27:09:
00:27:09: <!-- Client Control -->
00:27:09: <client-threads v='4'/>
00:27:09: <cycle-rate v='4'/>
00:27:09: <cycles v='-1'/>
00:27:09: <data-directory v='.'/>
00:27:09: <disable-sleep-when-active v='true'/>
00:27:09: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
00:27:09: <exit-when-done v='false'/>
00:27:09: <fold-anon v='false'/>
00:27:09: <open-web-control v='true'/>
00:27:09:
00:27:09: <!-- Configuration -->
00:27:09: <config-rotate v='true'/>
00:27:09: <config-rotate-dir v='configs'/>
00:27:09: <config-rotate-max v='16'/>
00:27:09:
00:27:09: <!-- Debugging -->
00:27:09: <assignment-servers>
00:27:09: assign3.stanford.edu:8080 assign4.stanford.edu:80
00:27:09: </assignment-servers>
00:27:09: <capture-directory v='capture'/>
00:27:09: <capture-on-error v='false'/>
00:27:09: <capture-packets v='false'/>
00:27:09: <capture-requests v='false'/>
00:27:09: <capture-responses v='false'/>
00:27:09: <capture-sockets v='false'/>
00:27:09: <debug-sockets v='false'/>
00:27:09: <exception-locations v='true'/>
00:27:09: <gpu-assignment-servers>
00:27:09: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
00:27:09: </gpu-assignment-servers>
00:27:09: <stack-traces v='false'/>
00:27:09:
00:27:09: <!-- Error Handling -->
00:27:09: <max-slot-errors v='5'/>
00:27:09: <max-unit-errors v='5'/>
00:27:09:
00:27:09: <!-- Folding Core -->
00:27:09: <checkpoint v='15'/>
00:27:09: <core-dir v='cores'/>
00:27:09: <core-priority v='low'/>
00:27:09: <cpu-affinity v='false'/>
00:27:09: <cpu-usage v='100'/>
00:27:09: <gpu-usage v='100'/>
00:27:09: <no-assembly v='false'/>
00:27:09:
00:27:09: <!-- Folding Slot Configuration -->
00:27:09: <cause v='ANY'/>
00:27:09: <client-subtype v='STDCLI'/>
00:27:09: <client-type v='advanced'/>
00:27:09: <cpu-species v='X86_PENTIUM_II'/>
00:27:09: <cpu-type v='AMD64'/>
00:27:09: <cpus v='-1'/>
00:27:09: <cuda-index v='0'/>
00:27:09: <gpu v='true'/>
00:27:09: <max-packet-size v='normal'/>
00:27:09: <opencl-index v='0'/>
00:27:09: <os-species v='UNKNOWN'/>
00:27:09: <os-type v='WIN32'/>
00:27:09: <power v='full'/>
00:27:09: <project-key v='0'/>
00:27:09: <smp v='true'/>
00:27:09:
00:27:09: <!-- HTTP Server -->
00:27:09: <allow v='127.0.0.1'/>
00:27:09: <connection-timeout v='60'/>
00:27:09: <deny v='0/0'/>
00:27:09: <http-addresses v='0:7396'/>
00:27:09: <https-addresses v=''/>
00:27:09: <max-connect-time v='900'/>
00:27:09: <max-connections v='800'/>
00:27:09: <max-request-length v='52428800'/>
00:27:09: <min-connect-time v='300'/>
00:27:09: <threads v='8'/>
00:27:09:
00:27:09: <!-- Logging -->
00:27:09: <log v='log.txt'/>
00:27:09: <log-color v='false'/>
00:27:09: <log-crlf v='true'/>
00:27:09: <log-date v='false'/>
00:27:09: <log-date-periodically v='21600'/>
00:27:09: <log-debug v='true'/>
00:27:09: <log-domain v='false'/>
00:27:09: <log-header v='true'/>
00:27:09: <log-level v='true'/>
00:27:09: <log-no-info-header v='true'/>
00:27:09: <log-redirect v='false'/>
00:27:09: <log-rotate v='true'/>
00:27:09: <log-rotate-dir v='logs'/>
00:27:09: <log-rotate-max v='16'/>
00:27:09: <log-short-level v='false'/>
00:27:09: <log-simple-domains v='true'/>
00:27:09: <log-thread-id v='false'/>
00:27:09: <log-thread-prefix v='true'/>
00:27:09: <log-time v='true'/>
00:27:09: <log-to-screen v='true'/>
00:27:09: <log-truncate v='false'/>
00:27:09: <verbosity v='4'/>
00:27:09:
00:27:09: <!-- Network -->
