I have an HP Pavilion dv7 4141sa notebook PC with two graphics units: one is an AMD/ATI Mobility Radeon HD4200, which I understand does not support the F@H software, and the other is an AMD/ATI Mobility Radeon HD5470, which I believe should support it. I have had to update from the HP-supplied drivers to the latest AMD drivers that the machine will run, in order to have the necessary OpenCL files installed to be able to run the F@H software. The driver package is 13-1-legacy_vista_win7_win8_64_dd_ccc.exe.
The problem is that the GPU will only perform up to about 15% of its work unit before the process fails with the log report "Nonzero force sum on GPU... ...Folding@home Core Shutdown: UNSTABLE_MACHINE.
Is there anything I can do about this, or should I just remove the slot, leaving the CPU slot working? It seems counterproductive to acquire work units if they can't be finished.
An example logfile is shown below.
Folding@Home GPU Core
Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
Build host: user-f6d030f24f
Board Type: AMD/OpenCL
Core : x=16
Window's signal control handler registered.
Preparing to commence simulation
- Looking at optimizations...
- Files status OK
sizeof(CORE_PACKET_HDR) = 512 file=<>
- Expanded 45182 -> 171163 (decompressed 378.8 percent)
Called DecompressByteArray: compressed_data_size=45182 data_size=171163, decompressed_data_size=171163 diff=0
- Digital signature verified
Project: 11293 (Run 20, Clone 39, Gen 42)
Assembly optimizations on if available.
Entering M.D.
Will resume from checkpoint file 00/wudata_01.ckp
Tpr hash 00/wudata_01.tpr: 1434198816 540116126 2021843840 3991596145 2502114219
Working on ALZHEIMER DISEASE AMYLOID
Client config unavailable.
Starting GUI Server
Resuming from checkpoint
fcCheckPointResume: retreived and current tpr file hash:
0 1434198816 1434198816
1 540116126 540116126
2 2021843840 2021843840
3 3991596145 3991596145
4 2502114219 2502114219
fcCheckPointResume: file hashes same.
fcCheckPointResume: state restored.
fcCheckPointResume: name 00/wudata_01.log Verified 00/wudata_01.log
fcCheckPointResume: name 00/wudata_01.trr Verified 00/wudata_01.trr
fcCheckPointResume: name 00/wudata_01.xtc Verified 00/wudata_01.xtc
fcCheckPointResume: name 00/wudata_01.edr Verified 00/wudata_01.edr
fcCheckPointResume: state restored 2
Resumed from checkpoint
Setting checkpoint frequency: 500000
Completed 2000001 out of 50000000 steps (4%).
Completed 2500000 out of 50000000 steps (5%).
Completed 3000000 out of 50000000 steps (6%).
Completed 3500000 out of 50000000 steps (7%).
Completed 4000000 out of 50000000 steps (8%).
Completed 4500000 out of 50000000 steps (9%).
Completed 5000000 out of 50000000 steps (10%).
Completed 5500000 out of 50000000 steps (11%).
Completed 6000000 out of 50000000 steps (12%).
Completed 6500000 out of 50000000 steps (13%).
Completed 7000000 out of 50000000 steps (14%).
mdrun_gpu returned 54
