I need help getting started
I just bought a new windows 8 desktop computer. I was folding on windows 7 which worked perfectly but when i downloaded folding today on my new computer it just keeps on saying "ready" (in blue) i have a Niviida GT630 and i5 3330, it's not letting me fold and i was also wondering how do i overclock?
Re: I need help getting started
Welcome to the F@H Forum Langley,
Can you please post the log file, especially the initial section which contains the system configuration and fah set-up, here with in the Code Tags (available in the Full Editor) so that we can get more information to help you out.
Please note that we don't really cater towards overclocking as it is a complex process and there are other forums which cater to such topics. You can start by visiting the forum of your favorite hardware review site.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
The log is found in Advanced Control.
Overclocking is done though the BIOS, though I wouldn't recommend doing that unless you know what you're doing.
It cannot connet thats the only problem. "Failed To Read Stream" "could not connect to stanford.edu:80"
Jesse_V
CPU: i7-6700k
Please post the log in between Code tags, likeLangley wrote:It cannot connet thats the only problem. "Failed To Read Stream" "could not connect to stanford.edu:80"
For a complete answer, we need to see the log. But a typical answer is that some AV or Firewall software is blocking the fah client from connecting to the internet. This could also be an IPv4 vs IPv6 issue, so we need that log. Start/All Programs/FAHClient/FAHControl. Select the log tab. Copy, paste. Thanks.
22:05:57:WARNING:Attempting to update GPUs.txt: Failed to read stream
22:06:39:ERROR:WU01:FS01:Exception: Failed to read stream
22:06:39:ERROR:WU00:FS02:Exception: Failed to read stream
22:07:17:ERROR:WU00:FS02:Exception: Failed to read stream
22:07:38:ERROR:WU01:FS01:Exception: Failed to read stream
22:09:07:ERROR:WU00:FS02:Exception: Failed to read stream
22:09:27:ERROR:WU01:FS01:Exception: Failed to read stream
22:11:54:ERROR:WU00:FS02:Exception: Failed to read stream
22:12:15:ERROR:WU01:FS01:Exception: Failed to read stream
22:15:26:ERROR:WU00:FS02:Exception: Could not get IP address for www.stanford.edu: No such host is known.
22:16:09:ERROR:WU01:FS01:Exception: Could not get IP address for www.stanford.edu: No such host is known.
22:22:17:ERROR:WU00:FS02:Exception: Could not get IP address for www.stanford.edu: No such host is known.
22:23:00:ERROR:WU01:FS01:Exception: Could not get IP address for www.stanford.edu: No such host is known.
22:33:44:ERROR:WU00:FS02:Exception: Failed to read stream
22:34:27:ERROR:WU01:FS01:Exception: Failed to read stream
22:51:40:ERROR:WU00:FS02:Exception: Failed to read stream
22:52:23:ERROR:WU01:FS01:Exception: Failed to read stream
23:20:43:ERROR:WU00:FS02:Exception: Failed to read stream
23:21:25:ERROR:WU01:FS01:Exception: Failed to read stream
There's 3 different errors, those are 2 of them ^^ Once i see the other one ill paste it in here, but this is the most common one.
Please post the whole log. Thanks.
that is the whole log, im not getting the third error anymore, just those 2. Please help thanks
If you are posting the log from FAHControl, please use the refresh button and temporarily uncheck the box "Follow" and then try to paste the log, specially the initial section which contains information about your system and your configuration. Alternatively, you might want to access the log file directly, assuming default installation, it should be in C:\Users\<Your Username>\AppData\Roaming\FAHClient\
Thanks, i found the full log.