00:27:09: <proxy v=':8080'/>
00:27:09: <proxy-enable v='false'/>
00:27:09: <proxy-pass v=''/>
00:27:09: <proxy-user v=''/>
00:27:09:
00:27:09: <!-- Process Control -->
00:27:09: <child v='false'/>
00:27:09: <daemon v='false'/>
00:27:09: <pid v='false'/>
00:27:09: <pid-file v='Folding@home Client.pid'/>
00:27:09: <respawn v='false'/>
00:27:09: <service v='false'/>
00:27:09:
00:27:09: <!-- Remote Command Server -->
00:27:09: <command-address v='0.0.0.0'/>
00:27:09: <command-allow-no-pass v='127.0.0.1'/>
00:27:09: <command-deny-no-pass v='0/0'/>
00:27:09: <command-port v='36330'/>
00:27:09:
00:27:09: <!-- Slot Control -->
00:27:09: <idle v='false'/>
00:27:09: <max-shutdown-wait v='60'/>
00:27:09: <pause-on-battery v='true'/>
00:27:09: <pause-on-start v='false'/>
00:27:09:
00:27:09: <!-- User Information -->
00:27:09: <machine-id v='0'/>
00:27:09: <passkey v='********************************'/>
00:27:09: <team v='36120'/>
00:27:09: <user v='LonePalm'/>
00:27:09:
00:27:09: <!-- Web Server -->
00:27:09: <session-timeout v='3600'/>
00:27:09: <web-allow v='127.0.0.1'/>
00:27:09: <web-deny v='0/0'/>
00:27:09:
00:27:09: <!-- Work Unit Control -->
00:27:09: <dump-after-deadline v='true'/>
00:27:09: <max-queue v='16'/>
00:27:09: <max-units v='0'/>
00:27:09: <next-unit-percentage v='99'/>
00:27:09:
00:27:09: <!-- Folding Slots -->
00:27:09: <slot id='0' type='GPU'>
00:27:09: <client-type v='beta'/>
00:27:09: <next-unit-percentage v='100'/>
00:27:09: </slot>
00:27:09: <slot id='1' type='CPU'>
00:27:09: </slot>
00:27:09:</config>
00:27:09:Trying to access database...
00:27:09:Successfully acquired database lock
00:27:09:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
00:27:09:Enabled folding slot 01: READY cpu:7
00:27:09:WU01:FS00:Starting
00:27:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:27:09:WU01:FS00:Started FahCore on PID 1564
00:27:11:WU01:FS00:Core PID:1952
00:27:11:WU01:FS00:FahCore 0x17 started
00:27:11:WU00:FS01:Starting
00:27:11:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 6764 -checkpoint 15 -np 7
00:27:11:WU00:FS01:Started FahCore on PID 5412
00:27:14:WU01:FS00:0x17:*********************** Log Started 2013-10-06T00:27:14Z ***********************
00:27:14:WU01:FS00:0x17:Project: 8900 (Run 467, Clone 1, Gen 162)
00:27:14:WU01:FS00:0x17:Unit: 0x000000c5028c126651a68e897c146981
00:27:14:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:27:14:WU01:FS00:0x17:Machine: 0
00:27:14:WU01:FS00:0x17:Digital signatures verified
00:27:15:WU01:FS00:0x17: Found a checkpoint file
00:27:15:WU00:FS01:Core PID:3628
00:27:15:WU00:FS01:FahCore 0xa3 started
00:27:16:WU00:FS01:0xa3:
00:27:16:WU00:FS01:0xa3:*------------------------------*
00:27:16:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
00:27:16:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
00:27:16:WU00:FS01:0xa3:Preparing to commence simulation
00:27:16:WU00:FS01:0xa3:- Ensuring status. Please wait.
00:27:21:2:127.0.0.1 GET /ping?_=1381019241472&callback=jQuery19008194399558602764_1381019241471
00:27:22:3:127.0.0.1 GET /?nocache=0.05890829551768406
00:27:23:4:127.0.0.1 GET /images/report-bug.png
00:27:24:5:127.0.0.1 GET /css/style.css?nocache=0.7163026050582443
00:27:25:6:127.0.0.1 GET /js/main.js?nocache=0.0439808982313028
00:27:25:6:127.0.0.1:New Web connection
00:27:25:7:127.0.0.1 GET /images/twitter.png
00:27:25:WU00:FS01:0xa3:- Looking at optimizations...
