129.74.246.143 WU not Progressing
Saloxn
Post by Saloxn »
I have a project on 129.74.246.143 that has been at 0 % for more then 12 hours the log shows no errore but no work is being done. Project 7083 is there a war to clear the work and or reset the project?
Re: 129.74.246.143 WU not Progressing
Post has been moved from your original location as it was not related to the upload timeout problem there.
Please post your log file showing the version of the client you are using, the system information and the folding configuration. Information on how to do that is posted in the Welcome topic above - viewtopic.php?f=61&t=16206. Then we can determine if the WU needs to have anything done to it, or if there is an issue with your settings.
Also, pause the WU, wait 3 minute or more, and resume folding. Did it resume from zero or had progress been recorded?