*********************** Log Started 2013-05-30T20:39:02Z ***********************
20:39:02:************************* Folding@home Client *************************
20:39:02: Website: http://folding.stanford.edu/
20:39:02: Copyright: (c) 2009-2013 Stanford University
20:39:02: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:39:02: Args: --open-web-control
20:39:02: Config: <none>
20:39:02:******************************** Build ********************************
20:39:02: Version: 7.3.6
20:39:02: Date: Feb 18 2013
20:39:02: Time: 15:25:17
20:39:02: SVN Rev: 3923
20:39:02: Branch: fah/trunk/client
20:39:02: Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:39:02: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:39:02: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:39:02: Platform: win32 XP
20:39:02: Bits: 32
20:39:02: Mode: Release
20:39:02:******************************* System ********************************
20:39:02: CPU: Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz
20:39:02: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
20:39:02: CPUs: 4
20:39:02: Memory: 5.94GiB
20:39:02: Free Memory: 4.58GiB
20:39:02: Threads: WINDOWS_THREADS
20:39:02: Has Battery: false
20:39:02: On Battery: false
20:39:02: UTC offset: -7
20:39:02: PID: 4708
20:39:02: CWD: C:/Users/Inspired/AppData/Roaming/FAHClient
20:39:02: OS: Windows 8
20:39:02: OS Arch: AMD64
20:39:02: GPUs: 1
20:39:02: GPU 0: NVIDIA:3 GK107 [GeForce GT 630]
20:39:02: CUDA: 3.0
20:39:02: CUDA Driver: 5000
20:39:02:Win32 Service: false
20:39:02:***********************************************************************
20:39:02:<config>
20:39:02: <!-- Folding Slots -->
20:39:02:</config>
20:39:02:Connecting to assign-GPU.stanford.edu:80
20:39:18:WARNING:Attempting to update GPUs.txt: Failed to read stream
20:39:18:Trying to access database...
20:39:19:Successfully acquired database lock
20:39:19:Enabled folding slot 00: PAUSED gpu:0:GK107 [GeForce GT 630] (not configured)
20:39:19:Enabled folding slot 01: PAUSED cpu:3 (not configured)
20:41:43:Saving configuration to config.xml
20:41:43:<config>
20:41:43: <!-- Folding Core -->
20:41:43: <checkpoint v='30'/>
20:41:43:
20:41:43: <!-- Folding Slot Configuration -->
20:41:43: <power v='FULL'/>
20:41:43:
20:41:43: <!-- Network -->
20:41:43: <proxy v=':8080'/>
20:41:43:
20:41:43: <!-- Folding Slots -->
20:41:43: <slot id='0' type='GPU'/>
20:41:43: <slot id='1' type='CPU'/>
20:41:43:</config>
20:42:03:Saving configuration to config.xml
20:42:03:<config>
20:42:03: <!-- Folding Core -->
20:42:03: <checkpoint v='30'/>
20:42:03:
20:42:03: <!-- Folding Slot Configuration -->
20:42:03: <power v='full'/>
20:42:03:
20:42:03: <!-- Network -->
20:42:03: <proxy v=':8080'/>
20:42:03:
20:42:03: <!-- User Information -->
20:42:03: <team v='143016'/>
20:42:03: <user v='Nicholas'/>
20:42:03:
20:42:03: <!-- Folding Slots -->
20:42:03: <slot id='0' type='GPU'/>
20:42:03: <slot id='1' type='CPU'/>
20:42:03:</config>
20:42:03:Set client configured
20:42:03:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:42:03:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
20:42:05:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:42:05:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:42:06:WU00:FS00:News: Welcome to Folding@Home
20:42:06:WU00:FS00:Assigned to work server 171.67.108.36