00:27:25:WU00:FS01:0xa3:- Working with standard loops on this execution.
00:27:25:WU00:FS01:0xa3:- Previous termination of core was improper.
00:27:25:WU00:FS01:0xa3:- Going to use standard loops.
00:27:25:WU00:FS01:0xa3:- Files status OK
00:27:25:WU00:FS01:0xa3:- Expanded 3552471 -> 3880552 (decompressed 109.2 percent)
00:27:25:8:127.0.0.1 GET /images/mail.png
00:27:25:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3552471 data_size=3880552, decompressed_data_size=3880552 diff=0
00:27:25:WU00:FS01:0xa3:- Digital signature verified
00:27:25:WU00:FS01:0xa3:Project: 7505 (Run 0, Clone 36, Gen 257)
00:27:25:WU00:FS01:0xa3:Entering M.D.
00:27:26:9:127.0.0.1 GET /images/header.png
00:27:26:10:127.0.0.1 GET /images/fah-logo.png
00:27:27:11:127.0.0.1 GET /api/updates/set?sid=0x261e1d3fd64802e94d9e394d6a14ffd4&update_id=0&update_path=/api/basic&update_rate=1
00:27:28:12:127.0.0.1 GET /api/updates/set?sid=0x261e1d3fd64802e94d9e394d6a14ffd4&update_id=1&update_path=/api/slots&update_rate=1
00:27:31:WU00:FS01:0xa3:Using Gromacs checkpoints
00:27:32:WU00:FS01:0xa3:Mapping NT from 7 to 7
00:27:33:WU00:FS01:0xa3:Resuming from checkpoint
00:27:33:WU00:FS01:0xa3:Verified 00/wudata_01.log
00:27:35:WU00:FS01:0xa3:Verified 00/wudata_01.trr
00:27:35:WU00:FS01:0xa3:Verified 00/wudata_01.xtc
00:27:35:WU00:FS01:0xa3:Verified 00/wudata_01.edr
00:27:35:WU00:FS01:0xa3:Completed 885700 out of 1000000 steps (88%)
00:30:13:WU01:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
00:34:50:WU01:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
00:35:07:WU00:FS01:0xa3:Completed 890000 out of 1000000 steps (89%)
00:39:06:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
00:39:07:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
00:39:07:WU02:FS00:News: Welcome to Folding@Home
00:39:07:WU02:FS00:Assigned to work server 171.64.65.69
00:39:07:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
00:39:07:WU02:FS00:Connecting to 171.64.65.69:8080
00:39:11:WU02:FS00:Downloading 4.18MiB
00:39:11:WU02:FS00:Download complete
00:39:11:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:768 clone:0 gen:152 core:0x17 unit:0x000000bf028c126651a6d1746c56c890
00:39:27:WU01:FS00:0x17:Saving result file logfile_01.txt
00:39:27:WU01:FS00:0x17:Saving result file checkpointState.xml
00:39:29:WU01:FS00:0x17:Saving result file checkpt.crc
00:39:29:WU01:FS00:0x17:Saving result file log.txt
00:39:29:WU01:FS00:0x17:Saving result file positions.xtc
00:39:32:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
08:07:32:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:07:32:WU00:FS00:News: Welcome to Folding@Home
08:07:32:WU00:FS00:Assigned to work server 171.64.65.69
08:07:32:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:07:32:WU00:FS00:Connecting to 171.64.65.69:8080
08:07:35:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:07:36:WU02:FS00:Upload 73.32%
08:07:42:WU02:FS00:Upload 83.93%
08:07:48:WU02:FS00:Upload 96.47%
08:07:58:WU02:FS00:Upload complete
08:07:58:WU02:FS00:Server responded WORK_ACK (400)
08:07:58:WU02:FS00:Final credit estimate, 27604.00 points
08:07:58:WU02:FS00:Cleaning up
08:09:09:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:09:09:WU00:FS00:News: Welcome to Folding@Home
08:09:09:WU00:FS00:Assigned to work server 171.64.65.69
08:09:09:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:09:09:WU00:FS00:Connecting to 171.64.65.69:8080
08:09:13:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:11:46:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:11:46:WU00:FS00:News: Welcome to Folding@Home
08:11:46:WU00:FS00:Assigned to work server 171.64.65.69
08:11:46:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:11:46:WU00:FS00:Connecting to 171.64.65.69:8080
08:11:50:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:12:33:WU01:FS01:0xa4:Completed 400000 out of 2500000 steps (16%)
08:16:00:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:16:00:WU00:FS00:News: Welcome to Folding@Home
08:16:00:WU00:FS00:Assigned to work server 171.64.65.69
08:16:00:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:16:00:WU00:FS00:Connecting to 171.64.65.69:8080
08:16:04:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:22:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:22:52:WU00:FS00:News: Welcome to Folding@Home