20:42:06:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 630] from 171.67.108.36
20:42:06:WU00:FS00:Connecting to 171.67.108.36:8080
20:42:06:WU01:FS01:News: Welcome to Folding@Home
20:42:06:WU01:FS01:Assigned to work server 171.64.65.101
20:42:06:WU01:FS01:Requesting new work unit for slot 01: READY cpu:4 from 171.64.65.101
20:42:06:WU01:FS01:Connecting to 171.64.65.101:8080
20:42:07:WU00:FS00:Downloading 58.75KiB
20:42:08:WU01:FS01:Downloading 535.85KiB
20:42:08:WU00:FS00:Download complete
20:42:08:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8074 run:7 clone:36 gen:17 core:0x15 unit:0x000000156652edb450b4301385121e85
20:42:08:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
20:42:08:WU00:FS00:Connecting to www.stanford.edu:80
20:42:14:WU01:FS01:Download 95.55%
20:42:14:WU01:FS01:Download complete
20:42:47:ERROR:WU00:FS00:Exception: Failed to read stream
20:42:48:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7645 run:567 clone:0 gen:94 core:0xa4 unit:0x0000006d664f2dcd4fa7fdb46e34ddd8
20:42:48:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:42:48:WU01:FS01:Connecting to www.stanford.edu:80
20:43:08:ERROR:WU01:FS01:Exception: Failed to read stream
20:43:08:Saving configuration to config.xml
20:43:08:<config>
20:43:08: <!-- Folding Core -->
20:43:08: <checkpoint v='30'/>
20:43:08:
20:43:08: <!-- Folding Slot Configuration -->
20:43:08: <power v='full'/>
20:43:08:
20:43:08: <!-- Network -->
20:43:08: <proxy v=':8080'/>
20:43:08:
20:43:08: <!-- User Information -->
20:43:08: <team v='143016'/>
20:43:08: <user v='Nicholas'/>
20:43:08:
20:43:08: <!-- Folding Slots -->
20:43:08: <slot id='0' type='GPU'/>
20:43:08: <slot id='1' type='CPU'/>
20:43:08:</config>
20:43:08:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
20:43:08:WU00:FS00:Connecting to www.stanford.edu:80
20:44:08:ERROR:WU00:FS00:Exception: Failed to read stream
20:44:08:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:44:08:WU01:FS01:Connecting to www.stanford.edu:80
20:44:52:ERROR:WU01:FS01:Exception: Failed to read stream
20:45:45:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:45:45:WU01:FS01:Connecting to www.stanford.edu:80
20:47:20:ERROR:WU01:FS01:Exception: Failed to read stream
20:47:51:Saving configuration to config.xml
20:47:51:<config>
20:47:51: <!-- Folding Core -->
20:47:51: <checkpoint v='30'/>
20:47:51:
20:47:51: <!-- Folding Slot Configuration -->
20:47:51: <power v='light'/>
20:47:51:
20:47:51: <!-- Network -->
20:47:51: <proxy v=':8080'/>
20:47:51:
20:47:51: <!-- User Information -->
20:47:51: <team v='143016'/>
20:47:51: <user v='Nicholas'/>
20:47:51:
20:47:51: <!-- Folding Slots -->
20:47:51:</config>
20:47:52:WARNING:WU00:Slot ID 0 no longer exists and there are no other matching slots, dumping
20:47:52:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:8074 run:7 clone:36 gen:17 core:0x15 unit:0x000000156652edb450b4301385121e85
20:47:52:WU00:Connecting to 171.67.108.36:8080
20:47:52:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping
20:47:52:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:7645 run:567 clone:0 gen:94 core:0xa4 unit:0x0000006d664f2dcd4fa7fdb46e34ddd8
20:47:52:WU01:Connecting to 171.64.65.101:8080
20:47:53:WU00:Server responded WORK_ACK (400)
20:47:53:WU00:Cleaning up
20:47:54:WU01:Server responded WORK_ACK (400)
20:47:54:WU01:Cleaning up