08:22:52:WU00:FS00:Assigned to work server 171.64.65.69
08:22:52:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:22:52:WU00:FS00:Connecting to 171.64.65.69:8080
08:22:56:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:29:22:WU01:FS01:0xa4:Completed 425000 out of 2500000 steps (17%)
08:33:57:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:33:57:WU00:FS00:News: Welcome to Folding@Home
08:33:57:WU00:FS00:Assigned to work server 171.64.65.69
08:33:57:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:33:57:WU00:FS00:Connecting to 171.64.65.69:8080
08:34:01:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:46:11:WU01:FS01:0xa4:Completed 450000 out of 2500000 steps (18%)
08:51:54:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
08:51:54:WU00:FS00:News: Welcome to Folding@Home
08:51:54:WU00:FS00:Assigned to work server 171.64.65.69
08:51:54:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
08:51:54:WU00:FS00:Connecting to 171.64.65.69:8080
08:51:58:ERROR:WU00:FS00:Exception: Server did not assign work unit
09:03:04:WU01:FS01:0xa4:Completed 475000 out of 2500000 steps (19%)
09:19:55:WU01:FS01:0xa4:Completed 500000 out of 2500000 steps (20%)
09:20:56:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
09:20:56:WU00:FS00:News: Welcome to Folding@Home
09:20:56:WU00:FS00:Assigned to work server 171.64.65.69
09:20:56:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
09:20:56:WU00:FS00:Connecting to 171.64.65.69:8080
09:21:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
09:36:48:WU01:FS01:0xa4:Completed 525000 out of 2500000 steps (21%)
09:53:39:WU01:FS01:0xa4:Completed 550000 out of 2500000 steps (22%)
10:07:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
10:07:55:WU00:FS00:News: Welcome to Folding@Home
10:07:55:WU00:FS00:Assigned to work server 171.64.65.69
10:07:55:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
10:07:55:WU00:FS00:Connecting to 171.64.65.69:8080
10:07:59:ERROR:WU00:FS00:Exception: Server did not assign work unit
10:10:31:WU01:FS01:0xa4:Completed 575000 out of 2500000 steps (23%)
10:27:21:WU01:FS01:0xa4:Completed 600000 out of 2500000 steps (24%)
10:44:11:WU01:FS01:0xa4:Completed 625000 out of 2500000 steps (25%)
11:01:03:WU01:FS01:0xa4:Completed 650000 out of 2500000 steps (26%)
11:17:53:WU01:FS01:0xa4:Completed 675000 out of 2500000 steps (27%)
11:23:56:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:23:56:WU00:FS00:News: Welcome to Folding@Home
11:23:56:WU00:FS00:Assigned to work server 171.64.65.69
11:23:56:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
11:23:56:WU00:FS00:Connecting to 171.64.65.69:8080
11:24:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
11:34:46:WU01:FS01:0xa4:Completed 700000 out of 2500000 steps (28%)
11:51:38:WU01:FS01:0xa4:Completed 725000 out of 2500000 steps (29%)
12:08:29:WU01:FS01:0xa4:Completed 750000 out of 2500000 steps (30%)
12:25:20:WU01:FS01:0xa4:Completed 775000 out of 2500000 steps (31%)
******************************* Date: 2013-10-06 *******************************
12:42:10:WU01:FS01:0xa4:Completed 800000 out of 2500000 steps (32%)
12:59:04:WU01:FS01:0xa4:Completed 825000 out of 2500000 steps (33%)
13:15:53:WU01:FS01:0xa4:Completed 850000 out of 2500000 steps (34%)
13:26:56:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
13:26:56:WU00:FS00:News: Welcome to Folding@Home
13:26:56:WU00:FS00:Assigned to work server 171.64.65.69
13:26:56:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
13:26:56:WU00:FS00:Connecting to 171.64.65.69:8080
13:27:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
13:32:43:WU01:FS01:0xa4:Completed 875000 out of 2500000 steps (35%)
13:49:34:WU01:FS01:0xa4:Completed 900000 out of 2500000 steps (36%)
14:06:24:WU01:FS01:0xa4:Completed 925000 out of 2500000 steps (37%)
14:23:14:WU01:FS01:0xa4:Completed 950000 out of 2500000 steps (38%)
14:40:10:WU01:FS01:0xa4:Completed 975000 out of 2500000 steps (39%)
14:43:49:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:43:49:WU00:FS00:News: Welcome to Folding@Home
14:43:49:WU00:FS00:Assigned to work server 171.64.65.69
14:43:49:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:43:49:WU00:FS00:Connecting to 171.64.65.69:8080
14:43:53:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:45:26:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:45:26:WU00:FS00:News: Welcome to Folding@Home
14:45:26:WU00:FS00:Assigned to work server 171.64.65.69
14:45:26:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:45:26:WU00:FS00:Connecting to 171.64.65.69:8080
14:45:30:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:46:26:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:46:26:WU00:FS00:News: Welcome to Folding@Home
14:46:26:WU00:FS00:Assigned to work server 171.64.65.69
14:46:26:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:46:26:WU00:FS00:Connecting to 171.64.65.69:8080
14:46:30:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:48:03:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:48:04:WU00:FS00:News: Welcome to Folding@Home
14:48:04:WU00:FS00:Assigned to work server 171.64.65.69
14:48:04:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:48:04:WU00:FS00:Connecting to 171.64.65.69:8080
14:48:07:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:49:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:49:04:WU00:FS00:News: Welcome to Folding@Home
14:49:04:WU00:FS00:Assigned to work server 171.64.65.69
14:49:04:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:49:04:WU00:FS00:Connecting to 171.64.65.69:8080
14:49:07:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:50:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:50:04:WU00:FS00:News: Welcome to Folding@Home
14:50:04:WU00:FS00:Assigned to work server 171.64.65.69
14:50:04:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:50:04:WU00:FS00:Connecting to 171.64.65.69:8080
14:50:08:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:51:41:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:51:41:WU00:FS00:News: Welcome to Folding@Home
14:51:41:WU00:FS00:Assigned to work server 171.64.65.69
14:51:41:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:51:41:WU00:FS00:Connecting to 171.64.65.69:8080
14:51:45:ERROR:WU00:FS00:Exception: Server did not assign work unit
14:54:18:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:54:18:WU00:FS00:News: Welcome to Folding@Home
14:54:18:WU00:FS00:Assigned to work server 171.64.65.69
14:54:18:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
14:54:18:WU00:FS00:Connecting to 171.64.65.69:8080
14:54:22:ERROR:WU00:FS00:Exception: Server did not assign work unit-
Someone gave you bad advice to use beta setting for GPU. You only need the advanced setting to get core 17 WUs. They also should have warned you that unless you are a member of the beta team, we can't assist you until you either remove the beta setting or agree to the rules of the beta team and join up.
Please set your GPU folding slot to advanced instead of beta. There is a known problem with a beta Core_17 that can result in WU's that will not be accepted when finished. Further support for beta folding is only in the Beta forum. From the log sections shown, so far it appears you have not had that issue. But eventually you might. The beta setting may be causing the Assignment Server to connect your system to the wrong server as well.
The latest issue of getting a new GPU WU does appear to coincide with the appearance of problems with that WS. From the log entries that appears to have been corrected as this morning Stanford time.
One additional note, the setting of logging verbosity higher than the default of 3 does not provide any additional useful information in almost all cases. The default setting is recommended also since the higher setting actually makes troubleshooting problems more difficult. Unlike the higher verbosity setting in version 6, with the V7 client it is not useful.
Under the configuration, expert, client type is listed as advanced.
Is there some place else I should look?
Check the settings for the GPU folding slot. In FAHControl click Configure and then Slots. Unless there was a change to the settings in the log gap, this is what was reported in your log:
00:27:09: </slot>
00:27:09: </slot>
00:27:09:</configRe: Server 171.64.65.98 out of WUs
Thank you for your assistance.
I finally broke into the top 2000 folders this week.