20:48:39:Saving configuration to config.xml
20:48:39:<config>
20:48:39: <!-- Folding Core -->
20:48:39: <checkpoint v='30'/>
20:48:39:
20:48:39: <!-- Folding Slot Configuration -->
20:48:39: <power v='light'/>
20:48:39:
20:48:39: <!-- Network -->
20:48:39: <proxy v=':8080'/>
20:48:39:
20:48:39: <!-- User Information -->
20:48:39: <team v='143016'/>
20:48:39: <user v='Nicholas'/>
20:48:39:
20:48:39: <!-- Folding Slots -->
20:48:39:</config>
20:49:22:Adding folding slot 00: PAUSED cpu:1 (paused)
20:49:22:Saving configuration to config.xml
20:49:22:<config>
20:49:22: <!-- Folding Core -->
20:49:22: <checkpoint v='30'/>
20:49:22:
20:49:22: <!-- Folding Slot Configuration -->
20:49:22: <power v='light'/>
20:49:22:
20:49:22: <!-- Network -->
20:49:22: <proxy v=':8080'/>
20:49:22:
20:49:22: <!-- User Information -->
20:49:22: <team v='143016'/>
20:49:22: <user v='Nicholas'/>
20:49:22:
20:49:22: <!-- Folding Slots -->
20:49:22: <slot id='0' type='CPU'>
20:49:22: <cpus v='1'/>
20:49:22: </slot>
20:49:22:</config>
20:49:23:WU00:FS00:Connecting to assign3.stanford.edu:8080
20:49:31:WU00:FS00:News: Welcome to Folding@Home
20:49:31:WU00:FS00:Assigned to work server 143.89.28.72
20:49:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 143.89.28.72
20:49:31:WU00:FS00:Connecting to 143.89.28.72:8080
20:49:37:WU00:FS00:Downloading 772.31KiB
20:49:40:Adding folding slot 01: PAUSED gpu:0:GK107 [GeForce GT 630] (waiting for idle)
20:49:40:Saving configuration to config.xml
20:49:40:<config>
20:49:40: <!-- Folding Core -->
20:49:40: <checkpoint v='30'/>
20:49:40:
20:49:40: <!-- Folding Slot Configuration -->
20:49:40: <power v='light'/>
20:49:40:
20:49:40: <!-- Network -->
20:49:40: <proxy v=':8080'/>
20:49:40:
20:49:40: <!-- User Information -->
20:49:40: <team v='143016'/>
20:49:40: <user v='Nicholas'/>
20:49:40:
20:49:40: <!-- Folding Slots -->
20:49:40: <slot id='0' type='CPU'>
20:49:40: <cpus v='1'/>
20:49:40: </slot>
20:49:40: <slot id='1' type='GPU'/>
20:49:40:</config>
20:49:43:WU00:FS00:Download 24.86%
20:49:50:WU00:FS00:Download 49.72%
20:50:06:WU00:FS00:Download 82.87%
20:50:12:WU00:FS00:Download 91.15%
20:50:13:WU00:FS00:Download complete
20:50:13:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:2974 run:68 clone:29 gen:16 core:0xa4 unit:0x000000210893a1884e218a92d8b3063f
20:50:13:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:50:13:WU00:FS00:Connecting to www.stanford.edu:80
20:50:34:ERROR:WU00:FS00:Exception: Failed to read streamRe: I need help getting started
I also allowed F@H on my firewall
One cause of "Failed to read stream" is due to insufficient privileges. Does F@H have read/write access to the location that you installed it in?
Another thing is that you configuration appears to be "missing":
Config: <none>
While I have this:
Config: C:/Users/PantherX/AppData/Roaming/FAHClient/config.xml
Not sure if this is related to the permission issue or not.
Config: <none>
While I have this:
My config.xml code is this
<config>
<checkpoint v="3"/>
<core-priority v="low"/>
<cpu-affinity v="true"/>
<cpu-usage v="45"/>
<power v="full"/>
<!-- Logging -->
<verbosity v="0"/>
<!-- Network -->
<proxy v=":8080"/>
<!-- Slot Control -->
<pause-on-battery v="false"/>
<team v="143016"/>
<user v="Nicholas"/>
<slot id="1" type="GPU"/>
<slot id="2" type="CPU">
<cpus v="-1"/>
</slot>
</config>
